1 |
/* Copyright (c) 1998 Silicon Graphics, Inc. */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ SGI"; |
5 |
#endif |
6 |
7 |
8 |
* sm_qtree.c: adapted from octree.c from radiance code |
9 |
10 |
11 |
* octree.c - routines dealing with octrees and cubes. |
12 |
13 |
* 7/28/85 |
14 |
15 |
16 |
#include "standard.h" |
17 |
18 |
#include "sm_geom.h" |
19 |
#include "sm_qtree.h" |
20 |
21 |
QUADTREE *quad_block[QT_MAX_BLK]; /* our quadtree */ |
22 |
static QUADTREE quad_free_list = EMPTY; /* freed octree nodes */ |
23 |
static QUADTREE treetop = 0; /* next free node */ |
24 |
int4 *quad_flag= NULL; |
25 |
26 |
#ifdef TEST_DRIVER |
27 |
extern FVECT Pick_v0[500],Pick_v1[500],Pick_v2[500]; |
28 |
extern int Pick_cnt,Pick_tri,Pick_samp; |
29 |
extern FVECT Pick_point[500]; |
30 |
#endif |
31 |
32 |
QUADTREE |
33 |
qtAlloc() /* allocate a quadtree */ |
34 |
35 |
register QUADTREE freet; |
36 |
37 |
if ((freet = quad_free_list) != EMPTY) |
38 |
39 |
quad_free_list = QT_NTH_CHILD(freet, 0); |
40 |
return(freet); |
41 |
42 |
freet = treetop; |
43 |
if (QT_BLOCK_INDEX(freet) == 0) |
44 |
45 |
if (QT_BLOCK(freet) >= QT_MAX_BLK) |
46 |
return(EMPTY); |
47 |
if ((quad_block[QT_BLOCK(freet)] = (QUADTREE *)malloc( |
48 |
QT_BLOCK_SIZE*4*sizeof(QUADTREE))) == NULL) |
49 |
return(EMPTY); |
50 |
51 |
quad_flag = (int4 *)realloc((char *)quad_flag, |
52 |
(QT_BLOCK(freet)+1)*(QT_BLOCK_SIZE/8)); |
53 |
if (quad_flag == NULL) |
54 |
return(EMPTY); |
55 |
56 |
treetop += 4; |
57 |
return(freet); |
58 |
59 |
60 |
61 |
qtClearAllFlags() /* clear all quadtree branch flags */ |
62 |
63 |
if (!treetop) return; |
64 |
bzero((char *)quad_flag, (QT_BLOCK(treetop-4)+1)*(QT_BLOCK_SIZE/8)); |
65 |
66 |
67 |
68 |
qtFree(qt) /* free a quadtree */ |
69 |
register QUADTREE qt; |
70 |
71 |
register int i; |
72 |
73 |
if (!QT_IS_TREE(qt)) |
74 |
75 |
qtfreeleaf(qt); |
76 |
return; |
77 |
78 |
for (i = 0; i < 4; i++) |
79 |
qtFree(QT_NTH_CHILD(qt, i)); |
80 |
QT_NTH_CHILD(qt, 0) = quad_free_list; |
81 |
quad_free_list = qt; |
82 |
83 |
84 |
85 |
qtDone() /* free EVERYTHING */ |
86 |
87 |
register int i; |
88 |
89 |
qtfreeleaves(); |
90 |
for (i = 0; i < QT_MAX_BLK; i++) |
91 |
92 |
if (quad_block[i] == NULL) |
93 |
break; |
94 |
free((char *)quad_block[i]); |
95 |
quad_block[i] = NULL; |
96 |
97 |
if (i) free((char *)quad_flag); |
98 |
quad_flag = NULL; |
99 |
quad_free_list = EMPTY; |
100 |
treetop = 0; |
101 |
102 |
103 |
QUADTREE |
104 |
*qtLocate_leaf(qtptr,bcoord,t0,t1,t2) |
105 |
QUADTREE *qtptr; |
106 |
double bcoord[3]; |
107 |
FVECT t0,t1,t2; |
108 |
109 |
int i; |
110 |
QUADTREE *child; |
111 |
FVECT a,b,c; |
112 |
113 |
if(QT_IS_TREE(*qtptr)) |
114 |
115 |
i = bary_child(bcoord); |
116 |
#ifdef DEBUG_TEST_DRIVER |
117 |
qtSubdivide_tri(Pick_v0[Pick_cnt-1],Pick_v1[Pick_cnt-1], |
118 |
Pick_v2[Pick_cnt-1],a,b,c); |
119 |
qtNth_child_tri(Pick_v0[Pick_cnt-1],Pick_v1[Pick_cnt-1], |
120 |
Pick_v2[Pick_cnt-1],a,b,c,i, |
121 |
Pick_v0[Pick_cnt],Pick_v1[Pick_cnt], |
122 |
Pick_v2[Pick_cnt]); |
123 |
Pick_cnt++; |
124 |
#endif |
125 |
126 |
child = QT_NTH_CHILD_PTR(*qtptr,i); |
127 |
if(t0) |
128 |
129 |
qtSubdivide_tri(t0,t1,t2,a,b,c); |
130 |
qtNth_child_tri(t0,t1,t2,a,b,c,i,t0,t1,t2); |
131 |
132 |
return(qtLocate_leaf(child,bcoord,t0,t1,t2)); |
133 |
134 |
else |
135 |
return(qtptr); |
136 |
137 |
138 |
139 |
QUADTREE |
140 |
*qtRoot_point_locate(qtptr,v0,v1,v2,pt,t0,t1,t2) |
141 |
QUADTREE *qtptr; |
142 |
FVECT v0,v1,v2; |
143 |
FVECT pt; |
144 |
FVECT t0,t1,t2; |
145 |
146 |
int d; |
147 |
int i,x,y; |
148 |
QUADTREE *child; |
149 |
FVECT n,i_pt,a,b,c; |
150 |
double pd,bcoord[3]; |
151 |
152 |
/* Determine if point lies within pyramid (and therefore |
153 |
inside a spherical quadtree cell):GT_INTERIOR, on one of the |
154 |
pyramid sides (and on cell edge):GT_EDGE(1,2 or 3), |
155 |
or on pyramid vertex (and on cell vertex):GT_VERTEX(1,2, or 3). |
156 |
For each triangle edge: compare the |
157 |
point against the plane formed by the edge and the view center |
158 |
159 |
d = point_in_stri(v0,v1,v2,pt); |
160 |
161 |
162 |
/* Not in this triangle */ |
163 |
if(!d) |
164 |
return(NULL); |
165 |
166 |
/* Will return lowest level triangle containing point: It the |
167 |
point is on an edge or vertex: will return first associated |
168 |
triangle encountered in the child traversal- the others can |
169 |
be derived using triangle adjacency information |
170 |
171 |
172 |
173 |
/* Find the intersection point */ |
174 |
tri_plane_equation(v0,v1,v2,n,&pd,FALSE); |
175 |
intersect_vector_plane(pt,n,pd,NULL,i_pt); |
176 |
177 |
i = max_index(n,NULL); |
178 |
x = (i+1)%3; |
179 |
y = (i+2)%3; |
180 |
/* Calculate barycentric coordinates of i_pt */ |
181 |
bary2d(v0[x],v0[y],v1[x],v1[y],v2[x],v2[y],i_pt[x],i_pt[y],bcoord); |
182 |
183 |
184 |
185 |
186 |
Pick_cnt = 0; |
187 |
VCOPY(Pick_v0[0],v0); |
188 |
VCOPY(Pick_v1[0],v1); |
189 |
VCOPY(Pick_v2[0],v2); |
190 |
Pick_cnt++; |
191 |
192 |
193 |
194 |
195 |
196 |
197 |
Pick_cnt++; |
198 |
#endif |
199 |
if(t0) |
200 |
201 |
qtSubdivide_tri(v0,v1,v2,a,b,c); |
202 |
qtNth_child_tri(v0,v1,v2,a,b,c,i,t0,t1,t2); |
203 |
204 |
205 |
206 |
else |
207 |
208 |
if(t0) |
209 |
210 |
VCOPY(t0,v0); |
211 |
VCOPY(t1,v1); |
212 |
VCOPY(t2,v2); |
213 |
214 |
return(qtptr); |
215 |
216 |
217 |
218 |
219 |
QUADTREE |
220 |
qtSubdivide(qtptr) |
221 |
QUADTREE *qtptr; |
222 |
223 |
QUADTREE node; |
224 |
node = qtAlloc(); |
225 |
QT_CLEAR_CHILDREN(node); |
226 |
*qtptr = node; |
227 |
return(node); |
228 |
229 |
230 |
231 |
QUADTREE |
232 |
qtSubdivide_nth_child(qt,n) |
233 |
QUADTREE qt; |
234 |
int n; |
235 |
236 |
QUADTREE node; |
237 |
238 |
node = qtSubdivide(&(QT_NTH_CHILD(qt,n))); |
239 |
240 |
return(node); |
241 |
242 |
243 |
/* for triangle v0-v1-v2- returns a,b,c: children are: |
244 |
245 |
v2 0: v0,a,c |
246 |
/\ 1: a,v1,b |
247 |
/2 \ 2: c,b,v2 |
248 |
c/____\b 3: b,c,a |
249 |
250 |
/0 \3 /1 \ |
251 |
v0____\/____\v1 |
252 |
a |
253 |
254 |
255 |
qtSubdivide_tri(v0,v1,v2,a,b,c) |
256 |
FVECT v0,v1,v2; |
257 |
FVECT a,b,c; |
258 |
259 |
EDGE_MIDPOINT_VEC3(a,v0,v1); |
260 |
EDGE_MIDPOINT_VEC3(b,v1,v2); |
261 |
EDGE_MIDPOINT_VEC3(c,v2,v0); |
262 |
263 |
264 |
qtNth_child_tri(v0,v1,v2,a,b,c,i,r0,r1,r2) |
265 |
FVECT v0,v1,v2; |
266 |
FVECT a,b,c; |
267 |
int i; |
268 |
FVECT r0,r1,r2; |
269 |
270 |
271 |
switch(i){ |
272 |
case 0: |
273 |
VCOPY(r0,v0); VCOPY(r1,a); VCOPY(r2,c); |
274 |
break; |
275 |
case 1: |
276 |
VCOPY(r0,a); VCOPY(r1,v1); VCOPY(r2,b); |
277 |
break; |
278 |
case 2: |
279 |
VCOPY(r0,c); VCOPY(r1,b); VCOPY(r2,v2); |
280 |
break; |
281 |
case 3: |
282 |
VCOPY(r0,b); VCOPY(r1,c); VCOPY(r2,a); |
283 |
break; |
284 |
285 |
286 |
287 |
/* Add triangle "id" to all leaf level cells that are children of |
288 |
quadtree pointed to by "qtptr" with cell vertices "t1,t2,t3" |
289 |
that it overlaps (vertex and edge adjacencies do not count |
290 |
as overlapping). If the addition of the triangle causes the cell to go over |
291 |
threshold- the cell is split- and the triangle must be recursively inserted |
292 |
into the new child cells: it is assumed that "v1,v2,v3" are normalized |
293 |
294 |
295 |
int |
296 |
qtRoot_add_tri(qtptr,q0,q1,q2,t0,t1,t2,id,n) |
297 |
QUADTREE *qtptr; |
298 |
FVECT q0,q1,q2; |
299 |
FVECT t0,t1,t2; |
300 |
int id; |
301 |
int n; |
302 |
303 |
int test; |
304 |
int found; |
305 |
306 |
test = stri_intersect(q0,q1,q2,t0,t1,t2); |
307 |
if(!test) |
308 |
return(FALSE); |
309 |
310 |
found = qtAdd_tri(qtptr,q0,q1,q2,t0,t1,t2,id,n); |
311 |
312 |
return(found); |
313 |
314 |
315 |
int |
316 |
qtAdd_tri(qtptr,q0,q1,q2,t0,t1,t2,id,n) |
317 |
QUADTREE *qtptr; |
318 |
FVECT q0,q1,q2; |
319 |
FVECT t0,t1,t2; |
320 |
int id; |
321 |
int n; |
322 |
323 |
int i,index,test,found; |
324 |
FVECT a,b,c; |
325 |
OBJECT os[QT_MAXSET+1],*optr; |
326 |
QUADTREE qt; |
327 |
FVECT r0,r1,r2; |
328 |
329 |
found = 0; |
330 |
/* if this is tree: recurse */ |
331 |
332 |
333 |
n++; |
334 |
qtSubdivide_tri(q0,q1,q2,a,b,c); |
335 |
test = stri_intersect(t0,t1,t2,q0,a,c); |
336 |
if(test) |
337 |
found |= qtAdd_tri(QT_NTH_CHILD_PTR(*qtptr,0),q0,a,c,t0,t1,t2,id,n); |
338 |
test = stri_intersect(t0,t1,t2,a,q1,b); |
339 |
if(test) |
340 |
found |= qtAdd_tri(QT_NTH_CHILD_PTR(*qtptr,1),a,q1,b,t0,t1,t2,id,n); |
341 |
test = stri_intersect(t0,t1,t2,c,b,q2); |
342 |
if(test) |
343 |
found |= qtAdd_tri(QT_NTH_CHILD_PTR(*qtptr,2),c,b,q2,t0,t1,t2,id,n); |
344 |
test = stri_intersect(t0,t1,t2,b,c,a); |
345 |
if(test) |
346 |
found |= qtAdd_tri(QT_NTH_CHILD_PTR(*qtptr,3),b,c,a,t0,t1,t2,id,n); |
347 |
348 |
else |
349 |
350 |
/* If this leave node emptry- create a new set */ |
351 |
if(QT_IS_EMPTY(*qtptr)) |
352 |
*qtptr = qtaddelem(*qtptr,id); |
353 |
else |
354 |
355 |
/* If the set is too large: subdivide */ |
356 |
optr = qtqueryset(*qtptr); |
357 |
358 |
if(QT_SET_CNT(optr) < QT_SET_THRESHOLD) |
359 |
360 |
else |
361 |
362 |
if (n < QT_MAX_LEVELS) |
363 |
364 |
/* If set size exceeds threshold: subdivide cell and |
365 |
reinsert set tris into cell |
366 |
367 |
qtgetset(os,*qtptr); |
368 |
369 |
n++; |
370 |
qtfreeleaf(*qtptr); |
371 |
qtSubdivide(qtptr); |
372 |
373 |
374 |
for(optr = QT_SET_PTR(os),i = QT_SET_CNT(os); i > 0; i--) |
375 |
376 |
id = QT_SET_NEXT_ELEM(optr); |
377 |
qtTri_from_id(id,r0,r1,r2,NULL,NULL,NULL,NULL,NULL,NULL); |
378 |
found=qtAdd_tri(qtptr,q0,q1,q2,r0,r1,r2,id,n); |
379 |
#ifdef DEBUG |
380 |
if(!found) |
381 |
eputs("qtAdd_tri():Reinsert-in parent but not children\n"); |
382 |
#endif |
383 |
384 |
385 |
else |
386 |
if(QT_SET_CNT(optr) < QT_MAXSET) |
387 |
388 |
else |
389 |
390 |
#ifdef DEBUG |
391 |
eputs("qtAdd_tri():two many levels\n"); |
392 |
#endif |
393 |
return(FALSE); |
394 |
395 |
396 |
397 |
398 |
return(TRUE); |
399 |
400 |
401 |
402 |
int |
403 |
qtApply_to_tri_cells(qtptr,t0,t1,t2,v0,v1,v2,func,arg) |
404 |
QUADTREE *qtptr; |
405 |
FVECT t0,t1,t2; |
406 |
FVECT v0,v1,v2; |
407 |
int (*func)(); |
408 |
int *arg; |
409 |
410 |
int test; |
411 |
FVECT a,b,c; |
412 |
413 |
/* test if triangle (t0,t1,t2) overlaps cell triangle (v0,v1,v2) */ |
414 |
test = stri_intersect(t0,t1,t2,v0,v1,v2); |
415 |
416 |
/* If triangles do not overlap: done */ |
417 |
if(!test) |
418 |
return(FALSE); |
419 |
420 |
421 |
func(qtptr,arg); |
422 |
423 |
424 |
425 |
QT_SET_FLAG(*qtptr); |
426 |
427 |
qtApply_to_tri_cells(QT_NTH_CHILD_PTR(*qtptr,0),t0,t1,t2,v0,a,c,func,arg); |
428 |
qtApply_to_tri_cells(QT_NTH_CHILD_PTR(*qtptr,1),t0,t1,t2,a,v1,b,func,arg); |
429 |
qtApply_to_tri_cells(QT_NTH_CHILD_PTR(*qtptr,2),t0,t1,t2,c,b,v2,func,arg); |
430 |
qtApply_to_tri_cells(QT_NTH_CHILD_PTR(*qtptr,3),t0,t1,t2,b,c,a,func,arg); |
431 |
432 |
433 |
434 |
int |
435 |
qtRemove_tri(qtptr,id,t0,t1,t2,v0,v1,v2) |
436 |
QUADTREE *qtptr; |
437 |
int id; |
438 |
FVECT t0,t1,t2; |
439 |
FVECT v0,v1,v2; |
440 |
441 |
442 |
int test; |
443 |
int i; |
444 |
FVECT a,b,c; |
445 |
OBJECT os[QT_MAXSET+1]; |
446 |
447 |
448 |
449 |
450 |
451 |
if(!test) |
452 |
return(FALSE); |
453 |
454 |
455 |
456 |
457 |
458 |
qtRemove_tri(QT_NTH_CHILD_PTR(*qtptr,0),id,t0,t1,t2,v0,a,c); |
459 |
qtRemove_tri(QT_NTH_CHILD_PTR(*qtptr,1),id,t0,t1,t2,a,v1,b); |
460 |
qtRemove_tri(QT_NTH_CHILD_PTR(*qtptr,2),id,t0,t1,t2,c,b,v2); |
461 |
qtRemove_tri(QT_NTH_CHILD_PTR(*qtptr,3),id,t0,t1,t2,b,c,a); |
462 |
463 |
else |
464 |
465 |
466 |
467 |
#ifdef DEBUG |
468 |
eputs("qtRemove_tri(): triangle not found\n"); |
469 |
#endif |
470 |
471 |
/* remove id from set */ |
472 |
else |
473 |
474 |
if(!qtinset(*qtptr,id)) |
475 |
476 |
#ifdef DEBUG |
477 |
eputs("qtRemove_tri(): tri not in set\n"); |
478 |
#endif |
479 |
480 |
else |
481 |
482 |
*qtptr = qtdelelem(*qtptr,id); |
483 |
484 |
485 |
486 |
return(TRUE); |
487 |
488 |
489 |
490 |
int |
491 |
move_to_nbr(b,db0,db1,db2,tptr) |
492 |
double b[3],db0,db1,db2; |
493 |
double *tptr; |
494 |
495 |
double t,dt; |
496 |
int nbr; |
497 |
498 |
nbr = -1; |
499 |
/* Advance to next node */ |
500 |
if(!ZERO(db0) && db0 < 0.0) |
501 |
502 |
t = -b[0]/db0; |
503 |
nbr = 0; |
504 |
505 |
else |
506 |
t = FHUGE; |
507 |
if(!ZERO(db1) && db1 < 0.0 ) |
508 |
509 |
dt = -b[1]/db1; |
510 |
if( dt < t) |
511 |
512 |
t = dt; |
513 |
nbr = 1; |
514 |
515 |
516 |
if(!ZERO(db2) && db2 < 0.0 ) |
517 |
518 |
dt = -b[2]/db2; |
519 |
if( dt < t) |
520 |
521 |
t = dt; |
522 |
nbr = 2; |
523 |
524 |
525 |
*tptr = t; |
526 |
return(nbr); |
527 |
528 |
529 |
int |
530 |
qtTrace_ray(qtptr,b,db0,db1,db2,orig,dir,func,arg1,arg2) |
531 |
QUADTREE *qtptr; |
532 |
533 |
FVECT orig,dir; |
534 |
int (*func)(); |
535 |
int *arg1,arg2; |
536 |
537 |
538 |
int i,found; |
539 |
QUADTREE *child; |
540 |
int nbr,next; |
541 |
double t; |
542 |
543 |
544 |
FVECT a1,b1,c1; |
545 |
int Pick_parent = Pick_cnt-1; |
546 |
qtSubdivide_tri(Pick_v0[Pick_parent],Pick_v1[Pick_parent], |
547 |
Pick_v2[Pick_parent],a1,b1,c1); |
548 |
549 |
#endif |
550 |
551 |
552 |
/* Find the appropriate child and reset the coord */ |
553 |
i = bary_child(b); |
554 |
555 |
556 |
557 |
for(;;) |
558 |
559 |
560 |
561 |
if(i != 3) |
562 |
nbr = qtTrace_ray(child,b,db0,db1,db2,orig,dir,func,arg1,arg2); |
563 |
else |
564 |
/* If the center cell- must flip direction signs */ |
565 |
nbr =qtTrace_ray(child,b,-db0,-db1,-db2,orig,dir,func,arg1,arg2); |
566 |
if(nbr == QT_DONE) |
567 |
return(nbr); |
568 |
569 |
/* If in same block: traverse */ |
570 |
if(i==3) |
571 |
next = nbr; |
572 |
else |
573 |
if(nbr == i) |
574 |
next = 3; |
575 |
else |
576 |
577 |
/* reset the barycentric coordinates in the parents*/ |
578 |
bary_parent(b,i); |
579 |
/* Else pop up to parent and traverse from there */ |
580 |
return(nbr); |
581 |
582 |
bary_from_child(b,i,next); |
583 |
i = next; |
584 |
585 |
586 |
else |
587 |
588 |
589 |
qtNth_child_tri(Pick_v0[Pick_parent],Pick_v1[Pick_parent], |
590 |
Pick_v2[Pick_parent],a1,b1,c1,i, |
591 |
592 |
593 |
Pick_cnt++; |
594 |
#endif |
595 |
596 |
if(func(qtptr,orig,dir,arg1,arg2) == QT_DONE) |
597 |
return(QT_DONE); |
598 |
599 |
600 |
/* NOTE: Optimize: should only have to check 1/2 */ |
601 |
nbr = move_to_nbr(b,db0,db1,db2,&t); |
602 |
603 |
if(nbr != -1) |
604 |
605 |
b[0] += t * db0; |
606 |
b[1] += t * db1; |
607 |
b[2] += t * db2; |
608 |
609 |
return(nbr); |
610 |
611 |
612 |
613 |
614 |
int |
615 |
qtRoot_trace_ray(qtptr,q0,q1,q2,orig,dir,func,arg1,arg2) |
616 |
QUADTREE *qtptr; |
617 |
FVECT q0,q1,q2; |
618 |
FVECT orig,dir; |
619 |
int (*func)(); |
620 |
int *arg1,arg2; |
621 |
622 |
int i,x,y,nbr; |
623 |
QUADTREE *child; |
624 |
FVECT n,c,i_pt,d; |
625 |
double pd,b[3],db[3],t; |
626 |
627 |
628 |
629 |
630 |
631 |
632 |
633 |
i = point_in_stri(q0,q1,q2,orig); |
634 |
635 |
636 |
if(!i) |
637 |
return(INVALID); |
638 |
/* Project the origin onto the root node plane */ |
639 |
640 |
/* Find the intersection point of the origin */ |
641 |
tri_plane_equation(q0,q1,q2,n,&pd,FALSE); |
642 |
intersect_vector_plane(orig,n,pd,NULL,i_pt); |
643 |
/* project the dir as well */ |
644 |
VADD(c,orig,dir); |
645 |
intersect_vector_plane(c,n,pd,&t,c); |
646 |
647 |
/* map to 2d by dropping maximum magnitude component of normal */ |
648 |
649 |
x = (i+1)%3; |
650 |
y = (i+2)%3; |
651 |
/* Calculate barycentric coordinates of orig */ |
652 |
bary2d(q0[x],q0[y],q1[x],q1[y],q2[x],q2[y],i_pt[x],i_pt[y],b); |
653 |
/* Calculate barycentric coordinates of dir */ |
654 |
bary2d(q0[x],q0[y],q1[x],q1[y],q2[x],q2[y],c[x],c[y],db); |
655 |
if(t < 0.0) |
656 |
VSUB(db,b,db); |
657 |
else |
658 |
VSUB(db,db,b); |
659 |
660 |
661 |
662 |
VCOPY(Pick_v0[Pick_cnt],q0); |
663 |
VCOPY(Pick_v1[Pick_cnt],q1); |
664 |
VCOPY(Pick_v2[Pick_cnt],q2); |
665 |
Pick_cnt++; |
666 |
#endif |
667 |
668 |
/* trace the ray starting with this node */ |
669 |
nbr = qtTrace_ray(qtptr,b,db[0],db[1],db[2],orig,dir,func,arg1,arg2); |
670 |
return(nbr); |
671 |
672 |
673 |
674 |
qtVisit_tri_interior(qtptr,q0,q1,q2,t0,t1,t2,n,func,arg1,arg2,arg3) |
675 |
QUADTREE *qtptr; |
676 |
FVECT q0,q1,q2; |
677 |
FVECT t0,t1,t2; |
678 |
int n; |
679 |
int (*func)(); |
680 |
int *arg1,arg2,*arg3; |
681 |
682 |
int i,found,test; |
683 |
QUADTREE *child; |
684 |
FVECT c0,c1,c2,a,b,c; |
685 |
686 |
int w; |
687 |
688 |
/* If qt Flag set, or qt vertices interior to t0t1t2-descend */ |
689 |
tree_modified: |
690 |
691 |
692 |
693 |
if(QT_IS_FLAG(*qtptr) || point_in_stri(t0,t1,t2,q0)) |
694 |
695 |
696 |
697 |
/* descend to children */ |
698 |
for(i=0;i < 4; i++) |
699 |
700 |
701 |
qtNth_child_tri(q0,q1,q2,a,b,c,i,c0,c1,c2); |
702 |
qtVisit_tri_interior(child,c0,c1,c2,t0,t1,t2,n+1, |
703 |
func,arg1,arg2,arg3); |
704 |
705 |
706 |
707 |
else |
708 |
709 |
/* NOTE THIS IN TRI TEST Could be replaced by a flag */ |
710 |
if(!QT_IS_EMPTY(*qtptr)) |
711 |
712 |
if(qtinset(*qtptr,arg2)) |
713 |
if(func(qtptr,q0,q1,q2,t0,t1,t2,n,arg1,arg2,arg3)==QT_MODIFIED) |
714 |
goto tree_modified; |
715 |
else |
716 |
return; |
717 |
718 |
if(point_in_stri(t0,t1,t2,q0) ) |
719 |
720 |
721 |
722 |
723 |
724 |
725 |
726 |
727 |
728 |
729 |
/* NOTE: SINCE DIR could be unit: then we could use integer math */ |
730 |
int |
731 |
qtVisit_tri_edges(qtptr,b,db0,db1,db2, |
732 |
db,wptr,t,sign,sfactor,func,arg1,arg2,arg3) |
733 |
QUADTREE *qtptr; |
734 |
double b[3],db0,db1,db2,db[3][3]; |
735 |
int *wptr; |
736 |
double t[3]; |
737 |
int sign; |
738 |
double sfactor; |
739 |
int (*func)(); |
740 |
741 |
742 |
int i,found; |
743 |
QUADTREE *child; |
744 |
int nbr,next,w; |
745 |
double t_l,t_g; |
746 |
747 |
FVECT a1,b1,c1; |
748 |
749 |
750 |
751 |
#endif |
752 |
753 |
754 |
755 |
756 |
757 |
758 |
759 |
for(;;) |
760 |
761 |
w = *wptr; |
762 |
763 |
764 |
if(i != 3) |
765 |
nbr = qtVisit_tri_edges(child,b,db0,db1,db2, |
766 |
db,wptr,t,sign, |
767 |
sfactor*2.0,func,arg1,arg2,arg3); |
768 |
else |
769 |
770 |
nbr = qtVisit_tri_edges(child,b,-db0,-db1,-db2, |
771 |
db,wptr,t,1-sign, |
772 |
773 |
774 |
775 |
return(nbr); |
776 |
if(*wptr != w) |
777 |
778 |
w = *wptr; |
779 |
db0 = db[w][0];db1 = db[w][1];db2 = db[w][2]; |
780 |
if(sign) |
781 |
{ db0 *= -1.0;db1 *= -1.0; db2 *= -1.0;} |
782 |
783 |
784 |
if(i==3) |
785 |
next = nbr; |
786 |
else |
787 |
if(nbr == i) |
788 |
next = 3; |
789 |
else |
790 |
791 |
792 |
bary_parent(b,i); |
793 |
794 |
return(nbr); |
795 |
796 |
797 |
i = next; |
798 |
799 |
800 |
else |
801 |
802 |
803 |
804 |
Pick_v2[Pick_parent],a1,b1,c1,i,Pick_v0[Pick_cnt], |
805 |
Pick_v1[Pick_cnt],Pick_v2[Pick_cnt]); |
806 |
Pick_cnt++; |
807 |
#endif |
808 |
809 |
if(func(qtptr,arg1,arg2,arg3) == QT_DONE) |
810 |
return(QT_DONE); |
811 |
812 |
813 |
w = *wptr; |
814 |
while(1) |
815 |
816 |
nbr = move_to_nbr(b,db0,db1,db2,&t_l); |
817 |
818 |
t_g = t_l/sfactor; |
819 |
#ifdef DEBUG |
820 |
if(t[w] <= 0.0) |
821 |
eputs("qtVisit_tri_edges():negative t\n"); |
822 |
#endif |
823 |
if(t_g >= t[w]) |
824 |
825 |
if(w == 2) |
826 |
return(QT_DONE); |
827 |
828 |
b[0] += (t[w])*sfactor*db0; |
829 |
b[1] += (t[w])*sfactor*db1; |
830 |
b[2] += (t[w])*sfactor*db2; |
831 |
w++; |
832 |
db0 = db[w][0]; |
833 |
db1 = db[w][1]; |
834 |
db2 = db[w][2]; |
835 |
if(sign) |
836 |
837 |
838 |
else |
839 |
if(nbr != INVALID) |
840 |
841 |
b[0] += t_l * db0; |
842 |
b[1] += t_l * db1; |
843 |
b[2] += t_l * db2; |
844 |
845 |
t[w] -= t_g; |
846 |
*wptr = w; |
847 |
return(nbr); |
848 |
849 |
else |
850 |
return(INVALID); |
851 |
852 |
853 |
854 |
855 |
856 |
857 |
int |
858 |
qtRoot_visit_tri_edges(qtptr,q0,q1,q2,tri,i_pt,wptr,func,arg1,arg2,arg3) |
859 |
QUADTREE *qtptr; |
860 |
FVECT q0,q1,q2; |
861 |
FVECT tri[3],i_pt; |
862 |
int *wptr; |
863 |
int (*func)(); |
864 |
865 |
866 |
int x,y,z,nbr,w,i,j; |
867 |
QUADTREE *child; |
868 |
FVECT n,c,d,v[3]; |
869 |
double pd,b[4][3],db[3][3],et[3],t[3],exit_pt; |
870 |
871 |
w = *wptr; |
872 |
873 |
874 |
875 |
876 |
877 |
878 |
z = max_index(n,NULL); |
879 |
x = (z+1)%3; |
880 |
y = (z+2)%3; |
881 |
/* Calculate barycentric coordinates for current vertex */ |
882 |
if(w != -1) |
883 |
884 |
bary2d(q0[x],q0[y],q1[x],q1[y],q2[x],q2[y],i_pt[x],i_pt[y],b[3]); |
885 |
intersect_vector_plane(tri[w],n,pd,&(et[w]),v[w]); |
886 |
bary2d(q0[x],q0[y],q1[x],q1[y],q2[x],q2[y],v[w][x],v[w][y],b[w]); |
887 |
888 |
else |
889 |
/* Just starting: b[0] is the origin point: guaranteed to be valid b*/ |
890 |
891 |
w = 0; |
892 |
intersect_vector_plane(tri[0],n,pd,&(et[0]),v[0]); |
893 |
bary2d(q0[x],q0[y],q1[x],q1[y],q2[x],q2[y],v[0][x],v[0][y],b[0]); |
894 |
VCOPY(b[3],b[0]); |
895 |
896 |
897 |
898 |
j = (w+1)%3; |
899 |
intersect_vector_plane(tri[j],n,pd,&(et[j]),v[j]); |
900 |
bary2d(q0[x],q0[y],q1[x],q1[y],q2[x],q2[y],v[j][x],v[j][y],b[j]); |
901 |
if(et[j] < 0.0) |
902 |
903 |
VSUB(db[w],b[3],b[j]); |
904 |
t[w] = FHUGE; |
905 |
906 |
else |
907 |
908 |
/* NOTE: for stability: do not increment with ipt- use full dir and |
909 |
calculate t: but for wrap around case: could get same problem? |
910 |
911 |
VSUB(db[w],b[j],b[3]); |
912 |
t[w] = 1.0; |
913 |
move_to_nbr(b[3],db[w][0],db[w][1],db[w][2],&exit_pt); |
914 |
if(exit_pt >= 1.0) |
915 |
916 |
for(;j < 3;j++) |
917 |
918 |
i = (j+1)%3; |
919 |
if(i!= w) |
920 |
921 |
intersect_vector_plane(tri[i],n,pd,&(et[i]),v[i]); |
922 |
bary2d(q0[x],q0[y],q1[x],q1[y],q2[x],q2[y],v[i][x], |
923 |
v[i][y],b[i]); |
924 |
925 |
if(et[i] < 0.0) |
926 |
927 |
VSUB(db[j],b[j],b[i]); |
928 |
t[j] = FHUGE; |
929 |
break; |
930 |
931 |
else |
932 |
933 |
VSUB(db[j],b[i],b[j]); |
934 |
t[j] = 1.0; |
935 |
936 |
move_to_nbr(b[j],db[j][0],db[j][1],db[j][2],&exit_pt); |
937 |
if(exit_pt < 1.0) |
938 |
break; |
939 |
940 |
941 |
942 |
*wptr = w; |
943 |
944 |
nbr = qtVisit_tri_edges(qtptr,b[3],db[w][0],db[w][1],db[w][2], |
945 |
db,wptr,t,0,1.0,func,arg1,arg2,arg3); |
946 |
if(nbr != INVALID && nbr != QT_DONE) |
947 |
948 |
i_pt[x] = b[3][0]*q0[x] + b[3][1]*q1[x] + b[3][2]*q2[x]; |
949 |
i_pt[y] = b[3][0]*q0[y] + b[3][1]*q1[y] + b[3][2]*q2[y]; |
950 |
i_pt[z] = (-n[x]*i_pt[x] - n[y]*i_pt[y] -pd)/n[z]; |
951 |
952 |
return(nbr); |
953 |
954 |
955 |
956 |
int |
957 |
move_to_nbri(b,db0,db1,db2,tptr) |
958 |
BCOORD b[3]; |
959 |
BDIR db0,db1,db2; |
960 |
TINT *tptr; |
961 |
962 |
TINT t,dt; |
963 |
BCOORD bc; |
964 |
int nbr; |
965 |
966 |
nbr = -1; |
967 |
968 |
if(db0 < 0) |
969 |
970 |
bc = MAXBCOORD*b[0]; |
971 |
t = bc/-db0; |
972 |
nbr = 0; |
973 |
974 |
else |
975 |
t = HUGET; |
976 |
if(db1 < 0) |
977 |
978 |
bc = MAXBCOORD*b[1]; |
979 |
dt = bc/-db1; |
980 |
if( dt < t) |
981 |
982 |
t = dt; |
983 |
nbr = 1; |
984 |
985 |
986 |
if(db2 < 0) |
987 |
988 |
bc = MAXBCOORD*b[2]; |
989 |
dt = bc/-db2; |
990 |
if( dt < t) |
991 |
992 |
t = dt; |
993 |
nbr = 2; |
994 |
995 |
996 |
*tptr = t; |
997 |
return(nbr); |
998 |
999 |
1000 |
int |
1001 |
qtVisit_tri_edgesi(qtptr,b,db0,db1,db2, |
1002 |
1003 |
QUADTREE *qtptr; |
1004 |
BCOORD b[3]; |
1005 |
BDIR db0,db1,db2,db[3][3]; |
1006 |
int *wptr; |
1007 |
TINT t[3]; |
1008 |
int sign; |
1009 |
int sfactor; |
1010 |
int (*func)(); |
1011 |
1012 |
1013 |
int i,found; |
1014 |
QUADTREE *child; |
1015 |
int nbr,next,w; |
1016 |
TINT t_g,t_l,t_i; |
1017 |
1018 |
FVECT a1,b1,c1; |
1019 |
1020 |
1021 |
1022 |
#endif |
1023 |
1024 |
1025 |
1026 |
i = baryi_child(b); |
1027 |
1028 |
1029 |
1030 |
for(;;) |
1031 |
1032 |
w = *wptr; |
1033 |
1034 |
1035 |
if(i != 3) |
1036 |
nbr = qtVisit_tri_edgesi(child,b,db0,db1,db2, |
1037 |
db,wptr,t,sign, |
1038 |
sfactor+1,func,arg1,arg2,arg3); |
1039 |
else |
1040 |
1041 |
nbr = qtVisit_tri_edgesi(child,b,-db0,-db1,-db2, |
1042 |
db,wptr,t,1-sign, |
1043 |
1044 |
1045 |
1046 |
return(nbr); |
1047 |
if(*wptr != w) |
1048 |
1049 |
w = *wptr; |
1050 |
1051 |
if(sign) |
1052 |
{ db0 *= -1;db1 *= -1; db2 *= -1;} |
1053 |
1054 |
1055 |
if(i==3) |
1056 |
next = nbr; |
1057 |
else |
1058 |
if(nbr == i) |
1059 |
next = 3; |
1060 |
else |
1061 |
1062 |
1063 |
baryi_parent(b,i); |
1064 |
1065 |
return(nbr); |
1066 |
1067 |
baryi_from_child(b,i,next); |
1068 |
i = next; |
1069 |
1070 |
1071 |
else |
1072 |
1073 |
1074 |
1075 |
1076 |
1077 |
Pick_cnt++; |
1078 |
#endif |
1079 |
1080 |
1081 |
return(QT_DONE); |
1082 |
1083 |
1084 |
w = *wptr; |
1085 |
while(1) |
1086 |
1087 |
nbr = move_to_nbri(b,db0,db1,db2,&t_i); |
1088 |
1089 |
t_g = t_i >> sfactor; |
1090 |
1091 |
if(t_g >= t[w]) |
1092 |
1093 |
if(w == 2) |
1094 |
return(QT_DONE); |
1095 |
1096 |
/* The edge fits in the cell- therefore the result of shifting db by |
1097 |
sfactor is guaranteed to be less than MAXBCOORD |
1098 |
1099 |
/* Caution: (t[w]*db) must occur before divide by MAXBCOORD |
1100 |
since t[w] will always be < MAXBCOORD |
1101 |
1102 |
b[0] = b[0] + (t[w]*db0*(1 << sfactor))/MAXBCOORD; |
1103 |
b[1] = b[1] + (t[w]*db1*(1 << sfactor))/MAXBCOORD; |
1104 |
b[2] = b[2] + (t[w]*db2*(1 << sfactor))/MAXBCOORD; |
1105 |
w++; |
1106 |
db0 = db[w][0]; db1 = db[w][1]; db2 = db[w][2]; |
1107 |
if(sign) |
1108 |
1109 |
1110 |
else |
1111 |
1112 |
1113 |
/* Caution: (t_i*db) must occur before divide by MAXBCOORD |
1114 |
since t_i will always be < MAXBCOORD |
1115 |
1116 |
b[0] = b[0] + (t_i *db0) / MAXBCOORD; |
1117 |
b[1] = b[1] + (t_i *db1) / MAXBCOORD; |
1118 |
b[2] = b[2] + (t_i *db2) / MAXBCOORD; |
1119 |
1120 |
t[w] -= t_g; |
1121 |
*wptr = w; |
1122 |
return(nbr); |
1123 |
1124 |
else |
1125 |
return(INVALID); |
1126 |
1127 |
1128 |
1129 |
1130 |
1131 |
int |
1132 |
qtRoot_visit_tri_edgesi(qtptr,q0,q1,q2,tri,i_pt,wptr,func,arg1,arg2,arg3) |
1133 |
QUADTREE *qtptr; |
1134 |
FVECT q0,q1,q2; |
1135 |
1136 |
int *wptr; |
1137 |
int (*func)(); |
1138 |
1139 |
1140 |
1141 |
QUADTREE *child; |
1142 |
FVECT n,c,d,v[3]; |
1143 |
double pd,b[4][3],db[3][3],et[3],exit_pt; |
1144 |
BCOORD bi[3]; |
1145 |
TINT t[3]; |
1146 |
BDIR dbi[3][3]; |
1147 |
w = *wptr; |
1148 |
1149 |
1150 |
1151 |
t[0] = t[1] = t[2] = 0; |
1152 |
1153 |
1154 |
1155 |
1156 |
x = (z+1)%3; |
1157 |
y = (z+2)%3; |
1158 |
1159 |
if(w != -1) |
1160 |
1161 |
1162 |
1163 |
1164 |
1165 |
else |
1166 |
1167 |
1168 |
w = 0; |
1169 |
1170 |
1171 |
VCOPY(b[3],b[0]); |
1172 |
1173 |
1174 |
1175 |
j = (w+1)%3; |
1176 |
1177 |
1178 |
if(et[j] < 0.0) |
1179 |
1180 |
1181 |
t[w] = HUGET; |
1182 |
1183 |
else |
1184 |
1185 |
1186 |
1187 |
1188 |
1189 |
/* Check if the point is out side of the triangle: if so t[w] =HUGET */ |
1190 |
if((fabs(b[j][0])>(FTINY+1.0)) ||(fabs(b[j][1])>(FTINY+1.0)) || |
1191 |
(fabs(b[j][2])>(FTINY+1.0))) |
1192 |
t[w] = HUGET; |
1193 |
else |
1194 |
1195 |
/* The next point is in the triangle- so db values will be in valid |
1196 |
range and t[w]= MAXT |
1197 |
1198 |
t[w] = MAXT; |
1199 |
if(j != 0) |
1200 |
for(;j < 3;j++) |
1201 |
1202 |
i = (j+1)%3; |
1203 |
if(i!= w) |
1204 |
1205 |
1206 |
1207 |
v[i][y],b[i]); |
1208 |
1209 |
if(et[i] < 0.0) |
1210 |
1211 |
1212 |
t[j] = HUGET; |
1213 |
break; |
1214 |
1215 |
else |
1216 |
1217 |
1218 |
if((fabs(b[j][0])>(FTINY+1.0)) || |
1219 |
1220 |
1221 |
1222 |
t[j] = HUGET; |
1223 |
break; |
1224 |
1225 |
else |
1226 |
t[j] = MAXT; |
1227 |
1228 |
1229 |
1230 |
1231 |
*wptr = w; |
1232 |
bary_dtol(b[3],db,bi,dbi,t); |
1233 |
1234 |
1235 |
nbr = qtVisit_tri_edgesi(qtptr,bi,dbi[w][0],dbi[w][1],dbi[w][2], |
1236 |
dbi,wptr,t,0,0,func,arg1,arg2,arg3); |
1237 |
1238 |
1239 |
b[3][0] = (double)bi[0]/(double)MAXBCOORD; |
1240 |
b[3][1] = (double)bi[1]/(double)MAXBCOORD; |
1241 |
b[3][2] = (double)bi[2]/(double)MAXBCOORD; |
1242 |
1243 |
1244 |
1245 |
1246 |
return(nbr); |
1247 |
1248 |
1249 |
1250 |
1251 |
1252 |
1253 |
1254 |
1255 |
1256 |
1257 |
1258 |
1259 |
1260 |
1261 |
1262 |
1263 |
1264 |
