root/radiance/ray/src/hd/sm_stree.h
Revision: 3.5
Committed: Thu Jun 10 15:22:24 1999 UTC (25 years ago) by gwlarson
Changes since 3.4: +3 -36 lines
Implemented sample quadtree in place of triangle quadtree
Made geometric predicates more robust
Added #define LORES which utilizes a single precision floating point
  sample array, the default is a double sample array
Added topology DEBUG commands (for DEBUG > 1)
Made code optimizations
1 /* Copyright (c) 1998 Silicon Graphics, Inc. */
2
3 /* SCCSid "$SunId$ SGI" */
4
5 /*
6 * sm_stree.h - header file for spherical quadtree code:
7 *
8 */
9
10 #define STR_INDEX(s) (stRoot_indices[(s)])
11 #define STR_NTH_INDEX(s,n) (stRoot_indices[(s)][(n)])
12
13 #define ST_NUM_ROOT_NODES 8
14
15
16
17 /* The base is an octahedron: Each face contains a planar quadtree. At
18 the root level, the "top" (positive y) four faces, and bottom four faces
19 are stored together:forming two root quadtree nodes
20 */
21
22 typedef struct _STREE {
23 QUADTREE qt[2]; /* root[0]= top four faces, root[1]=bottom 4 faces*/
24
25 }STREE;
26
27
28 #define ST_BASEI(n) ((n)>>2) /* root index: top or bottom */
29 #define ST_INDEX(n) ((n) & 0x3) /* which child in root */
30 #define ST_QT(s,i) ((s)->qt[ST_BASEI(i)]) /* top or bottom root*/
31 #define ST_QT_PTR(s,i) (&ST_QT(s,i)) /* ptr to top(0)/bottom(1)root*/
32 #define ST_TOP_QT(s) ((s)->qt[0]) /* top root (y>0)*/
33 #define ST_BOTTOM_QT(s) ((s)->qt[1]) /* bottom qt (y <= 0)*/
34 #define ST_TOP_QT_PTR(s) (&ST_TOP_QT(s)) /* ptr to top qt */
35 #define ST_BOTTOM_QT_PTR(s) (&ST_BOTTOM_QT(s)) /* ptr to bottom qt*/
36
37 #define ST_NTH_V(s,n,w) (stDefault_base[stBase_verts[n][w]])
38 #define ST_ROOT_QT(s,n) QT_NTH_CHILD(ST_QT(s,n),ST_INDEX(n))
39
40 #define ST_CLEAR_QT(st) (ST_TOP_QT(st)=EMPTY,ST_BOTTOM_QT(st)=EMPTY)
41 #define ST_INIT_QT(st) (QT_CLEAR_CHILDREN(ST_TOP_QT(st)), \
42 QT_CLEAR_CHILDREN(ST_BOTTOM_QT(st)))
43
44 #define ST_CLEAR_FLAGS(s) qtClearAllFlags()
45
46 /* Point location based on coordinate signs */
47 #define stLocate_root(p) (((p)[2]>0.0?0:4)|((p)[1]>0.0?0:2)|((p)[0]>0.0?0:1))
48 #define stClear(st) stInit(st)
49
50 #define ST_CLIP_VERTS 16
51 /* STREE functions
52 void stInit(STREE *st,FVECT center)
53 Initializes an stree structure with origin 'center':
54 Frees existing quadtrees hanging off of the roots
55
56 STREE *stAlloc(STREE *st)
57 Allocates a stree structure and creates octahedron base
58
59
60 QUADTREE stPoint_locate(STREE *st,FVECT p)
61 Returns quadtree leaf node containing point 'p'.
62
63 int stAdd_tri(STREE *st,int id,FVECT t0,t1,t2)
64 Add triangle 'id' with coordinates 't0,t1,t2' to the stree: returns
65 FALSE on error, TRUE otherwise
66
67 int stRemove_tri(STREE *st,int id,FVECT t0,t1,t2)
68 Removes triangle 'id' with coordinates 't0,t1,t2' from stree: returns
69 FALSE on error, TRUE otherwise
70
71 int stTrace_ray(STREE *st,FVECT orig,dir,int (*func)(),int *arg1,*arg2)
72 Trace ray 'orig-dir' through stree and apply 'func(arg1,arg2)' at each
73 node that it intersects
74
75 int stApply_to_tri(STREE *st,FVECT t0,t1,t2,int (*edge_func)(),
76 (*tri_func)(),int arg1,*arg2)
77 Visit nodes intersected by tri 't0,t1,t2'.Apply 'edge_func(arg1,arg2,arg3)',
78 to those nodes intersected by edges, and interior_func to ALL nodes:
79 ie some Nodes will be visited more than once
80 */
81
82 extern int stBase_verts[8][3];
83 extern FVECT stDefault_base[6];
84 extern STREE *stAlloc();
85 extern QUADTREE stPoint_locate();
86
87
88
89
90
