--- ray/src/hd/sm_stree.c 1998/09/11 11:52:27 3.4 +++ ray/src/hd/sm_stree.c 1998/10/06 18:18:54 3.6 @@ -6,553 +6,292 @@ static char SCCSid[] = "$SunId$ SGI"; /* * sm_stree.c + * An stree (spherical quadtree) is defined by an octahedron in + * canonical form,and a world center point. Each face of the + * octahedron is adaptively subdivided as a planar triangular quadtree. + * World space geometry is projected onto the quadtree faces from the + * sphere center. */ #include "standard.h" +#include "sm_flag.h" #include "sm_geom.h" +#include "sm_qtree.h" #include "sm_stree.h" -/* Define 4 vertices on the sphere to create a tetrahedralization on - the sphere: triangles are as follows: - (2,1,0),(3,2,0), (1,3,0), (2,3,1) -*/ - #ifdef TEST_DRIVER extern FVECT Pick_point[500],Pick_v0[500],Pick_v1[500],Pick_v2[500]; extern int Pick_cnt; #endif -FVECT stDefault_base[4] = { {SQRT3_INV, SQRT3_INV, SQRT3_INV}, - {-SQRT3_INV, -SQRT3_INV, SQRT3_INV}, - {-SQRT3_INV, SQRT3_INV, -SQRT3_INV}, - {SQRT3_INV, -SQRT3_INV, -SQRT3_INV}}; -int stTri_verts[4][3] = { {2,1,0},{3,2,0},{1,3,0},{2,3,1}}; -int stTri_nbrs[4][3] = { {2,1,3},{0,2,3},{1,0,3},{2,0,1}}; +/* octahedron coordinates */ +FVECT stDefault_base[6] = { {1.,0.,0.},{0.,1.,0.}, {0.,0.,1.}, + {-1.,0.,0.},{0.,-1.,0.},{0.,0.,-1.}}; +/* octahedron triangle vertices */ +int stBase_verts[8][3] = { {0,1,2},{0,5,1},{3,1,5},{3,2,1}, + {0,2,4},{5,0,4},{5,4,3},{2,3,4}}; +/* octahedron triangle nbrs ; nbr i is the face opposite vertex i*/ +int stBase_nbrs[8][3] = { {3,4,1},{2,0,5},{1,6,3},{0,2,7}, + {7,5,0},{4,6,1},{7,2,5},{6,4,3}}; +/* look up table for octahedron point location */ +int stlocatetbl[8] = {6,7,2,3,5,4,1,0}; -stNth_base_verts(st,i,v1,v2,v3) + +/* Initializes an stree structure with origin 'center': + Frees existing quadtrees hanging off of the roots +*/ +stInit(st) STREE *st; -int i; -FVECT v1,v2,v3; { - VCOPY(v1,ST_NTH_BASE(st,stTri_verts[i][0])); - VCOPY(v2,ST_NTH_BASE(st,stTri_verts[i][1])); - VCOPY(v3,ST_NTH_BASE(st,stTri_verts[i][2])); + ST_TOP_ROOT(st) = qtAlloc(); + ST_BOTTOM_ROOT(st) = qtAlloc(); + ST_INIT_ROOT(st); } -/* Frees the 4 quadtrees rooted at st */ +/* Frees the children of the 2 quadtrees rooted at st, + Does not free root nodes: just clears +*/ stClear(st) -STREE *st; + STREE *st; { - int i; - - /* stree always has 4 children corresponding to the base tris - */ - for (i = 0; i < 4; i++) - qtFree(ST_NTH_ROOT(st, i)); - - QT_CLEAR_CHILDREN(ST_ROOT(st)); - + qtDone(); + stInit(st); } - +/* Allocates a stree structure and creates octahedron base */ STREE -*stInit(st,center,base) -STREE *st; -FVECT center,base[4]; -{ - - if(base) - ST_SET_BASE(st,base); - else - ST_SET_BASE(st,stDefault_base); - - ST_SET_CENTER(st,center); - stClear(st); - - return(st); -} - - -/* "base" defines 4 vertices on the sphere to create a tetrahedralization on - the sphere: triangles are as follows:(0,1,2),(0,2,3), (0,3,1), (1,3,2) - if base is null: does default. - - */ -STREE *stAlloc(st) STREE *st; { - int i; - + int i,m; + FVECT v0,v1,v2; + FVECT n; + if(!st) - st = (STREE *)malloc(sizeof(STREE)); + if(!(st = (STREE *)malloc(sizeof(STREE)))) + error(SYSTEM,"stAlloc(): Unable to allocate memory\n"); - ST_ROOT(st) = qtAlloc(); - - QT_CLEAR_CHILDREN(ST_ROOT(st)); + /* Allocate the top and bottom quadtree root nodes */ + stInit(st); + + /* Set the octahedron base */ + ST_SET_BASE(st,stDefault_base); + /* Calculate octahedron face and edge normals */ + for(i=0; i < ST_NUM_ROOT_NODES; i++) + { + VCOPY(v0,ST_NTH_V(st,i,0)); + VCOPY(v1,ST_NTH_V(st,i,1)); + VCOPY(v2,ST_NTH_V(st,i,2)); + tri_plane_equation(v0,v1,v2, &ST_NTH_PLANE(st,i),FALSE); + m = max_index(FP_N(ST_NTH_PLANE(st,i)),NULL); + FP_X(ST_NTH_PLANE(st,i)) = (m+1)%3; + FP_Y(ST_NTH_PLANE(st,i)) = (m+2)%3; + FP_Z(ST_NTH_PLANE(st,i)) = m; + VCROSS(ST_EDGE_NORM(st,i,0),v1,v0); + VCROSS(ST_EDGE_NORM(st,i,1),v2,v1); + VCROSS(ST_EDGE_NORM(st,i,2),v0,v2); + } return(st); } -/* Find location of sample point in the DAG and return lowest level - containing triangle. "type" indicates whether the point was found - to be in interior to the triangle: GT_FACE, on one of its - edges GT_EDGE or coinciding with one of its vertices GT_VERTEX. - "which" specifies which vertex (0,1,2) or edge (0=v0v1, 1 = v1v2, 2 = v21) -*/ -int -stPoint_locate(st,npt) - STREE *st; - FVECT npt; -{ - int i,d,j,id; - QUADTREE *rootptr,*qtptr; - FVECT v1,v2,v3; - OBJECT os[QT_MAXSET+1],*optr; - FVECT p0,p1,p2; - - /* Test each of the root triangles against point id */ - for(i=0; i < 4; i++) - { - rootptr = ST_NTH_ROOT_PTR(st,i); - stNth_base_verts(st,i,v1,v2,v3); - /* Return tri that p falls in */ - qtptr = qtRoot_point_locate(rootptr,v1,v2,v3,npt,NULL,NULL,NULL); - if(!qtptr || QT_IS_EMPTY(*qtptr)) - continue; - /* Get the set */ - optr = qtqueryset(*qtptr); - for (j = QT_SET_CNT(optr),optr = QT_SET_PTR(optr);j > 0; j--) - { - /* Find the first triangle that pt falls */ - id = QT_SET_NEXT_ELEM(optr); - qtTri_from_id(id,NULL,NULL,NULL,p0,p1,p2,NULL,NULL,NULL); - d = point_in_stri(p0,p1,p2,npt); - if(d) - return(id); - } - } - return(EMPTY); -} - +/* Return quadtree leaf node containing point 'p'*/ QUADTREE -*stPoint_locate_cell(st,p,t0,t1,t2) +stPoint_locate(st,p) STREE *st; FVECT p; - FVECT t0,t1,t2; { - int i,d; - QUADTREE *rootptr,*qtptr; - FVECT v0,v1,v2; + int i; + QUADTREE root,qt; + /* Find root quadtree that contains p */ + i = stPoint_in_root(p); + root = ST_NTH_ROOT(st,i); - /* Test each of the root triangles against point id */ - for(i=0; i < 4; i++) - { - rootptr = ST_NTH_ROOT_PTR(st,i); - stNth_base_verts(st,i,v0,v1,v2); - /* Return quadtree tri that p falls in */ - qtptr = qtRoot_point_locate(rootptr,v0,v1,v2,p,t0,t1,t2); - if(qtptr) - return(qtptr); - } /* Point not found */ - return(NULL); + /* Traverse quadtree to leaf level */ + qt = qtRoot_point_locate(root,ST_NTH_V(st,i,0),ST_NTH_V(st,i,1), + ST_NTH_V(st,i,2),ST_NTH_PLANE(st,i),p); + return(qt); } +/* Add triangle 'id' with coordinates 't0,t1,t2' to the stree: returns + FALSE on error, TRUE otherwise +*/ -int -stAdd_tri(st,id,v0,v1,v2) +stAdd_tri(st,id,t0,t1,t2) STREE *st; int id; -FVECT v0,v1,v2; +FVECT t0,t1,t2; { - - int i,found; - QUADTREE *rootptr; - FVECT t0,t1,t2; + int i; + QUADTREE root; - found = 0; - for(i=0; i < 4; i++) + for(i=0; i < ST_NUM_ROOT_NODES; i++) { - rootptr = ST_NTH_ROOT_PTR(st,i); - stNth_base_verts(st,i,t0,t1,t2); - found |= qtRoot_add_tri(rootptr,t0,t1,t2,v0,v1,v2,id,0); + root = ST_NTH_ROOT(st,i); + ST_NTH_ROOT(st,i) = qtRoot_add_tri(root,ST_NTH_V(st,i,0),ST_NTH_V(st,i,1), + ST_NTH_V(st,i,2),t0,t1,t2,id,0); } - return(found); } -int -stApply_to_tri_cells(st,v0,v1,v2,func,arg) -STREE *st; -FVECT v0,v1,v2; -int (*func)(); -int *arg; -{ - int i,found; - QUADTREE *rootptr; - FVECT t0,t1,t2; +/* Remove triangle 'id' with coordinates 't0,t1,t2' to the stree: returns + FALSE on error, TRUE otherwise +*/ - found = 0; - func(ST_ROOT_PTR(st),arg); - QT_SET_FLAG(ST_ROOT(st)); - for(i=0; i < 4; i++) - { - rootptr = ST_NTH_ROOT_PTR(st,i); - stNth_base_verts(st,i,t0,t1,t2); - found |= qtApply_to_tri_cells(rootptr,v0,v1,v2,t0,t1,t2,func,arg); - } - return(found); -} - - - - -int -stRemove_tri(st,id,v0,v1,v2) +stRemove_tri(st,id,t0,t1,t2) STREE *st; int id; -FVECT v0,v1,v2; +FVECT t0,t1,t2; { - - int i,found; - QUADTREE *rootptr; - FVECT t0,t1,t2; + int i; + QUADTREE root; - found = 0; - for(i=0; i < 4; i++) + for(i=0; i < ST_NUM_ROOT_NODES; i++) { - rootptr = ST_NTH_ROOT_PTR(st,i); - stNth_base_verts(st,i,t0,t1,t2); - found |= qtRemove_tri(rootptr,id,v0,v1,v2,t0,t1,t2); + root = ST_NTH_ROOT(st,i); + ST_NTH_ROOT(st,i)=qtRoot_remove_tri(root,id,ST_NTH_V(st,i,0),ST_NTH_V(st,i,1), + ST_NTH_V(st,i,2),t0,t1,t2); } - return(found); } -int -stVisit_tri_edges(st,t0,t1,t2,func,arg1,arg2) - STREE *st; - FVECT t0,t1,t2; - int (*func)(); - int *arg1,arg2; -{ - int id,i,w; - QUADTREE *rootptr; - FVECT q0,q1,q2,n,v[3],sdir[3],dir[3],tv,d; - double pd,t; +/* Visit all nodes that are intersected by the edges of triangle 't0,t1,t2' + and apply 'func' +*/ - VCOPY(v[0],t0); VCOPY(v[1],t1); VCOPY(v[2],t2); - VSUB(dir[0],t1,t0); VSUB(dir[1],t2,t1);VSUB(dir[2],t0,t2); - VCOPY(sdir[0],dir[0]);VCOPY(sdir[1],dir[1]);VCOPY(sdir[2],dir[2]); - w = 0; - for(i=0; i < 4; i++) - { -#ifdef TEST_DRIVER -Pick_cnt = 0; -#endif - rootptr = ST_NTH_ROOT_PTR(st,i); - stNth_base_verts(st,i,q0,q1,q2); - /* Return quadtree tri that p falls in */ - if(!point_in_stri(q0,q1,q2,v[w])) - continue; - id = qtRoot_visit_tri_edges(rootptr,q0,q1,q2,v,dir,&w,func,arg1,arg2); - if(id == INVALID) - { -#ifdef DEBUG - eputs("stVisit_tri_edges(): Unable to trace edges\n"); -#endif - return(INVALID); - } - if(id == QT_DONE) - return(*arg1); - - /* Crossed over to next cell: id = nbr */ - while(1) - { - /* test if ray crosses plane between this quadtree triangle and - its neighbor- if it does then find intersection point with - ray and plane- this is the new origin - */ - if(id==0) - VCROSS(n,q1,q2); - else - if(id==1) - VCROSS(n,q2,q0); - else - VCROSS(n,q0,q1); - - if(w==0) - VCOPY(tv,t0); - else - if(w==1) - VCOPY(tv,t1); - else - VCOPY(tv,t2); - if(!intersect_ray_plane(tv,sdir[w],n,0.0,&t,v[w])) - return(INVALID); - - VSUM(v[w],v[w],sdir[w],10.0*FTINY); - - t = (1.0-t-10.0*FTINY); - if(t <= 0.0) - { - t = FTINY; -#if 0 - eputs("stVisit_tri_edges(): edge end on plane\n"); -#endif - } - dir[w][0] = sdir[w][0] * t; - dir[w][1] = sdir[w][1] * t; - dir[w][2] = sdir[w][2] * t; - i = stTri_nbrs[i][id]; - rootptr = ST_NTH_ROOT_PTR(st,i); - stNth_base_verts(st,i,q0,q1,q2); - id=qtRoot_visit_tri_edges(rootptr,q0,q1,q2,v,dir,&w,func,arg1,arg2); - if(id == QT_DONE) - return(*arg1); - if(id == INVALID) - { -#if 0 - eputs("stVisit_tri_edges(): point not found\n"); -#endif - return(INVALID); - } - - } - } /* Point not found */ - return(INVALID); -} - - -int -stVisit_tri_edges2(st,t0,t1,t2,func,arg1,arg2) +stVisit_tri_edges(st,t0,t1,t2,func,fptr,argptr) STREE *st; FVECT t0,t1,t2; - int (*func)(); - int *arg1,arg2; + int (*func)(),*fptr; + int *argptr; { - int id,i,w; - QUADTREE *rootptr; - FVECT q0,q1,q2,v[3],i_pt; + int id,i,w,next; + QUADTREE root; + FVECT v[3],i_pt; VCOPY(v[0],t0); VCOPY(v[1],t1); VCOPY(v[2],t2); w = -1; - for(i=0; i < 4; i++) - { -#ifdef TEST_DRIVER -Pick_cnt = 0; -#endif - rootptr = ST_NTH_ROOT_PTR(st,i); - stNth_base_verts(st,i,q0,q1,q2); - /* Return quadtree tri that p falls in */ - if(!point_in_stri(q0,q1,q2,v[0])) - continue; - id = qtRoot_visit_tri_edges2(rootptr,q0,q1,q2,v,i_pt,&w, - func,arg1,arg2); - if(id == INVALID) - { -#ifdef DEBUG - eputs("stVisit_tri_edges(): Unable to trace edges\n"); -#endif - return(INVALID); - } - if(id == QT_DONE) - return(*arg1); - - /* Crossed over to next cell: id = nbr */ - while(1) - { - /* test if ray crosses plane between this quadtree triangle and - its neighbor- if it does then find intersection point with - ray and plane- this is the new origin - */ - i = stTri_nbrs[i][id]; - rootptr = ST_NTH_ROOT_PTR(st,i); - stNth_base_verts(st,i,q0,q1,q2); - id=qtRoot_visit_tri_edges2(rootptr,q0,q1,q2,v,i_pt,&w, - func,arg1,arg2); - if(id == QT_DONE) - return(*arg1); - if(id == INVALID) - { -#ifdef DEBUG - eputs("stVisit_tri_edges(): point not found\n"); -#endif - return(INVALID); - } - - } - } /* Point not found */ - return(INVALID); -} -int -stTrace_edge(st,orig,dir,max_t,func,arg1,arg2) - STREE *st; - FVECT orig,dir; - double max_t; - int (*func)(); - int *arg1,arg2; -{ - int id,i; - QUADTREE *rootptr; - FVECT q0,q1,q2,o,n,d; - double pd,t; - -#if DEBUG - if(max_t > 1.0 || max_t < 0.0) + /* Locate the root containing triangle vertex v0 */ + i = stPoint_in_root(v[0]); + /* Mark the root node as visited */ + QT_SET_FLAG(ST_ROOT(st,i)); + root = ST_NTH_ROOT(st,i); + + ST_NTH_ROOT(st,i) = qtRoot_visit_tri_edges(root,ST_NTH_V(st,i,0), + ST_NTH_V(st,i,1),ST_NTH_V(st,i,2),ST_NTH_PLANE(st,i),v,i_pt,&w, + &next,func,fptr,argptr); + if(QT_FLAG_IS_DONE(*fptr)) + return; + + /* Crossed over to next node: id = nbr */ + while(1) { - eputs("stTrace_edge(): max_t must be in [0,1]:adjusting\n"); - max_t = 1.0; + /* test if ray crosses plane between this quadtree triangle and + its neighbor- if it does then find intersection point with + ray and plane- this is the new start point + */ + i = stBase_nbrs[i][next]; + root = ST_NTH_ROOT(st,i); + ST_NTH_ROOT(st,i) = + qtRoot_visit_tri_edges(root,ST_NTH_V(st,i,0),ST_NTH_V(st,i,1), + ST_NTH_V(st,i,2),ST_NTH_PLANE(st,i),v,i_pt,&w,&next,func,fptr,argptr); + if(QT_FLAG_IS_DONE(*fptr)) + return; } -#endif - - VCOPY(o,orig); - for(i=0; i < 4; i++) - { -#ifdef TEST_DRIVER -Pick_cnt = 0; -#endif - rootptr = ST_NTH_ROOT_PTR(st,i); - stNth_base_verts(st,i,q0,q1,q2); - /* Return quadtree tri that p falls in */ - id= qtRoot_trace_edge(rootptr,q0,q1,q2,o,dir,max_t,func,arg1,arg2); - if(id == INVALID) - continue; - if(id == QT_DONE) - return(*arg1); - - /* Crossed over to next cell: id = nbr */ - while(1) - { - /* test if ray crosses plane between this quadtree triangle and - its neighbor- if it does then find intersection point with - ray and plane- this is the new origin - */ - if(id==0) - VCROSS(n,q1,q2); - else - if(id==1) - VCROSS(n,q2,q0); - else - VCROSS(n,q0,q1); - - /* Ray does not cross into next cell: done and tri not found*/ - if(!intersect_ray_plane(orig,dir,n,0.0,&t,o)) - return(INVALID); - - VSUM(o,o,dir,10*FTINY); - - d[0] = dir[0]*(1-t-10*FTINY); - d[1] = dir[1]*(1-t-10*FTINY); - d[2] = dir[2]*(1-t-10*FTINY); - i = stTri_nbrs[i][id]; - rootptr = ST_NTH_ROOT_PTR(st,i); - stNth_base_verts(st,i,q0,q1,q2); - id = qtRoot_trace_edge(rootptr,q0,q1,q2,o,d,max_t,func,arg1,arg2); - if(id == QT_DONE) - return(*arg1); - if(id == INVALID) - { -#if 0 - eputs("stTrace_edges(): point not found\n"); -#endif - return(INVALID); - } - - } - } /* Point not found */ - return(INVALID); } - - +/* Trace ray 'orig-dir' through stree and apply 'func(qtptr,f,argptr)' at each + node that it intersects +*/ int -stTrace_ray(st,orig,dir,func,arg1,arg2) +stTrace_ray(st,orig,dir,func,argptr) STREE *st; FVECT orig,dir; int (*func)(); - int *arg1,arg2; + int *argptr; { - int id,i; - QUADTREE *rootptr; - FVECT q0,q1,q2,o,n; + int next,last,i,f=0; + QUADTREE root; + FVECT o,n; double pd,t; VCOPY(o,orig); - for(i=0; i < 4; i++) - { -#ifdef TEST_DRIVER -Pick_cnt = 0; -#endif - rootptr = ST_NTH_ROOT_PTR(st,i); - stNth_base_verts(st,i,q0,q1,q2); - /* Return quadtree tri that p falls in */ - id= qtRoot_trace_ray(rootptr,q0,q1,q2,o,dir,func,arg1,arg2); - if(id == INVALID) - continue; - if(id == QT_DONE) - return(*arg1); - - /* Crossed over to next cell: id = nbr */ - while(1) - { - /* test if ray crosses plane between this quadtree triangle and - its neighbor- if it does then find intersection point with - ray and plane- this is the new origin - */ - if(id==0) - VCROSS(n,q1,q2); - else - if(id==1) - VCROSS(n,q2,q0); - else - VCROSS(n,q0,q1); + /* Find the root node that o falls in */ + i = stPoint_in_root(o); + root = ST_NTH_ROOT(st,i); + + ST_NTH_ROOT(st,i) = + qtRoot_trace_ray(root,ST_NTH_V(st,i,0),ST_NTH_V(st,i,1), + ST_NTH_V(st,i,2),ST_NTH_PLANE(st,i),o,dir,&next,func,&f,argptr); + + if(QT_FLAG_IS_DONE(f)) + return(TRUE); + + /* Crossed over to next cell: id = nbr */ + while(1) + { + /* test if ray crosses plane between this quadtree triangle and + its neighbor- if it does then find intersection point with + ray and plane- this is the new origin + */ + if(next == INVALID) + return(FALSE); + if(!intersect_ray_oplane(orig,dir, + ST_EDGE_NORM(st,i,(next+1)%3),NULL,o)) /* Ray does not cross into next cell: done and tri not found*/ - if(!intersect_ray_plane(orig,dir,n,0.0,NULL,o)) - return(INVALID); + return(FALSE); - VSUM(o,o,dir,10*FTINY); - i = stTri_nbrs[i][id]; - rootptr = ST_NTH_ROOT_PTR(st,i); - stNth_base_verts(st,i,q0,q1,q2); - id = qtRoot_trace_ray(rootptr,q0,q1,q2,o,dir,func,arg1,arg2); - if(id == QT_DONE) - return(*arg1); - if(id == INVALID) - return(INVALID); - - } - } /* Point not found */ - return(INVALID); + VSUM(o,o,dir,10*FTINY); + i = stBase_nbrs[i][next]; + root = ST_NTH_ROOT(st,i); + + ST_NTH_ROOT(st,i) = + qtRoot_trace_ray(root, ST_NTH_V(st,i,0),ST_NTH_V(st,i,1), + ST_NTH_V(st,i,2),ST_NTH_PLANE(st,i),o,dir,&next,func,&f,argptr); + if(QT_FLAG_IS_DONE(f)) + return(TRUE); + } } - -stVisit_tri_interior(st,t0,t1,t2,func,arg1,arg2) +/* Visit nodes intersected by tri 't0,t1,t2' and apply 'func(arg1,arg2,arg3): + assumes that stVisit_tri_edges has already been called such that all nodes + intersected by tri edges are already marked as visited +*/ +stVisit_tri(st,t0,t1,t2,func,f,argptr) STREE *st; FVECT t0,t1,t2; - int (*func)(); - int *arg1,arg2; + int (*func)(),*f; + int *argptr; { int i; - QUADTREE *rootptr; - FVECT q0,q1,q2; + QUADTREE root; + FVECT n0,n1,n2; - for(i=0; i < 4; i++) + /* Calcuate the edge normals for tri */ + VCROSS(n0,t1,t0); + VCROSS(n1,t2,t1); + VCROSS(n2,t0,t2); + + for(i=0; i < ST_NUM_ROOT_NODES; i++) { - rootptr = ST_NTH_ROOT_PTR(st,i); - stNth_base_verts(st,i,q0,q1,q2); - qtVisit_tri_interior(rootptr,q0,q1,q2,t0,t1,t2,0,func,arg1,arg2); + root = ST_NTH_ROOT(st,i); + ST_NTH_ROOT(st,i) = qtVisit_tri_interior(root,ST_NTH_V(st,i,0), + ST_NTH_V(st,i,1),ST_NTH_V(st,i,2),t0,t1,t2,n0,n1,n2,0,func,f,argptr); + } } - +/* Visit nodes intersected by tri 't0,t1,t2'.Apply 'edge_func(arg1,arg2,arg3)', + to those nodes intersected by edges, and interior_func to ALL nodes: + ie some Nodes will be visited more than once + */ int -stApply_to_tri(st,t0,t1,t2,func,arg1,arg2) +stApply_to_tri(st,t0,t1,t2,edge_func,tri_func,argptr) STREE *st; FVECT t0,t1,t2; - int (*func)(); - int *arg1,arg2; + int (*edge_func)(),(*tri_func)(); + int *argptr; { int f; FVECT dir; @@ -560,45 +299,19 @@ stApply_to_tri(st,t0,t1,t2,func,arg1,arg2) /* First add all of the leaf cells lying on the triangle perimeter: mark all cells seen on the way */ - qtClearAllFlags(); /* clear all quadtree branch flags */ f = 0; - VSUB(dir,t1,t0); - stTrace_edge(st,t0,dir,1.0,func,arg1,arg2); - VSUB(dir,t2,t1); - stTrace_edge(st,t1,dir,1.0,func,arg1,arg2); - VSUB(dir,t0,t2); - stTrace_edge(st,t2,dir,1.0,func,arg1,arg2); - /* Now visit interior */ - stVisit_tri_interior(st,t0,t1,t2,func,arg1,arg2); + /* Visit cells along edges of the tri */ + stVisit_tri_edges(st,t0,t1,t2,edge_func,&f,argptr); + + /* Now visit All cells interior */ + if(QT_FLAG_FILL_TRI(f) || QT_FLAG_UPDATE(f)) + stVisit_tri(st,t0,t1,t2,tri_func,&f,argptr); } -int -stUpdate_tri(st,t_id,t0,t1,t2,edge_func,interior_func) - STREE *st; - int t_id; - FVECT t0,t1,t2; - int (*edge_func)(),(*interior_func)(); -{ - int f; - FVECT dir; - - /* First add all of the leaf cells lying on the triangle perimeter: - mark all cells seen on the way - */ - ST_CLEAR_FLAGS(st); - f = 0; - /* Visit cells along edges of the tri */ - - stVisit_tri_edges2(st,t0,t1,t2,edge_func,&f,t_id); - - /* Now visit interior */ - if(QT_FLAG_FILL_TRI(f) || QT_FLAG_UPDATE(f)) - stVisit_tri_interior(st,t0,t1,t2,interior_func,&f,t_id); -}
