1 |
/* Copyright (c) 1998 Silicon Graphics, Inc. */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ SGI"; |
5 |
#endif |
6 |
7 |
8 |
* sm_qtree.c: adapted from octree.c from radiance code |
9 |
10 |
11 |
* octree.c - routines dealing with octrees and cubes. |
12 |
13 |
* 7/28/85 |
14 |
15 |
16 |
#include "standard.h" |
17 |
18 |
#include "sm_geom.h" |
19 |
#include "sm_qtree.h" |
20 |
#include "object.h" |
21 |
22 |
QUADTREE *quad_block[QT_MAX_BLK]; /* our quadtree */ |
23 |
static QUADTREE quad_free_list = EMPTY; /* freed octree nodes */ |
24 |
static QUADTREE treetop = 0; /* next free node */ |
25 |
26 |
27 |
28 |
QUADTREE |
29 |
qtAlloc() /* allocate a quadtree */ |
30 |
31 |
register QUADTREE freet; |
32 |
33 |
if ((freet = quad_free_list) != EMPTY) |
34 |
35 |
quad_free_list = QT_NTH_CHILD(freet, 0); |
36 |
return(freet); |
37 |
38 |
freet = treetop; |
39 |
if (QT_BLOCK_INDEX(freet) == 0) |
40 |
41 |
if (QT_BLOCK(freet) >= QT_MAX_BLK) |
42 |
return(EMPTY); |
43 |
if ((quad_block[QT_BLOCK(freet)] = (QUADTREE *)malloc( |
44 |
(unsigned)QT_BLOCK_SIZE*4*sizeof(QUADTREE))) == NULL) |
45 |
return(EMPTY); |
46 |
47 |
treetop += 4; |
48 |
return(freet); |
49 |
50 |
51 |
52 |
qtFree(qt) /* free a quadtree */ |
53 |
register QUADTREE qt; |
54 |
55 |
register int i; |
56 |
57 |
if (!QT_IS_TREE(qt)) |
58 |
59 |
qtfreeleaf(qt); |
60 |
return; |
61 |
62 |
for (i = 0; i < 4; i++) |
63 |
qtFree(QT_NTH_CHILD(qt, i)); |
64 |
QT_NTH_CHILD(qt, 0) = quad_free_list; |
65 |
quad_free_list = qt; |
66 |
67 |
68 |
69 |
qtDone() /* free EVERYTHING */ |
70 |
71 |
register int i; |
72 |
73 |
for (i = 0; i < QT_MAX_BLK; i++) |
74 |
75 |
free((char *)quad_block[i], |
76 |
(unsigned)QT_BLOCK_SIZE*4*sizeof(QUADTREE)); |
77 |
quad_block[i] = NULL; |
78 |
79 |
quad_free_list = EMPTY; |
80 |
treetop = 0; |
81 |
82 |
83 |
QUADTREE |
84 |
qtCompress(qt) /* recursively combine nodes */ |
85 |
86 |
87 |
register int i; |
88 |
register QUADTREE qres; |
89 |
90 |
if (!QT_IS_TREE(qt)) /* not a tree */ |
91 |
return(qt); |
92 |
qres = QT_NTH_CHILD(qt,0) = qtCompress(QT_NTH_CHILD(qt,0)); |
93 |
for (i = 1; i < 4; i++) |
94 |
if((QT_NTH_CHILD(qt,i) = qtCompress(QT_NTH_CHILD(qt,i))) != qres) |
95 |
qres = qt; |
96 |
if(!QT_IS_TREE(qres)) |
97 |
{ /* all were identical leaves */ |
98 |
QT_NTH_CHILD(qt,0) = quad_free_list; |
99 |
100 |
101 |
return(qres); |
102 |
103 |
104 |
QUADTREE |
105 |
qtLocate_leaf(qtptr,bcoord,type,which) |
106 |
QUADTREE *qtptr; |
107 |
double bcoord[3]; |
108 |
char *type,*which; |
109 |
110 |
int i; |
111 |
QUADTREE *child; |
112 |
113 |
if(QT_IS_TREE(*qtptr)) |
114 |
115 |
i = bary2d_child(bcoord); |
116 |
child = QT_NTH_CHILD_PTR(*qtptr,i); |
117 |
return(qtLocate_leaf(child,bcoord,type,which)); |
118 |
119 |
else |
120 |
return(*qtptr); |
121 |
122 |
123 |
124 |
125 |
126 |
QUADTREE |
127 |
qtRoot_point_locate(qtptr,v0,v1,v2,pt,type,which) |
128 |
QUADTREE *qtptr; |
129 |
FVECT v0,v1,v2; |
130 |
FVECT pt; |
131 |
132 |
133 |
char d,w; |
134 |
int i,x,y; |
135 |
QUADTREE *child; |
136 |
QUADTREE qt; |
137 |
FVECT n,i_pt; |
138 |
double pd,bcoord[3]; |
139 |
140 |
/* Determine if point lies within pyramid (and therefore |
141 |
inside a spherical quadtree cell):GT_INTERIOR, on one of the |
142 |
pyramid sides (and on cell edge):GT_EDGE(1,2 or 3), |
143 |
or on pyramid vertex (and on cell vertex):GT_VERTEX(1,2, or 3). |
144 |
For each triangle edge: compare the |
145 |
point against the plane formed by the edge and the view center |
146 |
147 |
d = test_single_point_against_spherical_tri(v0,v1,v2,pt,&w); |
148 |
149 |
/* Not in this triangle */ |
150 |
if(!d) |
151 |
152 |
if(which) |
153 |
*which = 0; |
154 |
return(EMPTY); |
155 |
156 |
157 |
/* Will return lowest level triangle containing point: It the |
158 |
point is on an edge or vertex: will return first associated |
159 |
triangle encountered in the child traversal- the others can |
160 |
be derived using triangle adjacency information |
161 |
162 |
163 |
164 |
/* Find the intersection point */ |
165 |
tri_plane_equation(v0,v1,v2,n,&pd,FALSE); |
166 |
intersect_vector_plane(pt,n,pd,NULL,i_pt); |
167 |
168 |
i = max_index(n); |
169 |
x = (i+1)%3; |
170 |
y = (i+2)%3; |
171 |
/* Calculate barycentric coordinates of i_pt */ |
172 |
bary2d(v0[x],v0[y],v1[x],v1[y],v2[x],v2[y],i_pt[x],i_pt[y],bcoord); |
173 |
174 |
175 |
176 |
177 |
178 |
else |
179 |
if(!QT_IS_EMPTY(*qtptr)) |
180 |
181 |
/* map GT_VERTEX,GT_EDGE,GT_FACE GT_INTERIOR of pyramid to |
182 |
spherical triangle primitives |
183 |
184 |
if(type) |
185 |
*type = d; |
186 |
if(which) |
187 |
*which = w; |
188 |
return(*qtptr); |
189 |
190 |
return(EMPTY); |
191 |
192 |
193 |
int |
194 |
qtPoint_in_tri(qtptr,v0,v1,v2,pt,type,which) |
195 |
QUADTREE *qtptr; |
196 |
FVECT v0,v1,v2; |
197 |
FVECT pt; |
198 |
199 |
200 |
QUADTREE qt; |
201 |
OBJECT os[MAXSET+1],*optr; |
202 |
char d,w; |
203 |
int i,id; |
204 |
FVECT p0,p1,p2; |
205 |
206 |
qt = qtRoot_point_locate(qtptr,v0,v1,v2,pt,type,which); |
207 |
208 |
if(QT_IS_EMPTY(qt)) |
209 |
return(EMPTY); |
210 |
211 |
/* Get the set */ |
212 |
qtgetset(os,qt); |
213 |
for (i = QT_SET_CNT(os),optr = QT_SET_PTR(os); i > 0; i--) |
214 |
215 |
/* Find the triangle that pt falls in (NOTE:FOR now return first 1) */ |
216 |
id = QT_SET_NEXT_ELEM(optr); |
217 |
qtTri_verts_from_id(id,p0,p1,p2); |
218 |
d = test_single_point_against_spherical_tri(p0,p1,p2,pt,&w); |
219 |
if(d) |
220 |
221 |
if(type) |
222 |
*type = d; |
223 |
if(which) |
224 |
*which = w; |
225 |
return(id); |
226 |
227 |
228 |
return(EMPTY); |
229 |
230 |
231 |
QUADTREE |
232 |
qtSubdivide(qtptr) |
233 |
QUADTREE *qtptr; |
234 |
235 |
QUADTREE node; |
236 |
node = qtAlloc(); |
237 |
QT_CLEAR_CHILDREN(node); |
238 |
*qtptr = node; |
239 |
return(node); |
240 |
241 |
242 |
243 |
QUADTREE |
244 |
qtSubdivide_nth_child(qt,n) |
245 |
QUADTREE qt; |
246 |
int n; |
247 |
248 |
QUADTREE node; |
249 |
250 |
node = qtSubdivide(&(QT_NTH_CHILD(qt,n))); |
251 |
252 |
return(node); |
253 |
254 |
255 |
/* for triangle v0-v1-v2- returns a,b,c: children are: |
256 |
257 |
v2 0: v0,a,c |
258 |
/\ 1: a,v1,b |
259 |
/2 \ 2: c,b,v2 |
260 |
c/____\b 3: b,c,a |
261 |
262 |
/0 \3 /1 \ |
263 |
v0____\/____\v1 |
264 |
a |
265 |
266 |
267 |
qtSubdivide_tri(v0,v1,v2,a,b,c) |
268 |
FVECT v0,v1,v2; |
269 |
FVECT a,b,c; |
270 |
271 |
EDGE_MIDPOINT_VEC3(a,v0,v1); |
272 |
EDGE_MIDPOINT_VEC3(b,v1,v2); |
273 |
EDGE_MIDPOINT_VEC3(c,v2,v0); |
274 |
275 |
276 |
qtNth_child_tri(v0,v1,v2,a,b,c,i,r0,r1,r2) |
277 |
FVECT v0,v1,v2; |
278 |
FVECT a,b,c; |
279 |
int i; |
280 |
FVECT r0,r1,r2; |
281 |
282 |
switch(i){ |
283 |
case 0: |
284 |
VCOPY(r0,v0); VCOPY(r1,a); VCOPY(r2,c); |
285 |
break; |
286 |
case 1: |
287 |
VCOPY(r0,a); VCOPY(r1,v1); VCOPY(r2,b); |
288 |
break; |
289 |
case 2: |
290 |
VCOPY(r0,c); VCOPY(r1,b); VCOPY(r2,v2); |
291 |
break; |
292 |
case 3: |
293 |
VCOPY(r0,b); VCOPY(r1,c); VCOPY(r2,a); |
294 |
break; |
295 |
296 |
297 |
298 |
/* Add triangle "id" to all leaf level cells that are children of |
299 |
quadtree pointed to by "qtptr" with cell vertices "t1,t2,t3" |
300 |
that it overlaps (vertex and edge adjacencies do not count |
301 |
as overlapping). If the addition of the triangle causes the cell to go over |
302 |
threshold- the cell is split- and the triangle must be recursively inserted |
303 |
into the new child cells: it is assumed that "v1,v2,v3" are normalized |
304 |
305 |
306 |
int |
307 |
qtAdd_tri(qtptr,id,t0,t1,t2,v0,v1,v2,n) |
308 |
QUADTREE *qtptr; |
309 |
int id; |
310 |
FVECT t0,t1,t2; |
311 |
FVECT v0,v1,v2; |
312 |
int n; |
313 |
314 |
315 |
char test; |
316 |
int i,index; |
317 |
FVECT a,b,c; |
318 |
319 |
QUADTREE qt; |
320 |
int found; |
321 |
FVECT r0,r1,r2; |
322 |
323 |
/* test if triangle (t0,t1,t2) overlaps cell triangle (v0,v1,v2) */ |
324 |
test = spherical_tri_intersect(t0,t1,t2,v0,v1,v2); |
325 |
326 |
/* If triangles do not overlap: done */ |
327 |
if(!test) |
328 |
return(FALSE); |
329 |
found = 0; |
330 |
331 |
/* if this is tree: recurse */ |
332 |
333 |
334 |
n++; |
335 |
qtSubdivide_tri(v0,v1,v2,a,b,c); |
336 |
found |= qtAdd_tri(QT_NTH_CHILD_PTR(*qtptr,0),id,t0,t1,t2,v0,a,c,n); |
337 |
found |= qtAdd_tri(QT_NTH_CHILD_PTR(*qtptr,1),id,t0,t1,t2,a,v1,b,n); |
338 |
found |= qtAdd_tri(QT_NTH_CHILD_PTR(*qtptr,2),id,t0,t1,t2,c,b,v2,n); |
339 |
found |= qtAdd_tri(QT_NTH_CHILD_PTR(*qtptr,3),id,t0,t1,t2,b,c,a,n); |
340 |
341 |
#if 0 |
342 |
if(!found) |
343 |
344 |
#ifdef TEST_DRIVER |
345 |
HANDLE_ERROR("qtAdd_tri():Found in parent but not children\n"); |
346 |
#else |
347 |
eputs("qtAdd_tri():Found in parent but not children\n"); |
348 |
#endif |
349 |
350 |
#endif |
351 |
352 |
else |
353 |
354 |
/* If this leave node emptry- create a new set */ |
355 |
if(QT_IS_EMPTY(*qtptr)) |
356 |
357 |
*qtptr = qtaddelem(*qtptr,id); |
358 |
#if 0 |
359 |
360 |
int k; |
361 |
qtgetset(os,*qtptr); |
362 |
printf("\n%d:\n",os[0]); |
363 |
for(k=1; k <= os[0];k++) |
364 |
printf("%d ",os[k]); |
365 |
printf("\n"); |
366 |
367 |
#endif |
368 |
369 |
os[0] = 0; |
370 |
insertelem(os,id); |
371 |
qt = fullnode(os); |
372 |
*qtptr = qt; |
373 |
374 |
375 |
else |
376 |
377 |
378 |
/* If the set is too large: subdivide */ |
379 |
if(QT_SET_CNT(os) < QT_SET_THRESHOLD) |
380 |
381 |
382 |
#if 0 |
383 |
384 |
int k; |
385 |
386 |
387 |
388 |
389 |
printf("\n"); |
390 |
391 |
#endif |
392 |
393 |
394 |
*qtptr = fullnode(os); |
395 |
396 |
397 |
else |
398 |
399 |
if (n < QT_MAX_LEVELS) |
400 |
401 |
/* If set size exceeds threshold: subdivide cell and |
402 |
reinsert set tris into cell |
403 |
404 |
n++; |
405 |
qtfreeleaf(*qtptr); |
406 |
qtSubdivide(qtptr); |
407 |
found = qtAdd_tri(qtptr,id,t0,t1,t2,v0,v1,v2,n); |
408 |
#if 0 |
409 |
if(!found) |
410 |
411 |
412 |
413 |
#else |
414 |
415 |
#endif |
416 |
417 |
#endif |
418 |
for(optr = &(os[1]),i = QT_SET_CNT(os); i > 0; i--) |
419 |
420 |
421 |
qtTri_verts_from_id(id,r0,r1,r2); |
422 |
found=qtAdd_tri(qtptr,id,r0,r1,r2,v0,v1,v2,n); |
423 |
#ifdef DEBUG |
424 |
if(!found) |
425 |
eputs("qtAdd_tri():Reinsert-in parent but not children\n"); |
426 |
#endif |
427 |
428 |
429 |
else |
430 |
if(QT_SET_CNT(os) < QT_MAX_SET) |
431 |
432 |
433 |
#if 0 |
434 |
435 |
int k; |
436 |
437 |
438 |
439 |
440 |
printf("\n"); |
441 |
442 |
#endif |
443 |
444 |
445 |
446 |
447 |
448 |
else |
449 |
450 |
#ifdef DEBUG |
451 |
eputs("qtAdd_tri():two many levels\n"); |
452 |
#endif |
453 |
return(FALSE); |
454 |
455 |
456 |
457 |
458 |
return(TRUE); |
459 |
460 |
461 |
462 |
int |
463 |
qtApply_to_tri_cells(qtptr,t0,t1,t2,v0,v1,v2,func,arg) |
464 |
QUADTREE *qtptr; |
465 |
FVECT t0,t1,t2; |
466 |
FVECT v0,v1,v2; |
467 |
int (*func)(); |
468 |
char *arg; |
469 |
470 |
char test; |
471 |
FVECT a,b,c; |
472 |
473 |
474 |
475 |
476 |
477 |
if(!test) |
478 |
return(FALSE); |
479 |
480 |
481 |
482 |
483 |
484 |
qtApply_to_tri_cells(QT_NTH_CHILD_PTR(*qtptr,0),t0,t1,t2,v0,a,c,func,arg); |
485 |
qtApply_to_tri_cells(QT_NTH_CHILD_PTR(*qtptr,1),t0,t1,t2,a,v1,b,func,arg); |
486 |
qtApply_to_tri_cells(QT_NTH_CHILD_PTR(*qtptr,2),t0,t1,t2,c,b,v2,func,arg); |
487 |
qtApply_to_tri_cells(QT_NTH_CHILD_PTR(*qtptr,3),t0,t1,t2,b,c,a,func,arg); |
488 |
489 |
else |
490 |
return(func(qtptr,arg)); |
491 |
492 |
493 |
494 |
int |
495 |
qtRemove_tri(qtptr,id,t0,t1,t2,v0,v1,v2) |
496 |
QUADTREE *qtptr; |
497 |
int id; |
498 |
FVECT t0,t1,t2; |
499 |
FVECT v0,v1,v2; |
500 |
501 |
502 |
char test; |
503 |
int i; |
504 |
FVECT a,b,c; |
505 |
OBJECT os[MAXSET+1]; |
506 |
507 |
508 |
509 |
510 |
511 |
if(!test) |
512 |
return(FALSE); |
513 |
514 |
515 |
516 |
517 |
518 |
qtRemove_tri(QT_NTH_CHILD_PTR(*qtptr,0),id,t0,t1,t2,v0,a,c); |
519 |
qtRemove_tri(QT_NTH_CHILD_PTR(*qtptr,1),id,t0,t1,t2,a,v1,b); |
520 |
qtRemove_tri(QT_NTH_CHILD_PTR(*qtptr,2),id,t0,t1,t2,c,b,v2); |
521 |
qtRemove_tri(QT_NTH_CHILD_PTR(*qtptr,3),id,t0,t1,t2,b,c,a); |
522 |
523 |
else |
524 |
525 |
526 |
527 |
#ifdef DEBUG |
528 |
eputs("qtRemove_tri(): triangle not found\n"); |
529 |
#endif |
530 |
531 |
/* remove id from set */ |
532 |
else |
533 |
534 |
535 |
if(!inset(os,id)) |
536 |
537 |
#ifdef DEBUG |
538 |
eputs("qtRemove_tri(): tri not in set\n"); |
539 |
#endif |
540 |
541 |
else |
542 |
543 |
*qtptr = qtdelelem(*qtptr,id); |
544 |
#if 0 |
545 |
546 |
int k; |
547 |
548 |
{qtgetset(os,*qtptr); |
549 |
550 |
551 |
552 |
printf("\n"); |
553 |
554 |
555 |
556 |
#endif |
557 |
558 |
559 |
560 |
return(TRUE); |
561 |
562 |
563 |
564 |
565 |
566 |
567 |
568 |
569 |
570 |
571 |
572 |
