root/radiance/ray/src/hd/sm_qtree.h
Revision: 3.10
Committed: Tue Jan 5 16:52:39 1999 UTC (25 years, 3 months ago) by gwlarson
Changes since 3.9: +3 -3 lines
fixed logic in smTest to handle nearby and coincident points, added base tris to rendering, made list of new triangles to speed up rendering
1 /* Copyright (c) 1998 Silicon Graphics, Inc. */
2
3 /* SCCSid "$SunId$ SGI" */
4
5 /*
6 * sm_qtree.h - header file for routines using spherical quadtrees.
7 *
8 * adapted from octree.h
9 */
10
11 /*
12 * An quadtree is expressed as an integer which is either
13 * an index to 4 other nodes, the empty tree, or an index
14 * to a set of objects. If the quadtree has a value:
15 *
16 * > -1: it is an index to four other nodes.
17 *
18 * -1: it is empty
19 *
20 * < -1: it is an index to a set of objects
21 */
22 #include "object.h"
23 typedef struct _FUNC {
24 int (*func)();
25 int *argptr;
26 }FUNC;
27
28 #define F_FUNC(f) (f.func)
29 #define F_ARGS(f) (f.argptr)
30 #define QUADTREE int
31
32 #define EMPTY (-1)
33
34 #define QT_IS_EMPTY(qt) ((qt) == EMPTY)
35 #define QT_IS_LEAF(qt) ((qt) < EMPTY)
36 #define QT_IS_TREE(qt) ((qt) > EMPTY)
37
38 #define QT_INDEX(qt) (-(qt)-2) /* quadtree node from set */
39 #define QT_SET_INDEX(i) (-((i)+2)) /* object set from node */
40 #define QT_BLOCK_SIZE 1024 /* quadtrees in block */
41 #define QT_BLOCK(qt) ((qt)>>10) /* quadtree block index */
42 #define QT_BLOCK_INDEX(qt) (((qt)&0x3ff)<<2) /* quadtree index in block */
43
44
45 #ifndef QT_MAX_BLK
46 #ifdef BIGMEM
47 #define QT_MAX_BLK 16383 /* maximum quadtree block */
48 #else
49 #define QT_MAX_BLK 2047 /* maximum quadtree block */
50 #endif
51 #endif
52
53
54 #define QT_NTH_CHILD(qt,br) (quad_block[QT_BLOCK(qt)][QT_BLOCK_INDEX(qt)+br])
55 #define QT_NTH_CHILD_PTR(qt,br) (&QT_NTH_CHILD(qt,br))
56 #define QT_CLEAR_CHILDREN(qt) (QT_NTH_CHILD(qt,0)=QT_NTH_CHILD(qt,1)= \
57 QT_NTH_CHILD(qt,2)=QT_NTH_CHILD(qt,3)=EMPTY)
58
59
60 /* QUADTREE NODE FLAGS */
61 #define QT_IS_FLAG(qt) IS_FLAG(quad_flag,qt)
62 #define QT_SET_FLAG(qt) SET_FLAG(quad_flag,qt)
63 #define QT_CLR_FLAG(qt) CLR_FLAG(quad_flag,qt)
64 #define QT_LEAF_IS_FLAG(qt) IS_FLAG(qtsetflag,QT_INDEX(qt))
65 #define QT_LEAF_SET_FLAG(qt) SET_FLAG(qtsetflag,QT_INDEX(qt))
66 #define QT_LEAF_CLR_FLAG(qt) CLR_FLAG(qtsetflag,QT_INDEX(qt))
67
68 /* OBJECT SET CODE */
69 #define QT_SET_CNT(s) ((s)[0])
70 #define QT_SET_NTH_ELEM(s,n) ((s)[(n)])
71
72 #define QT_CLEAR_SET(s) ((s)[0] = 0)
73 #define QT_SET_NEXT_ELEM(p) (*(p)++)
74 #define QT_SET_PTR(s) (&((s)[1]))
75
76
77 #define QT_MAXSET 511
78 #define MAXCSET 2*QT_MAXSET
79 #define QT_MAXCSET MAXCSET
80 #ifndef QT_SET_THRESHOLD
81 #define QT_SET_THRESHOLD 64
82 #endif
83
84 #ifndef QT_MAX_LEVELS
85 #define QT_MAX_LEVELS 10
86 #endif
87
88 #define QT_FILL_THRESHOLD 2
89 #define QT_EXPAND 8
90 #define QT_COMPRESS 16
91 #define QT_DONE 32
92 #define QT_MODIFIED 64
93
94 #define QT_FLAG_FILL_TRI(f) (((f)&0x7) == QT_FILL_THRESHOLD)
95 #define QT_FLAG_UPDATE(f) ((f)& (QT_EXPAND | QT_COMPRESS))
96 #define QT_FLAG_IS_DONE(f) ((f)& QT_DONE)
97 #define QT_FLAG_SET_DONE(f) ((f) |= QT_DONE)
98 #define QT_FLAG_IS_MODIFIED(f) ((f)& QT_MODIFIED)
99 #define QT_FLAG_SET_MODIFIED(f) ((f) |= QT_MODIFIED)
100
101 #define qtSubdivide(qt) (qt = qtAlloc(),QT_CLEAR_CHILDREN(qt))
102 #define qtSubdivide_tri(v0,v1,v2,a,b,c) (EDGE_MIDPOINT(a,v1,v2), \
103 EDGE_MIDPOINT(b,v2,v0), \
104 EDGE_MIDPOINT(c,v0,v1))
105
106 extern QUADTREE qtnewleaf(), qtaddelem(), qtdelelem();
107
108 extern QUADTREE *quad_block[QT_MAX_BLK]; /* quadtree blocks */
109 extern int4 *quad_flag; /* zeroeth quadtree flag */
110
111 extern OBJECT **qtsettab; /* quadtree leaf node table */
112 extern QUADTREE qtnumsets; /* number of used set indices */
113 extern int4 *qtsetflag;
114 #ifdef DEBUG
115 extern OBJECT *qtqueryset();
116 #else
117 #define qtqueryset(qt) (qtsettab[QT_SET_INDEX(qt)])
118 #endif
119
120 #define qtinset(qt,id) inset(qtqueryset(qt),id)
121 #define qtgetset(os,qt) setcopy(os,qtqueryset(qt))
122
123
124 #define SIDES_GTR(b0,b1,b2,s0,s1,s2,a,b,c) \
125 (s0 = ((b0[0] > a?4:0) | (b1[0] > a?2:0) | (b2[0] > a?1:0)), \
126 s1 = ((b0[1] > b?4:0) | (b1[1] > b?2:0) | (b2[1] > b?1:0)), \
127 s2 = ((b0[2] > c?4:0) | (b1[2] > c?2:0) | (b2[2] > c?1:0)))
128
129 #define SIDES_LESS(b0,b1,b2,s0,s1,s2,a,b,c) \
130 (s0 = ((b0[0] < a?4:0) | (b1[0] < a?2:0) | (b2[0] < a?1:0)), \
131 s1 = ((b0[1] < b?4:0) | (b1[1] < b?2:0) | (b2[1] < b?1:0)), \
132 s2 = ((b0[2] < c?4:0) | (b1[2] < c?2:0) | (b2[2] < c?1:0)))
133
134 /*
135 QUADTREE qtRoot_point_locate(qt,q0,q1,q2,peq,pt,r0,r1,r2)
136 QUADTREE qt;
137 FVECT q0,q1,q2;
138 FPEQ peq;
139 FVECT pt;
140 FVECT r0,r1,r2;
141
142 Return the quadtree node containing pt. It is assumed that pt is in
143 the root node qt with ws vertices q0,q1,q2 and plane equation peq.
144 If r0 != NULL will return coordinates of node in (r0,r1,r2).
145 */
146
147 extern QUADTREE qtRoot_point_locate();
148 extern QUADTREE qtRoot_add_tri();
149 extern QUADTREE qtRoot_remove_tri();
150 extern QUADTREE qtAdd_tri();
151 extern QUADTREE qtRoot_visit_tri_edges();
152 extern QUADTREE qtRoot_trace_ray();
