--- ray/src/hd/sm_samp.c 1999/01/10 10:27:46 3.5 +++ ray/src/hd/sm_samp.c 2003/02/22 02:07:25 3.7 @@ -1,9 +1,6 @@ -/* Copyright (c) 1998 Silicon Graphics, Inc. */ - #ifndef lint -static char SCCSid[] = "$SunId$ SGI"; +static const char RCSid[] = "$Id: sm_samp.c,v 3.7 2003/02/22 02:07:25 greg Exp $"; #endif - /* * sm_samp.c */ @@ -14,19 +11,15 @@ static char SCCSid[] = "$SunId$ SGI"; SAMP rsL; int4 *samp_flag=NULL; - /* Each sample has a world coord point, and direction, brightness,chrominance, and RGB triples */ -#ifndef HP_VERSION + #define TMSIZE sizeof(TMbright) -#else -#define TMSIZE 0 -#endif -#define SAMPSIZ (3*sizeof(float)+sizeof(int4)+ 6*sizeof(BYTE) + TMSIZE) +#define SAMPSIZ (3*sizeof(SFLOAT)+sizeof(int4)+ 6*sizeof(BYTE) + TMSIZE + 2*sizeof(int)) - /* Extra points just need direction and world space point */ -#define POINTSIZ (3*sizeof(float)) + /* Extra points world space point, vert flag and qt flag */ +#define POINTSIZ (3*sizeof(SFLOAT) + 2*sizeof(int)) /* Clear the flags for all samples */ sClear_all_flags(s) @@ -79,23 +72,28 @@ int *nptr,extra_points; /* get number of samples that fit in block */ n = (i - 8 - extra_points*POINTSIZ) / SAMPSIZ; + /* Must make sure n + extra_points can fit in a S_ID identifier */ + if ( n > (S_ID_MAX - extra_points)) + n = (S_ID_MAX - extra_points); + S_BASE(s) = (char *)malloc(n*SAMPSIZ + extra_points*POINTSIZ); if (!S_BASE(s)) error(SYSTEM,"sAlloc(): Unable to allocate memory"); /* assign larger alignment types earlier */ - S_W_PT(s) = (float (*)[3])S_BASE(s); + S_W_PT(s) = (SFLOAT(*)[3])S_BASE(s); S_W_DIR(s) = (int4 *)(S_W_PT(s) + n + extra_points); S_BRT(s) = (TMbright *)(S_W_DIR(s) + n); S_CHR(s) = (BYTE (*)[3])(S_BRT(s) + n); S_RGB(s) = (BYTE (*)[3])(S_CHR(s) + n); + S_INFO(s) = (int *)(S_RGB(s)+n); + S_INFO1(s) = (int *)(S_INFO(s)+n+extra_points); S_MAX_SAMP(s) = n; S_MAX_BASE_PT(s) = n + extra_points; /* Allocate memory for a per/sample bit flag */ if(!(samp_flag = (int4 *)malloc(FLAG_BYTES(n+extra_points)))) error(SYSTEM,"sAlloc(): Unable to allocate flag memory"); - sInit(s); sClear_all_flags(s); @@ -109,12 +107,12 @@ int *nptr,extra_points; is added: These points are not displayed-they are used to form the initial mesh */ -int +S_ID sAdd_base_point(s,v) SAMP *s; FVECT v; { - int id; + S_ID id; /* Get pointer to next available point */ id = S_NEXT_BASE_PT(s); @@ -135,7 +133,7 @@ sAdd_base_point(s,v) int sCopy_samp(s,n_id,id) SAMP *s; - int n_id,id; + S_ID n_id,id; { #ifdef DEBUG @@ -168,10 +166,10 @@ sCopy_samp(s,n_id,id) void sInit_samp(s,id,c,d,p,o_id) SAMP *s; - int id; + S_ID id; COLR c; FVECT d,p; - int o_id; + S_ID o_id; { if(o_id != INVALID) @@ -188,91 +186,76 @@ sInit_samp(s,id,c,d,p,o_id) /* calculate the brightness and chrominance,RGB will be set by tonemapping */ -#ifndef TEST_DRIVER tmCvColrs(&S_NTH_BRT(s,id),S_NTH_CHR(s,id),c,1); -#else - if(c) - { - S_NTH_RGB(s,id)[0] = c[0]; - S_NTH_RGB(s,id)[1] = c[1]; - S_NTH_RGB(s,id)[2] = c[2]; - } - else - { - S_NTH_RGB(s,id)[0] = 100; - S_NTH_RGB(s,id)[1] = 0; - S_NTH_RGB(s,id)[2] = 0; - } -#endif } /* Set ACTIVE bit upon creation */ - S_SET_FLAG(id); -#ifndef TEST_DRIVER + S_SET_FLAG(id); if(id < S_TONE_MAP(s)) tmMapPixels(S_NTH_RGB(s,id),&S_NTH_BRT(s,id),S_NTH_CHR(s,id),1); -#endif } /* Allocate a new sample. If an existing sample was replaced: set flag */ -int +S_ID sAlloc_samp(s,replaced) SAMP *s; int *replaced; { - int id; + S_ID id; - if(replaced) - *replaced = 0; - /* First check if there are any freed sample available */ if((id = S_FREE_SAMP(s)) != INVALID) { + *replaced = 0; +#if 0 + fprintf(stderr,"allocating previously freed sample %d\n",id); +#endif S_FREE_SAMP(s) = S_NTH_NEXT(s,id); return(id); } /* If havn't reached end of sample array:return next sample */ if(S_NUM_SAMP(s) < S_MAX_SAMP(s)) - id = S_NUM_SAMP(s)++; - else { - /* CLOCKED LRU replacement policy: Search through samples starting - with S_REPLACE_SAMP for a sample that does not have its active - bit set. Clear bit along the way - */ - id = S_REPLACE_SAMP(s); - while(S_IS_FLAG(id)) - { - S_CLR_FLAG(id); - id = (id +1)% S_MAX_SAMP(s); - } - S_REPLACE_SAMP(s) = (id +1)% S_MAX_SAMP(s); - if(replaced) - *replaced = 1; + id = S_NUM_SAMP(s)++; +#if 0 + fprintf(stderr,"allocating sample %d\n",id); +#endif + *replaced = 0; + return(id); } - return(id); -} -/* Set the sample flag to be unused- so will get replaced on next LRU - iteration - */ -int -sDelete_samp(s,id) -SAMP *s; -int id; +#ifdef DEBUG { -#ifdef DEBUG - /* Fist check for a valid id */ - if(id >= S_MAX_SAMP(s) || id < 0) - return(0); + static int replace = 0; + if(replace == 0) + { + eputs("Out of samples: using replacement strategy\n"); + replace =1 ; + } +} #endif - /* Add sample to the free list */ - sUnalloc_samp(s,id); - - S_CLR_FLAG(id); - return(1); + + /* CLOCKED LRU replacement policy: Search through samples starting + with S_REPLACE_SAMP for a sample that does not have its active + bit set. Clear bit along the way + */ + id = S_REPLACE_SAMP(s); + while(S_IS_FLAG(id)) + { + S_CLR_FLAG(id); + id = (id +1)% S_MAX_SAMP(s); + } + S_REPLACE_SAMP(s) = (id +1)% S_MAX_SAMP(s); + *replaced = 1; + return(id); } + + + + + +
