root/radiance/ray/src/hd/sm_stree.h
Revision: 3.8
Committed: Fri Nov 5 03:31:37 2004 UTC (19 years, 7 months ago) by greg
Changes since 3.7: +1 -1 lines
State: FILE REMOVED
1 /* RCSid: $Id: sm_stree.h,v 3.7 2003/07/14 22:24:00 schorsch Exp $ */
2 /*
3 * sm_stree.h - header file for spherical quadtree code:
4 *
5 */
6 #ifndef _RAD_SM_STREE_H_
7 #define _RAD_SM_STREE_H_
8
9 #ifdef __cplusplus
10 extern "C" {
11 #endif
12
13
14 #define STR_INDEX(s) (stRoot_indices[(s)])
15 #define STR_NTH_INDEX(s,n) (stRoot_indices[(s)][(n)])
16
17 #define ST_NUM_ROOT_NODES 8
18
19
20
21 /* The base is an octahedron: Each face contains a planar quadtree. At
22 the root level, the "top" (positive y) four faces, and bottom four faces
23 are stored together:forming two root quadtree nodes
24 */
25
26 typedef struct _STREE {
27 QUADTREE qt[2]; /* root[0]= top four faces, root[1]=bottom 4 faces*/
28
29 }STREE;
30
31
32 #define ST_BASEI(n) ((n)>>2) /* root index: top or bottom */
33 #define ST_INDEX(n) ((n) & 0x3) /* which child in root */
34 #define ST_QT(s,i) ((s)->qt[ST_BASEI(i)]) /* top or bottom root*/
35 #define ST_QT_PTR(s,i) (&ST_QT(s,i)) /* ptr to top(0)/bottom(1)root*/
36 #define ST_TOP_QT(s) ((s)->qt[0]) /* top root (y>0)*/
37 #define ST_BOTTOM_QT(s) ((s)->qt[1]) /* bottom qt (y <= 0)*/
38 #define ST_TOP_QT_PTR(s) (&ST_TOP_QT(s)) /* ptr to top qt */
39 #define ST_BOTTOM_QT_PTR(s) (&ST_BOTTOM_QT(s)) /* ptr to bottom qt*/
40
41 #define ST_NTH_V(s,n,w) (stDefault_base[stBase_verts[n][w]])
42 #define ST_ROOT_QT(s,n) QT_NTH_CHILD(ST_QT(s,n),ST_INDEX(n))
43
44 #define ST_CLEAR_QT(st) (ST_TOP_QT(st)=EMPTY,ST_BOTTOM_QT(st)=EMPTY)
45 #define ST_INIT_QT(st) (QT_CLEAR_CHILDREN(ST_TOP_QT(st)), \
46 QT_CLEAR_CHILDREN(ST_BOTTOM_QT(st)))
47
48 #define ST_CLEAR_FLAGS(s) qtClearAllFlags()
49
50 /* Point location based on coordinate signs */
51 #define stLocate_root(p) (((p)[2]>0.0?0:4)|((p)[1]>0.0?0:2)|((p)[0]>0.0?0:1))
52 #define stClear(st) stInit(st)
53
54 #define ST_CLIP_VERTS 16
55 /* STREE functions
56 void stInit(STREE *st,FVECT center)
57 Initializes an stree structure with origin 'center':
58 Frees existing quadtrees hanging off of the roots
59
60 STREE *stAlloc(STREE *st)
61 Allocates a stree structure and creates octahedron base
62
63
64 QUADTREE stPoint_locate(STREE *st,FVECT p)
65 Returns quadtree leaf node containing point 'p'.
66
67 int stAdd_tri(STREE *st,int id,FVECT t0,t1,t2)
68 Add triangle 'id' with coordinates 't0,t1,t2' to the stree: returns
69 FALSE on error, TRUE otherwise
70
71 int stRemove_tri(STREE *st,int id,FVECT t0,t1,t2)
72 Removes triangle 'id' with coordinates 't0,t1,t2' from stree: returns
73 FALSE on error, TRUE otherwise
74
75 int stTrace_ray(STREE *st,FVECT orig,dir,int (*func)(),int *arg1,*arg2)
76 Trace ray 'orig-dir' through stree and apply 'func(arg1,arg2)' at each
77 node that it intersects
78
79 int stApply_to_tri(STREE *st,FVECT t0,t1,t2,int (*edge_func)(),
80 (*tri_func)(),int arg1,*arg2)
81 Visit nodes intersected by tri 't0,t1,t2'.Apply 'edge_func(arg1,arg2,arg3)',
82 to those nodes intersected by edges, and interior_func to ALL nodes:
83 ie some Nodes will be visited more than once
84 */
85
86 extern int stBase_verts[8][3];
87 extern FVECT stDefault_base[6];
88 extern STREE *stAlloc();
89 extern QUADTREE stPoint_locate();
90
91 #ifdef __cplusplus
92 }
93 #endif
94 #endif /* _RAD_SM_STREE_H_ */
95
96
