root/radiance/ray/src/hd/sm_qtree.h
Revision: 3.8
Committed: Wed Nov 11 12:05:40 1998 UTC (25 years, 7 months ago) by gwlarson
Changes since 3.7: +1 -1 lines
new triangulation code
changed triangle vertex order to CCW
changed numbering of triangle neighbors to match quadtree
fixed tone-mapping bug
removed errant printf() statements
redid logic for adding and testing samples with new epsilon
1 /* Copyright (c) 1998 Silicon Graphics, Inc. */
2
3 /* SCCSid "$SunId$ SGI" */
4
5 /*
6 * sm_qtree.h - header file for routines using spherical quadtrees.
7 *
8 * adapted from octree.h
9 */
10
11 /*
12 * An quadtree is expressed as an integer which is either
13 * an index to 4 other nodes, the empty tree, or an index
14 * to a set of objects. If the quadtree has a value:
15 *
16 * > -1: it is an index to four other nodes.
17 *
18 * -1: it is empty
19 *
20 * < -1: it is an index to a set of objects
21 */
22 #include "object.h"
23
24 #define QUADTREE int
25
26 #define EMPTY (-1)
27
28 #define QT_IS_EMPTY(qt) ((qt) == EMPTY)
29 #define QT_IS_LEAF(qt) ((qt) < EMPTY)
30 #define QT_IS_TREE(qt) ((qt) > EMPTY)
31
32 #define QT_INDEX(qt) (-(qt)-2) /* quadtree node from set */
33 #define QT_SET_INDEX(i) (-((i)+2)) /* object set from node */
34 #define QT_BLOCK_SIZE 1024 /* quadtrees in block */
35 #define QT_BLOCK(qt) ((qt)>>10) /* quadtree block index */
36 #define QT_BLOCK_INDEX(qt) (((qt)&0x3ff)<<2) /* quadtree index in block */
37
38
39 #ifndef QT_MAX_BLK
40 #ifdef BIGMEM
41 #define QT_MAX_BLK 16383 /* maximum quadtree block */
42 #else
43 #define QT_MAX_BLK 2047 /* maximum quadtree block */
44 #endif
45 #endif
46
47
48 #define QT_NTH_CHILD(qt,br) (quad_block[QT_BLOCK(qt)][QT_BLOCK_INDEX(qt)+br])
49 #define QT_NTH_CHILD_PTR(qt,br) (&QT_NTH_CHILD(qt,br))
50 #define QT_CLEAR_CHILDREN(qt) (QT_NTH_CHILD(qt,0)=QT_NTH_CHILD(qt,1)= \
51 QT_NTH_CHILD(qt,2)=QT_NTH_CHILD(qt,3)=EMPTY)
52
53
54 /* QUADTREE NODE FLAGS */
55 #define QT_IS_FLAG(qt) IS_FLAG(quad_flag,qt)
56 #define QT_SET_FLAG(qt) SET_FLAG(quad_flag,qt)
57 #define QT_CLR_FLAG(qt) CLR_FLAG(quad_flag,qt)
58 #define QT_LEAF_IS_FLAG(qt) IS_FLAG(qtsetflag,QT_INDEX(qt))
59 #define QT_LEAF_SET_FLAG(qt) SET_FLAG(qtsetflag,QT_INDEX(qt))
60 #define QT_LEAF_CLR_FLAG(qt) CLR_FLAG(qtsetflag,QT_INDEX(qt))
61
62 /* OBJECT SET CODE */
63 #define QT_SET_CNT(s) ((s)[0])
64 #define QT_SET_NTH_ELEM(s,n) ((s)[(n)])
65
66 #define QT_CLEAR_SET(s) ((s)[0] = 0)
67 #define QT_SET_NEXT_ELEM(p) (*(p)++)
68 #define QT_SET_PTR(s) (&((s)[1]))
69
70
71 #define QT_MAXSET 511
72 #define MAXCSET 2*QT_MAXSET
73 #define QT_MAXCSET MAXCSET
74 #ifndef QT_SET_THRESHOLD
75 #define QT_SET_THRESHOLD 30
76 #endif
77
78 #ifndef QT_MAX_LEVELS
79 #define QT_MAX_LEVELS 12
80 #endif
81
82 #define QT_FILL_THRESHOLD 2
83 #define QT_EXPAND 8
84 #define QT_COMPRESS 16
85 #define QT_DONE 32
86 #define QT_MODIFIED 64
87
88 #define QT_FLAG_FILL_TRI(f) (((f)&0x7) == QT_FILL_THRESHOLD)
89 #define QT_FLAG_UPDATE(f) ((f)& (QT_EXPAND | QT_COMPRESS))
90 #define QT_FLAG_IS_DONE(f) ((f)& QT_DONE)
91 #define QT_FLAG_SET_DONE(f) ((f) |= QT_DONE)
92 #define QT_FLAG_IS_MODIFIED(f) ((f)& QT_MODIFIED)
93 #define QT_FLAG_SET_MODIFIED(f) ((f) |= QT_MODIFIED)
94
95 #define qtSubdivide(qt) (qt = qtAlloc(),QT_CLEAR_CHILDREN(qt))
96 #define qtSubdivide_tri(v0,v1,v2,a,b,c) (EDGE_MIDPOINT_VEC3(a,v0,v1), \
97 EDGE_MIDPOINT_VEC3(b,v1,v2), \
98 EDGE_MIDPOINT_VEC3(c,v2,v0))
99
100 extern QUADTREE qtnewleaf(), qtaddelem(), qtdelelem();
101
102 extern QUADTREE *quad_block[QT_MAX_BLK]; /* quadtree blocks */
103 extern int4 *quad_flag; /* zeroeth quadtree flag */
104
105 extern OBJECT **qtsettab; /* quadtree leaf node table */
106 extern QUADTREE qtnumsets; /* number of used set indices */
107 extern int4 *qtsetflag;
108 #ifdef DEBUG
109 extern OBJECT *qtqueryset();
110 #else
111 #define qtqueryset(qt) (qtsettab[QT_SET_INDEX(qt)])
112 #endif
113
114 #define qtinset(qt,id) inset(qtqueryset(qt),id)
115 #define qtgetset(os,qt) setcopy(os,qtqueryset(qt))
116
117 /*
118 QUADTREE qtRoot_point_locate(qt,q0,q1,q2,peq,pt,r0,r1,r2)
119 QUADTREE qt;
120 FVECT q0,q1,q2;
121 FPEQ peq;
122 FVECT pt;
123 FVECT r0,r1,r2;
124
125 Return the quadtree node containing pt. It is assumed that pt is in
126 the root node qt with ws vertices q0,q1,q2 and plane equation peq.
127 If r0 != NULL will return coordinates of node in (r0,r1,r2).
128 */
129
130 extern QUADTREE qtRoot_point_locate();
131 extern QUADTREE qtRoot_add_tri();
132 extern QUADTREE qtRoot_remove_tri();
133 extern QUADTREE qtAdd_tri();
134 extern QUADTREE qtRoot_visit_tri_edges();
135 extern QUADTREE qtRoot_trace_ray();
