root/radiance/ray/src/hd/sm_qtree.h
Revision: 3.18
Committed: Fri Nov 5 03:31:37 2004 UTC (19 years, 7 months ago) by greg
Changes since 3.17: +1 -1 lines
State: FILE REMOVED
1 /* RCSid: $Id: sm_qtree.h,v 3.17 2003/08/30 08:17:32 schorsch Exp $ */
2 /*
3 * sm_qtree.h - header file for routines using spherical quadtrees.
4 *
5 * adapted from octree.h
6 */
7 #ifndef _RAD_SM_QTREE_H_
8 #define _RAD_SM_QTREE_H_
9
10 #ifdef __cplusplus
11 extern "C" {
12 #endif
13
14 /*
15 * An quadtree is expressed as an integer which is either
16 * an index to 4 other nodes, the empty tree, or an index
17 * to a set of objects. If the quadtree has a value:
18 *
19 * > -1: it is an index to four other nodes.
20 *
21 * -1: it is empty
22 *
23 * < -1: it is an index to a set of objects
24 */
25
26 typedef struct _FUNC {
27 int (*func)();
28 int (*func_after)();
29 int *argptr;
30 }FUNC;
31
32 #define F_FUNC(f) (f.func)
33 #define F_FUNC2(f) (f.func_after)
34 #define F_ARGS(f) (f.argptr)
35 #define QUADTREE int
36
37 #define EMPTY (-1)
38
39 #define QT_IS_EMPTY(qt) ((qt) == EMPTY)
40 #define QT_IS_LEAF(qt) ((qt) < EMPTY)
41 #define QT_IS_TREE(qt) ((qt) > EMPTY)
42
43 #define QT_INDEX(qt) (-(qt)-2) /* quadtree node from set */
44 #define QT_SET_INDEX(i) (-((i)+2)) /* object set from node */
45 #define QT_BLOCK_SIZE 1024 /* quadtrees in block */
46 #define QT_BLOCK(qt) ((qt)>>10) /* quadtree block index */
47 #define QT_BLOCK_INDEX(qt) (((qt)&0x3ff)<<2) /* quadtree index in block */
48
49
50 #ifndef QT_MAX_BLK
51 #ifdef SMLMEM
52 #define QT_MAX_BLK 2047 /* maximum quadtree block */
53 #else
54 #define QT_MAX_BLK 16383 /* maximum quadtree block */
55 #endif
56 #endif
57
58
59 #define QT_NTH_CHILD(qt,br) (quad_block[QT_BLOCK(qt)][QT_BLOCK_INDEX(qt)+br])
60 #define QT_NTH_CHILD_PTR(qt,br) (&QT_NTH_CHILD(qt,br))
61 #define QT_CLEAR_CHILDREN(qt) (QT_NTH_CHILD(qt,0)=QT_NTH_CHILD(qt,1)= \
62 QT_NTH_CHILD(qt,2)=QT_NTH_CHILD(qt,3)=EMPTY)
63
64
65 /* QUADTREE NODE FLAGS */
66 #define QT_IS_FLAG(qt) IS_FLAG(quad_flag,qt)
67 #define QT_SET_FLAG(qt) SET_FLAG(quad_flag,qt)
68 #define QT_CLR_FLAG(qt) CLR_FLAG(quad_flag,qt)
69 #define QT_LEAF_IS_FLAG(qt) IS_FLAG(qtsetflag,QT_INDEX(qt))
70 #define QT_LEAF_SET_FLAG(qt) SET_FLAG(qtsetflag,QT_INDEX(qt))
71 #define QT_LEAF_CLR_FLAG(qt) CLR_FLAG(qtsetflag,QT_INDEX(qt))
72
73 /* OBJECT SET CODE */
74 #define QT_SET_CNT(s) ((s)[0])
75 #define QT_SET_NTH_ELEM(s,n) ((s)[(n)])
76
77 #define QT_CLEAR_SET(s) ((s)[0] = 0)
78 #define QT_SET_NEXT_ELEM(p) (*(++p))
79 #define QT_SET_PTR(s) (&((s)[1]))
80
81
82 #define QT_MAXSET 511
83 #define MAXCSET 2*QT_MAXSET
84 #define QT_MAXCSET MAXCSET
85 #ifndef QT_SET_THRESHOLD
86 #define QT_SET_THRESHOLD 32
87 #endif
88
89 #ifndef QT_MAX_LEVELS
90 #define QT_MAX_LEVELS 10
91 #endif
92
93 #define QT_FILL_THRESHOLD 2
94 #define QT_EXPAND 8
95 #define QT_COMPRESS 16
96 #define QT_DONE 32
97 #define QT_MODIFIED 64
98
99 #define QT_FLAG_FILL_TRI(f) (((f)&0x7) == QT_FILL_THRESHOLD)
100 #define QT_FLAG_UPDATE(f) ((f)& (QT_EXPAND | QT_COMPRESS))
101 #define QT_FLAG_IS_DONE(f) ((f)& QT_DONE)
102 #define QT_FLAG_SET_DONE(f) ((f) |= QT_DONE)
103 #define QT_FLAG_IS_MODIFIED(f) ((f)& QT_MODIFIED)
104 #define QT_FLAG_SET_MODIFIED(f) ((f) |= QT_MODIFIED)
105
106 #define qtSubdivide(qt) (qt = qtAlloc(),QT_CLEAR_CHILDREN(qt))
107 #define qtSubdivide_tri(v0,v1,v2,a,b,c) (EDGE_MIDPOINT(a,v1,v2), \
108 EDGE_MIDPOINT(b,v2,v0), \
109 EDGE_MIDPOINT(c,v0,v1))
110
111 extern QUADTREE qtnewleaf(), qtaddelem(), qtdelelem();
112
113 extern QUADTREE *quad_block[QT_MAX_BLK]; /* quadtree blocks */
114 extern int32 *quad_flag; /* zeroeth quadtree flag */
115
116 extern OBJECT **qtsettab; /* quadtree leaf node table */
117 extern QUADTREE qtnumsets; /* number of used set indices */
118 extern int32 *qtsetflag;
119 #ifdef DEBUG
120 extern OBJECT *qtqueryset();
121 #else
122 #define qtqueryset(qt) (qtsettab[QT_SET_INDEX(qt)])
123 #endif
124 #if 0
125 #define qtremovelast(qt) ((*(qtqueryset(qt)))--)
126 #endif
127 #define qtinset(qt,id) inset(qtqueryset(qt),id)
128 #define qtgetset(os,qt) setcopy(os,qtqueryset(qt))
129
130
131 #define SIDES_GTR(b0,b1,b2,s0,s1,s2,a,b,c) \
132 (s0 = ((b0[0] > a?4:0) | (b1[0] > a?2:0) | (b2[0] > a?1:0)), \
133 s1 = ((b0[1] > b?4:0) | (b1[1] > b?2:0) | (b2[1] > b?1:0)), \
134 s2 = ((b0[2] > c?4:0) | (b1[2] > c?2:0) | (b2[2] > c?1:0)))
135
136 #define SIDES_LESS(b0,b1,b2,s0,s1,s2,a,b,c) \
137 (s0 = ((b0[0] < a?4:0) | (b1[0] < a?2:0) | (b2[0] < a?1:0)), \
138 s1 = ((b0[1] < b?4:0) | (b1[1] < b?2:0) | (b2[1] < b?1:0)), \
139 s2 = ((b0[2] < c?4:0) | (b1[2] < c?2:0) | (b2[2] < c?1:0)))
140
141 /*
142 QUADTREE qtRoot_point_locate(qt,q0,q1,q2,peq,pt,r0,r1,r2)
143 QUADTREE qt;
144 FVECT q0,q1,q2;
145 FPEQ peq;
146 FVECT pt;
147 FVECT r0,r1,r2;
148
149 Return the quadtree node containing pt. It is assumed that pt is in
150 the root node qt with ws vertices q0,q1,q2 and plane equation peq.
151 If r0 != NULL will return coordinates of node in (r0,r1,r2).
152 */
153
154 extern QUADTREE qtRoot_point_locate();
155 extern QUADTREE qtRoot_add_tri();
156 extern QUADTREE qtRoot_remove_tri();
157 extern QUADTREE qtAdd_tri();
158 extern QUADTREE qtRoot_visit_tri_edges();
159 extern QUADTREE qtRoot_trace_ray();
160
161
162 #ifdef __cplusplus
163 }
164 #endif
165 #endif /* _RAD_SM_QTREE_H_ */
166
