root/radiance/ray/src/hd/sm_samp.c
Revision: 3.10
Committed: Fri Nov 5 03:31:37 2004 UTC (20 years, 6 months ago) by greg
State: FILE REMOVED
2 static const char RCSid[] = "$Id: sm_samp.c,v 3.9 2003/06/30 14:59:12 schorsch Exp $";
5 * sm_samp.c
6 */
7
8 #include <string.h>
9
10 #include "standard.h"
11 #include "sm_flag.h"
12 #include "rhd_sample.h"
13
14 SAMP rsL;
15 int32 *samp_flag=NULL;
16
17 /* Each sample has a world coord point, and direction, brightness,chrominance,
18 and RGB triples
19 */
20
21 #define TMSIZE sizeof(TMbright)
22 #define SAMPSIZ (3*sizeof(SFLOAT)+sizeof(int32)+ 6*sizeof(BYTE) + TMSIZE + 2*sizeof(int))
23
24 /* Extra points world space point, vert flag and qt flag */
25 #define POINTSIZ (3*sizeof(SFLOAT) + 2*sizeof(int))
26
27 /* Clear the flags for all samples */
28 sClear_all_flags(s)
29 SAMP *s;
30 {
31 if(samp_flag)
32 memset((char *)samp_flag, '\0', FLAG_BYTES(S_MAX_BASE_PT(s)));
33 }
34
35 sInit(s)
36 SAMP *s;
37 {
38 S_REPLACE_SAMP(s) = 0;
39 S_NUM_SAMP(s) = 0;
40 S_TONE_MAP(s) = 0;
41 S_FREE_SAMP(s) = -1;
42 sClear_base_points(s);
43
44 }
45
46 sFree(s)
47 SAMP *s;
48 {
49 if(S_BASE(s))
50 {
51 free(S_BASE(s));
52 S_BASE(s)=NULL;
53 }
54 if(samp_flag)
55 {
56 free(samp_flag);
57 samp_flag = NULL;
58 }
59 }
60 /* Initialize/clear global smL sample list for at least n samples */
61 SAMP
62 *sAlloc(nptr,extra_points)
63 int *nptr,extra_points;
64 {
65 unsigned nbytes;
66 register unsigned i;
67 SAMP *s;
68 int n;
69
70 s = &rsL;
71 /* round space up to nearest power of 2 */
72 nbytes = (*nptr)*SAMPSIZ + extra_points*POINTSIZ + 8;
73 for (i = 1024; nbytes > i; i <<= 1)
74 ;
75 /* get number of samples that fit in block */
76 n = (i - 8 - extra_points*POINTSIZ) / SAMPSIZ;
77
78 /* Must make sure n + extra_points can fit in a S_ID identifier */
79 if ( n > (S_ID_MAX - extra_points))
80 n = (S_ID_MAX - extra_points);
81
82 S_BASE(s) = (char *)malloc(n*SAMPSIZ + extra_points*POINTSIZ);
83 if (!S_BASE(s))
84 error(SYSTEM,"sAlloc(): Unable to allocate memory");
85
86 /* assign larger alignment types earlier */
87 S_W_PT(s) = (SFLOAT(*)[3])S_BASE(s);
88 S_W_DIR(s) = (int32 *)(S_W_PT(s) + n + extra_points);
89 S_BRT(s) = (TMbright *)(S_W_DIR(s) + n);
90 S_CHR(s) = (BYTE (*)[3])(S_BRT(s) + n);
91 S_RGB(s) = (BYTE (*)[3])(S_CHR(s) + n);
92 S_INFO(s) = (int *)(S_RGB(s)+n);
93 S_INFO1(s) = (int *)(S_INFO(s)+n+extra_points);
94 S_MAX_SAMP(s) = n;
95 S_MAX_BASE_PT(s) = n + extra_points;
96
97 /* Allocate memory for a per/sample bit flag */
98 if(!(samp_flag = (int32 *)malloc(FLAG_BYTES(n+extra_points))))
99 error(SYSTEM,"sAlloc(): Unable to allocate flag memory");
100 sInit(s);
101 sClear_all_flags(s);
102
103 *nptr = n;
104
105 return(s);
106 }
107
108
109 /* Add a base point to the sample structure: only the world point
110 is added: These points are not displayed-they are used to form the
111 initial mesh
112 */
113 S_ID
114 sAdd_base_point(s,v)
115 SAMP *s;
116 FVECT v;
117 {
118 S_ID id;
119
120 /* Get pointer to next available point */
121 id = S_NEXT_BASE_PT(s);
122 if(id >= S_MAX_BASE_PT(s))
123 return(-1);
124
125 /* Update free aux pointer */
126 S_NEXT_BASE_PT(s)++;
127
128 /* Copy vector into point */
129 VCOPY(S_NTH_W_PT(s,id),v);
130 return(id);
131 }
132
133 /* Copy the values of sample n_id into sample id: Note must not call with
134 Base point n_id
135 */
136 int
137 sCopy_samp(s,n_id,id)
138 SAMP *s;
139 S_ID n_id,id;
140 {
141
142 #ifdef DEBUG
143 if(id <0||id >= S_MAX_SAMP(s)||n_id <0||n_id >= S_MAX_SAMP(s))
144 {
145 eputs("smReset_sample():invalid sample id\n");
146 return(0);
147 }
148 #endif
149 if(n_id == id)
150 return(1);
151 /* Copy vector into point */
152 VCOPY(S_NTH_W_PT(s,n_id),S_NTH_W_PT(s,id));
153 S_NTH_W_DIR(s,n_id) = S_NTH_W_DIR(s,id);
154
155 S_NTH_BRT(s,n_id) = S_NTH_BRT(s,id);
156 S_NTH_CHR(s,n_id)[0] = S_NTH_CHR(s,id)[0];
157 S_NTH_CHR(s,n_id)[1] = S_NTH_CHR(s,id)[1];
158 S_NTH_CHR(s,n_id)[2] = S_NTH_CHR(s,id)[2];
159
160 return(1);
161 }
162
163
164 /* Initialize the sample 'id' to contain world point 'p', direction 'd' and
165 color 'c'. If 'p' is NULL, a direction only is represented in 'd'. In
166 this case, the world point is set to the projection of the direction on
167 the view sphere, and the direction value is set to -1
168 */
169 void
170 sInit_samp(s,id,c,d,p,o_id)
171 SAMP *s;
172 S_ID id;
173 COLR c;
174 FVECT d,p;
175 S_ID o_id;
176 {
177
178 if(o_id != INVALID)
179 sCopy_samp(s,id,o_id);
180 else
181 {
182 /* Copy vector into point */
183 VCOPY(S_NTH_W_PT(s,id),p);
184 if(d)
185 S_NTH_W_DIR(s,id) = encodedir(d);
186 else
187 S_NTH_W_DIR(s,id) = -1;
188
189 /* calculate the brightness and chrominance,RGB will be set by
190 tonemapping
191 */
192 tmCvColrs(&S_NTH_BRT(s,id),S_NTH_CHR(s,id),c,1);
193 }
194 /* Set ACTIVE bit upon creation */
195 S_SET_FLAG(id);
196 if(id < S_TONE_MAP(s))
197 tmMapPixels(S_NTH_RGB(s,id),&S_NTH_BRT(s,id),S_NTH_CHR(s,id),1);
198 }
199
200
201 /* Allocate a new sample. If an existing sample was replaced: set flag */
202 S_ID
203 sAlloc_samp(s,replaced)
204 SAMP *s;
205 int *replaced;
206
207 {
208 S_ID id;
209
210 /* First check if there are any freed sample available */
211 if((id = S_FREE_SAMP(s)) != INVALID)
212 {
213 *replaced = 0;
214 #if 0
215 fprintf(stderr,"allocating previously freed sample %d\n",id);
216 #endif
217 S_FREE_SAMP(s) = S_NTH_NEXT(s,id);
218 return(id);
219 }
220 /* If havn't reached end of sample array:return next sample */
221 if(S_NUM_SAMP(s) < S_MAX_SAMP(s))
222 {
223 id = S_NUM_SAMP(s)++;
224 #if 0
225 fprintf(stderr,"allocating sample %d\n",id);
226 #endif
227 *replaced = 0;
228 return(id);
229 }
230
231 #ifdef DEBUG
232 {
233 static int replace = 0;
234 if(replace == 0)
235 {
236 eputs("Out of samples: using replacement strategy\n");
237 replace =1 ;
238 }
239 }
240 #endif
241
242 /* CLOCKED LRU replacement policy: Search through samples starting
243 with S_REPLACE_SAMP for a sample that does not have its active
244 bit set. Clear bit along the way
245 */
246 id = S_REPLACE_SAMP(s);
247 while(S_IS_FLAG(id))
248 {
249 S_CLR_FLAG(id);
250 id = (id +1)% S_MAX_SAMP(s);
251 }
252 S_REPLACE_SAMP(s) = (id +1)% S_MAX_SAMP(s);
253 *replaced = 1;
254 return(id);
255 }
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
