root/radiance/ray/src/hd/sm_stree.h
Changes since 3.6: +12 -3 lines
Diff to previous 3.6 , to selected 3.2
Sat Feb 22 02:07:25 2003 UTC (21 years, 2 months ago) by greg
Changes since 3.5: +1 -4 lines
Diff to previous 3.5 , to selected 3.2
Thu Jun 10 15:22:24 1999 UTC (24 years, 10 months ago) by gwlarson
Changes since 3.4: +3 -36 lines
Diff to previous 3.4 , to selected 3.2
Implemented sample quadtree in place of triangle quadtree
Made geometric predicates more robust
Added #define LORES which utilizes a single precision floating point
  sample array, the default is a double sample array
Added topology DEBUG commands (for DEBUG > 1)
Made code optimizations
Mon Dec 28 18:07:36 1998 UTC (25 years, 4 months ago) by gwlarson
Changes since 3.3: +32 -19 lines
Diff to previous 3.3 , to selected 3.2
New insertion routine
New Culling routine based on insertion algorithm
Adapted old insertion code: now used by picking
Point location code returns on-vertex,on-edge, or in-triangle
Added on_edge case for subdivision
Implemented unordered sets
Removed deletion from quadtree- added set compression to replace functionality
Tue Oct 6 18:18:55 1998 UTC (25 years, 7 months ago) by gwlarson
Changes since 3.2: +73 -35 lines
Diff to previous 3.2
new triangulate routine
added smTestSample to check for occlusion
added frustum culling before rebuild
changed base quadtree to use octahedron and created new point locate
added "sample active" flags and implemented LRU replacement
started handling case of too many triangles
set sizes are now unbounded\
Revision 3.2 - (view) (download) (annotate) - [selected]
Fri Sep 11 11:52:27 1998 UTC (25 years, 7 months ago) by gwlarson
Changes since 3.1: +5 -2 lines
Diff to previous 3.1
fixed triangle insertion using edge tracing
Wed Aug 19 17:45:24 1998 UTC (25 years, 8 months ago) by gwlarson
Diff to selected 3.2
