root/radiance/ray/src/hd/sm_qtree.h
Revision: 3.17
Committed: Sat Aug 30 08:17:32 2003 UTC (20 years, 8 months ago) by schorsch
CVS Tags: rad3R6P1, rad3R6
Changes since 3.16: +4 -4 lines
Corrected header instrumentation.
# User Rev Content
1 schorsch 3.17 /* RCSid: $Id: sm_qtree.h,v 3.16 2003/07/14 22:24:00 schorsch Exp $ */
2 gwlarson 3.1 /*
3     * sm_qtree.h - header file for routines using spherical quadtrees.
4     *
5     * adapted from octree.h
6     */
7 schorsch 3.17 #ifndef _RAD_SM_QTREE_H_
8     #define _RAD_SM_QTREE_H_
9 schorsch 3.16
10     #ifdef __cplusplus
11     extern "C" {
12     #endif
13 gwlarson 3.1
14     /*
15     * An quadtree is expressed as an integer which is either
16     * an index to 4 other nodes, the empty tree, or an index
17     * to a set of objects. If the quadtree has a value:
18     *
19     * > -1: it is an index to four other nodes.
20     *
21     * -1: it is empty
22     *
23     * < -1: it is an index to a set of objects
24     */
25 greg 3.13
26 gwlarson 3.9 typedef struct _FUNC {
27     int (*func)();
28 gwlarson 3.12 int (*func_after)();
29 gwlarson 3.9 int *argptr;
30     }FUNC;
31 gwlarson 3.1
32 gwlarson 3.9 #define F_FUNC(f) (f.func)
33 gwlarson 3.12 #define F_FUNC2(f) (f.func_after)
34 gwlarson 3.9 #define F_ARGS(f) (f.argptr)
35 gwlarson 3.1 #define QUADTREE int
36
37     #define EMPTY (-1)
38
39     #define QT_IS_EMPTY(qt) ((qt) == EMPTY)
40 gwlarson 3.3 #define QT_IS_LEAF(qt) ((qt) < EMPTY)
41     #define QT_IS_TREE(qt) ((qt) > EMPTY)
42 gwlarson 3.1
43 gwlarson 3.3 #define QT_INDEX(qt) (-(qt)-2) /* quadtree node from set */
44     #define QT_SET_INDEX(i) (-((i)+2)) /* object set from node */
45     #define QT_BLOCK_SIZE 1024 /* quadtrees in block */
46     #define QT_BLOCK(qt) ((qt)>>10) /* quadtree block index */
47     #define QT_BLOCK_INDEX(qt) (((qt)&0x3ff)<<2) /* quadtree index in block */
48 gwlarson 3.1
49 gwlarson 3.4
50 gwlarson 3.1 #ifndef QT_MAX_BLK
51 greg 3.14 #ifdef SMLMEM
52     #define QT_MAX_BLK 2047 /* maximum quadtree block */
53     #else
54 gwlarson 3.3 #define QT_MAX_BLK 16383 /* maximum quadtree block */
55 gwlarson 3.1 #endif
56     #endif
57
58
59     #define QT_NTH_CHILD(qt,br) (quad_block[QT_BLOCK(qt)][QT_BLOCK_INDEX(qt)+br])
60 gwlarson 3.3 #define QT_NTH_CHILD_PTR(qt,br) (&QT_NTH_CHILD(qt,br))
61     #define QT_CLEAR_CHILDREN(qt) (QT_NTH_CHILD(qt,0)=QT_NTH_CHILD(qt,1)= \
62     QT_NTH_CHILD(qt,2)=QT_NTH_CHILD(qt,3)=EMPTY)
63 gwlarson 3.1
64
65 gwlarson 3.3 /* QUADTREE NODE FLAGS */
66 gwlarson 3.7 #define QT_IS_FLAG(qt) IS_FLAG(quad_flag,qt)
67     #define QT_SET_FLAG(qt) SET_FLAG(quad_flag,qt)
68     #define QT_CLR_FLAG(qt) CLR_FLAG(quad_flag,qt)
69     #define QT_LEAF_IS_FLAG(qt) IS_FLAG(qtsetflag,QT_INDEX(qt))
70     #define QT_LEAF_SET_FLAG(qt) SET_FLAG(qtsetflag,QT_INDEX(qt))
71     #define QT_LEAF_CLR_FLAG(qt) CLR_FLAG(qtsetflag,QT_INDEX(qt))
72 gwlarson 3.1
73     /* OBJECT SET CODE */
74     #define QT_SET_CNT(s) ((s)[0])
75     #define QT_SET_NTH_ELEM(s,n) ((s)[(n)])
76
77     #define QT_CLEAR_SET(s) ((s)[0] = 0)
78 gwlarson 3.12 #define QT_SET_NEXT_ELEM(p) (*(++p))
79 gwlarson 3.1 #define QT_SET_PTR(s) (&((s)[1]))
80
81
82 gwlarson 3.6 #define QT_MAXSET 511
83 gwlarson 3.4 #define MAXCSET 2*QT_MAXSET
84     #define QT_MAXCSET MAXCSET
85 gwlarson 3.1 #ifndef QT_SET_THRESHOLD
86 gwlarson 3.12 #define QT_SET_THRESHOLD 32
87 gwlarson 3.1 #endif
88
89     #ifndef QT_MAX_LEVELS
90 gwlarson 3.9 #define QT_MAX_LEVELS 10
91 gwlarson 3.1 #endif
92
93 gwlarson 3.8 #define QT_FILL_THRESHOLD 2
94 gwlarson 3.4 #define QT_EXPAND 8
95     #define QT_COMPRESS 16
96 gwlarson 3.7 #define QT_DONE 32
97     #define QT_MODIFIED 64
98 gwlarson 3.4
99     #define QT_FLAG_FILL_TRI(f) (((f)&0x7) == QT_FILL_THRESHOLD)
100     #define QT_FLAG_UPDATE(f) ((f)& (QT_EXPAND | QT_COMPRESS))
101 gwlarson 3.7 #define QT_FLAG_IS_DONE(f) ((f)& QT_DONE)
102     #define QT_FLAG_SET_DONE(f) ((f) |= QT_DONE)
103     #define QT_FLAG_IS_MODIFIED(f) ((f)& QT_MODIFIED)
104     #define QT_FLAG_SET_MODIFIED(f) ((f) |= QT_MODIFIED)
105 gwlarson 3.4
106 gwlarson 3.7 #define qtSubdivide(qt) (qt = qtAlloc(),QT_CLEAR_CHILDREN(qt))
107 gwlarson 3.10 #define qtSubdivide_tri(v0,v1,v2,a,b,c) (EDGE_MIDPOINT(a,v1,v2), \
108     EDGE_MIDPOINT(b,v2,v0), \
109     EDGE_MIDPOINT(c,v0,v1))
110 gwlarson 3.7
111 gwlarson 3.1 extern QUADTREE qtnewleaf(), qtaddelem(), qtdelelem();
112
113     extern QUADTREE *quad_block[QT_MAX_BLK]; /* quadtree blocks */
114 greg 3.15 extern int32 *quad_flag; /* zeroeth quadtree flag */
115 gwlarson 3.4
116     extern OBJECT **qtsettab; /* quadtree leaf node table */
117     extern QUADTREE qtnumsets; /* number of used set indices */
118 greg 3.15 extern int32 *qtsetflag;
119 gwlarson 3.4 #ifdef DEBUG
120     extern OBJECT *qtqueryset();
121     #else
122     #define qtqueryset(qt) (qtsettab[QT_SET_INDEX(qt)])
123     #endif
124 gwlarson 3.12 #if 0
125     #define qtremovelast(qt) ((*(qtqueryset(qt)))--)
126     #endif
127 gwlarson 3.4 #define qtinset(qt,id) inset(qtqueryset(qt),id)
128     #define qtgetset(os,qt) setcopy(os,qtqueryset(qt))
129 gwlarson 3.9
130
131     #define SIDES_GTR(b0,b1,b2,s0,s1,s2,a,b,c) \
132     (s0 = ((b0[0] > a?4:0) | (b1[0] > a?2:0) | (b2[0] > a?1:0)), \
133     s1 = ((b0[1] > b?4:0) | (b1[1] > b?2:0) | (b2[1] > b?1:0)), \
134     s2 = ((b0[2] > c?4:0) | (b1[2] > c?2:0) | (b2[2] > c?1:0)))
135
136     #define SIDES_LESS(b0,b1,b2,s0,s1,s2,a,b,c) \
137     (s0 = ((b0[0] < a?4:0) | (b1[0] < a?2:0) | (b2[0] < a?1:0)), \
138     s1 = ((b0[1] < b?4:0) | (b1[1] < b?2:0) | (b2[1] < b?1:0)), \
139     s2 = ((b0[2] < c?4:0) | (b1[2] < c?2:0) | (b2[2] < c?1:0)))
140 gwlarson 3.4
141 gwlarson 3.7 /*
142     QUADTREE qtRoot_point_locate(qt,q0,q1,q2,peq,pt,r0,r1,r2)
143     QUADTREE qt;
144     FVECT q0,q1,q2;
145     FPEQ peq;
146     FVECT pt;
147     FVECT r0,r1,r2;
148
149     Return the quadtree node containing pt. It is assumed that pt is in
150     the root node qt with ws vertices q0,q1,q2 and plane equation peq.
151     If r0 != NULL will return coordinates of node in (r0,r1,r2).
152     */
153
154     extern QUADTREE qtRoot_point_locate();
155     extern QUADTREE qtRoot_add_tri();
156     extern QUADTREE qtRoot_remove_tri();
157     extern QUADTREE qtAdd_tri();
158     extern QUADTREE qtRoot_visit_tri_edges();
159     extern QUADTREE qtRoot_trace_ray();
160 gwlarson 3.12
161
162 schorsch 3.16 #ifdef __cplusplus
163     }
164     #endif
165 schorsch 3.17 #endif /* _RAD_SM_QTREE_H_ */
166 gwlarson 3.12
