root/radiance/ray/src/hd/sm_sets.c
Wed Apr 23 00:52:34 2003 UTC (22 years, 2 months ago) by greg
Changes since 3.6: +3 -3 lines
Diff to previous 3.6
Sat Feb 22 02:07:25 2003 UTC (22 years, 4 months ago) by greg
Changes since 3.5: +5 -8 lines
Diff to previous 3.5
Thu Jun 10 15:22:24 1999 UTC (26 years ago) by gwlarson
Changes since 3.4: +0 -0 lines
Diff to previous 3.4
Implemented sample quadtree in place of triangle quadtree
Made geometric predicates more robust
Added #define LORES which utilizes a single precision floating point
  sample array, the default is a double sample array
Added topology DEBUG commands (for DEBUG > 1)
Made code optimizations
Wed Nov 11 12:05:41 1998 UTC (26 years, 7 months ago) by gwlarson
Changes since 3.3: +26 -18 lines
Diff to previous 3.3
new triangulation code
changed triangle vertex order to CCW
changed numbering of triangle neighbors to match quadtree
fixed tone-mapping bug
removed errant printf() statements
redid logic for adding and testing samples with new epsilon
Wed Sep 16 18:16:29 1998 UTC (26 years, 9 months ago) by gwlarson
Changes since 3.2: +13 -18 lines
Diff to previous 3.2
implemented integer triangle tracing
Fri Sep 11 11:52:27 1998 UTC (26 years, 9 months ago) by gwlarson
Changes since 3.1: +55 -37 lines
Diff to previous 3.1
fixed triangle insertion using edge tracing
Wed Aug 19 17:45:23 1998 UTC (26 years, 10 months ago) by gwlarson
