| 1 |
/* Copyright (c) 1998 Silicon Graphics, Inc. */
| 2 |
| 3 |
#ifndef lint
| 4 |
static char SCCSid[] = "$SunId$ SGI";
| 5 |
#endif
| 6 |
| 7 |
| 8 |
* sm_stree.c
| 9 |
| 10 |
#include "standard.h"
| 11 |
#include "sm_geom.h"
| 12 |
#include "sm_stree.h"
| 13 |
| 14 |
/* Define 4 vertices on the sphere to create a tetrahedralization on
| 15 |
the sphere: triangles are as follows:
| 16 |
(2,1,0),(3,2,0), (1,3,0), (2,3,1)
| 17 |
| 18 |
| 19 |
#ifdef TEST_DRIVER
| 20 |
extern FVECT Pick_point[500],Pick_v0[500],Pick_v1[500],Pick_v2[500];
| 21 |
extern int Pick_cnt;
| 22 |
#endif
| 23 |
FVECT stDefault_base[4] = { {SQRT3_INV, SQRT3_INV, SQRT3_INV},
| 24 |
{-SQRT3_INV, -SQRT3_INV, SQRT3_INV},
| 25 |
{-SQRT3_INV, SQRT3_INV, -SQRT3_INV},
| 26 |
{SQRT3_INV, -SQRT3_INV, -SQRT3_INV}};
| 27 |
int stTri_verts[4][3] = { {2,1,0},{3,2,0},{1,3,0},{2,3,1}};
| 28 |
int stTri_nbrs[4][3] = { {2,1,3},{0,2,3},{1,0,3},{2,0,1}};
| 29 |
| 30 |
stNth_base_verts(st,i,v1,v2,v3)
| 31 |
STREE *st;
| 32 |
int i;
| 33 |
FVECT v1,v2,v3;
| 34 |
| 35 |
VCOPY(v1,ST_NTH_BASE(st,stTri_verts[i][0]));
| 36 |
VCOPY(v2,ST_NTH_BASE(st,stTri_verts[i][1]));
| 37 |
VCOPY(v3,ST_NTH_BASE(st,stTri_verts[i][2]));
| 38 |
| 39 |
| 40 |
/* Frees the 4 quadtrees rooted at st */
| 41 |
stClear(st)
| 42 |
STREE *st;
| 43 |
| 44 |
int i;
| 45 |
| 46 |
/* stree always has 4 children corresponding to the base tris
| 47 |
| 48 |
for (i = 0; i < 4; i++)
| 49 |
qtFree(ST_NTH_ROOT(st, i));
| 50 |
| 51 |
QT_CLEAR_CHILDREN(ST_ROOT(st));
| 52 |
| 53 |
| 54 |
| 55 |
| 56 |
STREE
| 57 |
*stInit(st,center,base)
| 58 |
STREE *st;
| 59 |
FVECT center,base[4];
| 60 |
| 61 |
| 62 |
if(base)
| 63 |
ST_SET_BASE(st,base);
| 64 |
else
| 65 |
ST_SET_BASE(st,stDefault_base);
| 66 |
| 67 |
ST_SET_CENTER(st,center);
| 68 |
stClear(st);
| 69 |
| 70 |
return(st);
| 71 |
| 72 |
| 73 |
| 74 |
/* "base" defines 4 vertices on the sphere to create a tetrahedralization on
| 75 |
the sphere: triangles are as follows:(0,1,2),(0,2,3), (0,3,1), (1,3,2)
| 76 |
if base is null: does default.
| 77 |
| 78 |
| 79 |
STREE
| 80 |
*stAlloc(st)
| 81 |
STREE *st;
| 82 |
| 83 |
int i;
| 84 |
| 85 |
if(!st)
| 86 |
st = (STREE *)malloc(sizeof(STREE));
| 87 |
| 88 |
ST_ROOT(st) = qtAlloc();
| 89 |
| 90 |
| 91 |
| 92 |
return(st);
| 93 |
| 94 |
| 95 |
| 96 |
/* Find location of sample point in the DAG and return lowest level
| 97 |
containing triangle. "type" indicates whether the point was found
| 98 |
to be in interior to the triangle: GT_FACE, on one of its
| 99 |
edges GT_EDGE or coinciding with one of its vertices GT_VERTEX.
| 100 |
"which" specifies which vertex (0,1,2) or edge (0=v0v1, 1 = v1v2, 2 = v21)
| 101 |
| 102 |
int
| 103 |
stPoint_locate(st,npt)
| 104 |
STREE *st;
| 105 |
FVECT npt;
| 106 |
| 107 |
int i,d,j,id;
| 108 |
QUADTREE *rootptr,*qtptr;
| 109 |
FVECT v1,v2,v3;
| 110 |
OBJECT os[QT_MAXSET+1],*optr;
| 111 |
FVECT p0,p1,p2;
| 112 |
| 113 |
/* Test each of the root triangles against point id */
| 114 |
for(i=0; i < 4; i++)
| 115 |
| 116 |
rootptr = ST_NTH_ROOT_PTR(st,i);
| 117 |
stNth_base_verts(st,i,v1,v2,v3);
| 118 |
/* Return tri that p falls in */
| 119 |
qtptr = qtRoot_point_locate(rootptr,v1,v2,v3,npt,NULL,NULL,NULL);
| 120 |
if(!qtptr || QT_IS_EMPTY(*qtptr))
| 121 |
continue;
| 122 |
/* Get the set */
| 123 |
optr = qtqueryset(*qtptr);
| 124 |
for (j = QT_SET_CNT(optr),optr = QT_SET_PTR(optr);j > 0; j--)
| 125 |
| 126 |
/* Find the first triangle that pt falls */
| 127 |
id = QT_SET_NEXT_ELEM(optr);
| 128 |
qtTri_from_id(id,NULL,NULL,NULL,p0,p1,p2,NULL,NULL,NULL);
| 129 |
d = point_in_stri(p0,p1,p2,npt);
| 130 |
if(d)
| 131 |
return(id);
| 132 |
| 133 |
| 134 |
return(EMPTY);
| 135 |
| 136 |
| 137 |
QUADTREE
| 138 |
*stPoint_locate_cell(st,p,t0,t1,t2)
| 139 |
STREE *st;
| 140 |
FVECT p;
| 141 |
FVECT t0,t1,t2;
| 142 |
| 143 |
int i,d;
| 144 |
| 145 |
FVECT v0,v1,v2;
| 146 |
| 147 |
| 148 |
| 149 |
| 150 |
| 151 |
| 152 |
stNth_base_verts(st,i,v0,v1,v2);
| 153 |
/* Return quadtree tri that p falls in */
| 154 |
qtptr = qtRoot_point_locate(rootptr,v0,v1,v2,p,t0,t1,t2);
| 155 |
if(qtptr)
| 156 |
return(qtptr);
| 157 |
} /* Point not found */
| 158 |
return(NULL);
| 159 |
| 160 |
| 161 |
| 162 |
int
| 163 |
stAdd_tri(st,id,v0,v1,v2)
| 164 |
STREE *st;
| 165 |
int id;
| 166 |
FVECT v0,v1,v2;
| 167 |
| 168 |
| 169 |
int i,found;
| 170 |
QUADTREE *rootptr;
| 171 |
FVECT t0,t1,t2;
| 172 |
| 173 |
found = 0;
| 174 |
| 175 |
| 176 |
| 177 |
stNth_base_verts(st,i,t0,t1,t2);
| 178 |
found |= qtRoot_add_tri(rootptr,t0,t1,t2,v0,v1,v2,id,0);
| 179 |
| 180 |
return(found);
| 181 |
| 182 |
| 183 |
int
| 184 |
stApply_to_tri_cells(st,v0,v1,v2,func,arg)
| 185 |
STREE *st;
| 186 |
FVECT v0,v1,v2;
| 187 |
int (*func)();
| 188 |
int *arg;
| 189 |
| 190 |
int i,found;
| 191 |
QUADTREE *rootptr;
| 192 |
FVECT t0,t1,t2;
| 193 |
| 194 |
found = 0;
| 195 |
func(ST_ROOT_PTR(st),arg);
| 196 |
QT_SET_FLAG(ST_ROOT(st));
| 197 |
| 198 |
| 199 |
| 200 |
| 201 |
found |= qtApply_to_tri_cells(rootptr,v0,v1,v2,t0,t1,t2,func,arg);
| 202 |
| 203 |
return(found);
| 204 |
| 205 |
| 206 |
| 207 |
| 208 |
| 209 |
int
| 210 |
stRemove_tri(st,id,v0,v1,v2)
| 211 |
STREE *st;
| 212 |
int id;
| 213 |
FVECT v0,v1,v2;
| 214 |
| 215 |
| 216 |
int i,found;
| 217 |
QUADTREE *rootptr;
| 218 |
FVECT t0,t1,t2;
| 219 |
| 220 |
found = 0;
| 221 |
| 222 |
| 223 |
| 224 |
| 225 |
found |= qtRemove_tri(rootptr,id,v0,v1,v2,t0,t1,t2);
| 226 |
| 227 |
return(found);
| 228 |
| 229 |
| 230 |
int
| 231 |
stVisit_tri_edges(st,t0,t1,t2,func,arg1,arg2)
| 232 |
STREE *st;
| 233 |
FVECT t0,t1,t2;
| 234 |
int (*func)();
| 235 |
int *arg1,arg2;
| 236 |
| 237 |
int id,i,w;
| 238 |
QUADTREE *rootptr;
| 239 |
FVECT q0,q1,q2,n,v[3],sdir[3],dir[3],tv,d;
| 240 |
double pd,t;
| 241 |
| 242 |
VCOPY(v[0],t0); VCOPY(v[1],t1); VCOPY(v[2],t2);
| 243 |
VSUB(dir[0],t1,t0); VSUB(dir[1],t2,t1);VSUB(dir[2],t0,t2);
| 244 |
VCOPY(sdir[0],dir[0]);VCOPY(sdir[1],dir[1]);VCOPY(sdir[2],dir[2]);
| 245 |
w = 0;
| 246 |
| 247 |
| 248 |
#ifdef TEST_DRIVER
| 249 |
Pick_cnt = 0;
| 250 |
#endif
| 251 |
| 252 |
stNth_base_verts(st,i,q0,q1,q2);
| 253 |
| 254 |
if(!point_in_stri(q0,q1,q2,v[w]))
| 255 |
continue;
| 256 |
id = qtRoot_visit_tri_edges(rootptr,q0,q1,q2,v,dir,&w,func,arg1,arg2);
| 257 |
if(id == INVALID)
| 258 |
| 259 |
#ifdef DEBUG
| 260 |
eputs("stVisit_tri_edges(): Unable to trace edges\n");
| 261 |
#endif
| 262 |
return(INVALID);
| 263 |
| 264 |
if(id == QT_DONE)
| 265 |
return(*arg1);
| 266 |
| 267 |
/* Crossed over to next cell: id = nbr */
| 268 |
while(1)
| 269 |
| 270 |
/* test if ray crosses plane between this quadtree triangle and
| 271 |
its neighbor- if it does then find intersection point with
| 272 |
ray and plane- this is the new origin
| 273 |
| 274 |
if(id==0)
| 275 |
VCROSS(n,q1,q2);
| 276 |
else
| 277 |
if(id==1)
| 278 |
VCROSS(n,q2,q0);
| 279 |
else
| 280 |
VCROSS(n,q0,q1);
| 281 |
| 282 |
if(w==0)
| 283 |
VCOPY(tv,t0);
| 284 |
else
| 285 |
if(w==1)
| 286 |
VCOPY(tv,t1);
| 287 |
else
| 288 |
VCOPY(tv,t2);
| 289 |
if(!intersect_ray_plane(tv,sdir[w],n,0.0,&t,v[w]))
| 290 |
return(INVALID);
| 291 |
| 292 |
VSUM(v[w],v[w],sdir[w],10.0*FTINY);
| 293 |
| 294 |
t = (1.0-t-10.0*FTINY);
| 295 |
if(t <= 0.0)
| 296 |
| 297 |
t = FTINY;
| 298 |
#if 0
| 299 |
eputs("stVisit_tri_edges(): edge end on plane\n");
| 300 |
#endif
| 301 |
| 302 |
dir[w][0] = sdir[w][0] * t;
| 303 |
dir[w][1] = sdir[w][1] * t;
| 304 |
dir[w][2] = sdir[w][2] * t;
| 305 |
i = stTri_nbrs[i][id];
| 306 |
| 307 |
| 308 |
id=qtRoot_visit_tri_edges(rootptr,q0,q1,q2,v,dir,&w,func,arg1,arg2);
| 309 |
if(id == QT_DONE)
| 310 |
return(*arg1);
| 311 |
if(id == INVALID)
| 312 |
| 313 |
#if 0
| 314 |
eputs("stVisit_tri_edges(): point not found\n");
| 315 |
#endif
| 316 |
return(INVALID);
| 317 |
| 318 |
| 319 |
| 320 |
| 321 |
return(INVALID);
| 322 |
| 323 |
| 324 |
| 325 |
int
| 326 |
stVisit_tri_edges2(st,t0,t1,t2,func,arg1,arg2)
| 327 |
STREE *st;
| 328 |
FVECT t0,t1,t2;
| 329 |
int (*func)();
| 330 |
int *arg1,arg2;
| 331 |
| 332 |
int id,i,w;
| 333 |
QUADTREE *rootptr;
| 334 |
FVECT q0,q1,q2,v[3],i_pt;
| 335 |
| 336 |
| 337 |
w = -1;
| 338 |
| 339 |
| 340 |
#ifdef TEST_DRIVER
| 341 |
Pick_cnt = 0;
| 342 |
#endif
| 343 |
| 344 |
| 345 |
| 346 |
if(!point_in_stri(q0,q1,q2,v[0]))
| 347 |
continue;
| 348 |
id = qtRoot_visit_tri_edges2(rootptr,q0,q1,q2,v,i_pt,&w,
| 349 |
func,arg1,arg2);
| 350 |
if(id == INVALID)
| 351 |
| 352 |
#ifdef DEBUG
| 353 |
| 354 |
#endif
| 355 |
return(INVALID);
| 356 |
| 357 |
if(id == QT_DONE)
| 358 |
return(*arg1);
| 359 |
| 360 |
| 361 |
while(1)
| 362 |
| 363 |
| 364 |
| 365 |
| 366 |
| 367 |
| 368 |
| 369 |
| 370 |
id=qtRoot_visit_tri_edges2(rootptr,q0,q1,q2,v,i_pt,&w,
| 371 |
func,arg1,arg2);
| 372 |
if(id == QT_DONE)
| 373 |
return(*arg1);
| 374 |
if(id == INVALID)
| 375 |
| 376 |
#ifdef DEBUG
| 377 |
| 378 |
#endif
| 379 |
return(INVALID);
| 380 |
| 381 |
| 382 |
| 383 |
| 384 |
return(INVALID);
| 385 |
| 386 |
| 387 |
int
| 388 |
stTrace_edge(st,orig,dir,max_t,func,arg1,arg2)
| 389 |
STREE *st;
| 390 |
FVECT orig,dir;
| 391 |
double max_t;
| 392 |
int (*func)();
| 393 |
int *arg1,arg2;
| 394 |
| 395 |
int id,i;
| 396 |
QUADTREE *rootptr;
| 397 |
FVECT q0,q1,q2,o,n,d;
| 398 |
double pd,t;
| 399 |
| 400 |
#if DEBUG
| 401 |
if(max_t > 1.0 || max_t < 0.0)
| 402 |
| 403 |
eputs("stTrace_edge(): max_t must be in [0,1]:adjusting\n");
| 404 |
max_t = 1.0;
| 405 |
| 406 |
#endif
| 407 |
| 408 |
VCOPY(o,orig);
| 409 |
| 410 |
| 411 |
#ifdef TEST_DRIVER
| 412 |
Pick_cnt = 0;
| 413 |
#endif
| 414 |
| 415 |
| 416 |
| 417 |
id= qtRoot_trace_edge(rootptr,q0,q1,q2,o,dir,max_t,func,arg1,arg2);
| 418 |
if(id == INVALID)
| 419 |
continue;
| 420 |
if(id == QT_DONE)
| 421 |
return(*arg1);
| 422 |
| 423 |
| 424 |
while(1)
| 425 |
| 426 |
| 427 |
| 428 |
| 429 |
| 430 |
if(id==0)
| 431 |
VCROSS(n,q1,q2);
| 432 |
else
| 433 |
if(id==1)
| 434 |
VCROSS(n,q2,q0);
| 435 |
else
| 436 |
VCROSS(n,q0,q1);
| 437 |
| 438 |
/* Ray does not cross into next cell: done and tri not found*/
| 439 |
if(!intersect_ray_plane(orig,dir,n,0.0,&t,o))
| 440 |
return(INVALID);
| 441 |
| 442 |
VSUM(o,o,dir,10*FTINY);
| 443 |
| 444 |
d[0] = dir[0]*(1-t-10*FTINY);
| 445 |
d[1] = dir[1]*(1-t-10*FTINY);
| 446 |
d[2] = dir[2]*(1-t-10*FTINY);
| 447 |
| 448 |
| 449 |
| 450 |
id = qtRoot_trace_edge(rootptr,q0,q1,q2,o,d,max_t,func,arg1,arg2);
| 451 |
if(id == QT_DONE)
| 452 |
return(*arg1);
| 453 |
if(id == INVALID)
| 454 |
| 455 |
#if 0
| 456 |
eputs("stTrace_edges(): point not found\n");
| 457 |
#endif
| 458 |
return(INVALID);
| 459 |
| 460 |
| 461 |
| 462 |
| 463 |
return(INVALID);
| 464 |
| 465 |
| 466 |
| 467 |
| 468 |
int
| 469 |
stTrace_ray(st,orig,dir,func,arg1,arg2)
| 470 |
STREE *st;
| 471 |
FVECT orig,dir;
| 472 |
int (*func)();
| 473 |
int *arg1,arg2;
| 474 |
| 475 |
int id,i;
| 476 |
QUADTREE *rootptr;
| 477 |
FVECT q0,q1,q2,o,n;
| 478 |
double pd,t;
| 479 |
| 480 |
VCOPY(o,orig);
| 481 |
| 482 |
| 483 |
#ifdef TEST_DRIVER
| 484 |
Pick_cnt = 0;
| 485 |
#endif
| 486 |
| 487 |
| 488 |
| 489 |
id= qtRoot_trace_ray(rootptr,q0,q1,q2,o,dir,func,arg1,arg2);
| 490 |
if(id == INVALID)
| 491 |
continue;
| 492 |
if(id == QT_DONE)
| 493 |
return(*arg1);
| 494 |
| 495 |
| 496 |
while(1)
| 497 |
| 498 |
| 499 |
| 500 |
| 501 |
| 502 |
if(id==0)
| 503 |
VCROSS(n,q1,q2);
| 504 |
else
| 505 |
if(id==1)
| 506 |
VCROSS(n,q2,q0);
| 507 |
else
| 508 |
VCROSS(n,q0,q1);
| 509 |
| 510 |
| 511 |
if(!intersect_ray_plane(orig,dir,n,0.0,NULL,o))
| 512 |
return(INVALID);
| 513 |
| 514 |
| 515 |
| 516 |
| 517 |
| 518 |
id = qtRoot_trace_ray(rootptr,q0,q1,q2,o,dir,func,arg1,arg2);
| 519 |
if(id == QT_DONE)
| 520 |
return(*arg1);
| 521 |
if(id == INVALID)
| 522 |
return(INVALID);
| 523 |
| 524 |
| 525 |
| 526 |
return(INVALID);
| 527 |
| 528 |
| 529 |
| 530 |
| 531 |
stVisit_tri_interior(st,t0,t1,t2,func,arg1,arg2)
| 532 |
STREE *st;
| 533 |
FVECT t0,t1,t2;
| 534 |
int (*func)();
| 535 |
int *arg1,arg2;
| 536 |
| 537 |
int i;
| 538 |
QUADTREE *rootptr;
| 539 |
FVECT q0,q1,q2;
| 540 |
| 541 |
| 542 |
| 543 |
| 544 |
| 545 |
qtVisit_tri_interior(rootptr,q0,q1,q2,t0,t1,t2,0,func,arg1,arg2);
| 546 |
| 547 |
| 548 |
| 549 |
| 550 |
int
| 551 |
stApply_to_tri(st,t0,t1,t2,func,arg1,arg2)
| 552 |
STREE *st;
| 553 |
FVECT t0,t1,t2;
| 554 |
int (*func)();
| 555 |
int *arg1,arg2;
| 556 |
| 557 |
int f;
| 558 |
FVECT dir;
| 559 |
| 560 |
/* First add all of the leaf cells lying on the triangle perimeter:
| 561 |
mark all cells seen on the way
| 562 |
| 563 |
qtClearAllFlags(); /* clear all quadtree branch flags */
| 564 |
f = 0;
| 565 |
VSUB(dir,t1,t0);
| 566 |
stTrace_edge(st,t0,dir,1.0,func,arg1,arg2);
| 567 |
VSUB(dir,t2,t1);
| 568 |
stTrace_edge(st,t1,dir,1.0,func,arg1,arg2);
| 569 |
VSUB(dir,t0,t2);
| 570 |
stTrace_edge(st,t2,dir,1.0,func,arg1,arg2);
| 571 |
/* Now visit interior */
| 572 |
stVisit_tri_interior(st,t0,t1,t2,func,arg1,arg2);
| 573 |
| 574 |
| 575 |
| 576 |
| 577 |
| 578 |
| 579 |
int
| 580 |
stUpdate_tri(st,t_id,t0,t1,t2,edge_func,interior_func)
| 581 |
STREE *st;
| 582 |
int t_id;
| 583 |
FVECT t0,t1,t2;
| 584 |
int (*edge_func)(),(*interior_func)();
| 585 |
| 586 |
int f;
| 587 |
FVECT dir;
| 588 |
| 589 |
| 590 |
| 591 |
| 592 |
ST_CLEAR_FLAGS(st);
| 593 |
f = 0;
| 594 |
/* Visit cells along edges of the tri */
| 595 |
| 596 |
stVisit_tri_edges2(st,t0,t1,t2,edge_func,&f,t_id);
| 597 |
| 598 |
| 599 |
if(QT_FLAG_FILL_TRI(f) || QT_FLAG_UPDATE(f))
| 600 |
stVisit_tri_interior(st,t0,t1,t2,interior_func,&f,t_id);
| 601 |
| 602 |
| 603 |
| 604 |
| 605 |
