1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: sm_test.c,v 3.1 2003/02/22 02:07:25 greg Exp $"; |
3 |
#endif |
4 |
5 |
* sm_test.c |
6 |
7 |
* A simple OGL display program to test sm code |
8 |
9 |
#include "standard.h" |
10 |
11 |
#include <glut.h> |
12 |
#include "ui.h" |
13 |
#include "sm_geom.h" |
14 |
#include "sm_qtree.h" |
15 |
#include "sm_stree.h" |
16 |
#include "sm.h" |
17 |
#include "sm_draw.h" |
18 |
19 |
struct driver odev; |
20 |
char *progname; |
21 |
double |
22 |
test_normalize(v) /* normalize a vector, return old magnitude */ |
23 |
register FVECT v; |
24 |
25 |
register double len; |
26 |
27 |
len = DOT(v, v); |
28 |
29 |
if (len <= 0.0) |
30 |
return(0.0); |
31 |
32 |
if (len <= 1.0+FTINY && len >= 1.0-FTINY) |
33 |
len = 0.5 + 0.5*len; /* first order approximation */ |
34 |
else |
35 |
len = sqrt(len); |
36 |
37 |
v[0] /= len; |
38 |
v[1] /= len; |
39 |
v[2] /= len; |
40 |
41 |
return(len); |
42 |
43 |
44 |
void |
45 |
print_usage(char *program) |
46 |
47 |
fprintf(stderr, "usage: %s \n", program); |
48 |
49 |
50 |
51 |
/* Parse the command line arguments to get the input file name. The depth |
52 |
* thresholding size may also be specified, as well as the disparity |
53 |
* threshold, specified in number of depth ranges, for creating depth |
54 |
* disparity lines. |
55 |
56 |
void |
57 |
parse_cmd_line(int argc, char* argv[]) |
58 |
59 |
int i; |
60 |
if(argc < 2) |
61 |
return; |
62 |
63 |
for(i=1;i<argc;i++) |
64 |
if(argv[i][0] == '-') |
65 |
switch(argv[i][1]) { |
66 |
case 't': |
67 |
Tri_intersect = TRUE; |
68 |
break; |
69 |
case 'd': |
70 |
Pt_delete = TRUE; |
71 |
break; |
72 |
case 'f': |
73 |
if(i+1 < argc) |
74 |
75 |
Filename = &(argv[i+1][0]); |
76 |
i++; |
77 |
78 |
else |
79 |
fprintf(stderr,"Must include file name\n"); |
80 |
81 |
/* Nothing for now */ |
82 |
83 |
84 |
void |
85 |
display() |
86 |
87 |
glutMainLoop(); |
88 |
89 |
90 |
VIEW View = {0,{0,0,0},{0,0,-1},{0,1,0},60,60,0}; |
91 |
int |
92 |
main(int argc, char *argv[]) |
93 |
94 |
COLR colr; |
95 |
FVECT v0,v1,v2,a,b,c,dir; |
96 |
double d[3]; |
97 |
double phi,theta; |
98 |
99 |
progname = argv[0]; |
100 |
parse_cmd_line(argc,argv); |
101 |
/* Open a display window */ |
102 |
smDraw_open_window(argc,argv); |
103 |
/* First read in the command line arguments */ |
104 |
105 |
odev.v = View; |
106 |
107 |
if(Filename) |
108 |
109 |
next_sample(a,a,colr,1); |
110 |
/* Initialize the data structures for 10 samples*/ |
111 |
smInit(262000); |
112 |
113 |
else |
114 |
smInit(100); |
115 |
display(); |
116 |
117 |
118 |
119 |
120 |
121 |
122 |
123 |
124 |
125 |
126 |
127 |
128 |
129 |
