1 |
/* Copyright (c) 1998 Silicon Graphics, Inc. */ |
2 |
3 |
/* SCCSid "$SunId$ SGI" */ |
4 |
5 |
6 |
* sm_qtree.h - header file for routines using spherical quadtrees. |
7 |
8 |
* adapted from octree.h |
9 |
10 |
11 |
12 |
* An quadtree is expressed as an integer which is either |
13 |
* an index to 4 other nodes, the empty tree, or an index |
14 |
* to a set of objects. If the quadtree has a value: |
15 |
16 |
* > -1: it is an index to four other nodes. |
17 |
18 |
* -1: it is empty |
19 |
20 |
* < -1: it is an index to a set of objects |
21 |
22 |
#include "object.h" |
23 |
typedef struct _FUNC { |
24 |
int (*func)(); |
25 |
int (*func_after)(); |
26 |
int *argptr; |
27 |
}FUNC; |
28 |
29 |
#define F_FUNC(f) (f.func) |
30 |
#define F_FUNC2(f) (f.func_after) |
31 |
#define F_ARGS(f) (f.argptr) |
32 |
#define QUADTREE int |
33 |
34 |
#define EMPTY (-1) |
35 |
36 |
#define QT_IS_EMPTY(qt) ((qt) == EMPTY) |
37 |
#define QT_IS_LEAF(qt) ((qt) < EMPTY) |
38 |
#define QT_IS_TREE(qt) ((qt) > EMPTY) |
39 |
40 |
#define QT_INDEX(qt) (-(qt)-2) /* quadtree node from set */ |
41 |
#define QT_SET_INDEX(i) (-((i)+2)) /* object set from node */ |
42 |
#define QT_BLOCK_SIZE 1024 /* quadtrees in block */ |
43 |
#define QT_BLOCK(qt) ((qt)>>10) /* quadtree block index */ |
44 |
#define QT_BLOCK_INDEX(qt) (((qt)&0x3ff)<<2) /* quadtree index in block */ |
45 |
46 |
47 |
#ifndef QT_MAX_BLK |
48 |
#ifdef BIGMEM |
49 |
#define QT_MAX_BLK 16383 /* maximum quadtree block */ |
50 |
#else |
51 |
#define QT_MAX_BLK 2047 /* maximum quadtree block */ |
52 |
#endif |
53 |
#endif |
54 |
55 |
56 |
#define QT_NTH_CHILD(qt,br) (quad_block[QT_BLOCK(qt)][QT_BLOCK_INDEX(qt)+br]) |
57 |
#define QT_NTH_CHILD_PTR(qt,br) (&QT_NTH_CHILD(qt,br)) |
58 |
#define QT_CLEAR_CHILDREN(qt) (QT_NTH_CHILD(qt,0)=QT_NTH_CHILD(qt,1)= \ |
59 |
QT_NTH_CHILD(qt,2)=QT_NTH_CHILD(qt,3)=EMPTY) |
60 |
61 |
62 |
/* QUADTREE NODE FLAGS */ |
63 |
#define QT_IS_FLAG(qt) IS_FLAG(quad_flag,qt) |
64 |
#define QT_SET_FLAG(qt) SET_FLAG(quad_flag,qt) |
65 |
#define QT_CLR_FLAG(qt) CLR_FLAG(quad_flag,qt) |
66 |
#define QT_LEAF_IS_FLAG(qt) IS_FLAG(qtsetflag,QT_INDEX(qt)) |
67 |
#define QT_LEAF_SET_FLAG(qt) SET_FLAG(qtsetflag,QT_INDEX(qt)) |
68 |
#define QT_LEAF_CLR_FLAG(qt) CLR_FLAG(qtsetflag,QT_INDEX(qt)) |
69 |
70 |
/* OBJECT SET CODE */ |
71 |
#define QT_SET_CNT(s) ((s)[0]) |
72 |
#define QT_SET_NTH_ELEM(s,n) ((s)[(n)]) |
73 |
74 |
#define QT_CLEAR_SET(s) ((s)[0] = 0) |
75 |
#define QT_SET_NEXT_ELEM(p) (*(++p)) |
76 |
#define QT_SET_PTR(s) (&((s)[1])) |
77 |
78 |
79 |
#define QT_MAXSET 511 |
80 |
#define MAXCSET 2*QT_MAXSET |
81 |
#define QT_MAXCSET MAXCSET |
82 |
#ifndef QT_SET_THRESHOLD |
83 |
#define QT_SET_THRESHOLD 32 |
84 |
#endif |
85 |
86 |
#ifndef QT_MAX_LEVELS |
87 |
#define QT_MAX_LEVELS 10 |
88 |
#endif |
89 |
90 |
#define QT_FILL_THRESHOLD 2 |
91 |
#define QT_EXPAND 8 |
92 |
#define QT_COMPRESS 16 |
93 |
#define QT_DONE 32 |
94 |
#define QT_MODIFIED 64 |
95 |
96 |
#define QT_FLAG_FILL_TRI(f) (((f)&0x7) == QT_FILL_THRESHOLD) |
97 |
#define QT_FLAG_UPDATE(f) ((f)& (QT_EXPAND | QT_COMPRESS)) |
98 |
#define QT_FLAG_IS_DONE(f) ((f)& QT_DONE) |
99 |
#define QT_FLAG_SET_DONE(f) ((f) |= QT_DONE) |
100 |
#define QT_FLAG_IS_MODIFIED(f) ((f)& QT_MODIFIED) |
101 |
#define QT_FLAG_SET_MODIFIED(f) ((f) |= QT_MODIFIED) |
102 |
103 |
#define qtSubdivide(qt) (qt = qtAlloc(),QT_CLEAR_CHILDREN(qt)) |
104 |
#define qtSubdivide_tri(v0,v1,v2,a,b,c) (EDGE_MIDPOINT(a,v1,v2), \ |
105 |
EDGE_MIDPOINT(b,v2,v0), \ |
106 |
EDGE_MIDPOINT(c,v0,v1)) |
107 |
108 |
extern QUADTREE qtnewleaf(), qtaddelem(), qtdelelem(); |
109 |
110 |
extern QUADTREE *quad_block[QT_MAX_BLK]; /* quadtree blocks */ |
111 |
extern int4 *quad_flag; /* zeroeth quadtree flag */ |
112 |
113 |
extern OBJECT **qtsettab; /* quadtree leaf node table */ |
114 |
extern QUADTREE qtnumsets; /* number of used set indices */ |
115 |
extern int4 *qtsetflag; |
116 |
#ifdef DEBUG |
117 |
extern OBJECT *qtqueryset(); |
118 |
#else |
119 |
#define qtqueryset(qt) (qtsettab[QT_SET_INDEX(qt)]) |
120 |
#endif |
121 |
#if 0 |
122 |
#define qtremovelast(qt) ((*(qtqueryset(qt)))--) |
123 |
#endif |
124 |
#define qtinset(qt,id) inset(qtqueryset(qt),id) |
125 |
#define qtgetset(os,qt) setcopy(os,qtqueryset(qt)) |
126 |
127 |
128 |
#define SIDES_GTR(b0,b1,b2,s0,s1,s2,a,b,c) \ |
129 |
(s0 = ((b0[0] > a?4:0) | (b1[0] > a?2:0) | (b2[0] > a?1:0)), \ |
130 |
s1 = ((b0[1] > b?4:0) | (b1[1] > b?2:0) | (b2[1] > b?1:0)), \ |
131 |
s2 = ((b0[2] > c?4:0) | (b1[2] > c?2:0) | (b2[2] > c?1:0))) |
132 |
133 |
#define SIDES_LESS(b0,b1,b2,s0,s1,s2,a,b,c) \ |
134 |
(s0 = ((b0[0] < a?4:0) | (b1[0] < a?2:0) | (b2[0] < a?1:0)), \ |
135 |
s1 = ((b0[1] < b?4:0) | (b1[1] < b?2:0) | (b2[1] < b?1:0)), \ |
136 |
s2 = ((b0[2] < c?4:0) | (b1[2] < c?2:0) | (b2[2] < c?1:0))) |
137 |
138 |
139 |
QUADTREE qtRoot_point_locate(qt,q0,q1,q2,peq,pt,r0,r1,r2) |
140 |
QUADTREE qt; |
141 |
FVECT q0,q1,q2; |
142 |
FPEQ peq; |
143 |
FVECT pt; |
144 |
FVECT r0,r1,r2; |
145 |
146 |
Return the quadtree node containing pt. It is assumed that pt is in |
147 |
the root node qt with ws vertices q0,q1,q2 and plane equation peq. |
148 |
If r0 != NULL will return coordinates of node in (r0,r1,r2). |
149 |
150 |
151 |
extern QUADTREE qtRoot_point_locate(); |
152 |
extern QUADTREE qtRoot_add_tri(); |
153 |
extern QUADTREE qtRoot_remove_tri(); |
154 |
extern QUADTREE qtAdd_tri(); |
155 |
extern QUADTREE qtRoot_visit_tri_edges(); |
156 |
extern QUADTREE qtRoot_trace_ray(); |
157 |
158 |
159 |
160 |
161 |
162 |
