--- ray/src/hd/sm_samp.c 1999/06/10 15:22:24 3.6 +++ ray/src/hd/sm_samp.c 2003/02/22 02:07:25 3.7 @@ -1,9 +1,6 @@ -/* Copyright (c) 1998 Silicon Graphics, Inc. */ - #ifndef lint -static char SCCSid[] = "$SunId$ SGI"; +static const char RCSid[] = "$Id: sm_samp.c,v 3.7 2003/02/22 02:07:25 greg Exp $"; #endif - /* * sm_samp.c */ @@ -75,6 +72,10 @@ int *nptr,extra_points; /* get number of samples that fit in block */ n = (i - 8 - extra_points*POINTSIZ) / SAMPSIZ; + /* Must make sure n + extra_points can fit in a S_ID identifier */ + if ( n > (S_ID_MAX - extra_points)) + n = (S_ID_MAX - extra_points); + S_BASE(s) = (char *)malloc(n*SAMPSIZ + extra_points*POINTSIZ); if (!S_BASE(s)) error(SYSTEM,"sAlloc(): Unable to allocate memory"); @@ -106,12 +107,12 @@ int *nptr,extra_points; is added: These points are not displayed-they are used to form the initial mesh */ -int +S_ID sAdd_base_point(s,v) SAMP *s; FVECT v; { - int id; + S_ID id; /* Get pointer to next available point */ id = S_NEXT_BASE_PT(s); @@ -132,7 +133,7 @@ sAdd_base_point(s,v) int sCopy_samp(s,n_id,id) SAMP *s; - int n_id,id; + S_ID n_id,id; { #ifdef DEBUG @@ -165,10 +166,10 @@ sCopy_samp(s,n_id,id) void sInit_samp(s,id,c,d,p,o_id) SAMP *s; - int id; + S_ID id; COLR c; FVECT d,p; - int o_id; + S_ID o_id; { if(o_id != INVALID) @@ -185,9 +186,7 @@ sInit_samp(s,id,c,d,p,o_id) /* calculate the brightness and chrominance,RGB will be set by tonemapping */ -#ifndef TEST_DRIVER tmCvColrs(&S_NTH_BRT(s,id),S_NTH_CHR(s,id),c,1); -#endif } /* Set ACTIVE bit upon creation */ S_SET_FLAG(id); @@ -197,13 +196,13 @@ sInit_samp(s,id,c,d,p,o_id) /* Allocate a new sample. If an existing sample was replaced: set flag */ -int +S_ID sAlloc_samp(s,replaced) SAMP *s; int *replaced; { - int id; + S_ID id; /* First check if there are any freed sample available */ if((id = S_FREE_SAMP(s)) != INVALID) @@ -251,6 +250,12 @@ sAlloc_samp(s,replaced) *replaced = 1; return(id); } + + + + + +
