root/radiance/ray/src/hd/sm_qtree.c
Revision: 3.5
Committed: Mon Sep 14 10:33:47 1998 UTC (25 years, 8 months ago) by gwlarson
Changes since 3.4: +3 -0 lines
optimized normalizing calls and bug fix in triangle counting
1 /* Copyright (c) 1998 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * sm_qtree.c: adapted from octree.c from radiance code
9 */
10 /*
11 * octree.c - routines dealing with octrees and cubes.
12 *
13 * 7/28/85
14 */
15
16 #include "standard.h"
17
18 #include "sm_geom.h"
19 #include "sm_qtree.h"
20
21 QUADTREE *quad_block[QT_MAX_BLK]; /* our quadtree */
22 static QUADTREE quad_free_list = EMPTY; /* freed octree nodes */
23 static QUADTREE treetop = 0; /* next free node */
24 int4 *quad_flag= NULL;
25
26 #ifdef TEST_DRIVER
27 extern FVECT Pick_v0[500],Pick_v1[500],Pick_v2[500];
28 extern int Pick_cnt,Pick_tri,Pick_samp;
29 extern FVECT Pick_point[500];
30 #endif
31
32 QUADTREE
33 qtAlloc() /* allocate a quadtree */
34 {
35 register QUADTREE freet;
36
37 if ((freet = quad_free_list) != EMPTY)
38 {
39 quad_free_list = QT_NTH_CHILD(freet, 0);
40 return(freet);
41 }
42 freet = treetop;
43 if (QT_BLOCK_INDEX(freet) == 0)
44 {
45 if (QT_BLOCK(freet) >= QT_MAX_BLK)
46 return(EMPTY);
47 if ((quad_block[QT_BLOCK(freet)] = (QUADTREE *)malloc(
48 QT_BLOCK_SIZE*4*sizeof(QUADTREE))) == NULL)
49 return(EMPTY);
50
51 quad_flag = (int4 *)realloc((char *)quad_flag,
52 (QT_BLOCK(freet)+1)*(QT_BLOCK_SIZE/8));
53 if (quad_flag == NULL)
54 return(EMPTY);
55 }
56 treetop += 4;
57 return(freet);
58 }
59
60
61 qtClearAllFlags() /* clear all quadtree branch flags */
62 {
63 if (!treetop) return;
64 bzero((char *)quad_flag, (QT_BLOCK(treetop-4)+1)*(QT_BLOCK_SIZE/8));
65 }
66
67
68 qtFree(qt) /* free a quadtree */
69 register QUADTREE qt;
70 {
71 register int i;
72
73 if (!QT_IS_TREE(qt))
74 {
75 qtfreeleaf(qt);
76 return;
77 }
78 for (i = 0; i < 4; i++)
79 qtFree(QT_NTH_CHILD(qt, i));
80 QT_NTH_CHILD(qt, 0) = quad_free_list;
81 quad_free_list = qt;
82 }
83
84
85 qtDone() /* free EVERYTHING */
86 {
87 register int i;
88
89 qtfreeleaves();
90 for (i = 0; i < QT_MAX_BLK; i++)
91 {
92 if (quad_block[i] == NULL)
93 break;
94 free((char *)quad_block[i]);
95 quad_block[i] = NULL;
96 }
97 if (i) free((char *)quad_flag);
98 quad_flag = NULL;
99 quad_free_list = EMPTY;
100 treetop = 0;
101 }
102
103 QUADTREE
104 *qtLocate_leaf(qtptr,bcoord,t0,t1,t2)
105 QUADTREE *qtptr;
106 double bcoord[3];
107 FVECT t0,t1,t2;
108 {
109 int i;
110 QUADTREE *child;
111 FVECT a,b,c;
112
113 if(QT_IS_TREE(*qtptr))
114 {
115 i = bary_child(bcoord);
116 #ifdef DEBUG_TEST_DRIVER
117 qtSubdivide_tri(Pick_v0[Pick_cnt-1],Pick_v1[Pick_cnt-1],
118 Pick_v2[Pick_cnt-1],a,b,c);
119 qtNth_child_tri(Pick_v0[Pick_cnt-1],Pick_v1[Pick_cnt-1],
120 Pick_v2[Pick_cnt-1],a,b,c,i,
121 Pick_v0[Pick_cnt],Pick_v1[Pick_cnt],
122 Pick_v2[Pick_cnt]);
123 Pick_cnt++;
124 #endif
125
126 child = QT_NTH_CHILD_PTR(*qtptr,i);
127 if(t0)
128 {
129 qtSubdivide_tri(t0,t1,t2,a,b,c);
130 qtNth_child_tri(t0,t1,t2,a,b,c,i,t0,t1,t2);
131 }
132 return(qtLocate_leaf(child,bcoord,t0,t1,t2));
133 }
134 else
135 return(qtptr);
136 }
137
138
139 QUADTREE
140 *qtRoot_point_locate(qtptr,v0,v1,v2,pt,t0,t1,t2)
141 QUADTREE *qtptr;
142 FVECT v0,v1,v2;
143 FVECT pt;
144 FVECT t0,t1,t2;
145 {
146 int d;
147 int i,x,y;
148 QUADTREE *child;
149 FVECT n,i_pt,a,b,c;
150 double pd,bcoord[3];
151
152 /* Determine if point lies within pyramid (and therefore
153 inside a spherical quadtree cell):GT_INTERIOR, on one of the
154 pyramid sides (and on cell edge):GT_EDGE(1,2 or 3),
155 or on pyramid vertex (and on cell vertex):GT_VERTEX(1,2, or 3).
156 For each triangle edge: compare the
157 point against the plane formed by the edge and the view center
158 */
159 d = point_in_stri(v0,v1,v2,pt);
160
161
162 /* Not in this triangle */
163 if(!d)
164 return(NULL);
165
166 /* Will return lowest level triangle containing point: It the
167 point is on an edge or vertex: will return first associated
168 triangle encountered in the child traversal- the others can
169 be derived using triangle adjacency information
170 */
171 if(QT_IS_TREE(*qtptr))
172 {
173 /* Find the intersection point */
174 tri_plane_equation(v0,v1,v2,n,&pd,FALSE);
175 intersect_vector_plane(pt,n,pd,NULL,i_pt);
176
177 i = max_index(n);
178 x = (i+1)%3;
179 y = (i+2)%3;
180 /* Calculate barycentric coordinates of i_pt */
181 bary2d(v0[x],v0[y],v1[x],v1[y],v2[x],v2[y],i_pt[x],i_pt[y],bcoord);
182
183 i = bary_child(bcoord);
184 child = QT_NTH_CHILD_PTR(*qtptr,i);
185 #ifdef DEBUG_TEST_DRIVER
186 Pick_cnt = 0;
187 VCOPY(Pick_v0[0],v0);
188 VCOPY(Pick_v1[0],v1);
189 VCOPY(Pick_v2[0],v2);
190 Pick_cnt++;
191 qtSubdivide_tri(Pick_v0[Pick_cnt-1],Pick_v1[Pick_cnt-1],
192 Pick_v2[Pick_cnt-1],a,b,c);
193 qtNth_child_tri(Pick_v0[Pick_cnt-1],Pick_v1[Pick_cnt-1],
194 Pick_v2[Pick_cnt-1],a,b,c,i,
195 Pick_v0[Pick_cnt],Pick_v1[Pick_cnt],
196 Pick_v2[Pick_cnt]);
197 Pick_cnt++;
198 #endif
199 if(t0)
200 {
201 qtSubdivide_tri(v0,v1,v2,a,b,c);
202 qtNth_child_tri(v0,v1,v2,a,b,c,i,t0,t1,t2);
203 }
204 return(qtLocate_leaf(child,bcoord,t0,t1,t2));
205 }
206 else
207 {
208 if(t0)
209 {
210 VCOPY(t0,v0);
211 VCOPY(t1,v1);
212 VCOPY(t2,v2);
213 }
214 return(qtptr);
215 }
216 }
217
218
219 QUADTREE
220 qtSubdivide(qtptr)
221 QUADTREE *qtptr;
222 {
223 QUADTREE node;
224 node = qtAlloc();
225 QT_CLEAR_CHILDREN(node);
226 *qtptr = node;
227 return(node);
228 }
229
230
231 QUADTREE
232 qtSubdivide_nth_child(qt,n)
233 QUADTREE qt;
234 int n;
235 {
236 QUADTREE node;
237
238 node = qtSubdivide(&(QT_NTH_CHILD(qt,n)));
239
240 return(node);
241 }
242
243 /* for triangle v0-v1-v2- returns a,b,c: children are:
244
245 v2 0: v0,a,c
246 /\ 1: a,v1,b
247 /2 \ 2: c,b,v2
248 c/____\b 3: b,c,a
249 /\ /\
250 /0 \3 /1 \
251 v0____\/____\v1
252 a
253 */
254
255 qtSubdivide_tri(v0,v1,v2,a,b,c)
256 FVECT v0,v1,v2;
257 FVECT a,b,c;
258 {
259 EDGE_MIDPOINT_VEC3(a,v0,v1);
260 EDGE_MIDPOINT_VEC3(b,v1,v2);
261 EDGE_MIDPOINT_VEC3(c,v2,v0);
262 }
263
264 qtNth_child_tri(v0,v1,v2,a,b,c,i,r0,r1,r2)
265 FVECT v0,v1,v2;
266 FVECT a,b,c;
267 int i;
268 FVECT r0,r1,r2;
269 {
270
271 switch(i){
272 case 0:
273 VCOPY(r0,v0); VCOPY(r1,a); VCOPY(r2,c);
274 break;
275 case 1:
276 VCOPY(r0,a); VCOPY(r1,v1); VCOPY(r2,b);
277 break;
278 case 2:
279 VCOPY(r0,c); VCOPY(r1,b); VCOPY(r2,v2);
280 break;
281 case 3:
282 VCOPY(r0,b); VCOPY(r1,c); VCOPY(r2,a);
283 break;
284 }
285 }
286
287 /* Add triangle "id" to all leaf level cells that are children of
288 quadtree pointed to by "qtptr" with cell vertices "t1,t2,t3"
289 that it overlaps (vertex and edge adjacencies do not count
290 as overlapping). If the addition of the triangle causes the cell to go over
291 threshold- the cell is split- and the triangle must be recursively inserted
292 into the new child cells: it is assumed that "v1,v2,v3" are normalized
293 */
294
295 int
296 qtRoot_add_tri(qtptr,q0,q1,q2,t0,t1,t2,id,n)
297 QUADTREE *qtptr;
298 FVECT q0,q1,q2;
299 FVECT t0,t1,t2;
300 int id;
301 int n;
302 {
303 int test;
304 int found;
305
306 test = stri_intersect(q0,q1,q2,t0,t1,t2);
307 if(!test)
308 return(FALSE);
309
310 found = qtAdd_tri(qtptr,q0,q1,q2,t0,t1,t2,id,n);
311
312 return(found);
313 }
314
315 int
316 qtAdd_tri(qtptr,q0,q1,q2,t0,t1,t2,id,n)
317 QUADTREE *qtptr;
318 FVECT q0,q1,q2;
319 FVECT t0,t1,t2;
320 int id;
321 int n;
322 {
323 int i,index,test,found;
324 FVECT a,b,c;
325 OBJECT os[QT_MAXSET+1],*optr;
326 QUADTREE qt;
327 FVECT r0,r1,r2;
328
329 found = 0;
330 /* if this is tree: recurse */
331 if(QT_IS_TREE(*qtptr))
332 {
333 n++;
334 qtSubdivide_tri(q0,q1,q2,a,b,c);
335 test = stri_intersect(t0,t1,t2,q0,a,c);
336 if(test)
337 found |= qtAdd_tri(QT_NTH_CHILD_PTR(*qtptr,0),q0,a,c,t0,t1,t2,id,n);
338 test = stri_intersect(t0,t1,t2,a,q1,b);
339 if(test)
340 found |= qtAdd_tri(QT_NTH_CHILD_PTR(*qtptr,1),a,q1,b,t0,t1,t2,id,n);
341 test = stri_intersect(t0,t1,t2,c,b,q2);
342 if(test)
343 found |= qtAdd_tri(QT_NTH_CHILD_PTR(*qtptr,2),c,b,q2,t0,t1,t2,id,n);
344 test = stri_intersect(t0,t1,t2,b,c,a);
345 if(test)
346 found |= qtAdd_tri(QT_NTH_CHILD_PTR(*qtptr,3),b,c,a,t0,t1,t2,id,n);
347 }
348 else
349 {
350 /* If this leave node emptry- create a new set */
351 if(QT_IS_EMPTY(*qtptr))
352 *qtptr = qtaddelem(*qtptr,id);
353 else
354 {
355 /* If the set is too large: subdivide */
356 optr = qtqueryset(*qtptr);
357
358 if(QT_SET_CNT(optr) < QT_SET_THRESHOLD)
359 *qtptr = qtaddelem(*qtptr,id);
360 else
361 {
362 if (n < QT_MAX_LEVELS)
363 {
364 /* If set size exceeds threshold: subdivide cell and
365 reinsert set tris into cell
366 */
367 qtgetset(os,*qtptr);
368
369 n++;
370 qtfreeleaf(*qtptr);
371 qtSubdivide(qtptr);
372 found = qtAdd_tri(qtptr,q0,q1,q2,t0,t1,t2,id,n);
373
374 for(optr = QT_SET_PTR(os),i = QT_SET_CNT(os); i > 0; i--)
375 {
376 id = QT_SET_NEXT_ELEM(optr);
377 qtTri_from_id(id,NULL,NULL,NULL,r0,r1,r2,NULL,NULL,NULL);
378 found=qtAdd_tri(qtptr,q0,q1,q2,r0,r1,r2,id,n);
379 #ifdef DEBUG
380 if(!found)
381 eputs("qtAdd_tri():Reinsert-in parent but not children\n");
382 #endif
383 }
384 }
385 else
386 if(QT_SET_CNT(optr) < QT_MAXSET)
387 *qtptr = qtaddelem(*qtptr,id);
388 else
389 {
390 #ifdef DEBUG
391 eputs("qtAdd_tri():two many levels\n");
392 #endif
393 return(FALSE);
394 }
395 }
396 }
397 }
398 return(TRUE);
399 }
400
401
402 int
403 qtApply_to_tri_cells(qtptr,t0,t1,t2,v0,v1,v2,func,arg)
404 QUADTREE *qtptr;
405 FVECT t0,t1,t2;
406 FVECT v0,v1,v2;
407 int (*func)();
408 int *arg;
409 {
410 int test;
411 FVECT a,b,c;
412
413 /* test if triangle (t0,t1,t2) overlaps cell triangle (v0,v1,v2) */
414 test = stri_intersect(t0,t1,t2,v0,v1,v2);
415
416 /* If triangles do not overlap: done */
417 if(!test)
418 return(FALSE);
419
420 /* if this is tree: recurse */
421 func(qtptr,arg);
422
423 if(QT_IS_TREE(*qtptr))
424 {
425 QT_SET_FLAG(*qtptr);
426 qtSubdivide_tri(v0,v1,v2,a,b,c);
427 qtApply_to_tri_cells(QT_NTH_CHILD_PTR(*qtptr,0),t0,t1,t2,v0,a,c,func,arg);
428 qtApply_to_tri_cells(QT_NTH_CHILD_PTR(*qtptr,1),t0,t1,t2,a,v1,b,func,arg);
429 qtApply_to_tri_cells(QT_NTH_CHILD_PTR(*qtptr,2),t0,t1,t2,c,b,v2,func,arg);
430 qtApply_to_tri_cells(QT_NTH_CHILD_PTR(*qtptr,3),t0,t1,t2,b,c,a,func,arg);
431 }
432 }
433
434 int
435 qtRemove_tri(qtptr,id,t0,t1,t2,v0,v1,v2)
436 QUADTREE *qtptr;
437 int id;
438 FVECT t0,t1,t2;
439 FVECT v0,v1,v2;
440 {
441
442 int test;
443 int i;
444 FVECT a,b,c;
445 OBJECT os[QT_MAXSET+1];
446
447 /* test if triangle (t0,t1,t2) overlaps cell triangle (v0,v1,v2) */
448 test = stri_intersect(t0,t1,t2,v0,v1,v2);
449
450 /* If triangles do not overlap: done */
451 if(!test)
452 return(FALSE);
453
454 /* if this is tree: recurse */
455 if(QT_IS_TREE(*qtptr))
456 {
457 qtSubdivide_tri(v0,v1,v2,a,b,c);
458 qtRemove_tri(QT_NTH_CHILD_PTR(*qtptr,0),id,t0,t1,t2,v0,a,c);
459 qtRemove_tri(QT_NTH_CHILD_PTR(*qtptr,1),id,t0,t1,t2,a,v1,b);
460 qtRemove_tri(QT_NTH_CHILD_PTR(*qtptr,2),id,t0,t1,t2,c,b,v2);
461 qtRemove_tri(QT_NTH_CHILD_PTR(*qtptr,3),id,t0,t1,t2,b,c,a);
462 }
463 else
464 {
465 if(QT_IS_EMPTY(*qtptr))
466 {
467 #ifdef DEBUG
468 eputs("qtRemove_tri(): triangle not found\n");
469 #endif
470 }
471 /* remove id from set */
472 else
473 {
474 if(!qtinset(*qtptr,id))
475 {
476 #ifdef DEBUG
477 eputs("qtRemove_tri(): tri not in set\n");
478 #endif
479 }
480 else
481 {
482 *qtptr = qtdelelem(*qtptr,id);
483 }
484 }
485 }
486 return(TRUE);
487 }
488
489
490 int
491 move_to_nbr(b,db0,db1,db2,tptr)
492 double b[3],db0,db1,db2;
493 double *tptr;
494 {
495 double t,dt;
496 int nbr;
497
498 nbr = -1;
499 /* Advance to next node */
500 if(!ZERO(db0) && db0 < 0.0)
501 {
502 t = -b[0]/db0;
503 nbr = 0;
504 }
505 else
506 t = FHUGE;
507 if(!ZERO(db1) && db1 < 0.0 )
508 {
509 dt = -b[1]/db1;
510 if( dt < t)
511 {
512 t = dt;
513 nbr = 1;
514 }
515 }
516 if(!ZERO(db2) && db2 < 0.0 )
517 {
518 dt = -b[2]/db2;
519 if( dt < t)
520 {
521 t = dt;
522 nbr = 2;
523 }
524 }
525 *tptr = t;
526 return(nbr);
527 }
528
529 int
530 qtTrace_edge(qtptr,b,db,orig,dir,max_t,func,arg1,arg2)
531 QUADTREE *qtptr;
532 double b[3],db[3];
533 FVECT orig,dir;
534 double max_t;
535 int (*func)();
536 int *arg1,arg2;
537 {
538
539 int i,found;
540 QUADTREE *child;
541 int nbr,next;
542 double t;
543 #ifdef DEBUG_TEST_DRIVER
544
545 FVECT a1,b1,c1;
546 int Pick_parent = Pick_cnt-1;
547 qtSubdivide_tri(Pick_v0[Pick_parent],Pick_v1[Pick_parent],
548 Pick_v2[Pick_parent],a1,b1,c1);
549
550 #endif
551 if(QT_IS_TREE(*qtptr))
552 {
553 /* Find the appropriate child and reset the coord */
554 i = bary_child(b);
555
556 QT_SET_FLAG(*qtptr);
557
558 for(;;)
559 {
560 child = QT_NTH_CHILD_PTR(*qtptr,i);
561
562 if(i != 3)
563 {
564
565 db[0] *= 2.0;db[1] *= 2.0; db[2] *= 2.0;
566 nbr = qtTrace_edge(child,b,db,orig,dir,max_t,func,arg1,arg2);
567 db[0] *= 0.5;db[1] *= 0.5; db[2] *= 0.5;
568 }
569 else
570 {
571 db[0] *=-2.0;db[1] *= -2.0; db[2] *= -2.0;
572 /* If the center cell- must flip direction signs */
573 nbr = qtTrace_edge(child,b,db,orig,dir,max_t,func,arg1,arg2);
574 db[0] *=-0.5;db[1] *= -0.5; db[2] *= -0.5;
575 }
576 if(nbr == QT_DONE)
577 return(nbr);
578
579 /* If in same block: traverse */
580 if(i==3)
581 next = nbr;
582 else
583 if(nbr == i)
584 next = 3;
585 else
586 {
587 /* reset the barycentric coordinates in the parents*/
588 bary_parent(b,i);
589 /* Else pop up to parent and traverse from there */
590 return(nbr);
591 }
592 bary_from_child(b,i,next);
593 i = next;
594 }
595 }
596 else
597 {
598 #ifdef DEBUG_TEST_DRIVER
599 qtNth_child_tri(Pick_v0[Pick_parent],Pick_v1[Pick_parent],
600 Pick_v2[Pick_parent],a1,b1,c1,i,
601 Pick_v0[Pick_cnt],Pick_v1[Pick_cnt],
602 Pick_v2[Pick_cnt]);
603 Pick_cnt++;
604 #endif
605
606 if(func(qtptr,arg1,arg2) == QT_DONE)
607 return(QT_DONE);
608
609 /* Advance to next node */
610 /* NOTE: Optimize: should only have to check 1/2 */
611 nbr = move_to_nbr(b,db[0],db[1],db[2],&t);
612
613 if(t >= max_t)
614 return(QT_DONE);
615 if(nbr != -1)
616 {
617 b[0] += t * db[0];
618 b[1] += t * db[1];
619 b[2] += t * db[2];
620 db[0] *= (1.0 - t);
621 db[1] *= (1.0 - t);
622 db[2] *= (1.0 - t);
623 }
624 return(nbr);
625 }
626
627 }
628
629
630 int
631 qtTrace_ray(qtptr,b,db0,db1,db2,orig,dir,func,arg1,arg2)
632 QUADTREE *qtptr;
633 double b[3],db0,db1,db2;
634 FVECT orig,dir;
635 int (*func)();
636 int *arg1,arg2;
637 {
638
639 int i,found;
640 QUADTREE *child;
641 int nbr,next;
642 double t;
643 #ifdef DEBUG_TEST_DRIVER
644
645 FVECT a1,b1,c1;
646 int Pick_parent = Pick_cnt-1;
647 qtSubdivide_tri(Pick_v0[Pick_parent],Pick_v1[Pick_parent],
648 Pick_v2[Pick_parent],a1,b1,c1);
649
650 #endif
651 if(QT_IS_TREE(*qtptr))
652 {
653 /* Find the appropriate child and reset the coord */
654 i = bary_child(b);
655
656 QT_SET_FLAG(*qtptr);
657
658 for(;;)
659 {
660 child = QT_NTH_CHILD_PTR(*qtptr,i);
661
662 if(i != 3)
663 nbr = qtTrace_ray(child,b,db0,db1,db2,orig,dir,func,arg1,arg2);
664 else
665 /* If the center cell- must flip direction signs */
666 nbr =qtTrace_ray(child,b,-db0,-db1,-db2,orig,dir,func,arg1,arg2);
667 if(nbr == QT_DONE)
668 return(nbr);
669
670 /* If in same block: traverse */
671 if(i==3)
672 next = nbr;
673 else
674 if(nbr == i)
675 next = 3;
676 else
677 {
678 /* reset the barycentric coordinates in the parents*/
679 bary_parent(b,i);
680 /* Else pop up to parent and traverse from there */
681 return(nbr);
682 }
683 bary_from_child(b,i,next);
684 i = next;
685 }
686 }
687 else
688 {
689 #ifdef DEBUG_TEST_DRIVER
690 qtNth_child_tri(Pick_v0[Pick_parent],Pick_v1[Pick_parent],
691 Pick_v2[Pick_parent],a1,b1,c1,i,
692 Pick_v0[Pick_cnt],Pick_v1[Pick_cnt],
693 Pick_v2[Pick_cnt]);
694 Pick_cnt++;
695 #endif
696
697 if(func(qtptr,orig,dir,arg1,arg2) == QT_DONE)
698 return(QT_DONE);
699
700 /* Advance to next node */
701 /* NOTE: Optimize: should only have to check 1/2 */
702 nbr = move_to_nbr(b,db0,db1,db2,&t);
703
704 if(nbr != -1)
705 {
706 b[0] += t * db0;
707 b[1] += t * db1;
708 b[2] += t * db2;
709 }
710 return(nbr);
711 }
712
713 }
714
715 int
716 qtRoot_trace_ray(qtptr,q0,q1,q2,orig,dir,func,arg1,arg2)
717 QUADTREE *qtptr;
718 FVECT q0,q1,q2;
719 FVECT orig,dir;
720 int (*func)();
721 int *arg1,arg2;
722 {
723 int i,x,y,nbr;
724 QUADTREE *child;
725 FVECT n,c,i_pt,d;
726 double pd,b[3],db[3],t;
727 /* Determine if point lies within pyramid (and therefore
728 inside a spherical quadtree cell):GT_INTERIOR, on one of the
729 pyramid sides (and on cell edge):GT_EDGE(1,2 or 3),
730 or on pyramid vertex (and on cell vertex):GT_VERTEX(1,2, or 3).
731 For each triangle edge: compare the
732 point against the plane formed by the edge and the view center
733 */
734 i = point_in_stri(q0,q1,q2,orig);
735
736 /* Not in this triangle */
737 if(!i)
738 return(INVALID);
739 /* Project the origin onto the root node plane */
740
741 /* Find the intersection point of the origin */
742 tri_plane_equation(q0,q1,q2,n,&pd,FALSE);
743 intersect_vector_plane(orig,n,pd,NULL,i_pt);
744 /* project the dir as well */
745 VADD(c,orig,dir);
746 intersect_vector_plane(c,n,pd,&t,c);
747
748 /* map to 2d by dropping maximum magnitude component of normal */
749 i = max_index(n);
750 x = (i+1)%3;
751 y = (i+2)%3;
752 /* Calculate barycentric coordinates of orig */
753 bary2d(q0[x],q0[y],q1[x],q1[y],q2[x],q2[y],i_pt[x],i_pt[y],b);
754 /* Calculate barycentric coordinates of dir */
755 bary2d(q0[x],q0[y],q1[x],q1[y],q2[x],q2[y],c[x],c[y],db);
756 if(t < 0.0)
757 VSUB(db,b,db);
758 else
759 VSUB(db,db,b);
760
761
762 #ifdef DEBUG_TEST_DRIVER
763 VCOPY(Pick_v0[Pick_cnt],q0);
764 VCOPY(Pick_v1[Pick_cnt],q1);
765 VCOPY(Pick_v2[Pick_cnt],q2);
766 Pick_cnt++;
767 #endif
768
769 /* trace the ray starting with this node */
770 nbr = qtTrace_ray(qtptr,b,db[0],db[1],db[2],orig,dir,func,arg1,arg2);
771 return(nbr);
772
773 }
774
775
776 int
777 qtRoot_trace_edge(qtptr,q0,q1,q2,orig,dir,max_t,func,arg1,arg2)
778 QUADTREE *qtptr;
779 FVECT q0,q1,q2;
780 FVECT orig,dir;
781 double max_t;
782 int (*func)();
783 int *arg1,arg2;
784 {
785 int i,x,y,nbr;
786 QUADTREE *child;
787 FVECT n,c,i_pt,d;
788 double pd,b[3],db[3],t;
789 /* Determine if point lies within pyramid (and therefore
790 inside a spherical quadtree cell):GT_INTERIOR, on one of the
791 pyramid sides (and on cell edge):GT_EDGE(1,2 or 3),
792 or on pyramid vertex (and on cell vertex):GT_VERTEX(1,2, or 3).
793 For each triangle edge: compare the
794 point against the plane formed by the edge and the view center
795 */
796 i = point_in_stri(q0,q1,q2,orig);
797
798 /* Not in this triangle */
799 if(!i)
800 return(-1);
801 /* Project the origin onto the root node plane */
802
803 /* Find the intersection point of the origin */
804 tri_plane_equation(q0,q1,q2,n,&pd,FALSE);
805 intersect_vector_plane(orig,n,pd,NULL,i_pt);
806 /* project the dir as well */
807 VADD(c,orig,dir);
808 intersect_vector_plane(c,n,pd,&t,c);
809
810 /* map to 2d by dropping maximum magnitude component of normal */
811 i = max_index(n);
812 x = (i+1)%3;
813 y = (i+2)%3;
814 /* Calculate barycentric coordinates of orig */
815 bary2d(q0[x],q0[y],q1[x],q1[y],q2[x],q2[y],i_pt[x],i_pt[y],b);
816 /* Calculate barycentric coordinates of dir */
817 bary2d(q0[x],q0[y],q1[x],q1[y],q2[x],q2[y],c[x],c[y],db);
818 if(t < 0.0)
819 VSUB(db,b,db);
820 else
821 VSUB(db,db,b);
822
823
824 #ifdef DEBUG_TEST_DRIVER
825 VCOPY(Pick_v0[Pick_cnt],q0);
826 VCOPY(Pick_v1[Pick_cnt],q1);
827 VCOPY(Pick_v2[Pick_cnt],q2);
828 Pick_cnt++;
829 #endif
830 /* trace the ray starting with this node */
831 nbr = qtTrace_edge(qtptr,b,db,orig,d,max_t,func,arg1,arg2);
832 return(nbr);
833
834 }
835
836
837 qtVisit_tri_interior(qtptr,q0,q1,q2,t0,t1,t2,n,func,arg1,arg2)
838 QUADTREE *qtptr;
839 FVECT q0,q1,q2;
840 FVECT t0,t1,t2;
841 int n;
842 int (*func)();
843 int *arg1,arg2;
844 {
845 int i,found,test;
846 QUADTREE *child;
847 FVECT c0,c1,c2,a,b,c;
848 OBJECT os[QT_MAXSET+1],*optr;
849 int w;
850
851 /* If qt Flag set, or qt vertices interior to t0t1t2-descend */
852 tree_modified:
853
854 if(QT_IS_TREE(*qtptr))
855 {
856 if(QT_IS_FLAG(*qtptr) || point_in_stri(t0,t1,t2,q0))
857 {
858 QT_SET_FLAG(*qtptr);
859 qtSubdivide_tri(q0,q1,q2,a,b,c);
860 /* descend to children */
861 for(i=0;i < 4; i++)
862 {
863 child = QT_NTH_CHILD_PTR(*qtptr,i);
864 qtNth_child_tri(q0,q1,q2,a,b,c,i,c0,c1,c2);
865 qtVisit_tri_interior(child,c0,c1,c2,t0,t1,t2,n+1,
866 func,arg1,arg2);
867 }
868 }
869 }
870 else
871 {
872 /* NOTE THIS IN TRI TEST Could be replaced by a flag */
873 if(!QT_IS_EMPTY(*qtptr))
874 {
875 if(qtinset(*qtptr,arg2))
876 if(func(qtptr,q0,q1,q2,t0,t1,t2,n,arg1,arg2)==QT_MODIFIED)
877 goto tree_modified;
878 else
879 return;
880 }
881 if(point_in_stri(t0,t1,t2,q0) )
882 if(func(qtptr,q0,q1,q2,t0,t1,t2,n,arg1,arg2)==QT_MODIFIED)
883 goto tree_modified;
884 }
885 }
886
887
888
889
890
891
892 int
893 qtVisit_tri_edges(qtptr,b,db,wptr,sfactor,func,arg1,arg2)
894 QUADTREE *qtptr;
895 double b[3],db[3][3];
896 int *wptr;
897 double sfactor;
898 int (*func)();
899 int *arg1,arg2;
900 {
901 int i,found;
902 QUADTREE *child;
903 int nbr,next,w;
904 double t;
905 #ifdef DEBUG_TEST_DRIVER
906 FVECT a1,b1,c1;
907 int Pick_parent = Pick_cnt-1;
908 qtSubdivide_tri(Pick_v0[Pick_parent],Pick_v1[Pick_parent],
909 Pick_v2[Pick_parent],a1,b1,c1);
910 #endif
911
912 if(QT_IS_TREE(*qtptr))
913 {
914 /* Find the appropriate child and reset the coord */
915 i = bary_child(b);
916
917 QT_SET_FLAG(*qtptr);
918
919 for(;;)
920 {
921 w = *wptr;
922 child = QT_NTH_CHILD_PTR(*qtptr,i);
923
924 if(i != 3)
925 {
926
927 db[w][0] *= 2.0;db[w][1] *= 2.0; db[w][2] *= 2.0;
928 nbr = qtVisit_tri_edges(child,b,db,wptr,sfactor*2.0,
929 func,arg1,arg2);
930 w = *wptr;
931 db[w][0] *= 0.5;db[w][1] *= 0.5; db[w][2] *= 0.5;
932 }
933 else
934 {
935 db[w][0] *=-2.0;db[w][1] *= -2.0; db[w][2] *= -2.0;
936 /* If the center cell- must flip direction signs */
937 nbr = qtVisit_tri_edges(child,b,db,wptr,sfactor*(-2.0),
938 func,arg1,arg2);
939 w = *wptr;
940 db[w][0] *=-0.5;db[w][1] *= -0.5; db[w][2] *= -0.5;
941 }
942 if(nbr == QT_DONE)
943 return(nbr);
944
945 /* If in same block: traverse */
946 if(i==3)
947 next = nbr;
948 else
949 if(nbr == i)
950 next = 3;
951 else
952 {
953 /* reset the barycentric coordinates in the parents*/
954 bary_parent(b,i);
955 /* Else pop up to parent and traverse from there */
956 return(nbr);
957 }
958 bary_from_child(b,i,next);
959 i = next;
960 }
961 }
962 else
963 {
964 #ifdef DEBUG_TEST_DRIVER
965 qtNth_child_tri(Pick_v0[Pick_parent],Pick_v1[Pick_parent],
966 Pick_v2[Pick_parent],a1,b1,c1,i,Pick_v0[Pick_cnt],
967 Pick_v1[Pick_cnt],Pick_v2[Pick_cnt]);
968 Pick_cnt++;
969 #endif
970
971 if(func(qtptr,arg1,arg2) == QT_DONE)
972 return(QT_DONE);
973
974 /* Advance to next node */
975 /* NOTE: Optimize: should only have to check 1/2 */
976 w = *wptr;
977 while(1)
978 {
979 nbr = move_to_nbr(b,db[w][0],db[w][1],db[w][2],&t);
980
981 if(t >= 1.0)
982 {
983 if(w == 2)
984 return(QT_DONE);
985 b[0] += db[w][0];
986 b[1] += db[w][1];
987 b[2] += db[w][2];
988 w++;
989 db[w][0] *= sfactor;
990 db[w][1] *= sfactor;
991 db[w][2] *= sfactor;
992 }
993 else
994 if(nbr != INVALID)
995 {
996 b[0] += t * db[w][0];
997 b[1] += t * db[w][1];
998 b[2] += t * db[w][2];
999 db[w][0] *= (1.0 - t);
1000 db[w][1] *= (1.0 - t);
1001 db[w][2] *= (1.0 - t);
1002 *wptr = w;
1003 return(nbr);
1004 }
1005 else
1006 return(INVALID);
1007 }
1008 }
1009
1010 }
1011
1012
1013 int
1014 qtRoot_visit_tri_edges(qtptr,q0,q1,q2,tri,dir,wptr,func,arg1,arg2)
1015 QUADTREE *qtptr;
1016 FVECT q0,q1,q2;
1017 FVECT tri[3],dir[3];
1018 int *wptr;
1019 int (*func)();
1020 int *arg1,arg2;
1021 {
1022 int i,x,y,nbr,w;
1023 QUADTREE *child;
1024 FVECT n,c,i_pt,d;
1025 double pd,b[3][3],db[3][3],t;
1026
1027 w = *wptr;
1028
1029 /* Project the origin onto the root node plane */
1030
1031 /* Find the intersection point of the origin */
1032 tri_plane_equation(q0,q1,q2,n,&pd,FALSE);
1033 /* map to 2d by dropping maximum magnitude component of normal */
1034 i = max_index(n);
1035 x = (i+1)%3;
1036 y = (i+2)%3;
1037 /* Calculate barycentric coordinates for current vertex */
1038
1039 for(i=0;i < 3; i++)
1040 {
1041 /* If processing 3rd edge-dont need info for t1 */
1042 if(i==1 && w==2)
1043 continue;
1044 /* project the dir as well */
1045 intersect_vector_plane(tri[i],n,pd,NULL,i_pt);
1046 bary2d(q0[x],q0[y],q1[x],q1[y],q2[x],q2[y],i_pt[x],i_pt[y],b[i]);
1047 VADD(c,tri[i],dir[i]);
1048 intersect_vector_plane(c,n,pd,&t,c);
1049 /* Calculate barycentric coordinates of dir */
1050 bary2d(q0[x],q0[y],q1[x],q1[y],q2[x],q2[y],c[x],c[y],db[i]);
1051 if(t < 0.0)
1052 VSUB(db[i],b[i],db[i]);
1053 else
1054 VSUB(db[i],db[i],b[i]);
1055 }
1056 #ifdef DEBUG_TEST_DRIVER
1057 VCOPY(Pick_v0[Pick_cnt],q0);
1058 VCOPY(Pick_v1[Pick_cnt],q1);
1059 VCOPY(Pick_v2[Pick_cnt],q2);
1060 Pick_cnt++;
1061 #endif
1062 /* trace the ray starting with this node */
1063 nbr = qtVisit_tri_edges(qtptr,b[w],db,wptr,1.0,func,arg1,arg2);
1064 return(nbr);
1065
1066 }
1067
1068
1069
1070
1071 /* NOTE: SINCE DIR could be unit: then we could use integer math */
1072 int
1073 qtVisit_tri_edges2(qtptr,b,db0,db1,db2,
1074 db,wptr,t,sign,sfactor,func,arg1,arg2)
1075 QUADTREE *qtptr;
1076 double b[3],db0,db1,db2,db[3][3];
1077 int *wptr;
1078 double t[3];
1079 int sign;
1080 double sfactor;
1081 int (*func)();
1082 int *arg1,arg2;
1083 {
1084 int i,found;
1085 QUADTREE *child;
1086 int nbr,next,w;
1087 double t_l,t_g;
1088 #ifdef DEBUG_TEST_DRIVER
1089 FVECT a1,b1,c1;
1090 int Pick_parent = Pick_cnt-1;
1091 qtSubdivide_tri(Pick_v0[Pick_parent],Pick_v1[Pick_parent],
1092 Pick_v2[Pick_parent],a1,b1,c1);
1093 #endif
1094 if(QT_IS_TREE(*qtptr))
1095 {
1096 /* Find the appropriate child and reset the coord */
1097 i = bary_child(b);
1098
1099 QT_SET_FLAG(*qtptr);
1100
1101 for(;;)
1102 {
1103 w = *wptr;
1104 child = QT_NTH_CHILD_PTR(*qtptr,i);
1105
1106 if(i != 3)
1107 nbr = qtVisit_tri_edges2(child,b,db0,db1,db2,
1108 db,wptr,t,sign,
1109 sfactor*2.0,func,arg1,arg2);
1110 else
1111 /* If the center cell- must flip direction signs */
1112 nbr = qtVisit_tri_edges2(child,b,-db0,-db1,-db2,
1113 db,wptr,t,1-sign,
1114 sfactor*2.0,func,arg1,arg2);
1115
1116 if(nbr == QT_DONE)
1117 return(nbr);
1118 if(*wptr != w)
1119 {
1120 w = *wptr;
1121 db0 = db[w][0];db1 = db[w][1];db2 = db[w][2];
1122 if(sign)
1123 { db0 *= -1.0;db1 *= -1.0; db2 *= -1.0;}
1124 }
1125 /* If in same block: traverse */
1126 if(i==3)
1127 next = nbr;
1128 else
1129 if(nbr == i)
1130 next = 3;
1131 else
1132 {
1133 /* reset the barycentric coordinates in the parents*/
1134 bary_parent(b,i);
1135 /* Else pop up to parent and traverse from there */
1136 return(nbr);
1137 }
1138 bary_from_child(b,i,next);
1139 i = next;
1140 }
1141 }
1142 else
1143 {
1144 #ifdef DEBUG_TEST_DRIVER
1145 qtNth_child_tri(Pick_v0[Pick_parent],Pick_v1[Pick_parent],
1146 Pick_v2[Pick_parent],a1,b1,c1,i,Pick_v0[Pick_cnt],
1147 Pick_v1[Pick_cnt],Pick_v2[Pick_cnt]);
1148 Pick_cnt++;
1149 #endif
1150
1151 if(func(qtptr,arg1,arg2) == QT_DONE)
1152 return(QT_DONE);
1153
1154 /* Advance to next node */
1155 w = *wptr;
1156 while(1)
1157 {
1158 nbr = move_to_nbr(b,db0,db1,db2,&t_l);
1159
1160 t_g = t_l/sfactor;
1161 #ifdef DEBUG
1162 if(t[w] <= 0.0)
1163 eputs("qtVisit_tri_edges2():negative t\n");
1164 #endif
1165 if(t_g >= t[w])
1166 {
1167 if(w == 2)
1168 return(QT_DONE);
1169
1170 b[0] += (t[w])*sfactor*db0;
1171 b[1] += (t[w])*sfactor*db1;
1172 b[2] += (t[w])*sfactor*db2;
1173 w++;
1174 db0 = db[w][0];
1175 db1 = db[w][1];
1176 db2 = db[w][2];
1177 if(sign)
1178 { db0 *= -1.0;db1 *= -1.0; db2 *= -1.0;}
1179 }
1180 else
1181 if(nbr != INVALID)
1182 {
1183 b[0] += t_l * db0;
1184 b[1] += t_l * db1;
1185 b[2] += t_l * db2;
1186
1187 t[w] -= t_g;
1188 *wptr = w;
1189 return(nbr);
1190 }
1191 else
1192 return(INVALID);
1193 }
1194 }
1195
1196 }
1197
1198
1199 int
1200 qtRoot_visit_tri_edges2(qtptr,q0,q1,q2,tri,i_pt,wptr,func,arg1,arg2)
1201 QUADTREE *qtptr;
1202 FVECT q0,q1,q2;
1203 FVECT tri[3],i_pt;
1204 int *wptr;
1205 int (*func)();
1206 int *arg1,arg2;
1207 {
1208 int x,y,z,nbr,w,i,j;
1209 QUADTREE *child;
1210 FVECT n,c,d,v[3];
1211 double pd,b[4][3],db[3][3],et[3],t[3],exit_pt;
1212
1213 w = *wptr;
1214
1215 /* Project the origin onto the root node plane */
1216
1217 /* Find the intersection point of the origin */
1218 tri_plane_equation(q0,q1,q2,n,&pd,FALSE);
1219 /* map to 2d by dropping maximum magnitude component of normal */
1220 z = max_index(n);
1221 x = (z+1)%3;
1222 y = (z+2)%3;
1223 /* Calculate barycentric coordinates for current vertex */
1224 if(w != -1)
1225 {
1226 bary2d(q0[x],q0[y],q1[x],q1[y],q2[x],q2[y],i_pt[x],i_pt[y],b[3]);
1227 intersect_vector_plane(tri[w],n,pd,&(et[w]),v[w]);
1228 bary2d(q0[x],q0[y],q1[x],q1[y],q2[x],q2[y],v[w][x],v[w][y],b[w]);
1229 }
1230 else
1231 /* Just starting: b[0] is the origin point: guaranteed to be valid b*/
1232 {
1233 w = 0;
1234 intersect_vector_plane(tri[0],n,pd,&(et[0]),v[0]);
1235 bary2d(q0[x],q0[y],q1[x],q1[y],q2[x],q2[y],v[0][x],v[0][y],b[0]);
1236 VCOPY(b[3],b[0]);
1237 }
1238
1239
1240 j = (w+1)%3;
1241 intersect_vector_plane(tri[j],n,pd,&(et[j]),v[j]);
1242 bary2d(q0[x],q0[y],q1[x],q1[y],q2[x],q2[y],v[j][x],v[j][y],b[j]);
1243 if(et[j] < 0.0)
1244 {
1245 VSUB(db[w],b[3],b[j]);
1246 t[w] = FHUGE;
1247 }
1248 else
1249 {
1250 /* NOTE: for stability: do not increment with ipt- use full dir and
1251 calculate t: but for wrap around case: could get same problem?
1252 */
1253 VSUB(db[w],b[j],b[3]);
1254 t[w] = 1.0;
1255 move_to_nbr(b[3],db[w][0],db[w][1],db[w][2],&exit_pt);
1256 if(exit_pt >= 1.0)
1257 {
1258 for(;j < 3;j++)
1259 {
1260 i = (j+1)%3;
1261 if(i!= w)
1262 {
1263 intersect_vector_plane(tri[i],n,pd,&(et[i]),v[i]);
1264 bary2d(q0[x],q0[y],q1[x],q1[y],q2[x],q2[y],v[i][x],
1265 v[i][y],b[i]);
1266 }
1267 if(et[i] < 0.0)
1268 {
1269 VSUB(db[j],b[j],b[i]);
1270 t[j] = FHUGE;
1271 break;
1272 }
1273 else
1274 {
1275 VSUB(db[j],b[i],b[j]);
1276 t[j] = 1.0;
1277 }
1278 move_to_nbr(b[j],db[j][0],db[j][1],db[j][2],&exit_pt);
1279 if(exit_pt < 1.0)
1280 break;
1281 }
1282 }
1283 }
1284 *wptr = w;
1285 /* trace the ray starting with this node */
1286 nbr = qtVisit_tri_edges2(qtptr,b[3],db[w][0],db[w][1],db[w][2],
1287 db,wptr,t,0,1.0,func,arg1,arg2);
1288 if(nbr != INVALID && nbr != QT_DONE)
1289 {
1290 i_pt[x] = b[3][0]*q0[x] + b[3][1]*q1[x] + b[3][2]*q2[x];
1291 i_pt[y] = b[3][0]*q0[y] + b[3][1]*q1[y] + b[3][2]*q2[y];
1292 i_pt[z] = (-n[x]*i_pt[x] - n[y]*i_pt[y] -pd)/n[z];
1293 }
1294 return(nbr);
1295
1296 }
1297
1298
1299
1300
1301
1302
1303
1304
1305
1306
1307
1308
1309
1310
1311
1312
1313
1314
