--- ray/src/hd/sm_samp.c 1998/08/19 17:45:24 3.1 +++ ray/src/hd/sm_samp.c 2003/06/20 00:25:49 3.8 @@ -1,263 +1,263 @@ -/* Copyright (c) 1998 Silicon Graphics, Inc. */ - #ifndef lint -static char SCCSid[] = "$SunId$ SGI"; +static const char RCSid[] = "$Id: sm_samp.c,v 3.8 2003/06/20 00:25:49 greg Exp $"; #endif - /* * sm_samp.c */ #include "standard.h" +#include "sm_flag.h" +#include "rhd_sample.h" -#include "sm.h" +SAMP rsL; +int32 *samp_flag=NULL; -RSAMP rsL; +/* Each sample has a world coord point, and direction, brightness,chrominance, + and RGB triples + */ +#define TMSIZE sizeof(TMbright) +#define SAMPSIZ (3*sizeof(SFLOAT)+sizeof(int32)+ 6*sizeof(BYTE) + TMSIZE + 2*sizeof(int)) -#define SAMPSIZ (3*sizeof(float)+sizeof(int4)+\ - sizeof(TMbright)+6*sizeof(BYTE)) -/* Initialize/clear global smL sample list for at least n samples */ -int -smAlloc_samples(sm,n,extra_points) -SM *sm; -register int n,extra_points; + /* Extra points world space point, vert flag and qt flag */ +#define POINTSIZ (3*sizeof(SFLOAT) + 2*sizeof(int)) + +/* Clear the flags for all samples */ +sClear_all_flags(s) +SAMP *s; { - unsigned nbytes; - register unsigned i; - RSAMP *rs; + if(samp_flag) + bzero((char *)samp_flag,FLAG_BYTES(S_MAX_BASE_PT(s))); +} - rs = &rsL; +sInit(s) + SAMP *s; +{ + S_REPLACE_SAMP(s) = 0; + S_NUM_SAMP(s) = 0; + S_TONE_MAP(s) = 0; + S_FREE_SAMP(s) = -1; + sClear_base_points(s); - SM_SAMP(sm) = rs; +} +sFree(s) +SAMP *s; +{ + if(S_BASE(s)) + { + free(S_BASE(s)); + S_BASE(s)=NULL; + } + if(samp_flag) + { + free(samp_flag); + samp_flag = NULL; + } +} + /* Initialize/clear global smL sample list for at least n samples */ +SAMP +*sAlloc(nptr,extra_points) +int *nptr,extra_points; +{ + unsigned nbytes; + register unsigned i; + SAMP *s; + int n; + + s = &rsL; /* round space up to nearest power of 2 */ - nbytes = n*SAMPSIZ + extra_points*SM_POINTSIZ + 8; + nbytes = (*nptr)*SAMPSIZ + extra_points*POINTSIZ + 8; for (i = 1024; nbytes > i; i <<= 1) ; - n = (i - 8 - extra_points*SM_POINTSIZ) / SAMPSIZ; + /* get number of samples that fit in block */ + n = (i - 8 - extra_points*POINTSIZ) / SAMPSIZ; - RS_BASE(rs) = (char *)malloc(n*SAMPSIZ + extra_points*SM_POINTSIZ); - if (!RS_BASE(rs)) - error(SYSTEM,"smInit_samples(): Unable to allocate memory"); + /* Must make sure n + extra_points can fit in a S_ID identifier */ + if ( n > (S_ID_MAX - extra_points)) + n = (S_ID_MAX - extra_points); + S_BASE(s) = (char *)malloc(n*SAMPSIZ + extra_points*POINTSIZ); + if (!S_BASE(s)) + error(SYSTEM,"sAlloc(): Unable to allocate memory"); + /* assign larger alignment types earlier */ - RS_W_PT(rs) = (float (*)[3])RS_BASE(rs); - RS_W_DIR(rs) = (int4 *)(RS_W_PT(rs) + n + extra_points); - RS_BRT(rs) = (TMbright *)(RS_W_DIR(rs) + n + extra_points); - RS_CHR(rs) = (BYTE (*)[3])(RS_BRT(rs) + n); - RS_RGB(rs) = (BYTE (*)[3])(RS_CHR(rs) + n); - RS_MAX_SAMP(rs) = n; - RS_MAX_AUX_PT(rs) = n + extra_points; + S_W_PT(s) = (SFLOAT(*)[3])S_BASE(s); + S_W_DIR(s) = (int32 *)(S_W_PT(s) + n + extra_points); + S_BRT(s) = (TMbright *)(S_W_DIR(s) + n); + S_CHR(s) = (BYTE (*)[3])(S_BRT(s) + n); + S_RGB(s) = (BYTE (*)[3])(S_CHR(s) + n); + S_INFO(s) = (int *)(S_RGB(s)+n); + S_INFO1(s) = (int *)(S_INFO(s)+n+extra_points); + S_MAX_SAMP(s) = n; + S_MAX_BASE_PT(s) = n + extra_points; - smClear_samples(sm); + /* Allocate memory for a per/sample bit flag */ + if(!(samp_flag = (int32 *)malloc(FLAG_BYTES(n+extra_points)))) + error(SYSTEM,"sAlloc(): Unable to allocate flag memory"); + sInit(s); + sClear_all_flags(s); - return(n); + *nptr = n; + + return(s); } -smClear_aux_samples(sm) -SM *sm; -{ - RS_NEXT_AUX_PT(SM_SAMP(sm)) = RS_MAX_SAMP(SM_SAMP(sm)); -} -int -smClear_samples(sm) - SM *sm; +/* Add a base point to the sample structure: only the world point + is added: These points are not displayed-they are used to form the + initial mesh + */ +S_ID +sAdd_base_point(s,v) + SAMP *s; + FVECT v; { - RSAMP *samp; + S_ID id; - samp = SM_SAMP(sm); - RS_FREE_SAMP(samp) = -1; - RS_REPLACE_SAMP(samp) = 0; - RS_NUM_SAMP(samp) = 0; - RS_TONE_MAP(samp) = 0; - smClear_aux_samples(sm); - return(1); -} - -int -smAdd_aux_point(sm,v,d) - SM *sm; - FVECT v,d; -{ - RSAMP *samp; - int id; - - /* Get the SM sample array */ - samp = SM_SAMP(sm); /* Get pointer to next available point */ - id = RS_NEXT_AUX_PT(samp); - if(id >= RS_MAX_AUX_PT(samp)) + id = S_NEXT_BASE_PT(s); + if(id >= S_MAX_BASE_PT(s)) return(-1); /* Update free aux pointer */ - RS_NEXT_AUX_PT(samp)++; + S_NEXT_BASE_PT(s)++; /* Copy vector into point */ - VCOPY(RS_NTH_W_PT(samp,id),v); - RS_NTH_W_DIR(samp,id) = encodedir(d); + VCOPY(S_NTH_W_PT(s,id),v); return(id); } -void -smInit_sample(sm,id,c,d,p) - SM *sm; - int id; - COLR c; - FVECT d,p; +/* Copy the values of sample n_id into sample id: Note must not call with + Base point n_id +*/ +int +sCopy_samp(s,n_id,id) + SAMP *s; + S_ID n_id,id; { - RSAMP *samp; - samp = SM_SAMP(sm); - if(p) +#ifdef DEBUG + if(id <0||id >= S_MAX_SAMP(s)||n_id <0||n_id >= S_MAX_SAMP(s)) { - /* Copy vector into point */ - VCOPY(RS_NTH_W_PT(samp,id),p); - RS_NTH_W_DIR(samp,id) = encodedir(d); + eputs("smReset_sample():invalid sample id\n"); + return(0); } - else - { - VADD(RS_NTH_W_PT(samp,id),d,SM_VIEW_CENTER(sm)); - RS_NTH_W_DIR(samp,id) = -1; - } - -#ifndef TEST_DRIVER - tmCvColrs(&RS_NTH_BRT(samp,id),RS_NTH_CHR(samp,id),c,1); -#else - if(c) - { - RS_NTH_RGB(samp,id)[0] = c[0]; - RS_NTH_RGB(samp,id)[1] = c[1]; - RS_NTH_RGB(samp,id)[2] = c[2]; - } - else - { - RS_NTH_RGB(samp,id)[0] = 100; - RS_NTH_RGB(samp,id)[1] = 0; - RS_NTH_RGB(samp,id)[2] = 0; - } #endif + if(n_id == id) + return(1); + /* Copy vector into point */ + VCOPY(S_NTH_W_PT(s,n_id),S_NTH_W_PT(s,id)); + S_NTH_W_DIR(s,n_id) = S_NTH_W_DIR(s,id); + + S_NTH_BRT(s,n_id) = S_NTH_BRT(s,id); + S_NTH_CHR(s,n_id)[0] = S_NTH_CHR(s,id)[0]; + S_NTH_CHR(s,n_id)[1] = S_NTH_CHR(s,id)[1]; + S_NTH_CHR(s,n_id)[2] = S_NTH_CHR(s,id)[2]; + + return(1); } +/* Initialize the sample 'id' to contain world point 'p', direction 'd' and + color 'c'. If 'p' is NULL, a direction only is represented in 'd'. In + this case, the world point is set to the projection of the direction on + the view sphere, and the direction value is set to -1 + */ void -smReset_sample(sm,id,n_id) - SM *sm; - int id,n_id; +sInit_samp(s,id,c,d,p,o_id) + SAMP *s; + S_ID id; + COLR c; + FVECT d,p; + S_ID o_id; { - RSAMP *samp; - samp = SM_SAMP(sm); - + if(o_id != INVALID) + sCopy_samp(s,id,o_id); + else + { /* Copy vector into point */ - VCOPY(RS_NTH_W_PT(samp,id),RS_NTH_W_PT(samp,n_id)); - RS_NTH_W_DIR(samp,id) = RS_NTH_W_DIR(samp,n_id); + VCOPY(S_NTH_W_PT(s,id),p); + if(d) + S_NTH_W_DIR(s,id) = encodedir(d); + else + S_NTH_W_DIR(s,id) = -1; - RS_NTH_BRT(samp,id) = RS_NTH_BRT(samp,n_id); - RS_NTH_CHR(samp,id)[0] = RS_NTH_CHR(samp,n_id)[0]; - RS_NTH_CHR(samp,id)[1] = RS_NTH_CHR(samp,n_id)[1]; - RS_NTH_CHR(samp,id)[2] = RS_NTH_CHR(samp,n_id)[2]; - RS_NTH_RGB(samp,id)[0] = RS_NTH_RGB(samp,n_id)[0]; - RS_NTH_RGB(samp,id)[1] = RS_NTH_RGB(samp,n_id)[1]; - RS_NTH_RGB(samp,id)[2] = RS_NTH_RGB(samp,n_id)[2]; - + /* calculate the brightness and chrominance,RGB will be set by + tonemapping + */ + tmCvColrs(&S_NTH_BRT(s,id),S_NTH_CHR(s,id),c,1); + } + /* Set ACTIVE bit upon creation */ + S_SET_FLAG(id); + if(id < S_TONE_MAP(s)) + tmMapPixels(S_NTH_RGB(s,id),&S_NTH_BRT(s,id),S_NTH_CHR(s,id),1); } -int -rsAlloc_samp(samp,replaced) - RSAMP *samp; - char *replaced; + +/* Allocate a new sample. If an existing sample was replaced: set flag */ +S_ID +sAlloc_samp(s,replaced) + SAMP *s; + int *replaced; { - int id; + S_ID id; - if(replaced) - *replaced = FALSE; - if(RS_NUM_SAMP(samp) < RS_MAX_SAMP(samp)) + /* First check if there are any freed sample available */ + if((id = S_FREE_SAMP(s)) != INVALID) { - id = RS_NUM_SAMP(samp); - RS_NUM_SAMP(samp)++; - + *replaced = 0; +#if 0 + fprintf(stderr,"allocating previously freed sample %d\n",id); +#endif + S_FREE_SAMP(s) = S_NTH_NEXT(s,id); + return(id); } - else - if(RS_REPLACE_SAMP(samp) != -1) - { - id = RS_REPLACE_SAMP(samp); - /* NOTE: NEED to do LRU later*/ - RS_REPLACE_SAMP(samp) = (id + 1)% RS_MAX_SAMP(samp); - if(replaced) - *replaced = TRUE; - } - else - if(RS_FREE_SAMP(samp) != -1) - { - id = RS_FREE_SAMP(samp); - RS_FREE_SAMP(samp) = RS_NTH_W_DIR(samp,id); - } - else - { -#ifdef DEBUG - eputs("rsAlloc_samp(): no samples available"); + /* If havn't reached end of sample array:return next sample */ + if(S_NUM_SAMP(s) < S_MAX_SAMP(s)) + { + id = S_NUM_SAMP(s)++; +#if 0 + fprintf(stderr,"allocating sample %d\n",id); #endif - id = -1; - } + *replaced = 0; + return(id); + } + +#ifdef DEBUG +{ + static int replace = 0; + if(replace == 0) + { + eputs("Out of samples: using replacement strategy\n"); + replace =1 ; + } +} +#endif + /* CLOCKED LRU replacement policy: Search through samples starting + with S_REPLACE_SAMP for a sample that does not have its active + bit set. Clear bit along the way + */ + id = S_REPLACE_SAMP(s); + while(S_IS_FLAG(id)) + { + S_CLR_FLAG(id); + id = (id +1)% S_MAX_SAMP(s); + } + S_REPLACE_SAMP(s) = (id +1)% S_MAX_SAMP(s); + *replaced = 1; return(id); } -int -rsDelete_sample(samp,id) -RSAMP *samp; -int id; -{ - /* First check for a valid id */ - if(id >= RS_MAX_SAMP(samp) || id < 0) - return(FALSE); - - RS_NTH_W_DIR(samp,id) = RS_FREE_SAMP(samp); - RS_FREE_SAMP(samp) = id; - return(TRUE); -} -int -smDelete_sample(sm,id) -SM *sm; -int id; -{ - RSAMP *samp; - samp = SM_SAMP(sm); - return(rsDelete_sample(samp,id)); -} -/* NEEDS: to add free list- and bit for clocked LRU */ -int -smAdd_sample_point(sm,c,dir,p) - SM *sm; - COLR c; - FVECT dir; - FVECT p; -{ - RSAMP *samp; - int id; - char replaced; - - /* Get the SM sample array */ - samp = SM_SAMP(sm); - /* Get pointer to next available point */ - id = rsAlloc_samp(samp,&replaced); - if(id < 0) - return(-1); - if(replaced) - smMesh_remove_vertex(sm,id); - - smInit_sample(sm,id,c,dir,p); - return(id); -}
