--- ray/src/hd/sm_stree.c 1998/10/06 18:18:54 3.6 +++ ray/src/hd/sm_stree.c 1998/11/11 12:05:41 3.7 @@ -26,11 +26,11 @@ extern int Pick_cnt; FVECT stDefault_base[6] = { {1.,0.,0.},{0.,1.,0.}, {0.,0.,1.}, {-1.,0.,0.},{0.,-1.,0.},{0.,0.,-1.}}; /* octahedron triangle vertices */ -int stBase_verts[8][3] = { {0,1,2},{0,5,1},{3,1,5},{3,2,1}, - {0,2,4},{5,0,4},{5,4,3},{2,3,4}}; +int stBase_verts[8][3] = { {2,1,0},{1,5,0},{5,1,3},{1,2,3}, + {4,2,0},{4,0,5},{3,4,5},{4,3,2}}; /* octahedron triangle nbrs ; nbr i is the face opposite vertex i*/ -int stBase_nbrs[8][3] = { {3,4,1},{2,0,5},{1,6,3},{0,2,7}, - {7,5,0},{4,6,1},{7,2,5},{6,4,3}}; +int stBase_nbrs[8][3] = { {1,4,3},{5,0,2},{3,6,1},{7,2,0}, + {0,5,7},{1,6,4},{5,2,7},{3,4,6}}; /* look up table for octahedron point location */ int stlocatetbl[8] = {6,7,2,3,5,4,1,0}; @@ -86,9 +86,9 @@ STREE *st; FP_X(ST_NTH_PLANE(st,i)) = (m+1)%3; FP_Y(ST_NTH_PLANE(st,i)) = (m+2)%3; FP_Z(ST_NTH_PLANE(st,i)) = m; - VCROSS(ST_EDGE_NORM(st,i,0),v1,v0); - VCROSS(ST_EDGE_NORM(st,i,1),v2,v1); - VCROSS(ST_EDGE_NORM(st,i,2),v0,v2); + VCROSS(ST_EDGE_NORM(st,i,0),v0,v1); + VCROSS(ST_EDGE_NORM(st,i,1),v1,v2); + VCROSS(ST_EDGE_NORM(st,i,2),v2,v0); } return(st); } @@ -211,11 +211,13 @@ stTrace_ray(st,orig,dir,func,argptr) { int next,last,i,f=0; QUADTREE root; - FVECT o,n; - double pd,t; + FVECT o,n,v; + double pd,t,d; VCOPY(o,orig); - +#ifdef TEST_DRIVER + Pick_cnt=0; +#endif; /* Find the root node that o falls in */ i = stPoint_in_root(o); root = ST_NTH_ROOT(st,i); @@ -226,7 +228,9 @@ stTrace_ray(st,orig,dir,func,argptr) if(QT_FLAG_IS_DONE(f)) return(TRUE); - + + d = DOT(orig,dir)/sqrt(DOT(orig,orig)); + VSUM(v,orig,dir,-d); /* Crossed over to next cell: id = nbr */ while(1) { @@ -236,8 +240,10 @@ stTrace_ray(st,orig,dir,func,argptr) */ if(next == INVALID) return(FALSE); - if(!intersect_ray_oplane(orig,dir, - ST_EDGE_NORM(st,i,(next+1)%3),NULL,o)) +#if 0 + if(!intersect_ray_oplane(o,dir,ST_EDGE_NORM(st,i,(next+1)%3),NULL,o)) +#endif + if(DOT(o,v) < 0.0) /* Ray does not cross into next cell: done and tri not found*/ return(FALSE); @@ -269,9 +275,9 @@ stVisit_tri(st,t0,t1,t2,func,f,argptr) FVECT n0,n1,n2; /* Calcuate the edge normals for tri */ - VCROSS(n0,t1,t0); - VCROSS(n1,t2,t1); - VCROSS(n2,t0,t2); + VCROSS(n0,t0,t1); + VCROSS(n1,t1,t2); + VCROSS(n2,t2,t0); for(i=0; i < ST_NUM_ROOT_NODES; i++) { @@ -295,7 +301,10 @@ stApply_to_tri(st,t0,t1,t2,edge_func,tri_func,argptr) { int f; FVECT dir; - + +#ifdef TEST_DRIVER + Pick_cnt=0; +#endif; /* First add all of the leaf cells lying on the triangle perimeter: mark all cells seen on the way */ @@ -307,6 +316,10 @@ stApply_to_tri(st,t0,t1,t2,edge_func,tri_func,argptr) if(QT_FLAG_FILL_TRI(f) || QT_FLAG_UPDATE(f)) stVisit_tri(st,t0,t1,t2,tri_func,&f,argptr); } + + + +
