root/radiance/ray/src/hd/sm_stree.h
Revision: 3.7
Committed: Mon Jul 14 22:24:00 2003 UTC (21 years, 10 months ago) by schorsch
CVS Tags: rad3R6P1, rad3R6
Changes since 3.6: +12 -3 lines
# User Rev Content
1 schorsch 3.7 /* RCSid: $Id: sm_stree.h,v 3.6 2003/02/22 02:07:25 greg Exp $ */
2 gwlarson 3.1 /*
3     * sm_stree.h - header file for spherical quadtree code:
4     *
5     */
6 schorsch 3.7 #ifndef _RAD_SM_STREE_H_
7     #define _RAD_SM_STREE_H_
8
9     #ifdef __cplusplus
10     extern "C" {
11     #endif
12
13 gwlarson 3.1
14 gwlarson 3.4 #define STR_INDEX(s) (stRoot_indices[(s)])
15     #define STR_NTH_INDEX(s,n) (stRoot_indices[(s)][(n)])
16 gwlarson 3.1
17 gwlarson 3.3 #define ST_NUM_ROOT_NODES 8
18 gwlarson 3.1
19 gwlarson 3.4
20
21 gwlarson 3.3 /* The base is an octahedron: Each face contains a planar quadtree. At
22     the root level, the "top" (positive y) four faces, and bottom four faces
23     are stored together:forming two root quadtree nodes
24     */
25 gwlarson 3.1
26     typedef struct _STREE {
27 gwlarson 3.4 QUADTREE qt[2]; /* root[0]= top four faces, root[1]=bottom 4 faces*/
28
29 gwlarson 3.1 }STREE;
30
31
32 gwlarson 3.3 #define ST_BASEI(n) ((n)>>2) /* root index: top or bottom */
33     #define ST_INDEX(n) ((n) & 0x3) /* which child in root */
34 gwlarson 3.4 #define ST_QT(s,i) ((s)->qt[ST_BASEI(i)]) /* top or bottom root*/
35     #define ST_QT_PTR(s,i) (&ST_QT(s,i)) /* ptr to top(0)/bottom(1)root*/
36     #define ST_TOP_QT(s) ((s)->qt[0]) /* top root (y>0)*/
37     #define ST_BOTTOM_QT(s) ((s)->qt[1]) /* bottom qt (y <= 0)*/
38     #define ST_TOP_QT_PTR(s) (&ST_TOP_QT(s)) /* ptr to top qt */
39     #define ST_BOTTOM_QT_PTR(s) (&ST_BOTTOM_QT(s)) /* ptr to bottom qt*/
40
41 gwlarson 3.5 #define ST_NTH_V(s,n,w) (stDefault_base[stBase_verts[n][w]])
42 gwlarson 3.4 #define ST_ROOT_QT(s,n) QT_NTH_CHILD(ST_QT(s,n),ST_INDEX(n))
43
44     #define ST_CLEAR_QT(st) (ST_TOP_QT(st)=EMPTY,ST_BOTTOM_QT(st)=EMPTY)
45     #define ST_INIT_QT(st) (QT_CLEAR_CHILDREN(ST_TOP_QT(st)), \
46     QT_CLEAR_CHILDREN(ST_BOTTOM_QT(st)))
47
48 gwlarson 3.2 #define ST_CLEAR_FLAGS(s) qtClearAllFlags()
49 gwlarson 3.3
50     /* Point location based on coordinate signs */
51 gwlarson 3.4 #define stLocate_root(p) (((p)[2]>0.0?0:4)|((p)[1]>0.0?0:2)|((p)[0]>0.0?0:1))
52 gwlarson 3.5 #define stClear(st) stInit(st)
53 gwlarson 3.3
54 gwlarson 3.4 #define ST_CLIP_VERTS 16
55 gwlarson 3.1 /* STREE functions
56 gwlarson 3.3 void stInit(STREE *st,FVECT center)
57     Initializes an stree structure with origin 'center':
58     Frees existing quadtrees hanging off of the roots
59 gwlarson 3.1
60 gwlarson 3.3 STREE *stAlloc(STREE *st)
61     Allocates a stree structure and creates octahedron base
62 gwlarson 3.1
63 gwlarson 3.3
64     QUADTREE stPoint_locate(STREE *st,FVECT p)
65     Returns quadtree leaf node containing point 'p'.
66 gwlarson 3.1
67 gwlarson 3.3 int stAdd_tri(STREE *st,int id,FVECT t0,t1,t2)
68     Add triangle 'id' with coordinates 't0,t1,t2' to the stree: returns
69     FALSE on error, TRUE otherwise
70
71     int stRemove_tri(STREE *st,int id,FVECT t0,t1,t2)
72     Removes triangle 'id' with coordinates 't0,t1,t2' from stree: returns
73     FALSE on error, TRUE otherwise
74
75     int stTrace_ray(STREE *st,FVECT orig,dir,int (*func)(),int *arg1,*arg2)
76     Trace ray 'orig-dir' through stree and apply 'func(arg1,arg2)' at each
77     node that it intersects
78 gwlarson 3.1
79 gwlarson 3.3 int stApply_to_tri(STREE *st,FVECT t0,t1,t2,int (*edge_func)(),
80     (*tri_func)(),int arg1,*arg2)
81     Visit nodes intersected by tri 't0,t1,t2'.Apply 'edge_func(arg1,arg2,arg3)',
82     to those nodes intersected by edges, and interior_func to ALL nodes:
83     ie some Nodes will be visited more than once
84 gwlarson 3.1 */
85
86 gwlarson 3.3 extern int stBase_verts[8][3];
87 gwlarson 3.5 extern FVECT stDefault_base[6];
88 gwlarson 3.2 extern STREE *stAlloc();
89 gwlarson 3.3 extern QUADTREE stPoint_locate();
90 gwlarson 3.1
91 schorsch 3.7 #ifdef __cplusplus
92     }
93     #endif
94     #endif /* _RAD_SM_STREE_H_ */
95 gwlarson 3.1
96
