root/radiance/ray/src/hd/sm_samp.c
Revision: 3.8
Committed: Fri Jun 20 00:25:49 2003 UTC (21 years, 10 months ago) by greg
Changes since 3.7: +5 -5 lines
2 static const char RCSid[] = "$Id: sm_samp.c,v 3.7 2003/02/22 02:07:25 greg Exp $";
5 * sm_samp.c
6 */
7 #include "standard.h"
8 #include "sm_flag.h"
9 #include "rhd_sample.h"
10
11 SAMP rsL;
12 int32 *samp_flag=NULL;
13
14 /* Each sample has a world coord point, and direction, brightness,chrominance,
15 and RGB triples
16 */
17
18 #define TMSIZE sizeof(TMbright)
19 #define SAMPSIZ (3*sizeof(SFLOAT)+sizeof(int32)+ 6*sizeof(BYTE) + TMSIZE + 2*sizeof(int))
20
21 /* Extra points world space point, vert flag and qt flag */
22 #define POINTSIZ (3*sizeof(SFLOAT) + 2*sizeof(int))
23
24 /* Clear the flags for all samples */
25 sClear_all_flags(s)
26 SAMP *s;
27 {
28 if(samp_flag)
29 bzero((char *)samp_flag,FLAG_BYTES(S_MAX_BASE_PT(s)));
30 }
31
32 sInit(s)
33 SAMP *s;
34 {
35 S_REPLACE_SAMP(s) = 0;
36 S_NUM_SAMP(s) = 0;
37 S_TONE_MAP(s) = 0;
38 S_FREE_SAMP(s) = -1;
39 sClear_base_points(s);
40
41 }
42
43 sFree(s)
44 SAMP *s;
45 {
46 if(S_BASE(s))
47 {
48 free(S_BASE(s));
49 S_BASE(s)=NULL;
50 }
51 if(samp_flag)
52 {
53 free(samp_flag);
54 samp_flag = NULL;
55 }
56 }
57 /* Initialize/clear global smL sample list for at least n samples */
58 SAMP
59 *sAlloc(nptr,extra_points)
60 int *nptr,extra_points;
61 {
62 unsigned nbytes;
63 register unsigned i;
64 SAMP *s;
65 int n;
66
67 s = &rsL;
68 /* round space up to nearest power of 2 */
69 nbytes = (*nptr)*SAMPSIZ + extra_points*POINTSIZ + 8;
70 for (i = 1024; nbytes > i; i <<= 1)
71 ;
72 /* get number of samples that fit in block */
73 n = (i - 8 - extra_points*POINTSIZ) / SAMPSIZ;
74
75 /* Must make sure n + extra_points can fit in a S_ID identifier */
76 if ( n > (S_ID_MAX - extra_points))
77 n = (S_ID_MAX - extra_points);
78
79 S_BASE(s) = (char *)malloc(n*SAMPSIZ + extra_points*POINTSIZ);
80 if (!S_BASE(s))
81 error(SYSTEM,"sAlloc(): Unable to allocate memory");
82
83 /* assign larger alignment types earlier */
84 S_W_PT(s) = (SFLOAT(*)[3])S_BASE(s);
85 S_W_DIR(s) = (int32 *)(S_W_PT(s) + n + extra_points);
86 S_BRT(s) = (TMbright *)(S_W_DIR(s) + n);
87 S_CHR(s) = (BYTE (*)[3])(S_BRT(s) + n);
88 S_RGB(s) = (BYTE (*)[3])(S_CHR(s) + n);
89 S_INFO(s) = (int *)(S_RGB(s)+n);
90 S_INFO1(s) = (int *)(S_INFO(s)+n+extra_points);
91 S_MAX_SAMP(s) = n;
92 S_MAX_BASE_PT(s) = n + extra_points;
93
94 /* Allocate memory for a per/sample bit flag */
95 if(!(samp_flag = (int32 *)malloc(FLAG_BYTES(n+extra_points))))
96 error(SYSTEM,"sAlloc(): Unable to allocate flag memory");
97 sInit(s);
98 sClear_all_flags(s);
99
100 *nptr = n;
101
102 return(s);
103 }
104
105
106 /* Add a base point to the sample structure: only the world point
107 is added: These points are not displayed-they are used to form the
108 initial mesh
109 */
110 S_ID
111 sAdd_base_point(s,v)
112 SAMP *s;
113 FVECT v;
114 {
115 S_ID id;
116
117 /* Get pointer to next available point */
118 id = S_NEXT_BASE_PT(s);
119 if(id >= S_MAX_BASE_PT(s))
120 return(-1);
121
122 /* Update free aux pointer */
123 S_NEXT_BASE_PT(s)++;
124
125 /* Copy vector into point */
126 VCOPY(S_NTH_W_PT(s,id),v);
127 return(id);
128 }
129
130 /* Copy the values of sample n_id into sample id: Note must not call with
131 Base point n_id
132 */
133 int
134 sCopy_samp(s,n_id,id)
135 SAMP *s;
136 S_ID n_id,id;
137 {
138
139 #ifdef DEBUG
140 if(id <0||id >= S_MAX_SAMP(s)||n_id <0||n_id >= S_MAX_SAMP(s))
141 {
142 eputs("smReset_sample():invalid sample id\n");
143 return(0);
144 }
145 #endif
146 if(n_id == id)
147 return(1);
148 /* Copy vector into point */
149 VCOPY(S_NTH_W_PT(s,n_id),S_NTH_W_PT(s,id));
150 S_NTH_W_DIR(s,n_id) = S_NTH_W_DIR(s,id);
151
152 S_NTH_BRT(s,n_id) = S_NTH_BRT(s,id);
153 S_NTH_CHR(s,n_id)[0] = S_NTH_CHR(s,id)[0];
154 S_NTH_CHR(s,n_id)[1] = S_NTH_CHR(s,id)[1];
155 S_NTH_CHR(s,n_id)[2] = S_NTH_CHR(s,id)[2];
156
157 return(1);
158 }
159
160
161 /* Initialize the sample 'id' to contain world point 'p', direction 'd' and
162 color 'c'. If 'p' is NULL, a direction only is represented in 'd'. In
163 this case, the world point is set to the projection of the direction on
164 the view sphere, and the direction value is set to -1
165 */
166 void
167 sInit_samp(s,id,c,d,p,o_id)
168 SAMP *s;
169 S_ID id;
170 COLR c;
171 FVECT d,p;
172 S_ID o_id;
173 {
174
175 if(o_id != INVALID)
176 sCopy_samp(s,id,o_id);
177 else
178 {
179 /* Copy vector into point */
180 VCOPY(S_NTH_W_PT(s,id),p);
181 if(d)
182 S_NTH_W_DIR(s,id) = encodedir(d);
183 else
184 S_NTH_W_DIR(s,id) = -1;
185
186 /* calculate the brightness and chrominance,RGB will be set by
187 tonemapping
188 */
189 tmCvColrs(&S_NTH_BRT(s,id),S_NTH_CHR(s,id),c,1);
190 }
191 /* Set ACTIVE bit upon creation */
192 S_SET_FLAG(id);
193 if(id < S_TONE_MAP(s))
194 tmMapPixels(S_NTH_RGB(s,id),&S_NTH_BRT(s,id),S_NTH_CHR(s,id),1);
195 }
196
197
198 /* Allocate a new sample. If an existing sample was replaced: set flag */
199 S_ID
200 sAlloc_samp(s,replaced)
201 SAMP *s;
202 int *replaced;
203
204 {
205 S_ID id;
206
207 /* First check if there are any freed sample available */
208 if((id = S_FREE_SAMP(s)) != INVALID)
209 {
210 *replaced = 0;
211 #if 0
212 fprintf(stderr,"allocating previously freed sample %d\n",id);
213 #endif
214 S_FREE_SAMP(s) = S_NTH_NEXT(s,id);
215 return(id);
216 }
217 /* If havn't reached end of sample array:return next sample */
218 if(S_NUM_SAMP(s) < S_MAX_SAMP(s))
219 {
220 id = S_NUM_SAMP(s)++;
221 #if 0
222 fprintf(stderr,"allocating sample %d\n",id);
223 #endif
224 *replaced = 0;
225 return(id);
226 }
227
228 #ifdef DEBUG
229 {
230 static int replace = 0;
231 if(replace == 0)
232 {
233 eputs("Out of samples: using replacement strategy\n");
234 replace =1 ;
235 }
236 }
237 #endif
238
239 /* CLOCKED LRU replacement policy: Search through samples starting
240 with S_REPLACE_SAMP for a sample that does not have its active
241 bit set. Clear bit along the way
242 */
243 id = S_REPLACE_SAMP(s);
244 while(S_IS_FLAG(id))
245 {
246 S_CLR_FLAG(id);
247 id = (id +1)% S_MAX_SAMP(s);
248 }
249 S_REPLACE_SAMP(s) = (id +1)% S_MAX_SAMP(s);
250 *replaced = 1;
251 return(id);
252 }
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
