--- ray/src/hd/sm_stree.c 1998/08/25 11:03:27 3.3 +++ ray/src/hd/sm_stree.c 1998/12/28 18:07:36 3.8 @@ -6,312 +6,748 @@ static char SCCSid[] = "$SunId$ SGI"; /* * sm_stree.c + * An stree (spherical quadtree) is defined by an octahedron in + * canonical form,and a world center point. Each face of the + * octahedron is adaptively subdivided as a planar triangular quadtree. + * World space geometry is projected onto the quadtree faces from the + * sphere center. */ #include "standard.h" -#include "object.h" - +#include "sm_list.h" +#include "sm_flag.h" #include "sm_geom.h" +#include "sm_qtree.h" #include "sm_stree.h" +#ifdef TEST_DRIVER +extern FVECT Pick_point[500],Pick_v0[500],Pick_v1[500],Pick_v2[500]; +extern int Pick_cnt; +#endif +/* octahedron coordinates */ +FVECT stDefault_base[6] = { {1.,0.,0.},{0.,1.,0.}, {0.,0.,1.}, + {-1.,0.,0.},{0.,-1.,0.},{0.,0.,-1.}}; +/* octahedron triangle vertices */ +int stBase_verts[8][3] = { {0,1,2},{3,1,2},{0,4,2},{3,4,2}, + {0,1,5},{3,1,5},{0,4,5},{3,4,5}}; +/* octahedron triangle nbrs ; nbr i is the face opposite vertex i*/ +int stBase_nbrs[8][3] = { {1,2,4},{0,3,5},{3,0,6},{2,1,7}, + {5,6,0},{4,7,1},{7,4,2},{6,5,3}}; +int stRoot_indices[8][3] = {{1,1,1},{-1,1,1},{1,-1,1},{-1,-1,1}, + {1,1,-1},{-1,1,-1},{1,-1,-1},{-1,-1,-1}}; +/* + +z y -z y + | | + 1 | 0 5 | 4 +______|______ x _______|______ x + 3 | 2 7 | 6 + | | -/* Define 4 vertices on the sphere to create a tetrahedralization on - the sphere: triangles are as follows: - (0,1,2),(0,2,3), (0,3,1), (1,3,2) +Nbrs + +z y -z y + /0|1\ /1|0\ + 5 / | \ 4 / | \ + /(1)|(0)\ 1 /(5)|(4)\ 0 + / | \ / | \ + /2 1|0 2\ /2 0|1 2\ +/------|------\x /------|------\x +\0 1|2 0/ \0 2|2 1/ + \ | / \ | / + 7\ (3)|(2) / 6 3 \ (7)|(6) / 2 + \ | / \ | / + \ 2|1 / \ 1|0 / */ -FVECT stDefault_base[4] = { {SQRT3_INV, SQRT3_INV, SQRT3_INV}, - {-SQRT3_INV, -SQRT3_INV, SQRT3_INV}, - {-SQRT3_INV, SQRT3_INV, -SQRT3_INV}, - {SQRT3_INV, -SQRT3_INV, -SQRT3_INV}}; -int stTri_verts[4][3] = { {2,1,0}, - {3,2,0}, - {1,3,0}, - {2,3,1}}; -stNth_base_verts(st,i,v1,v2,v3) +stInit(st) STREE *st; -int i; -FVECT v1,v2,v3; { - VCOPY(v1,ST_NTH_BASE(st,stTri_verts[i][0])); - VCOPY(v2,ST_NTH_BASE(st,stTri_verts[i][1])); - VCOPY(v3,ST_NTH_BASE(st,stTri_verts[i][2])); + int i,j; + + ST_TOP_QT(st) = qtAlloc(); + ST_BOTTOM_QT(st) = qtAlloc(); + /* Clear the children */ + + QT_CLEAR_CHILDREN(ST_TOP_QT(st)); + QT_CLEAR_CHILDREN(ST_BOTTOM_QT(st)); } -/* Frees the 4 quadtrees rooted at st */ +/* Frees the children of the 2 quadtrees rooted at st, + Does not free root nodes: just clears +*/ stClear(st) + STREE *st; +{ + qtDone(); + stInit(st); +} + +/* Allocates a stree structure and creates octahedron base */ +STREE +*stAlloc(st) STREE *st; { - int i; + int i,m; + FVECT v0,v1,v2; + FVECT n; + + if(!st) + if(!(st = (STREE *)malloc(sizeof(STREE)))) + error(SYSTEM,"stAlloc(): Unable to allocate memory\n"); - /* stree always has 4 children corresponding to the base tris - */ - for (i = 0; i < 4; i++) - qtFree(ST_NTH_ROOT(st, i)); + /* Allocate the top and bottom quadtree root nodes */ + stInit(st); + + + /* will go ********************************************/ + /* Set the octahedron base */ + ST_SET_BASE(st,stDefault_base); - QT_CLEAR_CHILDREN(ST_ROOT(st)); + /* Calculate octahedron face and edge normals */ + for(i=0; i < ST_NUM_ROOT_NODES; i++) + { + VCOPY(v0,ST_NTH_V(st,i,0)); + VCOPY(v1,ST_NTH_V(st,i,1)); + VCOPY(v2,ST_NTH_V(st,i,2)); + tri_plane_equation(v0,v1,v2, &ST_NTH_PLANE(st,i),FALSE); + m = max_index(FP_N(ST_NTH_PLANE(st,i)),NULL); + FP_X(ST_NTH_PLANE(st,i)) = (m+1)%3; + FP_Y(ST_NTH_PLANE(st,i)) = (m+2)%3; + FP_Z(ST_NTH_PLANE(st,i)) = m; + VCROSS(ST_EDGE_NORM(st,i,0),v0,v1); + VCROSS(ST_EDGE_NORM(st,i,1),v1,v2); + VCROSS(ST_EDGE_NORM(st,i,2),v2,v0); + } + /*****************************************************************/ + return(st); } +#define BARY_INT(v,b) if((v)>2.0) (b) = MAXBCOORD;else \ + if((v)<-2.0) (b)=-MAXBCOORD;else (b)=(BCOORD)((v)*MAXBCOORD2); -STREE -*stInit(st,center,base) -STREE *st; -FVECT center,base[4]; +vert_to_qt_frame(root,v,b) +int root; +FVECT v; +BCOORD b[3]; { + int i; + double scale; + double d0,d1,d2; - if(base) - ST_SET_BASE(st,base); + if(STR_NTH_INDEX(root,0)==-1) + d0 = -v[0]; else - ST_SET_BASE(st,stDefault_base); + d0 = v[0]; + if(STR_NTH_INDEX(root,1)==-1) + d1 = -v[1]; + else + d1 = v[1]; + if(STR_NTH_INDEX(root,2)==-1) + d2 = -v[2]; + else + d2 = v[2]; - ST_SET_CENTER(st,center); - stClear(st); + /* Plane is now x+y+z = 1 - intersection of pt ray is qtv/den */ + scale = 1.0/ (d0 + d1 + d2); + d0 *= scale; + d1 *= scale; + d2 *= scale; - return(st); + BARY_INT(d0,b[0]) + BARY_INT(d1,b[1]) + BARY_INT(d2,b[2]) } -/* "base" defines 4 vertices on the sphere to create a tetrahedralization on - the sphere: triangles are as follows:(0,1,2),(0,2,3), (0,3,1), (1,3,2) - if base is null: does default. - */ -STREE -*stAlloc(st) -STREE *st; + +ray_to_qt_frame(root,v,dir,b,db) +int root; +FVECT v,dir; +BCOORD b[3],db[3]; { int i; + double scale; + double d0,d1,d2; + double dir0,dir1,dir2; - if(!st) - st = (STREE *)malloc(sizeof(STREE)); + if(STR_NTH_INDEX(root,0)==-1) + { + d0 = -v[0]; + dir0 = -dir[0]; + } + else + { + d0 = v[0]; + dir0 = dir[0]; + } + if(STR_NTH_INDEX(root,1)==-1) + { + d1 = -v[1]; + dir1 = -dir[1]; + } + else + { + d1 = v[1]; + dir1 = dir[1]; + } + if(STR_NTH_INDEX(root,2)==-1) + { + d2 = -v[2]; + dir2 = -dir[2]; + } + else + { + d2 = v[2]; + dir2 = dir[2]; + } + /* Plane is now x+y+z = 1 - intersection of pt ray is qtv/den */ + scale = 1.0/ (d0 + d1 + d2); + d0 *= scale; + d1 *= scale; + d2 *= scale; - ST_ROOT(st) = qtAlloc(); - - QT_CLEAR_CHILDREN(ST_ROOT(st)); + /* Calculate intersection point of orig+dir: This calculation is done + after the origin is projected into the plane in order to constrain + the projection( i.e. the size of the projection of the unit direction + vector translated to the origin depends on how close + the origin is to the view center + */ + /* Must divide by at least root2 to insure that projection will fit + int [-2,2] bounds: assumed length is 1: therefore greatest projection + from endpoint of triangle is at 45 degrees or projected length of root2 + */ + dir0 = d0 + dir0*0.5; + dir1 = d1 + dir1*0.5; + dir2 = d2 + dir2*0.5; - return(st); -} + scale = 1.0/ (dir0 + dir1 + dir2); + dir0 *= scale; + dir1 *= scale; + dir2 *= scale; + BARY_INT(d0,b[0]) + BARY_INT(d1,b[1]) + BARY_INT(d2,b[2]) + BARY_INT(dir0,db[0]) + BARY_INT(dir1,db[1]) + BARY_INT(dir2,db[2]) -/* Find location of sample point in the DAG and return lowest level - containing triangle. "type" indicates whether the point was found - to be in interior to the triangle: GT_FACE, on one of its - edges GT_EDGE or coinciding with one of its vertices GT_VERTEX. - "which" specifies which vertex (0,1,2) or edge (0=v0v1, 1 = v1v2, 2 = v21) -*/ -int -stPoint_locate(st,npt,type,which) - STREE *st; - FVECT npt; - char *type,*which; + db[0] -= b[0]; + db[1] -= b[1]; + db[2] -= b[2]; +} + +qt_frame_to_vert(root,b,v) +int root; +BCOORD b[3]; +FVECT v; { - int i,d,j,id; - QUADTREE *rootptr,*qtptr; - FVECT v1,v2,v3; - OBJECT os[MAXSET+1],*optr; - char w; - FVECT p0,p1,p2; + int i; + double d0,d1,d2; - /* Test each of the root triangles against point id */ - for(i=0; i < 4; i++) - { - rootptr = ST_NTH_ROOT_PTR(st,i); - stNth_base_verts(st,i,v1,v2,v3); - /* Return tri that p falls in */ - qtptr = qtRoot_point_locate(rootptr,v1,v2,v3,npt,NULL,NULL,NULL); - if(!qtptr) - continue; - /* Get the set */ - qtgetset(os,*qtptr); - for (j = QT_SET_CNT(os),optr = QT_SET_PTR(os); j > 0; j--) - { - /* Find the first triangle that pt falls */ - id = QT_SET_NEXT_ELEM(optr); - qtTri_verts_from_id(id,p0,p1,p2); - d = test_single_point_against_spherical_tri(p0,p1,p2,npt,&w); - if(d) - { - if(type) - *type = d; - if(which) - *which = w; - return(id); - } - } - } - if(which) - *which = 0; - if(type) - *type = 0; - return(EMPTY); + d0 = b[0]/(double)MAXBCOORD2; + d1 = b[1]/(double)MAXBCOORD2; + d2 = b[2]/(double)MAXBCOORD2; + + if(STR_NTH_INDEX(root,0)==-1) + v[0] = -d0; + else + v[0] = d0; + if(STR_NTH_INDEX(root,1)==-1) + v[1] = -d1; + else + v[1] = d1; + if(STR_NTH_INDEX(root,2)==-1) + v[2] = -d2; + else + v[2] = d2; } + +/* Return quadtree leaf node containing point 'p'*/ QUADTREE -*stPoint_locate_cell(st,p,t0,t1,t2) +stPoint_locate(st,p) STREE *st; FVECT p; - FVECT t0,t1,t2; { - int i,d; - QUADTREE *rootptr,*qtptr; - FVECT v0,v1,v2; + QUADTREE qt; + BCOORD bcoordi[3]; + int i; + /* Find root quadtree that contains p */ + i = stLocate_root(p); + qt = ST_ROOT_QT(st,i); - /* Test each of the root triangles against point id */ - for(i=0; i < 4; i++) - { - rootptr = ST_NTH_ROOT_PTR(st,i); - stNth_base_verts(st,i,v0,v1,v2); - /* Return tri that p falls in */ - qtptr = qtRoot_point_locate(rootptr,v0,v1,v2,p,t0,t1,t2); - /* NOTE: For now return only one triangle */ - if(qtptr) - return(qtptr); - } /* Point not found */ - return(NULL); + /* Will return lowest level triangle containing point: It the + point is on an edge or vertex: will return first associated + triangle encountered in the child traversal- the others can + be derived using triangle adjacency information + */ + if(QT_IS_TREE(qt)) + { + vert_to_qt_frame(i,p,bcoordi); + i = bary_child(bcoordi); + return(qtLocate(QT_NTH_CHILD(qt,i),bcoordi)); + } + else + return(qt); } +static unsigned int nbr_b[8][3] ={{2,4,16},{1,8,32},{8,1,64},{4,2,128}, + {32,64,1},{16,128,2},{128,16,4},{64,32,8}}; +unsigned int +stTri_cells(st,v) + STREE *st; + FVECT v[3]; +{ + unsigned int cells,cross; + unsigned int vcell[3]; + double t0,t1; + int i,inext; -QUADTREE -*stAdd_tri_from_pt(st,p,t_id) - STREE *st; - FVECT p; - int t_id; + /* First find base cells that tri vertices are in (0-7)*/ + vcell[0] = stLocate_root(v[0]); + vcell[1] = stLocate_root(v[1]); + vcell[2] = stLocate_root(v[2]); + + /* If all in same cell- return that bit only */ + if(vcell[0] == vcell[1] && vcell[1] == vcell[2]) + return( 1 << vcell[0]); + + cells = 0; + for(i=0;i<3; i++) + { + if(i==2) + inext = 0; + else + inext = i+1; + /* Mark cell containing initial vertex */ + cells |= 1 << vcell[i]; + + /* Take the exclusive or: will have bits set where edge crosses axis=0*/ + cross = vcell[i] ^ vcell[inext]; + /* If crosses 2 planes: then have 2 options for edge crossing-pick closest + otherwise just hits two*/ + /* Neighbors are zyx */ + switch(cross){ + case 3: /* crosses x=0 and y=0 */ + t0 = -v[i][0]/(v[inext][0]-v[i][0]); + t1 = -v[i][1]/(v[inext][1]-v[i][1]); + if(t0==t1) + break; + else if(t0 < t1) + cells |= nbr_b[vcell[i]][0]; + else + cells |= nbr_b[vcell[i]][1]; + break; + case 5: /* crosses x=0 and z=0 */ + t0 = -v[i][0]/(v[inext][0]-v[i][0]); + t1 = -v[i][2]/(v[inext][2]-v[i][2]); + if(t0==t1) + break; + else if(t0 < t1) + cells |= nbr_b[vcell[i]][0]; + else + cells |=nbr_b[vcell[i]][2]; + + break; + case 6:/* crosses z=0 and y=0 */ + t0 = -v[i][2]/(v[inext][2]-v[i][2]); + t1 = -v[i][1]/(v[inext][1]-v[i][1]); + if(t0==t1) + break; + else if(t0 < t1) + { + cells |= nbr_b[vcell[i]][2]; + } + else + { + cells |=nbr_b[vcell[i]][1]; + } + break; + case 7: + error(CONSISTENCY," Insert:Edge shouldnt be able to span 3 cells"); + break; + } + } + return(cells); +} + + +stRoot_trace_ray(qt,root,orig,dir,nextptr,func,f) + QUADTREE qt; + int root; + FVECT orig,dir; + int *nextptr; + FUNC func; + int *f; { - int i,d; - QUADTREE *rootptr,*qtptr; - FVECT v0,v1,v2; + double br[3]; + BCOORD bi[3],dbi[3]; + + /* Project the origin onto the root node plane */ + /* Find the intersection point of the origin */ + ray_to_qt_frame(root,orig,dir,bi,dbi); - - /* Test each of the root triangles against point id */ - for(i=0; i < 4; i++) - { - rootptr = ST_NTH_ROOT_PTR(st,i); - stNth_base_verts(st,i,v0,v1,v2); - /* Return tri that p falls in */ - qtptr = qtRoot_add_tri_from_point(rootptr,v0,v1,v2,p,t_id); - /* NOTE: For now return only one triangle */ - if(qtptr) - return(qtptr); - } /* Point not found */ - return(NULL); + /* trace the ray starting with this node */ + qtTrace_ray(qt,bi,dbi[0],dbi[1],dbi[2],nextptr,0,0,func,f); + if(!QT_FLAG_IS_DONE(*f)) + qt_frame_to_vert(root,bi,orig); + } +/* Trace ray 'orig-dir' through stree and apply 'func(qtptr,f,argptr)' at each + node that it intersects +*/ int -stAdd_tri(st,id,v0,v1,v2) +stTrace_ray(st,orig,dir,func) + STREE *st; + FVECT orig,dir; + FUNC func; +{ + int next,last,i,f=0; + QUADTREE qt; + FVECT o,n,v; + double pd,t,d; + + VCOPY(o,orig); +#ifdef TEST_DRIVER + Pick_cnt=0; +#endif; + /* Find the qt node that o falls in */ + i = stLocate_root(o); + qt = ST_ROOT_QT(st,i); + + stRoot_trace_ray(qt,i,o,dir,&next,func,&f); + + if(QT_FLAG_IS_DONE(f)) + return(TRUE); + /* + d = DOT(orig,dir)/sqrt(DOT(orig,orig)); + VSUM(v,orig,dir,-d); + */ + /* Crossed over to next cell: id = nbr */ + while(1) + { + /* test if ray crosses plane between this quadtree triangle and + its neighbor- if it does then find intersection point with + ray and plane- this is the new origin + */ + if(next == INVALID) + return(FALSE); + /* + if(DOT(o,v) < 0.0) + return(FALSE); + */ + i = stBase_nbrs[i][next]; + qt = ST_ROOT_QT(st,i); + stRoot_trace_ray(qt,i,o,dir,&next,func,&f); + if(QT_FLAG_IS_DONE(f)) + return(TRUE); + } +} + + +stVisit_poly(st,verts,l,root,func) STREE *st; -int id; -FVECT v0,v1,v2; +FVECT *verts; +LIST *l; +unsigned int root; +FUNC func; { - - int i,found; - QUADTREE *rootptr; - FVECT t0,t1,t2; + int id0,id1,id2; + FVECT tri[3]; - found = 0; - for(i=0; i < 4; i++) + id0 = pop_list(&l); + id1 = pop_list(&l); + while(l) { - rootptr = ST_NTH_ROOT_PTR(st,i); - stNth_base_verts(st,i,t0,t1,t2); - found |= qtRoot_add_tri(rootptr,id,v0,v1,v2,t0,t1,t2,0); + id2 = pop_list(&l); + VCOPY(tri[0],verts[id0]); + VCOPY(tri[1],verts[id1]); + VCOPY(tri[2],verts[id2]); + stRoot_visit_tri(st,root,tri,func); + id1 = id2; } - return(found); } -int -stApply_to_tri_cells(st,v0,v1,v2,func,arg) -STREE *st; -FVECT v0,v1,v2; -int (*func)(); -char *arg; +stVisit_clip(st,i,verts,vcnt,l,cell,func) + STREE *st; + int i; + FVECT *verts; + int *vcnt; + LIST *l; + unsigned int cell; + FUNC func; { - int i,found; - QUADTREE *rootptr; - FVECT t0,t1,t2; - found = 0; - for(i=0; i < 4; i++) + LIST *labove,*lbelow,*endb,*enda; + int last = -1; + int id,last_id; + int first,first_id; + unsigned int cellb; + + labove = lbelow = NULL; + enda = endb = NULL; + while(l) { - rootptr = ST_NTH_ROOT_PTR(st,i); - stNth_base_verts(st,i,t0,t1,t2); - found |= qtApply_to_tri_cells(rootptr,v0,v1,v2,t0,t1,t2,func,arg); + id = pop_list(&l); + if(ZERO(verts[id][i])) + { + if(last==-1) + {/* add below and above */ + first = 2; + first_id= id; + } + lbelow=add_data(lbelow,id,&endb); + labove=add_data(labove,id,&enda); + last_id = id; + last = 2; + continue; + } + if(verts[id][i] < 0) + { + if(last != 1) + { + lbelow=add_data(lbelow,id,&endb); + if(last==-1) + { + first = 0; + first_id = id; + } + last_id = id; + last = 0; + continue; + } + /* intersect_edges */ + intersect_edge_coord_plane(verts[last_id],verts[id],i,verts[*vcnt]); + /*newpoint goes to above and below*/ + lbelow=add_data(lbelow,*vcnt,&endb); + lbelow=add_data(lbelow,id,&endb); + labove=add_data(labove,*vcnt,&enda); + last = 0; + last_id = id; + (*vcnt)++; + } + else + { + if(last != 0) + { + labove=add_data(labove,id,&enda); + if(last==-1) + { + first = 1; + first_id = id; + } + last_id = id; + last = 1; + continue; + } + /* intersect_edges */ + /*newpoint goes to above and below*/ + intersect_edge_coord_plane(verts[last_id],verts[id],i,verts[*vcnt]); + lbelow=add_data(lbelow,*vcnt,&endb); + labove=add_data(labove,*vcnt,&enda); + labove=add_data(labove,id,&enda); + last_id = id; + (*vcnt)++; + last = 1; + } } - return(found); + if(first != 2 && first != last) + { + intersect_edge_coord_plane(verts[id],verts[first_id],i,verts[*vcnt]); + /*newpoint goes to above and below*/ + lbelow=add_data(lbelow,*vcnt,&endb); + labove=add_data(labove,*vcnt,&enda); + (*vcnt)++; + + } + if(i==2) + { + if(lbelow) + { + if(LIST_NEXT(lbelow) && LIST_NEXT(LIST_NEXT(lbelow))) + { + cellb = cell | (1 << i); + stVisit_poly(st,verts,lbelow,cellb,func); + } + else + free_list(lbelow); + } + if(labove) + { + if(LIST_NEXT(labove) && LIST_NEXT(LIST_NEXT(labove))) + stVisit_poly(st,verts,labove,cell,func); + else + free_list(labove); + } + } + else + { + if(lbelow) + { + if(LIST_NEXT(lbelow) && LIST_NEXT(LIST_NEXT(lbelow))) + { + cellb = cell | (1 << i); + stVisit_clip(st,i+1,verts,vcnt,lbelow,cellb,func); + } + else + free_list(lbelow); + } + if(labove) + { + if(LIST_NEXT(labove) && LIST_NEXT(LIST_NEXT(labove))) + stVisit_clip(st,i+1,verts,vcnt,labove,cell,func); + else + free_list(labove); + } + } + } +stVisit(st,tri,func) + STREE *st; + FVECT tri[3]; + FUNC func; +{ + int r0,r1,r2; + LIST *l; + r0 = stLocate_root(tri[0]); + r1 = stLocate_root(tri[1]); + r2 = stLocate_root(tri[2]); + if(r0 == r1 && r1==r2) + stRoot_visit_tri(st,r0,tri,func); + else + { + FVECT verts[ST_CLIP_VERTS]; + int cnt; + VCOPY(verts[0],tri[0]); + VCOPY(verts[1],tri[1]); + VCOPY(verts[2],tri[2]); + + l = add_data(NULL,0,NULL); + l = add_data(l,1,NULL); + l = add_data(l,2,NULL); + cnt = 3; + stVisit_clip(st,0,verts,&cnt,l,0,func); + } +} -int -stRemove_tri(st,id,v0,v1,v2) -STREE *st; -int id; -FVECT v0,v1,v2; + +/* New Insertion code!!! */ + + +BCOORD qtRoot[3][3] = { {MAXBCOORD2,0,0},{0,MAXBCOORD2,0},{0,0,MAXBCOORD2}}; + + +convert_tri_to_frame(root,tri,b0,b1,b2,db10,db21,db02) +int root; +FVECT tri[3]; +BCOORD b0[3],b1[3],b2[3]; +BCOORD db10[3],db21[3],db02[3]; { - - int i,found; - QUADTREE *rootptr; - FVECT t0,t1,t2; + /* Project the vertex into the qtree plane */ + vert_to_qt_frame(root,tri[0],b0); + vert_to_qt_frame(root,tri[1],b1); + vert_to_qt_frame(root,tri[2],b2); - found = 0; - for(i=0; i < 4; i++) - { - rootptr = ST_NTH_ROOT_PTR(st,i); - stNth_base_verts(st,i,t0,t1,t2); - found |= qtRemove_tri(rootptr,id,v0,v1,v2,t0,t1,t2); - } - return(found); + /* calculate triangle edge differences in new frame */ + db10[0] = b1[0] - b0[0]; db10[1] = b1[1] - b0[1]; db10[2] = b1[2] - b0[2]; + db21[0] = b2[0] - b1[0]; db21[1] = b2[1] - b1[1]; db21[2] = b2[2] - b1[2]; + db02[0] = b0[0] - b2[0]; db02[1] = b0[1] - b2[1]; db02[2] = b0[2] - b2[2]; } +QUADTREE +stRoot_insert_tri(st,root,tri,f) + STREE *st; + int root; + FVECT tri[3]; + FUNC f; +{ + BCOORD b0[3],b1[3],b2[3]; + BCOORD db10[3],db21[3],db02[3]; + unsigned int s0,s1,s2,sq0,sq1,sq2; + QUADTREE qt; + /* Map the triangle vertices into the canonical barycentric frame */ + convert_tri_to_frame(root,tri,b0,b1,b2,db10,db21,db02); + /* Calculate initial sidedness info */ + SIDES_GTR(b0,b1,b2,s0,s1,s2,qtRoot[1][0],qtRoot[0][1],qtRoot[0][2]); + SIDES_GTR(b0,b1,b2,sq0,sq1,sq2,qtRoot[0][0],qtRoot[1][1],qtRoot[2][2]); -#if 0 -int -stAdd_tri_opt(st,id,v0,v1,v2) -STREE *st; -int id; -FVECT v0,v1,v2; + qt = ST_ROOT_QT(st,root); + /* Visit cells that triangle intersects */ + qt = qtInsert_tri(root,qt,qtRoot[0],qtRoot[1],qtRoot[2], + b0,b1,b2,db10,db21,db02,MAXBCOORD2 >> 1,s0,s1,s2, sq0,sq1,sq2,f,0); + + return(qt); +} + +stRoot_visit_tri(st,root,tri,f) + STREE *st; + int root; + FVECT tri[3]; + FUNC f; { + BCOORD b0[3],b1[3],b2[3]; + BCOORD db10[3],db21[3],db02[3]; + unsigned int s0,s1,s2,sq0,sq1,sq2; + QUADTREE qt; + + /* Map the triangle vertices into the canonical barycentric frame */ + convert_tri_to_frame(root,tri,b0,b1,b2,db10,db21,db02); + + /* Calculate initial sidedness info */ + SIDES_GTR(b0,b1,b2,s0,s1,s2,qtRoot[1][0],qtRoot[0][1],qtRoot[0][2]); + SIDES_GTR(b0,b1,b2,sq0,sq1,sq2,qtRoot[0][0],qtRoot[1][1],qtRoot[2][2]); + + qt = ST_ROOT_QT(st,root); + QT_SET_FLAG(ST_QT(st,root)); + /* Visit cells that triangle intersects */ + qtVisit_tri(root,qt,qtRoot[0],qtRoot[1],qtRoot[2], + b0,b1,b2,db10,db21,db02,MAXBCOORD2 >> 1,s0,s1,s2, sq0,sq1,sq2,f); + +} + +stInsert_tri(st,tri,f) + STREE *st; + FVECT tri[3]; + FUNC f; +{ + unsigned int cells,which; + int root; - int i,found; - QUADTREE *qtptr; - FVECT pt,t0,t1,t2; - /* First add all of the leaf cells lying on the triangle perimeter: - mark all cells seen on the way - */ - /* clear all of the flags */ - qtClearAllFlags(); /* clear all quadtree branch flags */ + /* calculate entry/exit points of edges through the cells */ + cells = stTri_cells(st,tri); - /* Now trace each triangle edge-marking cells visited, and adding tri to - the leafs - */ - stAdd_tri_from_pt(st,v0,id,t0,t1,t2); - /* Find next cell that projection of ray intersects */ - VCOPY(pt,v0); - /* NOTE: Check if in same cell */ - while(traceEdge(pt,v1,t0,t1,t2,pt)) + /* For each cell that quadtree intersects: Map the triangle vertices into + the canonical barycentric frame of (1,0,0), (0,1,0),(0,0,1). Insert + by first doing a trivial reject on the interior nodes, and then a + tri/tri intersection at the leaf nodes. + */ + for(root=0,which=1; root < ST_NUM_ROOT_NODES; root++,which <<= 1) { - stAdd_tri_from_pt(st,pt,id,t0,t1,t2); - traceEdge(pt,v1,t0,t1,t2,pt); + /* For each of the quadtree roots: check if marked as intersecting tri*/ + if(cells & which) + /* Visit tri cells */ + ST_ROOT_QT(st,root) = stRoot_insert_tri(st,root,tri,f); } - while(traceEdge(pt,v2,t0,t1,t2,pt)) - { - stAdd_tri_from_pt(st,pt,id,t0,t1,t2); - traceEdge(pt,v2,t0,t1,t2,pt); - } - while(traceEdge(pt,v0,t0,t1,t2,pt)) - { - stAdd_tri_from_pt(st,pt,id,t0,t1,t2); - traceEdge(pt,v2,t0,t1,t2,pt); - } - - /* NOTE: Optimization: if <= 2 cells added: dont need to fill */ - /* Traverse: follow nodes with flag set or one vertex in triangle */ - } -#endif + + + + + + + + + +
