root/radiance/ray/src/hd/sm_samp.c
Revision: 3.4
Committed: Wed Nov 11 12:05:40 1998 UTC (26 years, 6 months ago) by gwlarson
Changes since 3.3: +63 -47 lines
new triangulation code
changed triangle vertex order to CCW
changed numbering of triangle neighbors to match quadtree
fixed tone-mapping bug
removed errant printf() statements
redid logic for adding and testing samples with new epsilon
1 /* Copyright (c) 1998 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * sm_samp.c
9 */
10 #include "standard.h"
11 #include "sm_flag.h"
12 #include "rhd_sample.h"
13
14 SAMP rsL;
15 int4 *samp_flag=NULL;
16
17
18 /* Each sample has a world coord point, and direction, brightness,chrominance,
19 and RGB triples
20 */
21 #ifndef HP_VERSION
22 #define TMSIZE sizeof(TMbright)
23 #else
24 #define TMSIZE 0
25 #endif
26 #define SAMPSIZ (3*sizeof(float)+sizeof(int4)+ 6*sizeof(BYTE) + TMSIZE)
27
28 /* Extra points just need direction and world space point */
29 #define POINTSIZ (3*sizeof(float))
30
31 /* Clear the flags for all samples */
32 sClear_all_flags(s)
33 SAMP *s;
34 {
35 if(samp_flag)
36 bzero((char *)samp_flag,FLAG_BYTES(S_MAX_SAMP(s)));
37 }
38
39 sInit(s)
40 SAMP *s;
41 {
42 S_REPLACE_SAMP(s) = 0;
43 S_NUM_SAMP(s) = 0;
44 S_TONE_MAP(s) = 0;
45 S_FREE_SAMP(s) = -1;
46 sClear_base_points(s);
47
48 }
49
50 sFree(s)
51 SAMP *s;
52 {
53 if(S_BASE(s))
54 {
55 free(S_BASE(s));
56 S_BASE(s)=NULL;
57 }
58 if(samp_flag)
59 {
60 free(samp_flag);
61 samp_flag = NULL;
62 }
63 }
64 /* Initialize/clear global smL sample list for at least n samples */
65 SAMP
66 *sAlloc(nptr,extra_points)
67 int *nptr,extra_points;
68 {
69 unsigned nbytes;
70 register unsigned i;
71 SAMP *s;
72 int n;
73
74 s = &rsL;
75 /* round space up to nearest power of 2 */
76 nbytes = (*nptr)*SAMPSIZ + extra_points*POINTSIZ + 8;
77 for (i = 1024; nbytes > i; i <<= 1)
78 ;
79 /* get number of samples that fit in block */
80 n = (i - 8 - extra_points*POINTSIZ) / SAMPSIZ;
81
82 S_BASE(s) = (char *)malloc(n*SAMPSIZ + extra_points*POINTSIZ);
83 if (!S_BASE(s))
84 error(SYSTEM,"sAlloc(): Unable to allocate memory");
85
86 /* assign larger alignment types earlier */
87 S_W_PT(s) = (float (*)[3])S_BASE(s);
88 S_W_DIR(s) = (int4 *)(S_W_PT(s) + n + extra_points);
89 S_BRT(s) = (TMbright *)(S_W_DIR(s) + n);
90 S_CHR(s) = (BYTE (*)[3])(S_BRT(s) + n);
91 S_RGB(s) = (BYTE (*)[3])(S_CHR(s) + n);
92 S_MAX_SAMP(s) = n;
93 S_MAX_BASE_PT(s) = n + extra_points;
94
95 /* Allocate memory for a per/sample bit flag */
96 if(!(samp_flag = (int4 *)malloc(FLAG_BYTES(n))))
97 error(SYSTEM,"sAlloc(): Unable to allocate flag memory");
98
99 sInit(s);
100 sClear_all_flags(s);
101
102 *nptr = n;
103
104 return(s);
105 }
106
107
108 /* Add a base point to the sample structure: only the world point
109 is added: These points are not displayed-they are used to form the
110 initial mesh
111 */
112 int
113 sAdd_base_point(s,v)
114 SAMP *s;
115 FVECT v;
116 {
117 int id;
118
119 /* Get pointer to next available point */
120 id = S_NEXT_BASE_PT(s);
121 if(id >= S_MAX_BASE_PT(s))
122 return(-1);
123
124 /* Update free aux pointer */
125 S_NEXT_BASE_PT(s)++;
126
127 /* Copy vector into point */
128 VCOPY(S_NTH_W_PT(s,id),v);
129 return(id);
130 }
131
132 /* Copy the values of sample n_id into sample id: Note must not call with
133 Base point n_id
134 */
135 int
136 sCopy_samp(s,n_id,id)
137 SAMP *s;
138 int n_id,id;
139 {
140
141 #ifdef DEBUG
142 if(id <0||id >= S_MAX_SAMP(s)||n_id <0||n_id >= S_MAX_SAMP(s))
143 {
144 eputs("smReset_sample():invalid sample id\n");
145 return(0);
146 }
147 #endif
148 if(n_id == id)
149 return(1);
150 /* Copy vector into point */
151 VCOPY(S_NTH_W_PT(s,n_id),S_NTH_W_PT(s,id));
152 S_NTH_W_DIR(s,n_id) = S_NTH_W_DIR(s,id);
153
154 S_NTH_BRT(s,n_id) = S_NTH_BRT(s,id);
155 S_NTH_CHR(s,n_id)[0] = S_NTH_CHR(s,id)[0];
156 S_NTH_CHR(s,n_id)[1] = S_NTH_CHR(s,id)[1];
157 S_NTH_CHR(s,n_id)[2] = S_NTH_CHR(s,id)[2];
158
159 return(1);
160 }
161
162
163 /* Initialize the sample 'id' to contain world point 'p', direction 'd' and
164 color 'c'. If 'p' is NULL, a direction only is represented in 'd'. In
165 this case, the world point is set to the projection of the direction on
166 the view sphere, and the direction value is set to -1
167 */
168 void
169 sInit_samp(s,id,c,d,p,o_id,tonemap)
170 SAMP *s;
171 int id;
172 COLR c;
173 FVECT d,p;
174 int o_id,tonemap;
175 {
176
177 if(o_id != INVALID)
178 sCopy_samp(s,id,o_id);
179 else
180 {
181 /* Copy vector into point */
182 VCOPY(S_NTH_W_PT(s,id),p);
183 if(d)
184 S_NTH_W_DIR(s,id) = encodedir(d);
185 else
186 S_NTH_W_DIR(s,id) = -1;
187
188 /* calculate the brightness and chrominance,RGB will be set by
189 tonemapping
190 */
191 #ifndef TEST_DRIVER
192 tmCvColrs(&S_NTH_BRT(s,id),S_NTH_CHR(s,id),c,1);
193 #else
194 if(c)
195 {
196 S_NTH_RGB(s,id)[0] = c[0];
197 S_NTH_RGB(s,id)[1] = c[1];
198 S_NTH_RGB(s,id)[2] = c[2];
199 }
200 else
201 {
202 S_NTH_RGB(s,id)[0] = 100;
203 S_NTH_RGB(s,id)[1] = 0;
204 S_NTH_RGB(s,id)[2] = 0;
205 }
206 #endif
207 }
208 /* Set ACTIVE bit upon creation */
209 S_SET_FLAG(id);
210 #ifndef TEST_DRIVER
211 if(tonemap)
212 tmMapPixels(S_NTH_RGB(s,id),&S_NTH_BRT(s,id),S_NTH_CHR(s,id),1);
213 #endif
214 }
215
216
217 /* Allocate a new sample. If an existing sample was replaced: set flag */
218 int
219 sAlloc_samp(s,replaced)
220 SAMP *s;
221 int *replaced;
222
223 {
224 int id;
225
226 if(replaced)
227 *replaced = 0;
228
229 /* First check if there are any freed sample available */
230 if((id = S_FREE_SAMP(s)) != INVALID)
231 {
232 S_FREE_SAMP(s) = S_NTH_NEXT(s,id);
233 return(id);
234 }
235 /* If havn't reached end of sample array:return next sample */
236 if(S_NUM_SAMP(s) < S_MAX_SAMP(s))
237 id = S_NUM_SAMP(s)++;
238 else
239 {
240 /* CLOCKED LRU replacement policy: Search through samples starting
241 with S_REPLACE_SAMP for a sample that does not have its active
242 bit set. Clear bit along the way
243 */
244 id = S_REPLACE_SAMP(s);
245 while(S_IS_FLAG(id))
246 {
247 S_CLR_FLAG(id);
248 id = (id +1)% S_MAX_SAMP(s);
249 }
250 S_REPLACE_SAMP(s) = (id +1)% S_MAX_SAMP(s);
251 if(replaced)
252 *replaced = 1;
253 }
254 return(id);
255 }
256
257 /* Set the sample flag to be unused- so will get replaced on next LRU
258 iteration
259 */
260 int
261 sDelete_samp(s,id)
262 SAMP *s;
263 int id;
264 {
265 #ifdef DEBUG
266 /* Fist check for a valid id */
267 if(id >= S_MAX_SAMP(s) || id < 0)
268 return(0);
269 #endif
270 /* Add sample to the free list */
271 sUnalloc_samp(s,id);
272
273 S_CLR_FLAG(id);
274 return(1);
275 }
276
277
278
279
280
281
282
283
284
285
286
