--- ray/src/hd/sm_sets.c 1998/09/16 18:16:29 3.3 +++ ray/src/hd/sm_sets.c 1999/06/10 15:22:24 3.5 @@ -29,26 +29,26 @@ QUADTREE qtnewleaf(oset) /* return new leaf node for object set */ OBJECT *oset; { - register QUADTREE osi; + register QUADTREE osi; - if (*oset <= 0) - return(EMPTY); /* should be error? */ - if (qtfreesets != EMPTY) { - osi = qtfreesets; - qtfreesets = (int)qtsettab[osi]; - } else if ((osi = qtnumsets++) % QTSETIBLK == 0) { - qtsettab = (OBJECT **)realloc((char *)qtsettab, - (unsigned)(osi+QTSETIBLK)*sizeof(OBJECT *)); - if (qtsettab == NULL) - goto memerr; - } - qtsettab[osi] = (OBJECT *)malloc(QTNODESIZ(*oset)*sizeof(OBJECT)); - if (qtsettab[osi] == NULL) - goto memerr; - setcopy(qtsettab[osi], oset); - return(QT_INDEX(osi)); + if (*oset <= 0) + return(EMPTY); /* should be error? */ + if (qtfreesets != EMPTY) { + osi = qtfreesets; + qtfreesets = (int)qtsettab[osi]; + } else if ((osi = qtnumsets++) % QTSETIBLK == 0) { + qtsettab = (OBJECT **)realloc((char *)qtsettab, + (unsigned)(osi+QTSETIBLK)*sizeof(OBJECT *)); + if (qtsettab == NULL) + goto memerr; + } + qtsettab[osi] = (OBJECT *)malloc(QTNODESIZ(*oset)*sizeof(OBJECT)); + if (qtsettab[osi] == NULL) + goto memerr; + setcopy(qtsettab[osi], oset); + return(QT_INDEX(osi)); memerr: - error(SYSTEM, "out of memory in qtnewleaf"); + error(SYSTEM, "out of memory in qtnewleaf"); } @@ -195,4 +195,12 @@ register OBJECT *cs; /* cs' = cs + for (i = os[0]; i-- >= 0; ) *cs++ = *os++; } + + + + + + + +
