root/radiance/ray/src/hd/sm_samp.c
Revision 3.10
Fri Nov 5 03:31:37 2004 UTC (19 years, 6 months ago) by greg
FILE REMOVED
Changes since 3.8: +5 -2 lines
Diff to previous 3.8
Changes since 3.7: +5 -5 lines
Diff to previous 3.7
Sat Feb 22 02:07:25 2003 UTC (21 years, 2 months ago) by greg
Changes since 3.6: +18 -13 lines
Diff to previous 3.6
Thu Jun 10 15:22:24 1999 UTC (24 years, 10 months ago) by gwlarson
Changes since 3.5: +40 -62 lines
Diff to previous 3.5
Implemented sample quadtree in place of triangle quadtree
Made geometric predicates more robust
Added #define LORES which utilizes a single precision floating point
  sample array, the default is a double sample array
Added topology DEBUG commands (for DEBUG > 1)
Made code optimizations
Sun Jan 10 10:27:46 1999 UTC (25 years, 3 months ago) by gwlarson
Changes since 3.4: +5 -5 lines
Diff to previous 3.4
sm.c, sm_del.c sm_ogl.c sm.h
Fixed failure to tone-map on start up
added code for temporary buffer allocation
added bg flag, and fast flag checking routines for drawing
provided graceful backout if deletion triangulation fails
Wed Nov 11 12:05:40 1998 UTC (25 years, 5 months ago) by gwlarson
Changes since 3.3: +63 -47 lines
Diff to previous 3.3
new triangulation code
changed triangle vertex order to CCW
changed numbering of triangle neighbors to match quadtree
fixed tone-mapping bug
removed errant printf() statements
redid logic for adding and testing samples with new epsilon
Tue Oct 6 18:16:54 1998 UTC (25 years, 7 months ago) by gwlarson
Changes since 3.2: +180 -179 lines
Diff to previous 3.2
new triangulate routine
added smTestSample to check for occlusion
added frustum culling before rebuild
changed base quadtree to use octahedron and created new point locate
added "sample active" flags and implemented LRU replacement
started handling case of too many triangles
set sizes are now unbounded
changed all quadtree pointers to quadtrees
Fri Sep 11 11:52:27 1998 UTC (25 years, 7 months ago) by gwlarson
Changes since 3.1: +2 -2 lines
Diff to previous 3.1
fixed triangle insertion using edge tracing
Wed Aug 19 17:45:24 1998 UTC (25 years, 8 months ago) by gwlarson
