root/radiance/ray/src/hd/sm_qtree.h
Revision: 3.13
Committed: Sat Feb 22 02:07:25 2003 UTC (22 years, 4 months ago) by greg
Changes since 3.12: +2 -5 lines
1 /* RCSid: $Id$ */
2 /*
3 * sm_qtree.h - header file for routines using spherical quadtrees.
4 *
5 * adapted from octree.h
6 */
7
8 /*
9 * An quadtree is expressed as an integer which is either
10 * an index to 4 other nodes, the empty tree, or an index
11 * to a set of objects. If the quadtree has a value:
12 *
13 * > -1: it is an index to four other nodes.
14 *
15 * -1: it is empty
16 *
17 * < -1: it is an index to a set of objects
18 */
19
20 typedef struct _FUNC {
21 int (*func)();
22 int (*func_after)();
23 int *argptr;
24 }FUNC;
25
26 #define F_FUNC(f) (f.func)
27 #define F_FUNC2(f) (f.func_after)
28 #define F_ARGS(f) (f.argptr)
29 #define QUADTREE int
30
31 #define EMPTY (-1)
32
33 #define QT_IS_EMPTY(qt) ((qt) == EMPTY)
34 #define QT_IS_LEAF(qt) ((qt) < EMPTY)
35 #define QT_IS_TREE(qt) ((qt) > EMPTY)
36
37 #define QT_INDEX(qt) (-(qt)-2) /* quadtree node from set */
38 #define QT_SET_INDEX(i) (-((i)+2)) /* object set from node */
39 #define QT_BLOCK_SIZE 1024 /* quadtrees in block */
40 #define QT_BLOCK(qt) ((qt)>>10) /* quadtree block index */
41 #define QT_BLOCK_INDEX(qt) (((qt)&0x3ff)<<2) /* quadtree index in block */
42
43
44 #ifndef QT_MAX_BLK
45 #ifdef BIGMEM
46 #define QT_MAX_BLK 16383 /* maximum quadtree block */
47 #else
48 #define QT_MAX_BLK 2047 /* maximum quadtree block */
49 #endif
50 #endif
51
52
53 #define QT_NTH_CHILD(qt,br) (quad_block[QT_BLOCK(qt)][QT_BLOCK_INDEX(qt)+br])
54 #define QT_NTH_CHILD_PTR(qt,br) (&QT_NTH_CHILD(qt,br))
55 #define QT_CLEAR_CHILDREN(qt) (QT_NTH_CHILD(qt,0)=QT_NTH_CHILD(qt,1)= \
56 QT_NTH_CHILD(qt,2)=QT_NTH_CHILD(qt,3)=EMPTY)
57
58
59 /* QUADTREE NODE FLAGS */
60 #define QT_IS_FLAG(qt) IS_FLAG(quad_flag,qt)
61 #define QT_SET_FLAG(qt) SET_FLAG(quad_flag,qt)
62 #define QT_CLR_FLAG(qt) CLR_FLAG(quad_flag,qt)
63 #define QT_LEAF_IS_FLAG(qt) IS_FLAG(qtsetflag,QT_INDEX(qt))
64 #define QT_LEAF_SET_FLAG(qt) SET_FLAG(qtsetflag,QT_INDEX(qt))
65 #define QT_LEAF_CLR_FLAG(qt) CLR_FLAG(qtsetflag,QT_INDEX(qt))
66
67 /* OBJECT SET CODE */
68 #define QT_SET_CNT(s) ((s)[0])
69 #define QT_SET_NTH_ELEM(s,n) ((s)[(n)])
70
71 #define QT_CLEAR_SET(s) ((s)[0] = 0)
72 #define QT_SET_NEXT_ELEM(p) (*(++p))
73 #define QT_SET_PTR(s) (&((s)[1]))
74
75
76 #define QT_MAXSET 511
77 #define MAXCSET 2*QT_MAXSET
78 #define QT_MAXCSET MAXCSET
79 #ifndef QT_SET_THRESHOLD
80 #define QT_SET_THRESHOLD 32
81 #endif
82
83 #ifndef QT_MAX_LEVELS
84 #define QT_MAX_LEVELS 10
85 #endif
86
87 #define QT_FILL_THRESHOLD 2
88 #define QT_EXPAND 8
89 #define QT_COMPRESS 16
90 #define QT_DONE 32
91 #define QT_MODIFIED 64
92
93 #define QT_FLAG_FILL_TRI(f) (((f)&0x7) == QT_FILL_THRESHOLD)
94 #define QT_FLAG_UPDATE(f) ((f)& (QT_EXPAND | QT_COMPRESS))
95 #define QT_FLAG_IS_DONE(f) ((f)& QT_DONE)
96 #define QT_FLAG_SET_DONE(f) ((f) |= QT_DONE)
97 #define QT_FLAG_IS_MODIFIED(f) ((f)& QT_MODIFIED)
98 #define QT_FLAG_SET_MODIFIED(f) ((f) |= QT_MODIFIED)
99
100 #define qtSubdivide(qt) (qt = qtAlloc(),QT_CLEAR_CHILDREN(qt))
101 #define qtSubdivide_tri(v0,v1,v2,a,b,c) (EDGE_MIDPOINT(a,v1,v2), \
102 EDGE_MIDPOINT(b,v2,v0), \
103 EDGE_MIDPOINT(c,v0,v1))
104
105 extern QUADTREE qtnewleaf(), qtaddelem(), qtdelelem();
106
107 extern QUADTREE *quad_block[QT_MAX_BLK]; /* quadtree blocks */
108 extern int4 *quad_flag; /* zeroeth quadtree flag */
109
110 extern OBJECT **qtsettab; /* quadtree leaf node table */
111 extern QUADTREE qtnumsets; /* number of used set indices */
112 extern int4 *qtsetflag;
113 #ifdef DEBUG
114 extern OBJECT *qtqueryset();
115 #else
116 #define qtqueryset(qt) (qtsettab[QT_SET_INDEX(qt)])
117 #endif
118 #if 0
119 #define qtremovelast(qt) ((*(qtqueryset(qt)))--)
120 #endif
121 #define qtinset(qt,id) inset(qtqueryset(qt),id)
122 #define qtgetset(os,qt) setcopy(os,qtqueryset(qt))
123
124
125 #define SIDES_GTR(b0,b1,b2,s0,s1,s2,a,b,c) \
126 (s0 = ((b0[0] > a?4:0) | (b1[0] > a?2:0) | (b2[0] > a?1:0)), \
127 s1 = ((b0[1] > b?4:0) | (b1[1] > b?2:0) | (b2[1] > b?1:0)), \
128 s2 = ((b0[2] > c?4:0) | (b1[2] > c?2:0) | (b2[2] > c?1:0)))
129
130 #define SIDES_LESS(b0,b1,b2,s0,s1,s2,a,b,c) \
131 (s0 = ((b0[0] < a?4:0) | (b1[0] < a?2:0) | (b2[0] < a?1:0)), \
132 s1 = ((b0[1] < b?4:0) | (b1[1] < b?2:0) | (b2[1] < b?1:0)), \
133 s2 = ((b0[2] < c?4:0) | (b1[2] < c?2:0) | (b2[2] < c?1:0)))
134
135 /*
136 QUADTREE qtRoot_point_locate(qt,q0,q1,q2,peq,pt,r0,r1,r2)
137 QUADTREE qt;
138 FVECT q0,q1,q2;
139 FPEQ peq;
140 FVECT pt;
141 FVECT r0,r1,r2;
142
143 Return the quadtree node containing pt. It is assumed that pt is in
144 the root node qt with ws vertices q0,q1,q2 and plane equation peq.
145 If r0 != NULL will return coordinates of node in (r0,r1,r2).
146 */
147
148 extern QUADTREE qtRoot_point_locate();
149 extern QUADTREE qtRoot_add_tri();
150 extern QUADTREE qtRoot_remove_tri();
151 extern QUADTREE qtAdd_tri();
152 extern QUADTREE qtRoot_visit_tri_edges();
153 extern QUADTREE qtRoot_trace_ray();
154
155
156
157
158
159
