root/radiance/ray/src/hd/sm_sets.c
Revision: 3.5
Committed: Thu Jun 10 15:22:24 1999 UTC (24 years, 10 months ago) by gwlarson
Changes since 3.4: +0 -0 lines
Implemented sample quadtree in place of triangle quadtree
Made geometric predicates more robust
Added #define LORES which utilizes a single precision floating point
  sample array, the default is a double sample array
Added topology DEBUG commands (for DEBUG > 1)
Made code optimizations
1 /* Copyright (c) 1998 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Quadtree-specific set operations.
9 */
10
11 #include "standard.h"
12
13 #include "sm_qtree.h"
14
15
16 #define QTSETIBLK 2048 /* set index allocation block size */
17 #define QTELEMBLK 8 /* set element allocation block */
18 #define QTELEMMOD(ne) ((ne)&7) /* (ne) % QTELEMBLK */
19
20 #define QTONTHRESH(ne) (!QTELEMMOD((ne)+1))
21 #define QTNODESIZ(ne) ((ne) + QTELEMBLK - QTELEMMOD(ne))
22
23 OBJECT **qtsettab= NULL; /* quadtree leaf node table */
24 QUADTREE qtnumsets; /* number of used set indices */
25 static int qtfreesets = EMPTY; /* free set index list */
26
27
28 QUADTREE
29 qtnewleaf(oset) /* return new leaf node for object set */
30 OBJECT *oset;
31 {
32 register QUADTREE osi;
33
34 if (*oset <= 0)
35 return(EMPTY); /* should be error? */
36 if (qtfreesets != EMPTY) {
37 osi = qtfreesets;
38 qtfreesets = (int)qtsettab[osi];
39 } else if ((osi = qtnumsets++) % QTSETIBLK == 0) {
40 qtsettab = (OBJECT **)realloc((char *)qtsettab,
41 (unsigned)(osi+QTSETIBLK)*sizeof(OBJECT *));
42 if (qtsettab == NULL)
43 goto memerr;
44 }
45 qtsettab[osi] = (OBJECT *)malloc(QTNODESIZ(*oset)*sizeof(OBJECT));
46 if (qtsettab[osi] == NULL)
47 goto memerr;
48 setcopy(qtsettab[osi], oset);
49 return(QT_INDEX(osi));
50 memerr:
51 error(SYSTEM, "out of memory in qtnewleaf");
52 }
53
54
55 QUADTREE
56 qtdelelem(qt, id) /* delete element from leaf node */
57 QUADTREE qt;
58 OBJECT id;
59 {
60 register QUADTREE lf;
61
62 #ifdef DEBUG
63 if(id < 0)
64 eputs("qtdelelem():Invalid triangle id\n");
65 if (!QT_IS_LEAF(qt) || (lf = QT_SET_INDEX(qt)) >= qtnumsets)
66 error(CONSISTENCY, "empty/bad node in qtdelelem");
67 if (!inset(qtsettab[lf], id))
68 error(CONSISTENCY, "id not in leaf in qtdelelem");
69 #else
70 lf = QT_SET_INDEX(qt);
71 #endif
72 if (qtsettab[lf][0] <= 1) { /* blow leaf away */
73 free((char *)qtsettab[lf]);
74 qtsettab[lf] = (OBJECT *)qtfreesets;
75 qtfreesets = lf;
76 return(EMPTY);
77 }
78 deletelem(qtsettab[lf], id);
79 if (QTONTHRESH(qtsettab[lf][0]))
80 qtsettab[lf] = (OBJECT *)realloc((char *)qtsettab[lf],
81 QTNODESIZ(qtsettab[lf][0])*sizeof(OBJECT));
82 return(qt);
83 }
84
85
86 QUADTREE
87 qtaddelem(qt, id) /* add element to leaf node */
88 QUADTREE qt;
89 OBJECT id;
90 {
91 OBJECT newset[2];
92 register QUADTREE lf;
93
94 #ifdef DEBUG
95 if(id < 0)
96 eputs("qtaddelem():Invalid triangle id\n");
97 #endif
98 if (QT_IS_EMPTY(qt)) { /* create new leaf */
99 newset[0] = 1; newset[1] = id;
100 return(qtnewleaf(newset));
101 } /* else add element */
102 #ifdef DEBUG
103 if (!QT_IS_LEAF(qt) || (lf = QT_SET_INDEX(qt)) >= qtnumsets)
104 error(CONSISTENCY, "bad node in qtaddelem");
105 if (inset(qtsettab[lf], id))
106 error(CONSISTENCY, "id already in leaf in qtaddelem");
107 #else
108 lf = QT_SET_INDEX(qt);
109 #endif
110 if (QTONTHRESH(qtsettab[lf][0])) {
111 qtsettab[lf] = (OBJECT *)realloc((char *)qtsettab[lf],
112 QTNODESIZ(qtsettab[lf][0]+1)*sizeof(OBJECT));
113 if (qtsettab[lf] == NULL)
114 error(SYSTEM, "out of memory in qtaddelem");
115 }
116 insertelem(qtsettab[lf], id);
117 return(qt);
118 }
119
120
121 #ifdef DEBUG
122 OBJECT *
123 qtqueryset(qt) /* return object set for leaf node */
124 QUADTREE qt;
125 {
126 register QUADTREE lf;
127
128 if (!QT_IS_LEAF(qt) || (lf = QT_SET_INDEX(qt)) >= qtnumsets)
129 error(CONSISTENCY, "bad node in qtqueryset");
130 return(qtsettab[lf]);
131 }
132 #endif
133
134
135 qtfreeleaf(qt) /* free set and leaf node */
136 QUADTREE qt;
137 {
138 register QUADTREE osi;
139
140 if (!QT_IS_LEAF(qt))
141 return;
142 osi = QT_SET_INDEX(qt);
143 if (osi >= qtnumsets)
144 return;
145 free((char *)qtsettab[osi]);
146 qtsettab[osi] = (OBJECT *)qtfreesets;
147 qtfreesets = osi;
148 }
149
150
151
152 qtfreeleaves() /* free ALL sets and leaf nodes */
153 {
154 register int i;
155
156 while ((i = qtfreesets) != EMPTY) {
157 qtfreesets = (int)qtsettab[i];
158 qtsettab[i] = NULL;
159 }
160 for (i = qtnumsets; i--; )
161 if (qtsettab[i] != NULL)
162 free((char *)qtsettab[i]);
163 free((char *)qtsettab);
164 qtsettab = NULL;
165 qtnumsets = 0;
166 }
167
168
169 check_set(os, cs) /* modify checked set and set to check */
170 register OBJECT *os; /* os' = os - cs */
171 register OBJECT *cs; /* cs' = cs + os */
172 {
173 OBJECT cset[QT_MAXCSET+QT_MAXSET+1];
174 register int i, j;
175 int k;
176 /* copy os in place, cset <- cs */
177 cset[0] = 0;
178 k = 0;
179 for (i = j = 1; i <= os[0]; i++) {
180 while (j <= cs[0] && cs[j] < os[i])
181 cset[++cset[0]] = cs[j++];
182 if (j > cs[0] || os[i] != cs[j]) { /* object to check */
183 os[++k] = os[i];
184 cset[++cset[0]] = os[i];
185 }
186 }
187 if (!(os[0] = k)) /* new "to check" set size */
188 return; /* special case */
189 while (j <= cs[0]) /* get the rest of cs */
190 cset[++cset[0]] = cs[j++];
191 if (cset[0] > QT_MAXCSET) /* truncate "checked" set if nec. */
192 cset[0] = QT_MAXCSET;
193 /* setcopy(cs, cset); */ /* copy cset back to cs */
194 os = cset;
195 for (i = os[0]; i-- >= 0; )
196 *cs++ = *os++;
197 }
198
199
200
201
202
203
204
205
206
