--- ray/src/hd/sm_sets.c 1998/09/11 11:52:27 3.2 +++ ray/src/hd/sm_sets.c 1998/09/16 18:16:29 3.3 @@ -15,10 +15,12 @@ static char SCCSid[] = "$SunId$ SGI"; #define QTSETIBLK 2048 /* set index allocation block size */ #define QTELEMBLK 8 /* set element allocation block */ +#define QTELEMMOD(ne) ((ne)&7) /* (ne) % QTELEMBLK */ -#define QTNODESIZ(ne) ((ne) + QTELEMBLK - ((ne) % QTELEMBLK)) +#define QTONTHRESH(ne) (!QTELEMMOD((ne)+1)) +#define QTNODESIZ(ne) ((ne) + QTELEMBLK - QTELEMMOD(ne)) -OBJECT **qtsettab= NULL; /* quadtree leaf node table */ +OBJECT **qtsettab= NULL; /* quadtree leaf node table */ QUADTREE qtnumsets; /* number of used set indices */ static int qtfreesets = EMPTY; /* free set index list */ @@ -28,7 +30,6 @@ qtnewleaf(oset) /* return new leaf node for object s OBJECT *oset; { register QUADTREE osi; - int nalc; if (*oset <= 0) return(EMPTY); /* should be error? */ @@ -41,8 +42,8 @@ OBJECT *oset; if (qtsettab == NULL) goto memerr; } - nalc = QTNODESIZ(*oset); - if ((qtsettab[osi] = (OBJECT *)malloc(nalc*sizeof(OBJECT))) == NULL) + qtsettab[osi] = (OBJECT *)malloc(QTNODESIZ(*oset)*sizeof(OBJECT)); + if (qtsettab[osi] == NULL) goto memerr; setcopy(qtsettab[osi], oset); return(QT_INDEX(osi)); @@ -52,12 +53,11 @@ memerr: QUADTREE -qtdelelem(qt, id) /* delete element from leaf node, no quest. */ +qtdelelem(qt, id) /* delete element from leaf node */ QUADTREE qt; OBJECT id; { register QUADTREE lf; - int oalc, nalc; #ifdef DEBUG if(id < 0) @@ -74,25 +74,22 @@ OBJECT id; qtsettab[lf] = (OBJECT *)qtfreesets; qtfreesets = lf; return(EMPTY); - } /* else delete element */ - oalc = QTNODESIZ(qtsettab[lf][0]); - nalc = QTNODESIZ(qtsettab[lf][0] - 1); + } deletelem(qtsettab[lf], id); - if (nalc != oalc) + if (QTONTHRESH(qtsettab[lf][0])) qtsettab[lf] = (OBJECT *)realloc((char *)qtsettab[lf], - nalc*sizeof(OBJECT)); + QTNODESIZ(qtsettab[lf][0])*sizeof(OBJECT)); return(qt); } QUADTREE -qtaddelem(qt, id) /* add element to leaf node, no quest. */ +qtaddelem(qt, id) /* add element to leaf node */ QUADTREE qt; OBJECT id; { OBJECT newset[2]; register QUADTREE lf; - int oalc, nalc; #ifdef DEBUG if(id < 0) @@ -110,11 +107,9 @@ OBJECT id; #else lf = QT_SET_INDEX(qt); #endif - oalc = QTNODESIZ(qtsettab[lf][0]); - nalc = QTNODESIZ(qtsettab[lf][0] + 1); - if (nalc != oalc) { + if (QTONTHRESH(qtsettab[lf][0])) { qtsettab[lf] = (OBJECT *)realloc((char *)qtsettab[lf], - nalc*sizeof(OBJECT)); + QTNODESIZ(qtsettab[lf][0]+1)*sizeof(OBJECT)); if (qtsettab[lf] == NULL) error(SYSTEM, "out of memory in qtaddelem"); }
