root/radiance/ray/src/hd/sm_sets.c
Revision: 3.7
Committed: Wed Apr 23 00:52:34 2003 UTC (22 years ago) by greg
CVS Tags: rad3R6P1, rad3R6
Changes since 3.6: +3 -3 lines
5 * Quadtree-specific set operations.
6 */
7
8 #include "standard.h"
9
10 #include "sm_qtree.h"
11
12
13 #define QTSETIBLK 2048 /* set index allocation block size */
14 #define QTELEMBLK 8 /* set element allocation block */
15 #define QTELEMMOD(ne) ((ne)&7) /* (ne) % QTELEMBLK */
16
17 #define QTONTHRESH(ne) (!QTELEMMOD((ne)+1))
18 #define QTNODESIZ(ne) ((ne) + QTELEMBLK - QTELEMMOD(ne))
19
20 OBJECT **qtsettab= NULL; /* quadtree leaf node table */
21 QUADTREE qtnumsets; /* number of used set indices */
22 static int qtfreesets = EMPTY; /* free set index list */
23
24
25 QUADTREE
26 qtnewleaf(oset) /* return new leaf node for object set */
27 OBJECT *oset;
28 {
29 register QUADTREE osi;
30
31 if (*oset <= 0)
32 return(EMPTY); /* should be error? */
33 if (qtfreesets != EMPTY) {
34 osi = qtfreesets;
35 qtfreesets = (int)qtsettab[osi];
36 } else if ((osi = qtnumsets++) % QTSETIBLK == 0) {
37 qtsettab = (OBJECT **)realloc((void *)qtsettab,
38 (unsigned)(osi+QTSETIBLK)*sizeof(OBJECT *));
39 if (qtsettab == NULL)
40 goto memerr;
41 }
42 qtsettab[osi] = (OBJECT *)malloc(QTNODESIZ(*oset)*sizeof(OBJECT));
43 if (qtsettab[osi] == NULL)
44 goto memerr;
45 setcopy(qtsettab[osi], oset);
46 return(QT_INDEX(osi));
47 memerr:
48 error(SYSTEM, "out of memory in qtnewleaf");
49 }
50
51
52 QUADTREE
53 qtdelelem(qt, id) /* delete element from leaf node */
54 QUADTREE qt;
55 OBJECT id;
56 {
57 register QUADTREE lf;
58
59 #ifdef DEBUG
60 if(id < 0)
61 eputs("qtdelelem():Invalid triangle id\n");
62 if (!QT_IS_LEAF(qt) || (lf = QT_SET_INDEX(qt)) >= qtnumsets)
63 error(CONSISTENCY, "empty/bad node in qtdelelem");
64 if (!inset(qtsettab[lf], id))
65 error(CONSISTENCY, "id not in leaf in qtdelelem");
66 #else
67 lf = QT_SET_INDEX(qt);
68 #endif
69 if (qtsettab[lf][0] <= 1) { /* blow leaf away */
70 free((void *)qtsettab[lf]);
71 qtsettab[lf] = (OBJECT *)qtfreesets;
72 qtfreesets = lf;
73 return(EMPTY);
74 }
75 deletelem(qtsettab[lf], id);
76 if (QTONTHRESH(qtsettab[lf][0]))
77 qtsettab[lf] = (OBJECT *)realloc((void *)qtsettab[lf],
78 QTNODESIZ(qtsettab[lf][0])*sizeof(OBJECT));
79 return(qt);
80 }
81
82
83 QUADTREE
84 qtaddelem(qt, id) /* add element to leaf node */
85 QUADTREE qt;
86 OBJECT id;
87 {
88 OBJECT newset[2];
89 register QUADTREE lf;
90
91 #ifdef DEBUG
92 if(id < 0)
93 eputs("qtaddelem():Invalid triangle id\n");
94 #endif
95 if (QT_IS_EMPTY(qt)) { /* create new leaf */
96 newset[0] = 1; newset[1] = id;
97 return(qtnewleaf(newset));
98 } /* else add element */
99 #ifdef DEBUG
100 if (!QT_IS_LEAF(qt) || (lf = QT_SET_INDEX(qt)) >= qtnumsets)
101 error(CONSISTENCY, "bad node in qtaddelem");
102 if (inset(qtsettab[lf], id))
103 error(CONSISTENCY, "id already in leaf in qtaddelem");
104 #else
105 lf = QT_SET_INDEX(qt);
106 #endif
107 if (QTONTHRESH(qtsettab[lf][0])) {
108 qtsettab[lf] = (OBJECT *)realloc((void *)qtsettab[lf],
109 QTNODESIZ(qtsettab[lf][0]+1)*sizeof(OBJECT));
110 if (qtsettab[lf] == NULL)
111 error(SYSTEM, "out of memory in qtaddelem");
112 }
113 insertelem(qtsettab[lf], id);
114 return(qt);
115 }
116
117
118 #ifdef DEBUG
119 OBJECT *
120 qtqueryset(qt) /* return object set for leaf node */
121 QUADTREE qt;
122 {
123 register QUADTREE lf;
124
125 if (!QT_IS_LEAF(qt) || (lf = QT_SET_INDEX(qt)) >= qtnumsets)
126 error(CONSISTENCY, "bad node in qtqueryset");
127 return(qtsettab[lf]);
128 }
129 #endif
130
131
132 qtfreeleaf(qt) /* free set and leaf node */
133 QUADTREE qt;
134 {
135 register QUADTREE osi;
136
137 if (!QT_IS_LEAF(qt))
138 return;
139 osi = QT_SET_INDEX(qt);
140 if (osi >= qtnumsets)
141 return;
142 free((void *)qtsettab[osi]);
143 qtsettab[osi] = (OBJECT *)qtfreesets;
144 qtfreesets = osi;
145 }
146
147
148
149 qtfreeleaves() /* free ALL sets and leaf nodes */
150 {
151 register int i;
152
153 while ((i = qtfreesets) != EMPTY) {
154 qtfreesets = (int)qtsettab[i];
155 qtsettab[i] = NULL;
156 }
157 for (i = qtnumsets; i--; )
158 if (qtsettab[i] != NULL)
159 free((void *)qtsettab[i]);
160 free((void *)qtsettab);
161 qtsettab = NULL;
162 qtnumsets = 0;
163 }
164
165
166 check_set(os, cs) /* modify checked set and set to check */
167 register OBJECT *os; /* os' = os - cs */
168 register OBJECT *cs; /* cs' = cs + os */
169 {
170 OBJECT cset[QT_MAXCSET+QT_MAXSET+1];
171 register int i, j;
172 int k;
173 /* copy os in place, cset <- cs */
174 cset[0] = 0;
175 k = 0;
176 for (i = j = 1; i <= os[0]; i++) {
177 while (j <= cs[0] && cs[j] < os[i])
178 cset[++cset[0]] = cs[j++];
179 if (j > cs[0] || os[i] != cs[j]) { /* object to check */
180 os[++k] = os[i];
181 cset[++cset[0]] = os[i];
182 }
183 }
184 if (!(os[0] = k)) /* new "to check" set size */
185 return; /* special case */
186 while (j <= cs[0]) /* get the rest of cs */
187 cset[++cset[0]] = cs[j++];
188 if (cset[0] > QT_MAXCSET) /* truncate "checked" set if nec. */
189 cset[0] = QT_MAXCSET;
190 /* setcopy(cs, cset); */ /* copy cset back to cs */
191 os = cset;
192 for (i = os[0]; i-- >= 0; )
193 *cs++ = *os++;
194 }
195
196
197
198
199
200
201
202
203
