--- ray/src/hd/sm_stree.c 1998/08/19 17:45:24 3.1 +++ ray/src/hd/sm_stree.c 1998/08/25 11:03:27 3.3 @@ -107,23 +107,23 @@ stPoint_locate(st,npt,type,which) char *type,*which; { int i,d,j,id; - QUADTREE *rootptr,qt; + QUADTREE *rootptr,*qtptr; FVECT v1,v2,v3; OBJECT os[MAXSET+1],*optr; - FVECT p0,p1,p2; char w; - + FVECT p0,p1,p2; + /* Test each of the root triangles against point id */ for(i=0; i < 4; i++) { rootptr = ST_NTH_ROOT_PTR(st,i); stNth_base_verts(st,i,v1,v2,v3); /* Return tri that p falls in */ - qt = qtPoint_locate(rootptr,v1,v2,v3,npt,type,which,p0,p1,p2); - if(QT_IS_EMPTY(qt)) + qtptr = qtRoot_point_locate(rootptr,v1,v2,v3,npt,NULL,NULL,NULL); + if(!qtptr) continue; /* Get the set */ - qtgetset(os,qt); + qtgetset(os,*qtptr); for (j = QT_SET_CNT(os),optr = QT_SET_PTR(os); j > 0; j--) { /* Find the first triangle that pt falls */ @@ -147,14 +147,14 @@ stPoint_locate(st,npt,type,which) return(EMPTY); } -int -stPoint_locate_cell(st,p,p0,p1,p2,type,which) +QUADTREE +*stPoint_locate_cell(st,p,t0,t1,t2) STREE *st; - FVECT p,p0,p1,p2; - char *type,*which; + FVECT p; + FVECT t0,t1,t2; { int i,d; - QUADTREE *rootptr,qt; + QUADTREE *rootptr,*qtptr; FVECT v0,v1,v2; @@ -164,35 +164,57 @@ stPoint_locate_cell(st,p,p0,p1,p2,type,which) rootptr = ST_NTH_ROOT_PTR(st,i); stNth_base_verts(st,i,v0,v1,v2); /* Return tri that p falls in */ - qt = qtPoint_locate(rootptr,v0,v1,v2,p,type,which,p0,p1,p2); + qtptr = qtRoot_point_locate(rootptr,v0,v1,v2,p,t0,t1,t2); /* NOTE: For now return only one triangle */ - if(!QT_IS_EMPTY(qt)) - return(qt); + if(qtptr) + return(qtptr); } /* Point not found */ - if(which) - *which = 0; - if(type) - *type = 0; - return(EMPTY); + return(NULL); } + +QUADTREE +*stAdd_tri_from_pt(st,p,t_id) + STREE *st; + FVECT p; + int t_id; +{ + int i,d; + QUADTREE *rootptr,*qtptr; + FVECT v0,v1,v2; + + + /* Test each of the root triangles against point id */ + for(i=0; i < 4; i++) + { + rootptr = ST_NTH_ROOT_PTR(st,i); + stNth_base_verts(st,i,v0,v1,v2); + /* Return tri that p falls in */ + qtptr = qtRoot_add_tri_from_point(rootptr,v0,v1,v2,p,t_id); + /* NOTE: For now return only one triangle */ + if(qtptr) + return(qtptr); + } /* Point not found */ + return(NULL); +} + int -stAdd_tri(st,id,v1,v2,v3) +stAdd_tri(st,id,v0,v1,v2) STREE *st; int id; -FVECT v1,v2,v3; +FVECT v0,v1,v2; { int i,found; QUADTREE *rootptr; - FVECT t1,t2,t3; - + FVECT t0,t1,t2; + found = 0; for(i=0; i < 4; i++) { rootptr = ST_NTH_ROOT_PTR(st,i); - stNth_base_verts(st,i,t1,t2,t3); - found |= qtAdd_tri(rootptr,id,v1,v2,v3,t1,t2,t3,0); + stNth_base_verts(st,i,t0,t1,t2); + found |= qtRoot_add_tri(rootptr,id,v0,v1,v2,t0,t1,t2,0); } return(found); } @@ -246,3 +268,50 @@ FVECT v0,v1,v2; +#if 0 +int +stAdd_tri_opt(st,id,v0,v1,v2) +STREE *st; +int id; +FVECT v0,v1,v2; +{ + + int i,found; + QUADTREE *qtptr; + FVECT pt,t0,t1,t2; + + /* First add all of the leaf cells lying on the triangle perimeter: + mark all cells seen on the way + */ + /* clear all of the flags */ + qtClearAllFlags(); /* clear all quadtree branch flags */ + + /* Now trace each triangle edge-marking cells visited, and adding tri to + the leafs + */ + stAdd_tri_from_pt(st,v0,id,t0,t1,t2); + /* Find next cell that projection of ray intersects */ + VCOPY(pt,v0); + /* NOTE: Check if in same cell */ + while(traceEdge(pt,v1,t0,t1,t2,pt)) + { + stAdd_tri_from_pt(st,pt,id,t0,t1,t2); + traceEdge(pt,v1,t0,t1,t2,pt); + } + while(traceEdge(pt,v2,t0,t1,t2,pt)) + { + stAdd_tri_from_pt(st,pt,id,t0,t1,t2); + traceEdge(pt,v2,t0,t1,t2,pt); + } + while(traceEdge(pt,v0,t0,t1,t2,pt)) + { + stAdd_tri_from_pt(st,pt,id,t0,t1,t2); + traceEdge(pt,v2,t0,t1,t2,pt); + } + + /* NOTE: Optimization: if <= 2 cells added: dont need to fill */ + /* Traverse: follow nodes with flag set or one vertex in triangle */ + +} + +#endif
