root/radiance/ray/src/hd/sm_sets.c
Revision: 3.7
Committed: Wed Apr 23 00:52:34 2003 UTC (22 years ago) by greg
CVS Tags: rad3R6P1, rad3R6
Changes since 3.6: +3 -3 lines
# User Rev Content
1 gwlarson 3.1 #ifndef lint
2 greg 3.6 static const char RCSid[] = "$Id$";
3 gwlarson 3.1 #endif
4     /*
5     * Quadtree-specific set operations.
6     */
7
8     #include "standard.h"
9
10     #include "sm_qtree.h"
11
12 gwlarson 3.2
13     #define QTSETIBLK 2048 /* set index allocation block size */
14 gwlarson 3.1 #define QTELEMBLK 8 /* set element allocation block */
15 gwlarson 3.3 #define QTELEMMOD(ne) ((ne)&7) /* (ne) % QTELEMBLK */
16 gwlarson 3.1
17 gwlarson 3.3 #define QTONTHRESH(ne) (!QTELEMMOD((ne)+1))
18     #define QTNODESIZ(ne) ((ne) + QTELEMBLK - QTELEMMOD(ne))
19 gwlarson 3.1
20 gwlarson 3.3 OBJECT **qtsettab= NULL; /* quadtree leaf node table */
21 gwlarson 3.2 QUADTREE qtnumsets; /* number of used set indices */
22 gwlarson 3.1 static int qtfreesets = EMPTY; /* free set index list */
23
24
25     QUADTREE
26     qtnewleaf(oset) /* return new leaf node for object set */
27     OBJECT *oset;
28     {
29 gwlarson 3.4 register QUADTREE osi;
30 gwlarson 3.1
31 gwlarson 3.4 if (*oset <= 0)
32     return(EMPTY); /* should be error? */
33     if (qtfreesets != EMPTY) {
34     osi = qtfreesets;
35     qtfreesets = (int)qtsettab[osi];
36     } else if ((osi = qtnumsets++) % QTSETIBLK == 0) {
37 greg 3.7 qtsettab = (OBJECT **)realloc((void *)qtsettab,
38 gwlarson 3.4 (unsigned)(osi+QTSETIBLK)*sizeof(OBJECT *));
39     if (qtsettab == NULL)
40     goto memerr;
41     }
42     qtsettab[osi] = (OBJECT *)malloc(QTNODESIZ(*oset)*sizeof(OBJECT));
43     if (qtsettab[osi] == NULL)
44     goto memerr;
45     setcopy(qtsettab[osi], oset);
46     return(QT_INDEX(osi));
47 gwlarson 3.1 memerr:
48 gwlarson 3.4 error(SYSTEM, "out of memory in qtnewleaf");
49 gwlarson 3.1 }
50
51
52     QUADTREE
53 gwlarson 3.3 qtdelelem(qt, id) /* delete element from leaf node */
54 gwlarson 3.1 QUADTREE qt;
55     OBJECT id;
56     {
57     register QUADTREE lf;
58
59 gwlarson 3.2 #ifdef DEBUG
60     if(id < 0)
61     eputs("qtdelelem():Invalid triangle id\n");
62     if (!QT_IS_LEAF(qt) || (lf = QT_SET_INDEX(qt)) >= qtnumsets)
63     error(CONSISTENCY, "empty/bad node in qtdelelem");
64     if (!inset(qtsettab[lf], id))
65     error(CONSISTENCY, "id not in leaf in qtdelelem");
66     #else
67 gwlarson 3.1 lf = QT_SET_INDEX(qt);
68 gwlarson 3.2 #endif
69 gwlarson 3.1 if (qtsettab[lf][0] <= 1) { /* blow leaf away */
70 greg 3.6 free((void *)qtsettab[lf]);
71 gwlarson 3.1 qtsettab[lf] = (OBJECT *)qtfreesets;
72     qtfreesets = lf;
73     return(EMPTY);
74 gwlarson 3.3 }
75 gwlarson 3.1 deletelem(qtsettab[lf], id);
76 gwlarson 3.3 if (QTONTHRESH(qtsettab[lf][0]))
77 greg 3.7 qtsettab[lf] = (OBJECT *)realloc((void *)qtsettab[lf],
78 gwlarson 3.3 QTNODESIZ(qtsettab[lf][0])*sizeof(OBJECT));
79 gwlarson 3.1 return(qt);
80     }
81
82
83     QUADTREE
84 gwlarson 3.3 qtaddelem(qt, id) /* add element to leaf node */
85 gwlarson 3.1 QUADTREE qt;
86     OBJECT id;
87     {
88     OBJECT newset[2];
89     register QUADTREE lf;
90
91 gwlarson 3.2 #ifdef DEBUG
92     if(id < 0)
93     eputs("qtaddelem():Invalid triangle id\n");
94     #endif
95 gwlarson 3.1 if (QT_IS_EMPTY(qt)) { /* create new leaf */
96     newset[0] = 1; newset[1] = id;
97     return(qtnewleaf(newset));
98     } /* else add element */
99 gwlarson 3.2 #ifdef DEBUG
100     if (!QT_IS_LEAF(qt) || (lf = QT_SET_INDEX(qt)) >= qtnumsets)
101     error(CONSISTENCY, "bad node in qtaddelem");
102     if (inset(qtsettab[lf], id))
103     error(CONSISTENCY, "id already in leaf in qtaddelem");
104     #else
105 gwlarson 3.1 lf = QT_SET_INDEX(qt);
106 gwlarson 3.2 #endif
107 gwlarson 3.3 if (QTONTHRESH(qtsettab[lf][0])) {
108 greg 3.7 qtsettab[lf] = (OBJECT *)realloc((void *)qtsettab[lf],
109 gwlarson 3.3 QTNODESIZ(qtsettab[lf][0]+1)*sizeof(OBJECT));
110 gwlarson 3.1 if (qtsettab[lf] == NULL)
111     error(SYSTEM, "out of memory in qtaddelem");
112     }
113     insertelem(qtsettab[lf], id);
114     return(qt);
115     }
116
117
118 gwlarson 3.2 #ifdef DEBUG
119     OBJECT *
120     qtqueryset(qt) /* return object set for leaf node */
121 gwlarson 3.1 QUADTREE qt;
122     {
123 gwlarson 3.2 register QUADTREE lf;
124 gwlarson 3.1
125 gwlarson 3.2 if (!QT_IS_LEAF(qt) || (lf = QT_SET_INDEX(qt)) >= qtnumsets)
126     error(CONSISTENCY, "bad node in qtqueryset");
127     return(qtsettab[lf]);
128 gwlarson 3.1 }
129 gwlarson 3.2 #endif
130 gwlarson 3.1
131
132     qtfreeleaf(qt) /* free set and leaf node */
133     QUADTREE qt;
134     {
135     register QUADTREE osi;
136
137     if (!QT_IS_LEAF(qt))
138     return;
139     osi = QT_SET_INDEX(qt);
140     if (osi >= qtnumsets)
141 gwlarson 3.2 return;
142 greg 3.6 free((void *)qtsettab[osi]);
143 gwlarson 3.1 qtsettab[osi] = (OBJECT *)qtfreesets;
144     qtfreesets = osi;
145     }
146
147
148 gwlarson 3.2
149     qtfreeleaves() /* free ALL sets and leaf nodes */
150     {
151     register int i;
152
153     while ((i = qtfreesets) != EMPTY) {
154     qtfreesets = (int)qtsettab[i];
155     qtsettab[i] = NULL;
156     }
157     for (i = qtnumsets; i--; )
158     if (qtsettab[i] != NULL)
159 greg 3.6 free((void *)qtsettab[i]);
160     free((void *)qtsettab);
161 gwlarson 3.2 qtsettab = NULL;
162     qtnumsets = 0;
163     }
164
165
166 gwlarson 3.1 check_set(os, cs) /* modify checked set and set to check */
167     register OBJECT *os; /* os' = os - cs */
168     register OBJECT *cs; /* cs' = cs + os */
169     {
170 gwlarson 3.2 OBJECT cset[QT_MAXCSET+QT_MAXSET+1];
171 gwlarson 3.1 register int i, j;
172     int k;
173     /* copy os in place, cset <- cs */
174     cset[0] = 0;
175     k = 0;
176     for (i = j = 1; i <= os[0]; i++) {
177     while (j <= cs[0] && cs[j] < os[i])
178     cset[++cset[0]] = cs[j++];
179     if (j > cs[0] || os[i] != cs[j]) { /* object to check */
180     os[++k] = os[i];
181     cset[++cset[0]] = os[i];
182     }
183     }
184     if (!(os[0] = k)) /* new "to check" set size */
185     return; /* special case */
186     while (j <= cs[0]) /* get the rest of cs */
187     cset[++cset[0]] = cs[j++];
188 gwlarson 3.2 if (cset[0] > QT_MAXCSET) /* truncate "checked" set if nec. */
189     cset[0] = QT_MAXCSET;
190 gwlarson 3.1 /* setcopy(cs, cset); */ /* copy cset back to cs */
191     os = cset;
192     for (i = os[0]; i-- >= 0; )
193     *cs++ = *os++;
194     }
195 gwlarson 3.4
196
197
198
199
200
201
202
203 gwlarson 3.2
