root/radiance/ray/src/hd/sm_samp.c
Revision: 3.10
Committed: Fri Nov 5 03:31:37 2004 UTC (20 years, 6 months ago) by greg
State: FILE REMOVED
# User Rev Content
1 gwlarson 3.1 #ifndef lint
2 greg 3.10 static const char RCSid[] = "$Id: sm_samp.c,v 3.9 2003/06/30 14:59:12 schorsch Exp $";
3 gwlarson 3.1 #endif
4     /*
5     * sm_samp.c
6     */
7 schorsch 3.9
8     #include <string.h>
9
10 gwlarson 3.1 #include "standard.h"
11 gwlarson 3.3 #include "sm_flag.h"
12     #include "rhd_sample.h"
13 gwlarson 3.1
14 gwlarson 3.3 SAMP rsL;
15 greg 3.8 int32 *samp_flag=NULL;
16 gwlarson 3.1
17 gwlarson 3.3 /* Each sample has a world coord point, and direction, brightness,chrominance,
18     and RGB triples
19     */
20 gwlarson 3.6
21 gwlarson 3.3 #define TMSIZE sizeof(TMbright)
22 greg 3.8 #define SAMPSIZ (3*sizeof(SFLOAT)+sizeof(int32)+ 6*sizeof(BYTE) + TMSIZE + 2*sizeof(int))
23 gwlarson 3.1
24 gwlarson 3.6 /* Extra points world space point, vert flag and qt flag */
25     #define POINTSIZ (3*sizeof(SFLOAT) + 2*sizeof(int))
26 gwlarson 3.3
27     /* Clear the flags for all samples */
28     sClear_all_flags(s)
29     SAMP *s;
30 gwlarson 3.1 {
31 gwlarson 3.3 if(samp_flag)
32 schorsch 3.9 memset((char *)samp_flag, '\0', FLAG_BYTES(S_MAX_BASE_PT(s)));
33 gwlarson 3.3 }
34 gwlarson 3.1
35 gwlarson 3.3 sInit(s)
36     SAMP *s;
37     {
38     S_REPLACE_SAMP(s) = 0;
39     S_NUM_SAMP(s) = 0;
40     S_TONE_MAP(s) = 0;
41     S_FREE_SAMP(s) = -1;
42     sClear_base_points(s);
43 gwlarson 3.1
44 gwlarson 3.3 }
45 gwlarson 3.1
46 gwlarson 3.3 sFree(s)
47     SAMP *s;
48     {
49     if(S_BASE(s))
50     {
51     free(S_BASE(s));
52     S_BASE(s)=NULL;
53     }
54     if(samp_flag)
55     {
56     free(samp_flag);
57     samp_flag = NULL;
58     }
59     }
60     /* Initialize/clear global smL sample list for at least n samples */
61     SAMP
62     *sAlloc(nptr,extra_points)
63     int *nptr,extra_points;
64     {
65     unsigned nbytes;
66     register unsigned i;
67     SAMP *s;
68     int n;
69
70     s = &rsL;
71 gwlarson 3.1 /* round space up to nearest power of 2 */
72 gwlarson 3.3 nbytes = (*nptr)*SAMPSIZ + extra_points*POINTSIZ + 8;
73 gwlarson 3.1 for (i = 1024; nbytes > i; i <<= 1)
74     ;
75 gwlarson 3.3 /* get number of samples that fit in block */
76     n = (i - 8 - extra_points*POINTSIZ) / SAMPSIZ;
77 gwlarson 3.1
78 greg 3.7 /* Must make sure n + extra_points can fit in a S_ID identifier */
79     if ( n > (S_ID_MAX - extra_points))
80     n = (S_ID_MAX - extra_points);
81
82 gwlarson 3.3 S_BASE(s) = (char *)malloc(n*SAMPSIZ + extra_points*POINTSIZ);
83     if (!S_BASE(s))
84 gwlarson 3.4 error(SYSTEM,"sAlloc(): Unable to allocate memory");
85 gwlarson 3.1
86     /* assign larger alignment types earlier */
87 gwlarson 3.6 S_W_PT(s) = (SFLOAT(*)[3])S_BASE(s);
88 greg 3.8 S_W_DIR(s) = (int32 *)(S_W_PT(s) + n + extra_points);
89 gwlarson 3.4 S_BRT(s) = (TMbright *)(S_W_DIR(s) + n);
90 gwlarson 3.3 S_CHR(s) = (BYTE (*)[3])(S_BRT(s) + n);
91     S_RGB(s) = (BYTE (*)[3])(S_CHR(s) + n);
92 gwlarson 3.6 S_INFO(s) = (int *)(S_RGB(s)+n);
93     S_INFO1(s) = (int *)(S_INFO(s)+n+extra_points);
94 gwlarson 3.3 S_MAX_SAMP(s) = n;
95     S_MAX_BASE_PT(s) = n + extra_points;
96 gwlarson 3.1
97 gwlarson 3.3 /* Allocate memory for a per/sample bit flag */
98 greg 3.8 if(!(samp_flag = (int32 *)malloc(FLAG_BYTES(n+extra_points))))
99 gwlarson 3.4 error(SYSTEM,"sAlloc(): Unable to allocate flag memory");
100 gwlarson 3.3 sInit(s);
101 gwlarson 3.4 sClear_all_flags(s);
102
103 gwlarson 3.3 *nptr = n;
104
105     return(s);
106 gwlarson 3.1 }
107
108
109 gwlarson 3.3 /* Add a base point to the sample structure: only the world point
110     is added: These points are not displayed-they are used to form the
111     initial mesh
112     */
113 greg 3.7 S_ID
114 gwlarson 3.3 sAdd_base_point(s,v)
115     SAMP *s;
116     FVECT v;
117 gwlarson 3.1 {
118 greg 3.7 S_ID id;
119 gwlarson 3.1
120     /* Get pointer to next available point */
121 gwlarson 3.3 id = S_NEXT_BASE_PT(s);
122     if(id >= S_MAX_BASE_PT(s))
123 gwlarson 3.1 return(-1);
124
125     /* Update free aux pointer */
126 gwlarson 3.3 S_NEXT_BASE_PT(s)++;
127 gwlarson 3.1
128     /* Copy vector into point */
129 gwlarson 3.3 VCOPY(S_NTH_W_PT(s,id),v);
130 gwlarson 3.1 return(id);
131     }
132
133 gwlarson 3.4 /* Copy the values of sample n_id into sample id: Note must not call with
134     Base point n_id
135     */
136     int
137     sCopy_samp(s,n_id,id)
138     SAMP *s;
139 greg 3.7 S_ID n_id,id;
140 gwlarson 3.4 {
141
142     #ifdef DEBUG
143     if(id <0||id >= S_MAX_SAMP(s)||n_id <0||n_id >= S_MAX_SAMP(s))
144     {
145     eputs("smReset_sample():invalid sample id\n");
146     return(0);
147     }
148     #endif
149     if(n_id == id)
150     return(1);
151     /* Copy vector into point */
152     VCOPY(S_NTH_W_PT(s,n_id),S_NTH_W_PT(s,id));
153     S_NTH_W_DIR(s,n_id) = S_NTH_W_DIR(s,id);
154
155     S_NTH_BRT(s,n_id) = S_NTH_BRT(s,id);
156     S_NTH_CHR(s,n_id)[0] = S_NTH_CHR(s,id)[0];
157     S_NTH_CHR(s,n_id)[1] = S_NTH_CHR(s,id)[1];
158     S_NTH_CHR(s,n_id)[2] = S_NTH_CHR(s,id)[2];
159
160     return(1);
161     }
162
163
164 gwlarson 3.3 /* Initialize the sample 'id' to contain world point 'p', direction 'd' and
165     color 'c'. If 'p' is NULL, a direction only is represented in 'd'. In
166     this case, the world point is set to the projection of the direction on
167     the view sphere, and the direction value is set to -1
168     */
169 gwlarson 3.1 void
170 gwlarson 3.5 sInit_samp(s,id,c,d,p,o_id)
171 gwlarson 3.3 SAMP *s;
172 greg 3.7 S_ID id;
173 gwlarson 3.1 COLR c;
174     FVECT d,p;
175 greg 3.7 S_ID o_id;
176 gwlarson 3.1 {
177 gwlarson 3.4
178     if(o_id != INVALID)
179     sCopy_samp(s,id,o_id);
180     else
181     {
182 gwlarson 3.3 /* Copy vector into point */
183     VCOPY(S_NTH_W_PT(s,id),p);
184     if(d)
185     S_NTH_W_DIR(s,id) = encodedir(d);
186     else
187     S_NTH_W_DIR(s,id) = -1;
188 gwlarson 3.1
189 gwlarson 3.4 /* calculate the brightness and chrominance,RGB will be set by
190     tonemapping
191     */
192 gwlarson 3.3 tmCvColrs(&S_NTH_BRT(s,id),S_NTH_CHR(s,id),c,1);
193 gwlarson 3.4 }
194 gwlarson 3.3 /* Set ACTIVE bit upon creation */
195 gwlarson 3.6 S_SET_FLAG(id);
196 gwlarson 3.5 if(id < S_TONE_MAP(s))
197 gwlarson 3.4 tmMapPixels(S_NTH_RGB(s,id),&S_NTH_BRT(s,id),S_NTH_CHR(s,id),1);
198 gwlarson 3.1 }
199
200
201 gwlarson 3.3 /* Allocate a new sample. If an existing sample was replaced: set flag */
202 greg 3.7 S_ID
203 gwlarson 3.3 sAlloc_samp(s,replaced)
204     SAMP *s;
205 gwlarson 3.2 int *replaced;
206 gwlarson 3.1
207     {
208 greg 3.7 S_ID id;
209 gwlarson 3.1
210 gwlarson 3.4 /* First check if there are any freed sample available */
211 gwlarson 3.3 if((id = S_FREE_SAMP(s)) != INVALID)
212 gwlarson 3.1 {
213 gwlarson 3.6 *replaced = 0;
214     #if 0
215     fprintf(stderr,"allocating previously freed sample %d\n",id);
216     #endif
217 gwlarson 3.4 S_FREE_SAMP(s) = S_NTH_NEXT(s,id);
218 gwlarson 3.3 return(id);
219 gwlarson 3.1 }
220 gwlarson 3.3 /* If havn't reached end of sample array:return next sample */
221     if(S_NUM_SAMP(s) < S_MAX_SAMP(s))
222     {
223 gwlarson 3.6 id = S_NUM_SAMP(s)++;
224     #if 0
225     fprintf(stderr,"allocating sample %d\n",id);
226     #endif
227     *replaced = 0;
228     return(id);
229 gwlarson 3.3 }
230 gwlarson 3.1
231 gwlarson 3.6 #ifdef DEBUG
232 gwlarson 3.1 {
233 gwlarson 3.6 static int replace = 0;
234     if(replace == 0)
235     {
236     eputs("Out of samples: using replacement strategy\n");
237     replace =1 ;
238     }
239     }
240 gwlarson 3.3 #endif
241 gwlarson 3.6
242     /* CLOCKED LRU replacement policy: Search through samples starting
243     with S_REPLACE_SAMP for a sample that does not have its active
244     bit set. Clear bit along the way
245     */
246     id = S_REPLACE_SAMP(s);
247     while(S_IS_FLAG(id))
248     {
249     S_CLR_FLAG(id);
250     id = (id +1)% S_MAX_SAMP(s);
251     }
252     S_REPLACE_SAMP(s) = (id +1)% S_MAX_SAMP(s);
253     *replaced = 1;
254     return(id);
255 gwlarson 3.1 }
256 greg 3.7
257
258
259
260
261
262 gwlarson 3.4
263
264
265
266
267
268 gwlarson 3.1
269
270
271
272
