1 |
/* Copyright (c) 1998 Silicon Graphics, Inc. */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ SGI"; |
5 |
#endif |
6 |
7 |
8 |
* Quadtree-specific set operations. |
9 |
10 |
11 |
#include "standard.h" |
12 |
13 |
#include "sm_qtree.h" |
14 |
#include "object.h" |
15 |
16 |
#define QTSETIBLK 1024 /* set index allocation block size */ |
17 |
#define QTELEMBLK 8 /* set element allocation block */ |
18 |
19 |
#define QTNODESIZ(ne) ((ne) + QTELEMBLK - ((ne) % QTELEMBLK)) |
20 |
21 |
static OBJECT **qtsettab; /* quadtree leaf node table */ |
22 |
static QUADTREE qtnumsets; /* number of used set indices */ |
23 |
static int qtfreesets = EMPTY; /* free set index list */ |
24 |
25 |
26 |
QUADTREE |
27 |
qtnewleaf(oset) /* return new leaf node for object set */ |
28 |
OBJECT *oset; |
29 |
30 |
register QUADTREE osi; |
31 |
int nalc; |
32 |
33 |
if (*oset <= 0) |
34 |
return(EMPTY); /* should be error? */ |
35 |
if (qtfreesets != EMPTY) { |
36 |
osi = qtfreesets; |
37 |
qtfreesets = (int)qtsettab[osi]; |
38 |
} else if ((osi = qtnumsets++) % QTSETIBLK == 0) { |
39 |
qtsettab = (OBJECT **)realloc((char *)qtsettab, |
40 |
(unsigned)(osi+QTSETIBLK)*sizeof(OBJECT *)); |
41 |
if (qtsettab == NULL) |
42 |
goto memerr; |
43 |
44 |
nalc = QTNODESIZ(*oset); |
45 |
if ((qtsettab[osi] = (OBJECT *)malloc(nalc*sizeof(OBJECT))) == NULL) |
46 |
goto memerr; |
47 |
setcopy(qtsettab[osi], oset); |
48 |
return(QT_INDEX(osi)); |
49 |
memerr: |
50 |
error(SYSTEM, "out of memory in qtnewleaf"); |
51 |
52 |
53 |
54 |
QUADTREE |
55 |
qtdelelem(qt, id) /* delete element from leaf node, no quest. */ |
56 |
QUADTREE qt; |
57 |
OBJECT id; |
58 |
59 |
register QUADTREE lf; |
60 |
int oalc, nalc; |
61 |
62 |
if (QT_IS_EMPTY(qt)) |
63 |
return(EMPTY); |
64 |
if (!QT_IS_LEAF(qt)) |
65 |
goto noderr; |
66 |
lf = QT_SET_INDEX(qt); |
67 |
if (lf >= qtnumsets) |
68 |
goto noderr; |
69 |
if (qtsettab[lf][0] <= 1) { /* blow leaf away */ |
70 |
free((char *)qtsettab[lf]); |
71 |
qtsettab[lf] = (OBJECT *)qtfreesets; |
72 |
qtfreesets = lf; |
73 |
return(EMPTY); |
74 |
} /* else delete element */ |
75 |
oalc = QTNODESIZ(qtsettab[lf][0]); |
76 |
nalc = QTNODESIZ(qtsettab[lf][0] - 1); |
77 |
deletelem(qtsettab[lf], id); |
78 |
if (nalc != oalc) |
79 |
qtsettab[lf] = (OBJECT *)realloc((char *)qtsettab[lf], |
80 |
nalc*sizeof(OBJECT)); |
81 |
return(qt); |
82 |
noderr: |
83 |
error(CONSISTENCY, "bad node in qtdelelem"); |
84 |
85 |
86 |
87 |
QUADTREE |
88 |
qtaddelem(qt, id) /* add element to leaf node, no quest. */ |
89 |
QUADTREE qt; |
90 |
OBJECT id; |
91 |
92 |
OBJECT newset[2]; |
93 |
94 |
int oalc, nalc; |
95 |
96 |
if (QT_IS_EMPTY(qt)) { /* create new leaf */ |
97 |
newset[0] = 1; newset[1] = id; |
98 |
return(qtnewleaf(newset)); |
99 |
} /* else add element */ |
100 |
101 |
goto noderr; |
102 |
103 |
104 |
goto noderr; |
105 |
106 |
nalc = QTNODESIZ(qtsettab[lf][0] + 1); |
107 |
if (nalc != oalc) { |
108 |
109 |
110 |
if (qtsettab[lf] == NULL) |
111 |
error(SYSTEM, "out of memory in qtaddelem"); |
112 |
113 |
insertelem(qtsettab[lf], id); |
114 |
return(qt); |
115 |
noderr: |
116 |
error(CONSISTENCY, "bad node in qtaddelem"); |
117 |
118 |
119 |
120 |
qtgetset(oset, qt) /* get object set for leaf node */ |
121 |
register OBJECT *oset; |
122 |
QUADTREE qt; |
123 |
124 |
QUADTREE lf; |
125 |
register OBJECT *os; |
126 |
register int i; |
127 |
128 |
129 |
goto noderr; |
130 |
131 |
132 |
goto noderr; |
133 |
for (i = *(os = qtsettab[lf]); i-- >= 0; ) |
134 |
*oset++ = *os++; |
135 |
return; |
136 |
noderr: |
137 |
error(CONSISTENCY, "bad node in qtgetset"); |
138 |
139 |
140 |
141 |
qtfreeleaf(qt) /* free set and leaf node */ |
142 |
QUADTREE qt; |
143 |
144 |
145 |
146 |
147 |
return; |
148 |
osi = QT_SET_INDEX(qt); |
149 |
if (osi >= qtnumsets) |
150 |
error(CONSISTENCY, "bad node in qtfreeleaf"); |
151 |
free((char *)qtsettab[osi]); |
152 |
qtsettab[osi] = (OBJECT *)qtfreesets; |
153 |
qtfreesets = osi; |
154 |
155 |
156 |
157 |
check_set(os, cs) /* modify checked set and set to check */ |
158 |
register OBJECT *os; /* os' = os - cs */ |
159 |
register OBJECT *cs; /* cs' = cs + os */ |
160 |
161 |
OBJECT cset[MAXCSET+MAXSET+1]; |
162 |
register int i, j; |
163 |
int k; |
164 |
/* copy os in place, cset <- cs */ |
165 |
cset[0] = 0; |
166 |
k = 0; |
167 |
for (i = j = 1; i <= os[0]; i++) { |
168 |
while (j <= cs[0] && cs[j] < os[i]) |
169 |
cset[++cset[0]] = cs[j++]; |
170 |
if (j > cs[0] || os[i] != cs[j]) { /* object to check */ |
171 |
os[++k] = os[i]; |
172 |
cset[++cset[0]] = os[i]; |
173 |
174 |
175 |
if (!(os[0] = k)) /* new "to check" set size */ |
176 |
return; /* special case */ |
177 |
while (j <= cs[0]) /* get the rest of cs */ |
178 |
179 |
if (cset[0] > MAXCSET) /* truncate "checked" set if nec. */ |
180 |
cset[0] = MAXCSET; |
181 |
/* setcopy(cs, cset); */ /* copy cset back to cs */ |
182 |
os = cset; |
183 |
for (i = os[0]; i-- >= 0; ) |
184 |
*cs++ = *os++; |
185 |
