--- ray/src/hd/sm_stree.c 1998/10/06 18:18:54 3.6 +++ ray/src/hd/sm_stree.c 1998/12/28 18:07:36 3.8 @@ -13,6 +13,7 @@ static char SCCSid[] = "$SunId$ SGI"; * sphere center. */ #include "standard.h" +#include "sm_list.h" #include "sm_flag.h" #include "sm_geom.h" #include "sm_qtree.h" @@ -26,24 +27,48 @@ extern int Pick_cnt; FVECT stDefault_base[6] = { {1.,0.,0.},{0.,1.,0.}, {0.,0.,1.}, {-1.,0.,0.},{0.,-1.,0.},{0.,0.,-1.}}; /* octahedron triangle vertices */ -int stBase_verts[8][3] = { {0,1,2},{0,5,1},{3,1,5},{3,2,1}, - {0,2,4},{5,0,4},{5,4,3},{2,3,4}}; +int stBase_verts[8][3] = { {0,1,2},{3,1,2},{0,4,2},{3,4,2}, + {0,1,5},{3,1,5},{0,4,5},{3,4,5}}; /* octahedron triangle nbrs ; nbr i is the face opposite vertex i*/ -int stBase_nbrs[8][3] = { {3,4,1},{2,0,5},{1,6,3},{0,2,7}, - {7,5,0},{4,6,1},{7,2,5},{6,4,3}}; -/* look up table for octahedron point location */ -int stlocatetbl[8] = {6,7,2,3,5,4,1,0}; +int stBase_nbrs[8][3] = { {1,2,4},{0,3,5},{3,0,6},{2,1,7}, + {5,6,0},{4,7,1},{7,4,2},{6,5,3}}; +int stRoot_indices[8][3] = {{1,1,1},{-1,1,1},{1,-1,1},{-1,-1,1}, + {1,1,-1},{-1,1,-1},{1,-1,-1},{-1,-1,-1}}; +/* + +z y -z y + | | + 1 | 0 5 | 4 +______|______ x _______|______ x + 3 | 2 7 | 6 + | | - -/* Initializes an stree structure with origin 'center': - Frees existing quadtrees hanging off of the roots +Nbrs + +z y -z y + /0|1\ /1|0\ + 5 / | \ 4 / | \ + /(1)|(0)\ 1 /(5)|(4)\ 0 + / | \ / | \ + /2 1|0 2\ /2 0|1 2\ +/------|------\x /------|------\x +\0 1|2 0/ \0 2|2 1/ + \ | / \ | / + 7\ (3)|(2) / 6 3 \ (7)|(6) / 2 + \ | / \ | / + \ 2|1 / \ 1|0 / */ + + stInit(st) STREE *st; { - ST_TOP_ROOT(st) = qtAlloc(); - ST_BOTTOM_ROOT(st) = qtAlloc(); - ST_INIT_ROOT(st); + int i,j; + + ST_TOP_QT(st) = qtAlloc(); + ST_BOTTOM_QT(st) = qtAlloc(); + /* Clear the children */ + + QT_CLEAR_CHILDREN(ST_TOP_QT(st)); + QT_CLEAR_CHILDREN(ST_BOTTOM_QT(st)); } /* Frees the children of the 2 quadtrees rooted at st, @@ -72,6 +97,8 @@ STREE *st; /* Allocate the top and bottom quadtree root nodes */ stInit(st); + + /* will go ********************************************/ /* Set the octahedron base */ ST_SET_BASE(st,stDefault_base); @@ -86,147 +113,320 @@ STREE *st; FP_X(ST_NTH_PLANE(st,i)) = (m+1)%3; FP_Y(ST_NTH_PLANE(st,i)) = (m+2)%3; FP_Z(ST_NTH_PLANE(st,i)) = m; - VCROSS(ST_EDGE_NORM(st,i,0),v1,v0); - VCROSS(ST_EDGE_NORM(st,i,1),v2,v1); - VCROSS(ST_EDGE_NORM(st,i,2),v0,v2); + VCROSS(ST_EDGE_NORM(st,i,0),v0,v1); + VCROSS(ST_EDGE_NORM(st,i,1),v1,v2); + VCROSS(ST_EDGE_NORM(st,i,2),v2,v0); } + + /*****************************************************************/ return(st); } +#define BARY_INT(v,b) if((v)>2.0) (b) = MAXBCOORD;else \ + if((v)<-2.0) (b)=-MAXBCOORD;else (b)=(BCOORD)((v)*MAXBCOORD2); +vert_to_qt_frame(root,v,b) +int root; +FVECT v; +BCOORD b[3]; +{ + int i; + double scale; + double d0,d1,d2; + + if(STR_NTH_INDEX(root,0)==-1) + d0 = -v[0]; + else + d0 = v[0]; + if(STR_NTH_INDEX(root,1)==-1) + d1 = -v[1]; + else + d1 = v[1]; + if(STR_NTH_INDEX(root,2)==-1) + d2 = -v[2]; + else + d2 = v[2]; + + /* Plane is now x+y+z = 1 - intersection of pt ray is qtv/den */ + scale = 1.0/ (d0 + d1 + d2); + d0 *= scale; + d1 *= scale; + d2 *= scale; + + BARY_INT(d0,b[0]) + BARY_INT(d1,b[1]) + BARY_INT(d2,b[2]) +} + + + + +ray_to_qt_frame(root,v,dir,b,db) +int root; +FVECT v,dir; +BCOORD b[3],db[3]; +{ + int i; + double scale; + double d0,d1,d2; + double dir0,dir1,dir2; + + if(STR_NTH_INDEX(root,0)==-1) + { + d0 = -v[0]; + dir0 = -dir[0]; + } + else + { + d0 = v[0]; + dir0 = dir[0]; + } + if(STR_NTH_INDEX(root,1)==-1) + { + d1 = -v[1]; + dir1 = -dir[1]; + } + else + { + d1 = v[1]; + dir1 = dir[1]; + } + if(STR_NTH_INDEX(root,2)==-1) + { + d2 = -v[2]; + dir2 = -dir[2]; + } + else + { + d2 = v[2]; + dir2 = dir[2]; + } + /* Plane is now x+y+z = 1 - intersection of pt ray is qtv/den */ + scale = 1.0/ (d0 + d1 + d2); + d0 *= scale; + d1 *= scale; + d2 *= scale; + + /* Calculate intersection point of orig+dir: This calculation is done + after the origin is projected into the plane in order to constrain + the projection( i.e. the size of the projection of the unit direction + vector translated to the origin depends on how close + the origin is to the view center + */ + /* Must divide by at least root2 to insure that projection will fit + int [-2,2] bounds: assumed length is 1: therefore greatest projection + from endpoint of triangle is at 45 degrees or projected length of root2 + */ + dir0 = d0 + dir0*0.5; + dir1 = d1 + dir1*0.5; + dir2 = d2 + dir2*0.5; + + scale = 1.0/ (dir0 + dir1 + dir2); + dir0 *= scale; + dir1 *= scale; + dir2 *= scale; + + BARY_INT(d0,b[0]) + BARY_INT(d1,b[1]) + BARY_INT(d2,b[2]) + BARY_INT(dir0,db[0]) + BARY_INT(dir1,db[1]) + BARY_INT(dir2,db[2]) + + db[0] -= b[0]; + db[1] -= b[1]; + db[2] -= b[2]; +} + +qt_frame_to_vert(root,b,v) +int root; +BCOORD b[3]; +FVECT v; +{ + int i; + double d0,d1,d2; + + d0 = b[0]/(double)MAXBCOORD2; + d1 = b[1]/(double)MAXBCOORD2; + d2 = b[2]/(double)MAXBCOORD2; + + if(STR_NTH_INDEX(root,0)==-1) + v[0] = -d0; + else + v[0] = d0; + if(STR_NTH_INDEX(root,1)==-1) + v[1] = -d1; + else + v[1] = d1; + if(STR_NTH_INDEX(root,2)==-1) + v[2] = -d2; + else + v[2] = d2; +} + + /* Return quadtree leaf node containing point 'p'*/ QUADTREE stPoint_locate(st,p) STREE *st; FVECT p; { + QUADTREE qt; + BCOORD bcoordi[3]; int i; - QUADTREE root,qt; /* Find root quadtree that contains p */ - i = stPoint_in_root(p); - root = ST_NTH_ROOT(st,i); + i = stLocate_root(p); + qt = ST_ROOT_QT(st,i); - /* Traverse quadtree to leaf level */ - qt = qtRoot_point_locate(root,ST_NTH_V(st,i,0),ST_NTH_V(st,i,1), - ST_NTH_V(st,i,2),ST_NTH_PLANE(st,i),p); - return(qt); + /* Will return lowest level triangle containing point: It the + point is on an edge or vertex: will return first associated + triangle encountered in the child traversal- the others can + be derived using triangle adjacency information + */ + if(QT_IS_TREE(qt)) + { + vert_to_qt_frame(i,p,bcoordi); + i = bary_child(bcoordi); + return(qtLocate(QT_NTH_CHILD(qt,i),bcoordi)); + } + else + return(qt); } -/* Add triangle 'id' with coordinates 't0,t1,t2' to the stree: returns - FALSE on error, TRUE otherwise -*/ - -stAdd_tri(st,id,t0,t1,t2) -STREE *st; -int id; -FVECT t0,t1,t2; +static unsigned int nbr_b[8][3] ={{2,4,16},{1,8,32},{8,1,64},{4,2,128}, + {32,64,1},{16,128,2},{128,16,4},{64,32,8}}; +unsigned int +stTri_cells(st,v) + STREE *st; + FVECT v[3]; { - int i; - QUADTREE root; + unsigned int cells,cross; + unsigned int vcell[3]; + double t0,t1; + int i,inext; - for(i=0; i < ST_NUM_ROOT_NODES; i++) - { - root = ST_NTH_ROOT(st,i); - ST_NTH_ROOT(st,i) = qtRoot_add_tri(root,ST_NTH_V(st,i,0),ST_NTH_V(st,i,1), - ST_NTH_V(st,i,2),t0,t1,t2,id,0); - } -} + /* First find base cells that tri vertices are in (0-7)*/ + vcell[0] = stLocate_root(v[0]); + vcell[1] = stLocate_root(v[1]); + vcell[2] = stLocate_root(v[2]); -/* Remove triangle 'id' with coordinates 't0,t1,t2' to the stree: returns - FALSE on error, TRUE otherwise -*/ + /* If all in same cell- return that bit only */ + if(vcell[0] == vcell[1] && vcell[1] == vcell[2]) + return( 1 << vcell[0]); -stRemove_tri(st,id,t0,t1,t2) -STREE *st; -int id; -FVECT t0,t1,t2; -{ - int i; - QUADTREE root; - - for(i=0; i < ST_NUM_ROOT_NODES; i++) + cells = 0; + for(i=0;i<3; i++) { - root = ST_NTH_ROOT(st,i); - ST_NTH_ROOT(st,i)=qtRoot_remove_tri(root,id,ST_NTH_V(st,i,0),ST_NTH_V(st,i,1), - ST_NTH_V(st,i,2),t0,t1,t2); + if(i==2) + inext = 0; + else + inext = i+1; + /* Mark cell containing initial vertex */ + cells |= 1 << vcell[i]; + + /* Take the exclusive or: will have bits set where edge crosses axis=0*/ + cross = vcell[i] ^ vcell[inext]; + /* If crosses 2 planes: then have 2 options for edge crossing-pick closest + otherwise just hits two*/ + /* Neighbors are zyx */ + switch(cross){ + case 3: /* crosses x=0 and y=0 */ + t0 = -v[i][0]/(v[inext][0]-v[i][0]); + t1 = -v[i][1]/(v[inext][1]-v[i][1]); + if(t0==t1) + break; + else if(t0 < t1) + cells |= nbr_b[vcell[i]][0]; + else + cells |= nbr_b[vcell[i]][1]; + break; + case 5: /* crosses x=0 and z=0 */ + t0 = -v[i][0]/(v[inext][0]-v[i][0]); + t1 = -v[i][2]/(v[inext][2]-v[i][2]); + if(t0==t1) + break; + else if(t0 < t1) + cells |= nbr_b[vcell[i]][0]; + else + cells |=nbr_b[vcell[i]][2]; + + break; + case 6:/* crosses z=0 and y=0 */ + t0 = -v[i][2]/(v[inext][2]-v[i][2]); + t1 = -v[i][1]/(v[inext][1]-v[i][1]); + if(t0==t1) + break; + else if(t0 < t1) + { + cells |= nbr_b[vcell[i]][2]; + } + else + { + cells |=nbr_b[vcell[i]][1]; + } + break; + case 7: + error(CONSISTENCY," Insert:Edge shouldnt be able to span 3 cells"); + break; + } } + return(cells); } -/* Visit all nodes that are intersected by the edges of triangle 't0,t1,t2' - and apply 'func' -*/ -stVisit_tri_edges(st,t0,t1,t2,func,fptr,argptr) - STREE *st; - FVECT t0,t1,t2; - int (*func)(),*fptr; - int *argptr; +stRoot_trace_ray(qt,root,orig,dir,nextptr,func,f) + QUADTREE qt; + int root; + FVECT orig,dir; + int *nextptr; + FUNC func; + int *f; { - int id,i,w,next; - QUADTREE root; - FVECT v[3],i_pt; + double br[3]; + BCOORD bi[3],dbi[3]; + + /* Project the origin onto the root node plane */ + /* Find the intersection point of the origin */ + ray_to_qt_frame(root,orig,dir,bi,dbi); - VCOPY(v[0],t0); VCOPY(v[1],t1); VCOPY(v[2],t2); - w = -1; + /* trace the ray starting with this node */ + qtTrace_ray(qt,bi,dbi[0],dbi[1],dbi[2],nextptr,0,0,func,f); + if(!QT_FLAG_IS_DONE(*f)) + qt_frame_to_vert(root,bi,orig); - /* Locate the root containing triangle vertex v0 */ - i = stPoint_in_root(v[0]); - /* Mark the root node as visited */ - QT_SET_FLAG(ST_ROOT(st,i)); - root = ST_NTH_ROOT(st,i); - - ST_NTH_ROOT(st,i) = qtRoot_visit_tri_edges(root,ST_NTH_V(st,i,0), - ST_NTH_V(st,i,1),ST_NTH_V(st,i,2),ST_NTH_PLANE(st,i),v,i_pt,&w, - &next,func,fptr,argptr); - if(QT_FLAG_IS_DONE(*fptr)) - return; - - /* Crossed over to next node: id = nbr */ - while(1) - { - /* test if ray crosses plane between this quadtree triangle and - its neighbor- if it does then find intersection point with - ray and plane- this is the new start point - */ - i = stBase_nbrs[i][next]; - root = ST_NTH_ROOT(st,i); - ST_NTH_ROOT(st,i) = - qtRoot_visit_tri_edges(root,ST_NTH_V(st,i,0),ST_NTH_V(st,i,1), - ST_NTH_V(st,i,2),ST_NTH_PLANE(st,i),v,i_pt,&w,&next,func,fptr,argptr); - if(QT_FLAG_IS_DONE(*fptr)) - return; - } } /* Trace ray 'orig-dir' through stree and apply 'func(qtptr,f,argptr)' at each node that it intersects */ int -stTrace_ray(st,orig,dir,func,argptr) +stTrace_ray(st,orig,dir,func) STREE *st; FVECT orig,dir; - int (*func)(); - int *argptr; + FUNC func; { int next,last,i,f=0; - QUADTREE root; - FVECT o,n; - double pd,t; + QUADTREE qt; + FVECT o,n,v; + double pd,t,d; VCOPY(o,orig); - - /* Find the root node that o falls in */ - i = stPoint_in_root(o); - root = ST_NTH_ROOT(st,i); +#ifdef TEST_DRIVER + Pick_cnt=0; +#endif; + /* Find the qt node that o falls in */ + i = stLocate_root(o); + qt = ST_ROOT_QT(st,i); - ST_NTH_ROOT(st,i) = - qtRoot_trace_ray(root,ST_NTH_V(st,i,0),ST_NTH_V(st,i,1), - ST_NTH_V(st,i,2),ST_NTH_PLANE(st,i),o,dir,&next,func,&f,argptr); + stRoot_trace_ray(qt,i,o,dir,&next,func,&f); if(QT_FLAG_IS_DONE(f)) return(TRUE); - + /* + d = DOT(orig,dir)/sqrt(DOT(orig,orig)); + VSUM(v,orig,dir,-d); + */ /* Crossed over to next cell: id = nbr */ while(1) { @@ -236,77 +436,312 @@ stTrace_ray(st,orig,dir,func,argptr) */ if(next == INVALID) return(FALSE); - if(!intersect_ray_oplane(orig,dir, - ST_EDGE_NORM(st,i,(next+1)%3),NULL,o)) - /* Ray does not cross into next cell: done and tri not found*/ - return(FALSE); - - VSUM(o,o,dir,10*FTINY); + /* + if(DOT(o,v) < 0.0) + return(FALSE); + */ i = stBase_nbrs[i][next]; - root = ST_NTH_ROOT(st,i); - - ST_NTH_ROOT(st,i) = - qtRoot_trace_ray(root, ST_NTH_V(st,i,0),ST_NTH_V(st,i,1), - ST_NTH_V(st,i,2),ST_NTH_PLANE(st,i),o,dir,&next,func,&f,argptr); + qt = ST_ROOT_QT(st,i); + stRoot_trace_ray(qt,i,o,dir,&next,func,&f); if(QT_FLAG_IS_DONE(f)) return(TRUE); } } -/* Visit nodes intersected by tri 't0,t1,t2' and apply 'func(arg1,arg2,arg3): - assumes that stVisit_tri_edges has already been called such that all nodes - intersected by tri edges are already marked as visited -*/ -stVisit_tri(st,t0,t1,t2,func,f,argptr) - STREE *st; - FVECT t0,t1,t2; - int (*func)(),*f; - int *argptr; +stVisit_poly(st,verts,l,root,func) +STREE *st; +FVECT *verts; +LIST *l; +unsigned int root; +FUNC func; { - int i; - QUADTREE root; - FVECT n0,n1,n2; + int id0,id1,id2; + FVECT tri[3]; - /* Calcuate the edge normals for tri */ - VCROSS(n0,t1,t0); - VCROSS(n1,t2,t1); - VCROSS(n2,t0,t2); + id0 = pop_list(&l); + id1 = pop_list(&l); + while(l) + { + id2 = pop_list(&l); + VCOPY(tri[0],verts[id0]); + VCOPY(tri[1],verts[id1]); + VCOPY(tri[2],verts[id2]); + stRoot_visit_tri(st,root,tri,func); + id1 = id2; + } +} - for(i=0; i < ST_NUM_ROOT_NODES; i++) +stVisit_clip(st,i,verts,vcnt,l,cell,func) + STREE *st; + int i; + FVECT *verts; + int *vcnt; + LIST *l; + unsigned int cell; + FUNC func; +{ + + LIST *labove,*lbelow,*endb,*enda; + int last = -1; + int id,last_id; + int first,first_id; + unsigned int cellb; + + labove = lbelow = NULL; + enda = endb = NULL; + while(l) { - root = ST_NTH_ROOT(st,i); - ST_NTH_ROOT(st,i) = qtVisit_tri_interior(root,ST_NTH_V(st,i,0), - ST_NTH_V(st,i,1),ST_NTH_V(st,i,2),t0,t1,t2,n0,n1,n2,0,func,f,argptr); + id = pop_list(&l); + if(ZERO(verts[id][i])) + { + if(last==-1) + {/* add below and above */ + first = 2; + first_id= id; + } + lbelow=add_data(lbelow,id,&endb); + labove=add_data(labove,id,&enda); + last_id = id; + last = 2; + continue; + } + if(verts[id][i] < 0) + { + if(last != 1) + { + lbelow=add_data(lbelow,id,&endb); + if(last==-1) + { + first = 0; + first_id = id; + } + last_id = id; + last = 0; + continue; + } + /* intersect_edges */ + intersect_edge_coord_plane(verts[last_id],verts[id],i,verts[*vcnt]); + /*newpoint goes to above and below*/ + lbelow=add_data(lbelow,*vcnt,&endb); + lbelow=add_data(lbelow,id,&endb); + labove=add_data(labove,*vcnt,&enda); + last = 0; + last_id = id; + (*vcnt)++; + } + else + { + if(last != 0) + { + labove=add_data(labove,id,&enda); + if(last==-1) + { + first = 1; + first_id = id; + } + last_id = id; + last = 1; + continue; + } + /* intersect_edges */ + /*newpoint goes to above and below*/ + intersect_edge_coord_plane(verts[last_id],verts[id],i,verts[*vcnt]); + lbelow=add_data(lbelow,*vcnt,&endb); + labove=add_data(labove,*vcnt,&enda); + labove=add_data(labove,id,&enda); + last_id = id; + (*vcnt)++; + last = 1; + } + } + if(first != 2 && first != last) + { + intersect_edge_coord_plane(verts[id],verts[first_id],i,verts[*vcnt]); + /*newpoint goes to above and below*/ + lbelow=add_data(lbelow,*vcnt,&endb); + labove=add_data(labove,*vcnt,&enda); + (*vcnt)++; } + if(i==2) + { + if(lbelow) + { + if(LIST_NEXT(lbelow) && LIST_NEXT(LIST_NEXT(lbelow))) + { + cellb = cell | (1 << i); + stVisit_poly(st,verts,lbelow,cellb,func); + } + else + free_list(lbelow); + } + if(labove) + { + if(LIST_NEXT(labove) && LIST_NEXT(LIST_NEXT(labove))) + stVisit_poly(st,verts,labove,cell,func); + else + free_list(labove); + } + } + else + { + if(lbelow) + { + if(LIST_NEXT(lbelow) && LIST_NEXT(LIST_NEXT(lbelow))) + { + cellb = cell | (1 << i); + stVisit_clip(st,i+1,verts,vcnt,lbelow,cellb,func); + } + else + free_list(lbelow); + } + if(labove) + { + if(LIST_NEXT(labove) && LIST_NEXT(LIST_NEXT(labove))) + stVisit_clip(st,i+1,verts,vcnt,labove,cell,func); + else + free_list(labove); + } + } + } -/* Visit nodes intersected by tri 't0,t1,t2'.Apply 'edge_func(arg1,arg2,arg3)', - to those nodes intersected by edges, and interior_func to ALL nodes: - ie some Nodes will be visited more than once - */ -int -stApply_to_tri(st,t0,t1,t2,edge_func,tri_func,argptr) +stVisit(st,tri,func) STREE *st; - FVECT t0,t1,t2; - int (*edge_func)(),(*tri_func)(); - int *argptr; + FVECT tri[3]; + FUNC func; { - int f; - FVECT dir; - - /* First add all of the leaf cells lying on the triangle perimeter: - mark all cells seen on the way - */ - f = 0; - /* Visit cells along edges of the tri */ - stVisit_tri_edges(st,t0,t1,t2,edge_func,&f,argptr); + int r0,r1,r2; + LIST *l; - /* Now visit All cells interior */ - if(QT_FLAG_FILL_TRI(f) || QT_FLAG_UPDATE(f)) - stVisit_tri(st,t0,t1,t2,tri_func,&f,argptr); + r0 = stLocate_root(tri[0]); + r1 = stLocate_root(tri[1]); + r2 = stLocate_root(tri[2]); + if(r0 == r1 && r1==r2) + stRoot_visit_tri(st,r0,tri,func); + else + { + FVECT verts[ST_CLIP_VERTS]; + int cnt; + + VCOPY(verts[0],tri[0]); + VCOPY(verts[1],tri[1]); + VCOPY(verts[2],tri[2]); + + l = add_data(NULL,0,NULL); + l = add_data(l,1,NULL); + l = add_data(l,2,NULL); + cnt = 3; + stVisit_clip(st,0,verts,&cnt,l,0,func); + } } + + +/* New Insertion code!!! */ + + +BCOORD qtRoot[3][3] = { {MAXBCOORD2,0,0},{0,MAXBCOORD2,0},{0,0,MAXBCOORD2}}; + + +convert_tri_to_frame(root,tri,b0,b1,b2,db10,db21,db02) +int root; +FVECT tri[3]; +BCOORD b0[3],b1[3],b2[3]; +BCOORD db10[3],db21[3],db02[3]; +{ + /* Project the vertex into the qtree plane */ + vert_to_qt_frame(root,tri[0],b0); + vert_to_qt_frame(root,tri[1],b1); + vert_to_qt_frame(root,tri[2],b2); + + /* calculate triangle edge differences in new frame */ + db10[0] = b1[0] - b0[0]; db10[1] = b1[1] - b0[1]; db10[2] = b1[2] - b0[2]; + db21[0] = b2[0] - b1[0]; db21[1] = b2[1] - b1[1]; db21[2] = b2[2] - b1[2]; + db02[0] = b0[0] - b2[0]; db02[1] = b0[1] - b2[1]; db02[2] = b0[2] - b2[2]; +} + + +QUADTREE +stRoot_insert_tri(st,root,tri,f) + STREE *st; + int root; + FVECT tri[3]; + FUNC f; +{ + BCOORD b0[3],b1[3],b2[3]; + BCOORD db10[3],db21[3],db02[3]; + unsigned int s0,s1,s2,sq0,sq1,sq2; + QUADTREE qt; + + /* Map the triangle vertices into the canonical barycentric frame */ + convert_tri_to_frame(root,tri,b0,b1,b2,db10,db21,db02); + + /* Calculate initial sidedness info */ + SIDES_GTR(b0,b1,b2,s0,s1,s2,qtRoot[1][0],qtRoot[0][1],qtRoot[0][2]); + SIDES_GTR(b0,b1,b2,sq0,sq1,sq2,qtRoot[0][0],qtRoot[1][1],qtRoot[2][2]); + + qt = ST_ROOT_QT(st,root); + /* Visit cells that triangle intersects */ + qt = qtInsert_tri(root,qt,qtRoot[0],qtRoot[1],qtRoot[2], + b0,b1,b2,db10,db21,db02,MAXBCOORD2 >> 1,s0,s1,s2, sq0,sq1,sq2,f,0); + + return(qt); +} + +stRoot_visit_tri(st,root,tri,f) + STREE *st; + int root; + FVECT tri[3]; + FUNC f; +{ + BCOORD b0[3],b1[3],b2[3]; + BCOORD db10[3],db21[3],db02[3]; + unsigned int s0,s1,s2,sq0,sq1,sq2; + QUADTREE qt; + + /* Map the triangle vertices into the canonical barycentric frame */ + convert_tri_to_frame(root,tri,b0,b1,b2,db10,db21,db02); + + /* Calculate initial sidedness info */ + SIDES_GTR(b0,b1,b2,s0,s1,s2,qtRoot[1][0],qtRoot[0][1],qtRoot[0][2]); + SIDES_GTR(b0,b1,b2,sq0,sq1,sq2,qtRoot[0][0],qtRoot[1][1],qtRoot[2][2]); + + qt = ST_ROOT_QT(st,root); + QT_SET_FLAG(ST_QT(st,root)); + /* Visit cells that triangle intersects */ + qtVisit_tri(root,qt,qtRoot[0],qtRoot[1],qtRoot[2], + b0,b1,b2,db10,db21,db02,MAXBCOORD2 >> 1,s0,s1,s2, sq0,sq1,sq2,f); + +} + +stInsert_tri(st,tri,f) + STREE *st; + FVECT tri[3]; + FUNC f; +{ + unsigned int cells,which; + int root; + + + /* calculate entry/exit points of edges through the cells */ + cells = stTri_cells(st,tri); + + /* For each cell that quadtree intersects: Map the triangle vertices into + the canonical barycentric frame of (1,0,0), (0,1,0),(0,0,1). Insert + by first doing a trivial reject on the interior nodes, and then a + tri/tri intersection at the leaf nodes. + */ + for(root=0,which=1; root < ST_NUM_ROOT_NODES; root++,which <<= 1) + { + /* For each of the quadtree roots: check if marked as intersecting tri*/ + if(cells & which) + /* Visit tri cells */ + ST_ROOT_QT(st,root) = stRoot_insert_tri(st,root,tri,f); + } +} + +
