root/radiance/ray/src/hd/sm_stree.c
Revision: 3.2
Committed: Thu Aug 20 16:47:22 1998 UTC (26 years, 9 months ago) by gwlarson
Changes since 3.1: +12 -12 lines
switched to barycentric coordinates
fixed background poly rendering
1 /* Copyright (c) 1998 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * sm_stree.c
9 */
10 #include "standard.h"
11 #include "object.h"
12
13 #include "sm_geom.h"
14 #include "sm_stree.h"
15
16
17 /* Define 4 vertices on the sphere to create a tetrahedralization on
18 the sphere: triangles are as follows:
19 (0,1,2),(0,2,3), (0,3,1), (1,3,2)
20 */
21
22 FVECT stDefault_base[4] = { {SQRT3_INV, SQRT3_INV, SQRT3_INV},
23 {-SQRT3_INV, -SQRT3_INV, SQRT3_INV},
24 {-SQRT3_INV, SQRT3_INV, -SQRT3_INV},
25 {SQRT3_INV, -SQRT3_INV, -SQRT3_INV}};
26 int stTri_verts[4][3] = { {2,1,0},
27 {3,2,0},
28 {1,3,0},
29 {2,3,1}};
30
31 stNth_base_verts(st,i,v1,v2,v3)
32 STREE *st;
33 int i;
34 FVECT v1,v2,v3;
35 {
36 VCOPY(v1,ST_NTH_BASE(st,stTri_verts[i][0]));
37 VCOPY(v2,ST_NTH_BASE(st,stTri_verts[i][1]));
38 VCOPY(v3,ST_NTH_BASE(st,stTri_verts[i][2]));
39 }
40
41 /* Frees the 4 quadtrees rooted at st */
42 stClear(st)
43 STREE *st;
44 {
45 int i;
46
47 /* stree always has 4 children corresponding to the base tris
48 */
49 for (i = 0; i < 4; i++)
50 qtFree(ST_NTH_ROOT(st, i));
51
52 QT_CLEAR_CHILDREN(ST_ROOT(st));
53
54 }
55
56
57 STREE
58 *stInit(st,center,base)
59 STREE *st;
60 FVECT center,base[4];
61 {
62
63 if(base)
64 ST_SET_BASE(st,base);
65 else
66 ST_SET_BASE(st,stDefault_base);
67
68 ST_SET_CENTER(st,center);
69 stClear(st);
70
71 return(st);
72 }
73
74
75 /* "base" defines 4 vertices on the sphere to create a tetrahedralization on
76 the sphere: triangles are as follows:(0,1,2),(0,2,3), (0,3,1), (1,3,2)
77 if base is null: does default.
78
79 */
80 STREE
81 *stAlloc(st)
82 STREE *st;
83 {
84 int i;
85
86 if(!st)
87 st = (STREE *)malloc(sizeof(STREE));
88
89 ST_ROOT(st) = qtAlloc();
90
91 QT_CLEAR_CHILDREN(ST_ROOT(st));
92
93 return(st);
94 }
95
96
97 /* Find location of sample point in the DAG and return lowest level
98 containing triangle. "type" indicates whether the point was found
99 to be in interior to the triangle: GT_FACE, on one of its
100 edges GT_EDGE or coinciding with one of its vertices GT_VERTEX.
101 "which" specifies which vertex (0,1,2) or edge (0=v0v1, 1 = v1v2, 2 = v21)
102 */
103 int
104 stPoint_locate(st,npt,type,which)
105 STREE *st;
106 FVECT npt;
107 char *type,*which;
108 {
109 int i,d,j,id;
110 QUADTREE *rootptr,qt;
111 FVECT v1,v2,v3;
112 OBJECT os[MAXSET+1],*optr;
113 char w;
114 FVECT p0,p1,p2;
115
116 /* Test each of the root triangles against point id */
117 for(i=0; i < 4; i++)
118 {
119 rootptr = ST_NTH_ROOT_PTR(st,i);
120 stNth_base_verts(st,i,v1,v2,v3);
121 /* Return tri that p falls in */
122 qt = qtRoot_point_locate(rootptr,v1,v2,v3,npt,type,which);
123 if(QT_IS_EMPTY(qt))
124 continue;
125 /* Get the set */
126 qtgetset(os,qt);
127 for (j = QT_SET_CNT(os),optr = QT_SET_PTR(os); j > 0; j--)
128 {
129 /* Find the first triangle that pt falls */
130 id = QT_SET_NEXT_ELEM(optr);
131 qtTri_verts_from_id(id,p0,p1,p2);
132 d = test_single_point_against_spherical_tri(p0,p1,p2,npt,&w);
133 if(d)
134 {
135 if(type)
136 *type = d;
137 if(which)
138 *which = w;
139 return(id);
140 }
141 }
142 }
143 if(which)
144 *which = 0;
145 if(type)
146 *type = 0;
147 return(EMPTY);
148 }
149
150 int
151 stPoint_locate_cell(st,p,type,which)
152 STREE *st;
153 FVECT p;
154 char *type,*which;
155 {
156 int i,d;
157 QUADTREE *rootptr,qt;
158 FVECT v0,v1,v2;
159
160
161 /* Test each of the root triangles against point id */
162 for(i=0; i < 4; i++)
163 {
164 rootptr = ST_NTH_ROOT_PTR(st,i);
165 stNth_base_verts(st,i,v0,v1,v2);
166 /* Return tri that p falls in */
167 qt = qtRoot_point_locate(rootptr,v0,v1,v2,p,type,which);
168 /* NOTE: For now return only one triangle */
169 if(!QT_IS_EMPTY(qt))
170 return(qt);
171 } /* Point not found */
172 if(which)
173 *which = 0;
174 if(type)
175 *type = 0;
176 return(EMPTY);
177 }
178
179 int
180 stAdd_tri(st,id,v0,v1,v2)
181 STREE *st;
182 int id;
183 FVECT v0,v1,v2;
184 {
185
186 int i,found;
187 QUADTREE *rootptr;
188 FVECT t0,t1,t2;
189
190 found = 0;
191 for(i=0; i < 4; i++)
192 {
193 rootptr = ST_NTH_ROOT_PTR(st,i);
194 stNth_base_verts(st,i,t0,t1,t2);
195 found |= qtAdd_tri(rootptr,id,v0,v1,v2,t0,t1,t2,0);
196 }
197 return(found);
198 }
199
200 int
201 stApply_to_tri_cells(st,v0,v1,v2,func,arg)
202 STREE *st;
203 FVECT v0,v1,v2;
204 int (*func)();
205 char *arg;
206 {
207 int i,found;
208 QUADTREE *rootptr;
209 FVECT t0,t1,t2;
210
211 found = 0;
212 for(i=0; i < 4; i++)
213 {
214 rootptr = ST_NTH_ROOT_PTR(st,i);
215 stNth_base_verts(st,i,t0,t1,t2);
216 found |= qtApply_to_tri_cells(rootptr,v0,v1,v2,t0,t1,t2,func,arg);
217 }
218 return(found);
219 }
220
221
222
223
224 int
225 stRemove_tri(st,id,v0,v1,v2)
226 STREE *st;
227 int id;
228 FVECT v0,v1,v2;
229 {
230
231 int i,found;
232 QUADTREE *rootptr;
233 FVECT t0,t1,t2;
234
235 found = 0;
236 for(i=0; i < 4; i++)
237 {
238 rootptr = ST_NTH_ROOT_PTR(st,i);
239 stNth_base_verts(st,i,t0,t1,t2);
240 found |= qtRemove_tri(rootptr,id,v0,v1,v2,t0,t1,t2);
241 }
242 return(found);
243 }
244
245
246
247
248
