root/radiance/ray/src/hd/sm_stree.h
Revision: 3.3
Committed: Tue Oct 6 18:18:55 1998 UTC (25 years, 8 months ago) by gwlarson
Changes since 3.2: +73 -35 lines
new triangulate routine
added smTestSample to check for occlusion
added frustum culling before rebuild
changed base quadtree to use octahedron and created new point locate
added "sample active" flags and implemented LRU replacement
started handling case of too many triangles
set sizes are now unbounded\
1 /* Copyright (c) 1998 Silicon Graphics, Inc. */
2
3 /* SCCSid "$SunId$ SGI" */
4
5 /*
6 * sm_stree.h - header file for spherical quadtree code:
7 *
8 */
9
10
11 #define ST_NUM_ROOT_NODES 8
12
13 /* The base is an octahedron: Each face contains a planar quadtree. At
14 the root level, the "top" (positive y) four faces, and bottom four faces
15 are stored together:forming two root quadtree nodes
16 */
17
18 typedef struct _STREE {
19 QUADTREE root[2]; /* root[0]= top four faces, root[1]=bottom 4 faces*/
20 FVECT center; /* sphere center */
21 FVECT base[6]; /* 6 vertices on sphere that define base octahedron:
22 in canonical form: origin(0,0,0) points (1,0,0),
23 (0,1,0),(0,0,1),(-1,0,0),(0,-1,0),(0,0,-1) */
24 FPEQ fplane[8]; /* Face plane equations */
25
26 FVECT enorms[8][3]; /* Edge normals: For plane through edge and origin*/
27 }STREE;
28
29
30 #define ST_BASEI(n) ((n)>>2) /* root index: top or bottom */
31 #define ST_INDEX(n) ((n) & 0x3) /* which child in root */
32 #define ST_ROOT(s,i) ((s)->root[ST_BASEI(i)]) /* top or bottom root*/
33 #define ST_ROOT_PTR(s,i) (&ST_ROOT(s,i)) /* ptr to top(0)/bottom(1)root*/
34 #define ST_TOP_ROOT(s) ((s)->root[0]) /* top root (y>0)*/
35 #define ST_BOTTOM_ROOT(s) ((s)->root[1]) /* bottom root (y <= 0)*/
36 #define ST_TOP_ROOT_PTR(s) (&ST_TOP_ROOT(s)) /* ptr to top root */
37 #define ST_BOTTOM_ROOT_PTR(s) (&ST_BOTTOM_ROOT(s)) /* ptr to bottom root*/
38 #define ST_NTH_ROOT(s,n) QT_NTH_CHILD(ST_ROOT(s,n),ST_INDEX(n))
39 #define ST_NTH_ROOT_PTR(s,n) QT_NTH_CHILD_PTR(ST_ROOT(s,n),ST_INDEX(n))
40 #define ST_CLEAR_ROOT(st) (ST_TOP_ROOT(st)=EMPTY,ST_BOTTOM_ROOT(st)=EMPTY)
41 #define ST_INIT_ROOT(st) (QT_CLEAR_CHILDREN(ST_TOP_ROOT(st)), \
42 QT_CLEAR_CHILDREN(ST_BOTTOM_ROOT(st)))
43 #define ST_BASE(s) ((s)->base)
44 #define ST_NTH_BASE(s,n) ((s)->base[(n)])
45 #define ST_NTH_V(s,n,i) ST_NTH_BASE(s,stBase_verts[(n)][(i)])
46 #define ST_SET_NTH_BASE(s,n,b) VCOPY(ST_NTH_BASE(s,n),b)
47 #define ST_SET_BASE(s,b) (VCOPY(ST_NTH_BASE(s,0),(b)[0]), \
48 VCOPY(ST_NTH_BASE(s,1),(b)[1]), \
49 VCOPY(ST_NTH_BASE(s,2),(b)[2]), \
50 VCOPY(ST_NTH_BASE(s,3),(b)[3]), \
51 VCOPY(ST_NTH_BASE(s,4),(b)[4]), \
52 VCOPY(ST_NTH_BASE(s,5),(b)[5]))
53
54 #define ST_CENTER(s) ((s)->center)
55 #define ST_SET_CENTER(s,b) VCOPY(ST_CENTER(s),b)
56
57 #define ST_NTH_PLANE(s,i) ((s)->fplane[(i)])
58 #define ST_NTH_NORM(s,i) (ST_NTH_PLANE(s,i).n)
59 #define ST_NTH_D(s,i) (ST_NTH_PLANE(s,i).d)
60 #define ST_EDGE_NORM(s,i,n) ((s)->enorms[(i)][(n)])
61
62 #define ST_COORD(s,p,r) VSUB(r,p,ST_CENTER(s))
63 #define ST_CLEAR_FLAGS(s) qtClearAllFlags()
64
65 /* Point location based on coordinate signs */
66 #define TST(p) ((p)>0.0?1:0)
67 #define stPoint_in_root(p) stlocatetbl[TST((p)[0])<<2 | (TST((p)[1])<<1) \
68 | TST((p)[2])]
69
70 /* STREE functions
71 void stInit(STREE *st,FVECT center)
72 Initializes an stree structure with origin 'center':
73 Frees existing quadtrees hanging off of the roots
74
75 STREE *stAlloc(STREE *st)
76 Allocates a stree structure and creates octahedron base
77
78 void stClear(STREE *st)
79 Frees any existing root children and clears roots
80
81 QUADTREE stPoint_locate(STREE *st,FVECT p)
82 Returns quadtree leaf node containing point 'p'.
83
84 int stAdd_tri(STREE *st,int id,FVECT t0,t1,t2)
85 Add triangle 'id' with coordinates 't0,t1,t2' to the stree: returns
86 FALSE on error, TRUE otherwise
87
88 int stRemove_tri(STREE *st,int id,FVECT t0,t1,t2)
89 Removes triangle 'id' with coordinates 't0,t1,t2' from stree: returns
90 FALSE on error, TRUE otherwise
91
92 int stTrace_ray(STREE *st,FVECT orig,dir,int (*func)(),int *arg1,*arg2)
93 Trace ray 'orig-dir' through stree and apply 'func(arg1,arg2)' at each
94 node that it intersects
95
96 int stApply_to_tri(STREE *st,FVECT t0,t1,t2,int (*edge_func)(),
97 (*tri_func)(),int arg1,*arg2)
98 Visit nodes intersected by tri 't0,t1,t2'.Apply 'edge_func(arg1,arg2,arg3)',
99 to those nodes intersected by edges, and interior_func to ALL nodes:
100 ie some Nodes will be visited more than once
101 */
102
103 extern int stBase_verts[8][3];
104 extern STREE *stAlloc();
105 extern QUADTREE stPoint_locate();
106
107
108
109
110
