1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: sm_qtree.c,v 3.15 2003/04/23 00:52:34 greg Exp $"; |
3 |
#endif |
4 |
5 |
* sm_qtree.c: adapted from octree.c from radiance code |
6 |
7 |
8 |
* octree.c - routines dealing with octrees and cubes. |
9 |
10 |
* 7/28/85 |
11 |
12 |
13 |
#include "standard.h" |
14 |
#include "sm_flag.h" |
15 |
#include "sm_geom.h" |
16 |
#include "object.h" |
17 |
#include "sm_qtree.h" |
18 |
19 |
QUADTREE *quad_block[QT_MAX_BLK]; /* our quadtree */ |
20 |
static QUADTREE quad_free_list = EMPTY; /* freed octree nodes */ |
21 |
static QUADTREE treetop = 0; /* next free node */ |
22 |
int32 *quad_flag= NULL; /* quadtree flags */ |
23 |
24 |
25 |
qtremovelast(qt,id) |
26 |
QUADTREE qt; |
27 |
OBJECT id; |
28 |
29 |
#ifdef DEBUG |
30 |
if(qtqueryset(qt)[(*(qtqueryset(qt)))] != id) |
31 |
error(CONSISTENCY,"not removed\n"); |
32 |
#endif |
33 |
((*(qtqueryset(qt)))--); |
34 |
35 |
QUADTREE |
36 |
qtAlloc() /* allocate a quadtree */ |
37 |
38 |
register QUADTREE freet; |
39 |
40 |
if ((freet = quad_free_list) != EMPTY) |
41 |
42 |
quad_free_list = QT_NTH_CHILD(freet, 0); |
43 |
return(freet); |
44 |
45 |
freet = treetop; |
46 |
if (QT_BLOCK_INDEX(freet) == 0) |
47 |
48 |
if (QT_BLOCK(freet) >= QT_MAX_BLK) |
49 |
return(EMPTY); |
50 |
if ((quad_block[QT_BLOCK(freet)] = (QUADTREE *)malloc( |
51 |
QT_BLOCK_SIZE*4*sizeof(QUADTREE))) == NULL) |
52 |
error(SYSTEM,"qtAlloc(): Unable to allocate memory\n"); |
53 |
54 |
/* Realloc the per/node flags */ |
55 |
quad_flag = (int32 *)realloc((void *)quad_flag, |
56 |
(QT_BLOCK(freet)+1)*((QT_BLOCK_SIZE+7)>>3)); |
57 |
if (quad_flag == NULL) |
58 |
59 |
60 |
treetop += 4; |
61 |
return(freet); |
62 |
63 |
64 |
65 |
qtClearAllFlags() /* clear all quadtree branch flags */ |
66 |
67 |
if (!treetop) |
68 |
return; |
69 |
70 |
/* Clear the node flags*/ |
71 |
bzero((char *)quad_flag, (QT_BLOCK(treetop-4)+1)*((QT_BLOCK_SIZE+7)>>3)); |
72 |
/* Clear set flags */ |
73 |
qtclearsetflags(); |
74 |
75 |
76 |
qtFree(qt) /* free a quadtree */ |
77 |
register QUADTREE qt; |
78 |
79 |
register int i; |
80 |
81 |
if (!QT_IS_TREE(qt)) |
82 |
83 |
qtfreeleaf(qt); |
84 |
return; |
85 |
86 |
for (i = 0; i < 4; i++) |
87 |
qtFree(QT_NTH_CHILD(qt, i)); |
88 |
QT_NTH_CHILD(qt, 0) = quad_free_list; |
89 |
quad_free_list = qt; |
90 |
91 |
92 |
93 |
qtDone() /* free EVERYTHING */ |
94 |
95 |
register int i; |
96 |
97 |
qtfreeleaves(); |
98 |
for (i = 0; i < QT_MAX_BLK; i++) |
99 |
100 |
if (quad_block[i] == NULL) |
101 |
break; |
102 |
free((void *)quad_block[i]); |
103 |
quad_block[i] = NULL; |
104 |
105 |
/* Free the flags */ |
106 |
if (i) free((void *)quad_flag); |
107 |
quad_flag = NULL; |
108 |
quad_free_list = EMPTY; |
109 |
treetop = 0; |
110 |
111 |
112 |
113 |
* bary_parent(coord,i) : Set coord to be value of pt at one level up in |
114 |
* quadtree, given it was the ith child |
115 |
* BCOORD coord[3]; :barycentric coordinates of point, also will hold |
116 |
* result as side effect |
117 |
* int i; :designates which child coord was |
118 |
119 |
bary_parent(coord,i) |
120 |
BCOORD coord[3]; |
121 |
int i; |
122 |
123 |
switch(i) { |
124 |
case 0: |
125 |
/* update bary for child */ |
126 |
coord[0] = (coord[0] >> 1) + MAXBCOORD4; |
127 |
coord[1] >>= 1; |
128 |
coord[2] >>= 1; |
129 |
break; |
130 |
case 1: |
131 |
coord[0] >>= 1; |
132 |
coord[1] = (coord[1] >> 1) + MAXBCOORD4; |
133 |
coord[2] >>= 1; |
134 |
break; |
135 |
136 |
case 2: |
137 |
coord[0] >>= 1; |
138 |
coord[1] >>= 1; |
139 |
coord[2] = (coord[2] >> 1) + MAXBCOORD4; |
140 |
break; |
141 |
142 |
case 3: |
143 |
coord[0] = MAXBCOORD4 - (coord[0] >> 1); |
144 |
coord[1] = MAXBCOORD4 - (coord[1] >> 1); |
145 |
coord[2] = MAXBCOORD4 - (coord[2] >> 1); |
146 |
break; |
147 |
#ifdef DEBUG |
148 |
default: |
149 |
eputs("bary_parent():Invalid child\n"); |
150 |
break; |
151 |
#endif |
152 |
153 |
154 |
155 |
156 |
* bary_from_child(coord,child,next): Given that coord was the (child) child |
157 |
* of the quadtree node, calculate what the (next) child |
158 |
* is at the same level. |
159 |
* BCOORD coord[3]; :At current level (child)th child of node,will also hold |
160 |
161 |
* int child,next; :Which child coord was (child), and which one |
162 |
* is now desired(next) |
163 |
164 |
bary_from_child(coord,child,next) |
165 |
BCOORD coord[3]; |
166 |
int child,next; |
167 |
168 |
#ifdef DEBUG |
169 |
if(child <0 || child > 3) |
170 |
171 |
eputs("bary_from_child():Invalid child\n"); |
172 |
return; |
173 |
174 |
if(next <0 || next > 3) |
175 |
176 |
eputs("bary_from_child():Invalid next\n"); |
177 |
return; |
178 |
179 |
#endif |
180 |
if(next == child) |
181 |
return; |
182 |
183 |
switch(child){ |
184 |
case 0: |
185 |
coord[0] = 0; |
186 |
coord[1] = MAXBCOORD2 - coord[1]; |
187 |
coord[2] = MAXBCOORD2 - coord[2]; |
188 |
break; |
189 |
case 1: |
190 |
coord[0] = MAXBCOORD2 - coord[0]; |
191 |
coord[1] = 0; |
192 |
193 |
break; |
194 |
case 2: |
195 |
196 |
197 |
coord[2] = 0; |
198 |
break; |
199 |
case 3: |
200 |
switch(next){ |
201 |
case 0: |
202 |
coord[0] = 0; |
203 |
204 |
205 |
break; |
206 |
case 1: |
207 |
208 |
coord[1] = 0; |
209 |
210 |
break; |
211 |
case 2: |
212 |
213 |
214 |
coord[2] = 0; |
215 |
break; |
216 |
217 |
break; |
218 |
219 |
220 |
221 |
222 |
* int |
223 |
* bary_child(coord): Return which child coord is of node at current level |
224 |
* As side effect recalculate coord at next level |
225 |
* BCOORD coord[3]; :At current level coordinates of point, will also set |
226 |
* to coords at next level as side effect |
227 |
228 |
int |
229 |
bary_child(coord) |
230 |
BCOORD coord[3]; |
231 |
232 |
int i; |
233 |
234 |
if(coord[0] > MAXBCOORD4) |
235 |
236 |
237 |
coord[0] = (coord[0]<< 1) - MAXBCOORD2; |
238 |
coord[1] <<= 1; |
239 |
coord[2] <<= 1; |
240 |
return(0); |
241 |
242 |
else |
243 |
if(coord[1] > MAXBCOORD4) |
244 |
245 |
coord[0] <<= 1; |
246 |
coord[1] = (coord[1] << 1) - MAXBCOORD2; |
247 |
coord[2] <<= 1; |
248 |
return(1); |
249 |
250 |
else |
251 |
if(coord[2] > MAXBCOORD4) |
252 |
253 |
coord[0] <<= 1; |
254 |
coord[1] <<= 1; |
255 |
coord[2] = (coord[2] << 1) - MAXBCOORD2; |
256 |
return(2); |
257 |
258 |
else |
259 |
260 |
coord[0] = MAXBCOORD2 - (coord[0] << 1); |
261 |
coord[1] = MAXBCOORD2 - (coord[1] << 1); |
262 |
coord[2] = MAXBCOORD2 - (coord[2] << 1); |
263 |
return(3); |
264 |
265 |
266 |
267 |
268 |
269 |
QUADTREE |
270 |
qtLocate(qt,bcoord) |
271 |
QUADTREE qt; |
272 |
BCOORD bcoord[3]; |
273 |
274 |
int i; |
275 |
276 |
if(QT_IS_TREE(qt)) |
277 |
278 |
i = bary_child(bcoord); |
279 |
280 |
return(qtLocate(QT_NTH_CHILD(qt,i),bcoord)); |
281 |
282 |
else |
283 |
return(qt); |
284 |
285 |
286 |
int |
287 |
move_to_nbr(b,db0,db1,db2,tptr) |
288 |
BCOORD b[3]; |
289 |
BDIR db0,db1,db2; |
290 |
double *tptr; |
291 |
292 |
double t,dt; |
293 |
BCOORD bc; |
294 |
int nbr; |
295 |
296 |
nbr = -1; |
297 |
*tptr = 0.0; |
298 |
/* Advance to next node */ |
299 |
if(b[0]==0 && db0 < 0) |
300 |
return(0); |
301 |
if(b[1]==0 && db1 < 0) |
302 |
return(1); |
303 |
if(b[2]==0 && db2 < 0) |
304 |
return(2); |
305 |
if(db0 < 0) |
306 |
307 |
t = ((double)b[0])/-db0; |
308 |
nbr = 0; |
309 |
310 |
else |
311 |
t = MAXFLOAT; |
312 |
if(db1 < 0) |
313 |
314 |
dt = ((double)b[1])/-db1; |
315 |
if( dt < t) |
316 |
317 |
t = dt; |
318 |
nbr = 1; |
319 |
320 |
321 |
if(db2 < 0) |
322 |
323 |
dt = ((double)b[2])/-db2; |
324 |
if( dt < t) |
325 |
326 |
t = dt; |
327 |
nbr = 2; |
328 |
329 |
330 |
*tptr = t; |
331 |
return(nbr); |
332 |
333 |
334 |
qtTrace_ray(qt,b,db0,db1,db2,nextptr,sign,sfactor,func,f) |
335 |
QUADTREE qt; |
336 |
BCOORD b[3]; |
337 |
BDIR db0,db1,db2; |
338 |
int *nextptr; |
339 |
int sign,sfactor; |
340 |
FUNC func; |
341 |
int *f; |
342 |
343 |
int i,found; |
344 |
QUADTREE child; |
345 |
int nbr,next,w; |
346 |
double t; |
347 |
348 |
349 |
350 |
/* Find the appropriate child and reset the coord */ |
351 |
i = bary_child(b); |
352 |
353 |
for(;;) |
354 |
355 |
child = QT_NTH_CHILD(qt,i); |
356 |
if(i != 3) |
357 |
qtTrace_ray(child,b,db0,db1,db2,nextptr,sign,sfactor+1,func,f); |
358 |
else |
359 |
/* If the center cell- must flip direction signs */ |
360 |
qtTrace_ray(child,b,-db0,-db1,-db2,nextptr,1-sign,sfactor+1,func,f); |
361 |
362 |
if(QT_FLAG_IS_DONE(*f)) |
363 |
return; |
364 |
/* If in same block: traverse */ |
365 |
if(i==3) |
366 |
next = *nextptr; |
367 |
else |
368 |
if(*nextptr == i) |
369 |
next = 3; |
370 |
else |
371 |
372 |
/* reset the barycentric coordinates in the parents*/ |
373 |
bary_parent(b,i); |
374 |
/* Else pop up to parent and traverse from there */ |
375 |
return(qt); |
376 |
377 |
bary_from_child(b,i,next); |
378 |
i = next; |
379 |
380 |
381 |
else |
382 |
383 |
#ifdef TEST_DRIVER |
384 |
if(Pick_cnt < 500) |
385 |
Pick_q[Pick_cnt++]=qt; |
386 |
#endif; |
387 |
F_FUNC(func)(qt,F_ARGS(func),f); |
388 |
389 |
return; |
390 |
391 |
nbr = move_to_nbr(b,db0,db1,db2,&t); |
392 |
393 |
if(nbr==-1) |
394 |
395 |
QT_FLAG_SET_DONE(*f); |
396 |
return; |
397 |
398 |
b[0] += (BCOORD)(t *db0); |
399 |
b[1] += (BCOORD)(t *db1); |
400 |
b[2] += (BCOORD)(t *db2); |
401 |
*nextptr = nbr; |
402 |
return; |
403 |
404 |
405 |
406 |
407 |
#define TEST_INT(tl,th,d,q0,q1,h,l) \ |
408 |
tl=d>q0;th=d<q1; if(tl&&th) goto Lfunc_call; \ |
409 |
if(tl) if(l) goto Lfunc_call; else h=TRUE; \ |
410 |
if(th) if(h) goto Lfunc_call; else l = TRUE; \ |
411 |
if(th) if(h) goto Lfunc_call; else l = TRUE; |
412 |
413 |
/* Leaf node: Do definitive test */ |
414 |
QUADTREE |
415 |
qtLeaf_insert_tri(root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02, |
416 |
scale, s0,s1,s2,sq0,sq1,sq2,f,n) |
417 |
int root; |
418 |
QUADTREE qt; |
419 |
BCOORD q0[3],q1[3],q2[3]; |
420 |
BCOORD t0[3],t1[3],t2[3]; |
421 |
BCOORD dt10[3],dt21[3],dt02[3]; |
422 |
unsigned int scale,s0,s1,s2,sq0,sq1,sq2; |
423 |
FUNC f; |
424 |
int n; |
425 |
426 |
double db; |
427 |
unsigned int e0,e1,e2; |
428 |
char al,ah,bl,bh,cl,ch,testl,testh; |
429 |
char test_t0t1,test_t1t2,test_t2t0; |
430 |
BCOORD a,b,c; |
431 |
432 |
/* First check if can trivial accept: if vertex in cell */ |
433 |
if(s0 & s1 & s2) |
434 |
435 |
goto Lfunc_call; |
436 |
437 |
/* Assumption: Could not trivial reject*/ |
438 |
/* IF any coords lie on edge- must be in if couldnt reject */ |
439 |
a = q1[0];b= q0[1]; c= q0[2]; |
440 |
if(t0[0]== a || t0[1] == b || t0[2] == c) |
441 |
442 |
goto Lfunc_call; |
443 |
444 |
if(t1[0]== a || t1[1] == b || t1[2] == c) |
445 |
446 |
goto Lfunc_call; |
447 |
448 |
if(t2[0]== a || t2[1] == b || t2[2] == c) |
449 |
450 |
goto Lfunc_call; |
451 |
452 |
/* Test for edge crossings */ |
453 |
/* Test t0t1,t1t2,t2t0 against a */ |
454 |
/* Calculate edge crossings */ |
455 |
e0 = (s0 ^ ((s0 >> 1) | (s0 << 2 & 4))); |
456 |
/* See if edge can be trivially rejected from intersetion testing */ |
457 |
test_t0t1 = !(((s0 & 6)==0) || ((s1 & 6)==0)|| ((s2 & 6)==0) || |
458 |
((sq0 & 6)==6) ||((sq1 & 6)==6)|| ((sq2 & 6)==6)); |
459 |
bl=bh=0; |
460 |
if(test_t0t1 && (e0 & 2) ) |
461 |
462 |
/* Must do double calculation to avoid overflow */ |
463 |
db = t0[1] + dt10[1]*((double)(a-t0[0]))/dt10[0]; |
464 |
TEST_INT(testl,testh,db,b,q1[1],bl,bh) |
465 |
466 |
test_t1t2= !(((s0 & 3)==0) || ((s1 & 3)==0)|| ((s2 & 3)==0) || |
467 |
((sq0 & 3)==3) ||((sq1 & 3)==3)|| ((sq2 & 3)==3)); |
468 |
if(test_t1t2 && (e0 & 1)) |
469 |
{ /* test t1t2 against a */ |
470 |
db = t1[1] + dt21[1]*((double)(a - t1[0]))/dt21[0]; |
471 |
472 |
473 |
test_t2t0 = !(((s0 & 5)==0) || ((s1 & 5)==0)|| ((s2 & 5)==0) || |
474 |
((sq0 & 5)==5) ||((sq1 & 5)==5)|| ((sq2 & 5)==5)); |
475 |
if(test_t2t0 && (e0 & 4)) |
476 |
477 |
db = t2[1] + dt02[1]*((double)(a - t2[0]))/dt02[0]; |
478 |
479 |
480 |
e1 = (s1 ^ ((s1 >> 1) | (s1 << 2 & 4))); |
481 |
cl = ch = 0; |
482 |
if(test_t0t1 && (e1 & 2)) |
483 |
{/* test t0t1 against b */ |
484 |
db = t0[2] + dt10[2]*((double)(b-t0[1]))/dt10[1]; |
485 |
TEST_INT(testl,testh,db,c,q2[2],cl,ch) |
486 |
487 |
if(test_t1t2 && (e1 & 1)) |
488 |
{/* test t1t2 against b */ |
489 |
db = t1[2] + dt21[2]*((double)(q0[1] - t1[1]))/dt21[1]; |
490 |
491 |
492 |
if(test_t2t0 && (e1 & 4)) |
493 |
{/* test t2t0 against b */ |
494 |
db = t2[2] + dt02[2]*((double)(q0[1] - t2[1]))/dt02[1]; |
495 |
496 |
497 |
498 |
/* test edges against c */ |
499 |
e2 = (s2 ^ ((s2 >> 1) | (s2 << 2 & 4))); |
500 |
al = ah = 0; |
501 |
if(test_t0t1 && (e2 & 2)) |
502 |
{ /* test t0t1 against c */ |
503 |
db = t0[0] + dt10[0]*((double)(c-t0[2]))/dt10[2]; |
504 |
TEST_INT(testl,testh,db,a,q0[0],al,ah) |
505 |
506 |
if(test_t1t2 && (e2 & 1)) |
507 |
508 |
db = t1[0] + dt21[0]*((double)(c - t1[2]))/dt21[2]; |
509 |
510 |
511 |
if(test_t2t0 && (e2 & 4)) |
512 |
{ /* test t2t0 against c */ |
513 |
db = t2[0] + dt02[0]*((double)(c - t2[2]))/dt02[2]; |
514 |
515 |
516 |
/* Only remaining case is if some edge trivially rejected */ |
517 |
if(!e0 || !e1 || !e2) |
518 |
return(qt); |
519 |
520 |
/* Only one/none got tested - pick either of other two/any two */ |
521 |
/* Only need to test one edge */ |
522 |
if(!test_t0t1 && (e0 & 2)) |
523 |
524 |
525 |
526 |
527 |
if(!test_t1t2 && (e0 & 1)) |
528 |
{/* test t1t2 against a */ |
529 |
530 |
531 |
532 |
if(!test_t2t0 && (e0 & 4)) |
533 |
534 |
535 |
536 |
537 |
538 |
return(qt); |
539 |
540 |
Lfunc_call: |
541 |
qt = f.func(f.argptr,root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02,scale, |
542 |
s0,s1,s2,sq0,sq1,sq2,0,f,n); |
543 |
return(qt); |
544 |
545 |
546 |
547 |
548 |
549 |
550 |
QUADTREE |
551 |
qtLeaf_insert_tri_rev(root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02, |
552 |
553 |
int root; |
554 |
QUADTREE qt; |
555 |
556 |
557 |
558 |
559 |
FUNC f; |
560 |
int n; |
561 |
562 |
double db; |
563 |
564 |
BCOORD a,b,c; |
565 |
double p0[2], p1[2],cp; |
566 |
char al,ah,bl,bh,cl,ch; |
567 |
char testl,testh,test_t0t1,test_t1t2,test_t2t0; |
568 |
unsigned int ls0,ls1,ls2; |
569 |
570 |
571 |
/* May have gotten passed trivial reject if one/two vertices are ON */ |
572 |
573 |
SIDES_LESS(t0,t1,t2,ls0,ls1,ls2,a,b,c); |
574 |
575 |
576 |
if(ls0 & ls1 & ls2) |
577 |
578 |
goto Lfunc_call; |
579 |
580 |
if(ls0==0 || ls1 == 0 || ls2 ==0) |
581 |
return(qt); |
582 |
583 |
584 |
585 |
586 |
587 |
goto Lfunc_call; |
588 |
589 |
590 |
591 |
goto Lfunc_call; |
592 |
593 |
594 |
595 |
goto Lfunc_call; |
596 |
597 |
598 |
/* Test t0t1 against a,b,c */ |
599 |
/* First test if t0t1 can be trivially rejected */ |
600 |
/* If both edges are outside bounds- dont need to test */ |
601 |
602 |
603 |
test_t0t1 = !(((ls0 & 6)==0) || ((ls1 & 6)==0)|| ((ls2 & 6)==0) || |
604 |
((sq0 & 6)==0) ||((sq1 & 6)==0)|| ((sq2 & 6)==0)); |
605 |
e0 = (ls0 ^ ((ls0 >> 1) | (ls0 << 2 & 4))); |
606 |
bl=bh=0; |
607 |
608 |
609 |
610 |
db = t0[1] + dt10[1]*((double)(a-t0[0])/dt10[0]); |
611 |
TEST_INT(testl,testh,db,q1[1],b,bl,bh) |
612 |
613 |
test_t1t2= !(((ls0 & 3)==0) || ((ls1 & 3)==0)|| ((ls2 & 3)==0) || |
614 |
((sq0 & 3)==0) ||((sq1 & 3)==0)|| ((sq2 & 3)==0)); |
615 |
616 |
617 |
618 |
619 |
620 |
test_t2t0 = !(((ls0 & 5)==0) || ((ls1 & 5)==0)|| ((ls2 & 5)==0) || |
621 |
((sq0 & 5)==0) ||((sq1 & 5)==0)|| ((sq2 & 5)==0)); |
622 |
623 |
624 |
625 |
626 |
627 |
cl = ch = 0; |
628 |
e1 = (ls1 ^ ((ls1 >> 1) | (ls1 << 2 & 4))); |
629 |
630 |
631 |
db = t0[2] + dt10[2]*(((double)(b-t0[1]))/dt10[1]); |
632 |
TEST_INT(testl,testh,db,q1[2],c,cl,ch) |
633 |
634 |
635 |
636 |
db = t1[2] + dt21[2]*((double)(b - t1[1]))/dt21[1]; |
637 |
638 |
639 |
640 |
641 |
db = t2[2] + dt02[2]*((double)(b - t2[1]))/dt02[1]; |
642 |
643 |
644 |
al = ah = 0; |
645 |
e2 = (ls2 ^ ((ls2 >> 1) | (ls2 << 2 & 4))); |
646 |
647 |
648 |
db = t0[0] + dt10[0]*(((double)(c-t0[2]))/dt10[2]); |
649 |
TEST_INT(testl,testh,db,q0[0],a,al,ah) |
650 |
651 |
652 |
653 |
654 |
655 |
656 |
657 |
658 |
659 |
660 |
661 |
662 |
663 |
return(qt); |
664 |
665 |
666 |
667 |
668 |
669 |
670 |
671 |
672 |
673 |
674 |
675 |
676 |
677 |
678 |
679 |
680 |
681 |
682 |
683 |
return(qt); |
684 |
Lfunc_call: |
685 |
686 |
s0,s1,s2,sq0,sq1,sq2,1,f,n); |
687 |
return(qt); |
688 |
689 |
690 |
691 |
692 |
/* ASSUMPTION: that triangle t0,t1,t2 intersects quad cell q0,q1,q2 */ |
693 |
694 |
/*-------q2--------- sq2 |
695 |
696 |
s1 /sc \ s0 |
697 |
qb_____qa |
698 |
699 |
\sq0/sa \ /sb \ /sq1 |
700 |
\ q0____qc____q1/ |
701 |
702 |
\ s2 / |
703 |
704 |
705 |
int Find_id=0; |
706 |
707 |
QUADTREE |
708 |
qtInsert_tri(root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02,scale, |
709 |
710 |
int root; |
711 |
QUADTREE qt; |
712 |
713 |
714 |
715 |
BCOORD scale; |
716 |
unsigned int s0,s1,s2,sq0,sq1,sq2; |
717 |
FUNC f; |
718 |
int n; |
719 |
720 |
BCOORD a,b,c; |
721 |
BCOORD va[3],vb[3],vc[3]; |
722 |
unsigned int sa,sb,sc; |
723 |
724 |
/* If a tree: trivial reject and recurse on potential children */ |
725 |
726 |
727 |
/* Test against new a edge: if entirely to left: only need |
728 |
to visit child 0 |
729 |
730 |
a = q1[0] + scale; |
731 |
b = q0[1] + scale; |
732 |
c = q0[2] + scale; |
733 |
734 |
SIDES_GTR(t0,t1,t2,sa,sb,sc,a,b,c); |
735 |
736 |
if(sa==7) |
737 |
738 |
vb[1] = q0[1]; |
739 |
vc[2] = q0[2]; |
740 |
vc[1] = b; |
741 |
vb[2] = c; |
742 |
vb[0] = vc[0] = a; |
743 |
QT_NTH_CHILD(qt,0) = qtInsert_tri(root,QT_NTH_CHILD(qt,0),q0,vc, |
744 |
vb,t0,t1,t2,dt10,dt21,dt02, scale>>1,sa,s1,s2,sq0,sb,sc,f,n+1); |
745 |
return(qt); |
746 |
747 |
if(sb==7) |
748 |
749 |
va[0] = q1[0]; |
750 |
vc[2] = q0[2]; |
751 |
va[1] = vc[1] = b; |
752 |
va[2] = c; |
753 |
vc[0] = a; |
754 |
QT_NTH_CHILD(qt,1) = qtInsert_tri(root,QT_NTH_CHILD(qt,1),vc,q1,va, |
755 |
t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,sb,s2,sa,sq1,sc,f,n+1); |
756 |
return(qt); |
757 |
758 |
if(sc==7) |
759 |
760 |
va[0] = q1[0]; |
761 |
vb[1] = q0[1]; |
762 |
va[1] = b; |
763 |
va[2] = vb[2] = c; |
764 |
vb[0] = a; |
765 |
QT_NTH_CHILD(qt,2) = qtInsert_tri(root,QT_NTH_CHILD(qt,2),vb,va, |
766 |
q2,t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,s1,sc,sa,sb,sq2,f,n+1); |
767 |
return(qt); |
768 |
769 |
770 |
va[0] = q1[0]; |
771 |
vb[1] = q0[1]; |
772 |
vc[2] = q0[2]; |
773 |
774 |
775 |
776 |
/* If outside of all edges: only need to Visit 3 */ |
777 |
if(sa==0 && sb==0 && sc==0) |
778 |
779 |
QT_NTH_CHILD(qt,3) = qtInsert_tri_rev(root,QT_NTH_CHILD(qt,3),va,vb, |
780 |
vc,t0,t1,t2,dt10,dt21,dt02, scale>>1,sa,sb,sc,s0,s1,s2,f,n+1); |
781 |
return(qt); |
782 |
783 |
784 |
if(sa) |
785 |
QT_NTH_CHILD(qt,0) = qtInsert_tri(root,QT_NTH_CHILD(qt,0),q0,vc,vb,t0, |
786 |
t1,t2,dt10,dt21,dt02,scale>>1,sa,s1,s2,sq0,sb,sc,f,n+1); |
787 |
if(sb) |
788 |
QT_NTH_CHILD(qt,1) = qtInsert_tri(root,QT_NTH_CHILD(qt,1),vc,q1,va,t0, |
789 |
790 |
if(sc) |
791 |
QT_NTH_CHILD(qt,2) = qtInsert_tri(root,QT_NTH_CHILD(qt,2),vb,va,q2,t0, |
792 |
793 |
QT_NTH_CHILD(qt,3) = qtInsert_tri_rev(root,QT_NTH_CHILD(qt,3),va,vb,vc,t0, |
794 |
t1,t2,dt10,dt21,dt02,scale>>1,sa,sb,sc,s0,s1,s2,f,n+1); |
795 |
return(qt); |
796 |
797 |
798 |
else |
799 |
return(qt = qtLeaf_insert_tri(root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02, |
800 |
scale,s0,s1,s2,sq0,sq1,sq2,f,n)); |
801 |
802 |
803 |
804 |
QUADTREE |
805 |
qtInsert_tri_rev(root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02,scale, |
806 |
807 |
int root; |
808 |
QUADTREE qt; |
809 |
810 |
811 |
812 |
BCOORD scale; |
813 |
814 |
FUNC f; |
815 |
int n; |
816 |
817 |
BCOORD a,b,c; |
818 |
819 |
820 |
821 |
822 |
823 |
824 |
825 |
to visit child 0 |
826 |
827 |
a = q1[0] - scale; |
828 |
b = q0[1] - scale; |
829 |
c = q0[2] - scale; |
830 |
831 |
832 |
833 |
if(sa==0) |
834 |
835 |
vb[1] = q0[1]; |
836 |
vc[2] = q0[2]; |
837 |
vc[1] = b; |
838 |
vb[2] = c; |
839 |
840 |
841 |
QT_NTH_CHILD(qt,0) = qtInsert_tri_rev(root,QT_NTH_CHILD(qt,0),q0,vc, |
842 |
843 |
return(qt); |
844 |
845 |
if(sb==0) |
846 |
847 |
va[0] = q1[0]; |
848 |
vc[2] = q0[2]; |
849 |
850 |
va[2] = c; |
851 |
vc[0] = a; |
852 |
QT_NTH_CHILD(qt,1) = qtInsert_tri_rev(root,QT_NTH_CHILD(qt,1),vc,q1,va, |
853 |
854 |
return(qt); |
855 |
856 |
if(sc==0) |
857 |
858 |
va[0] = q1[0]; |
859 |
vb[1] = q0[1]; |
860 |
va[1] = b; |
861 |
862 |
vb[0] = a; |
863 |
QT_NTH_CHILD(qt,2) = qtInsert_tri_rev(root,QT_NTH_CHILD(qt,2),vb,va, |
864 |
865 |
return(qt); |
866 |
867 |
va[0] = q1[0]; |
868 |
vb[1] = q0[1]; |
869 |
vc[2] = q0[2]; |
870 |
871 |
872 |
873 |
874 |
if(sa==7 && sb==7 && sc==7) |
875 |
876 |
QT_NTH_CHILD(qt,3) = qtInsert_tri(root,QT_NTH_CHILD(qt,3),va,vb, |
877 |
878 |
return(qt); |
879 |
880 |
if(sa!=7) |
881 |
QT_NTH_CHILD(qt,0) = qtInsert_tri_rev(root,QT_NTH_CHILD(qt,0),q0,vc,vb, |
882 |
t0,t1,t2,dt10,dt21,dt02,scale>>1,sa,s1,s2,sq0,sb,sc,f,n+1); |
883 |
if(sb!=7) |
884 |
885 |
886 |
if(sc!=7) |
887 |
QT_NTH_CHILD(qt,2) = qtInsert_tri_rev(root,QT_NTH_CHILD(qt,2),vb,va,q2, |
888 |
889 |
890 |
QT_NTH_CHILD(qt,3) = qtInsert_tri(root,QT_NTH_CHILD(qt,3),va,vb,vc,t0,t1, |
891 |
892 |
return(qt); |
893 |
894 |
895 |
else |
896 |
return(qt = qtLeaf_insert_tri_rev(root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02, |
897 |
898 |
899 |
900 |
901 |
902 |
903 |
904 |
/* Visit code for applying functions: NOTE THIS IS THE SAME AS INSERT CODE: |
905 |
except sets flags: wanted insert to be as efficient as possible: so |
906 |
broke into two sets of routines. Also traverses only to n levels. |
907 |
908 |
909 |
qtVisit_tri(root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02,scale, |
910 |
911 |
int root; |
912 |
QUADTREE qt; |
913 |
914 |
915 |
916 |
BCOORD scale; |
917 |
918 |
FUNC f; |
919 |
int n; |
920 |
921 |
BCOORD a,b,c; |
922 |
923 |
924 |
925 |
if(n == 0) |
926 |
return; |
927 |
928 |
929 |
930 |
QT_SET_FLAG(qt); |
931 |
932 |
933 |
to visit child 0 |
934 |
935 |
936 |
937 |
938 |
939 |
940 |
941 |
if(sa==7) |
942 |
943 |
vb[1] = q0[1]; |
944 |
vc[2] = q0[2]; |
945 |
vc[1] = b; |
946 |
vb[2] = c; |
947 |
948 |
qtVisit_tri(root,QT_NTH_CHILD(qt,0),q0,vc, |
949 |
vb,t0,t1,t2,dt10,dt21,dt02, scale>>1,sa,s1,s2,sq0,sb,sc,f,n-1); |
950 |
return; |
951 |
952 |
if(sb==7) |
953 |
954 |
va[0] = q1[0]; |
955 |
vc[2] = q0[2]; |
956 |
957 |
va[2] = c; |
958 |
vc[0] = a; |
959 |
qtVisit_tri(root,QT_NTH_CHILD(qt,1),vc,q1,va, |
960 |
t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,sb,s2,sa,sq1,sc,f,n-1); |
961 |
return; |
962 |
963 |
if(sc==7) |
964 |
965 |
va[0] = q1[0]; |
966 |
vb[1] = q0[1]; |
967 |
va[1] = b; |
968 |
969 |
vb[0] = a; |
970 |
qtVisit_tri(root,QT_NTH_CHILD(qt,2),vb,va, |
971 |
q2,t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,s1,sc,sa,sb,sq2,f,n-1); |
972 |
return; |
973 |
974 |
975 |
va[0] = q1[0]; |
976 |
vb[1] = q0[1]; |
977 |
vc[2] = q0[2]; |
978 |
979 |
980 |
981 |
982 |
983 |
984 |
qtVisit_tri_rev(root,QT_NTH_CHILD(qt,3),va,vb, |
985 |
vc,t0,t1,t2,dt10,dt21,dt02, scale>>1,sa,sb,sc,s0,s1,s2,f,n-1); |
986 |
return; |
987 |
988 |
989 |
if(sa) |
990 |
qtVisit_tri(root,QT_NTH_CHILD(qt,0),q0,vc,vb,t0, |
991 |
t1,t2,dt10,dt21,dt02,scale>>1,sa,s1,s2,sq0,sb,sc,f,n-1); |
992 |
if(sb) |
993 |
qtVisit_tri(root,QT_NTH_CHILD(qt,1),vc,q1,va,t0, |
994 |
995 |
if(sc) |
996 |
qtVisit_tri(root,QT_NTH_CHILD(qt,2),vb,va,q2,t0, |
997 |
998 |
qtVisit_tri_rev(root,QT_NTH_CHILD(qt,3),va,vb,vc,t0, |
999 |
t1,t2,dt10,dt21,dt02,scale>>1,sa,sb,sc,s0,s1,s2,f,n-1); |
1000 |
1001 |
1002 |
else |
1003 |
qtLeaf_visit_tri(root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02, |
1004 |
scale,s0,s1,s2,sq0,sq1,sq2,f,n); |
1005 |
1006 |
1007 |
1008 |
1009 |
qtVisit_tri_rev(root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02,scale, |
1010 |
1011 |
int root; |
1012 |
QUADTREE qt; |
1013 |
1014 |
1015 |
1016 |
BCOORD scale; |
1017 |
1018 |
FUNC f; |
1019 |
int n; |
1020 |
1021 |
BCOORD a,b,c; |
1022 |
1023 |
1024 |
1025 |
if(n==0) |
1026 |
return; |
1027 |
1028 |
1029 |
1030 |
QT_SET_FLAG(qt); |
1031 |
1032 |
to visit child 0 |
1033 |
1034 |
1035 |
1036 |
1037 |
1038 |
1039 |
1040 |
if(sa==0) |
1041 |
1042 |
vb[1] = q0[1]; |
1043 |
vc[2] = q0[2]; |
1044 |
vc[1] = b; |
1045 |
vb[2] = c; |
1046 |
1047 |
qtVisit_tri_rev(root,QT_NTH_CHILD(qt,0),q0,vc, |
1048 |
1049 |
return; |
1050 |
1051 |
if(sb==0) |
1052 |
1053 |
va[0] = q1[0]; |
1054 |
vc[2] = q0[2]; |
1055 |
1056 |
va[2] = c; |
1057 |
vc[0] = a; |
1058 |
qtVisit_tri_rev(root,QT_NTH_CHILD(qt,1),vc,q1,va, |
1059 |
1060 |
return; |
1061 |
1062 |
if(sc==0) |
1063 |
1064 |
va[0] = q1[0]; |
1065 |
vb[1] = q0[1]; |
1066 |
va[1] = b; |
1067 |
1068 |
vb[0] = a; |
1069 |
qtVisit_tri_rev(root,QT_NTH_CHILD(qt,2),vb,va, |
1070 |
1071 |
return; |
1072 |
1073 |
va[0] = q1[0]; |
1074 |
vb[1] = q0[1]; |
1075 |
vc[2] = q0[2]; |
1076 |
1077 |
1078 |
1079 |
1080 |
1081 |
1082 |
qtVisit_tri(root,QT_NTH_CHILD(qt,3),va,vb, |
1083 |
1084 |
return; |
1085 |
1086 |
if(sa!=7) |
1087 |
qtVisit_tri_rev(root,QT_NTH_CHILD(qt,0),q0,vc,vb, |
1088 |
t0,t1,t2,dt10,dt21,dt02,scale>>1,sa,s1,s2,sq0,sb,sc,f,n-1); |
1089 |
if(sb!=7) |
1090 |
1091 |
1092 |
if(sc!=7) |
1093 |
qtVisit_tri_rev(root,QT_NTH_CHILD(qt,2),vb,va,q2, |
1094 |
1095 |
1096 |
qtVisit_tri(root,QT_NTH_CHILD(qt,3),va,vb,vc,t0,t1, |
1097 |
1098 |
return; |
1099 |
1100 |
1101 |
else |
1102 |
qtLeaf_visit_tri_rev(root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02, |
1103 |
1104 |
1105 |
1106 |
1107 |
1108 |
1109 |
1110 |
int root; |
1111 |
QUADTREE qt; |
1112 |
1113 |
1114 |
1115 |
1116 |
FUNC f; |
1117 |
int n; |
1118 |
1119 |
double db; |
1120 |
1121 |
1122 |
1123 |
BCOORD a,b,c; |
1124 |
1125 |
1126 |
if(s0 & s1 & s2) |
1127 |
goto Lfunc_call; |
1128 |
1129 |
1130 |
1131 |
1132 |
1133 |
goto Lfunc_call; |
1134 |
1135 |
goto Lfunc_call; |
1136 |
1137 |
goto Lfunc_call; |
1138 |
1139 |
1140 |
1141 |
1142 |
1143 |
1144 |
1145 |
1146 |
bl=bh=0; |
1147 |
1148 |
1149 |
1150 |
1151 |
1152 |
1153 |
1154 |
1155 |
1156 |
1157 |
1158 |
1159 |
1160 |
1161 |
1162 |
1163 |
1164 |
1165 |
1166 |
1167 |
1168 |
cl = ch = 0; |
1169 |
1170 |
1171 |
1172 |
1173 |
1174 |
1175 |
1176 |
1177 |
1178 |
1179 |
1180 |
1181 |
1182 |
1183 |
1184 |
1185 |
1186 |
1187 |
al = ah = 0; |
1188 |
1189 |
1190 |
1191 |
1192 |
1193 |
1194 |
1195 |
1196 |
1197 |
1198 |
1199 |
1200 |
1201 |
1202 |
1203 |
1204 |
1205 |
return; |
1206 |
1207 |
1208 |
1209 |
1210 |
1211 |
1212 |
1213 |
1214 |
1215 |
1216 |
1217 |
1218 |
1219 |
1220 |
1221 |
1222 |
1223 |
1224 |
1225 |
return; |
1226 |
1227 |
Lfunc_call: |
1228 |
1229 |
f.func(f.argptr,root,qt,n); |
1230 |
if(!QT_IS_EMPTY(qt)) |
1231 |
QT_LEAF_SET_FLAG(qt); |
1232 |
1233 |
1234 |
1235 |
1236 |
1237 |
1238 |
QUADTREE |
1239 |
1240 |
1241 |
int root; |
1242 |
QUADTREE qt; |
1243 |
1244 |
1245 |
1246 |
1247 |
FUNC f; |
1248 |
int n; |
1249 |
1250 |
double db; |
1251 |
1252 |
BCOORD a,b,c; |
1253 |
1254 |
1255 |
1256 |
1257 |
1258 |
1259 |
1260 |
1261 |
1262 |
1263 |
1264 |
goto Lfunc_call; |
1265 |
1266 |
1267 |
return; |
1268 |
1269 |
1270 |
1271 |
1272 |
goto Lfunc_call; |
1273 |
1274 |
goto Lfunc_call; |
1275 |
1276 |
goto Lfunc_call; |
1277 |
1278 |
1279 |
1280 |
1281 |
1282 |
1283 |
1284 |
1285 |
1286 |
1287 |
bl=bh=0; |
1288 |
1289 |
1290 |
1291 |
1292 |
1293 |
1294 |
1295 |
1296 |
1297 |
1298 |
1299 |
1300 |
1301 |
1302 |
1303 |
1304 |
1305 |
1306 |
1307 |
1308 |
cl = ch = 0; |
1309 |
1310 |
1311 |
1312 |
1313 |
1314 |
1315 |
1316 |
1317 |
1318 |
1319 |
1320 |
1321 |
1322 |
1323 |
1324 |
1325 |
al = ah = 0; |
1326 |
1327 |
1328 |
1329 |
1330 |
1331 |
1332 |
1333 |
1334 |
1335 |
1336 |
1337 |
1338 |
1339 |
1340 |
1341 |
1342 |
1343 |
1344 |
return; |
1345 |
1346 |
1347 |
1348 |
1349 |
1350 |
1351 |
1352 |
1353 |
1354 |
1355 |
1356 |
1357 |
1358 |
1359 |
1360 |
1361 |
1362 |
1363 |
1364 |
return; |
1365 |
1366 |
Lfunc_call: |
1367 |
1368 |
1369 |
1370 |
1371 |
1372 |
1373 |
QUADTREE |
1374 |
qtInsert_point(root,qt,parent,q0,q1,q2,bc,scale,f,n,doneptr) |
1375 |
int root; |
1376 |
QUADTREE qt,parent; |
1377 |
BCOORD q0[3],q1[3],q2[3],bc[3],scale; |
1378 |
FUNC f; |
1379 |
int n,*doneptr; |
1380 |
1381 |
BCOORD a,b,c; |
1382 |
1383 |
1384 |
1385 |
1386 |
1387 |
1388 |
1389 |
if(bc[0] > a) |
1390 |
1391 |
vc[0] = a; vc[1] = b; vc[2] = q0[2]; |
1392 |
vb[0] = a; vb[1] = q0[1]; vb[2] = c; |
1393 |
QT_NTH_CHILD(qt,0) = qtInsert_point(root,QT_NTH_CHILD(qt,0), |
1394 |
qt,q0,vc,vb,bc,scale>>1,f,n+1,doneptr); |
1395 |
if(!*doneptr) |
1396 |
1397 |
f.func_after(f.argptr,QT_NTH_CHILD(qt,1),f,doneptr); |
1398 |
if(!*doneptr) |
1399 |
f.func_after(f.argptr,QT_NTH_CHILD(qt,2),f,doneptr); |
1400 |
if(!*doneptr) |
1401 |
f.func_after(f.argptr,QT_NTH_CHILD(qt,3),f,doneptr); |
1402 |
1403 |
return(qt); |
1404 |
1405 |
if(bc[1] > b) |
1406 |
1407 |
1408 |
va[0] = q1[0]; va[1] = b; va[2] = c; |
1409 |
QT_NTH_CHILD(qt,1) =qtInsert_point(root,QT_NTH_CHILD(qt,1), |
1410 |
qt,vc,q1,va,bc,scale >>1,f,n+1,doneptr); |
1411 |
if(!*doneptr) |
1412 |
1413 |
f.func_after(f.argptr,QT_NTH_CHILD(qt,0),f,doneptr); |
1414 |
if(!*doneptr) |
1415 |
1416 |
if(!*doneptr) |
1417 |
1418 |
1419 |
return(qt); |
1420 |
1421 |
if(bc[2] > c) |
1422 |
1423 |
1424 |
1425 |
QT_NTH_CHILD(qt,2) = qtInsert_point(root,QT_NTH_CHILD(qt,2), |
1426 |
qt,vb,va,q2,bc,scale>>1,f,n+1,doneptr); |
1427 |
if(!*doneptr) |
1428 |
1429 |
1430 |
if(!*doneptr) |
1431 |
1432 |
if(!*doneptr) |
1433 |
1434 |
1435 |
return(qt); |
1436 |
1437 |
else |
1438 |
1439 |
1440 |
1441 |
1442 |
QT_NTH_CHILD(qt,3) = qtInsert_point_rev(root,QT_NTH_CHILD(qt,3), |
1443 |
qt,va,vb,vc,bc,scale>>1,f,n+1,doneptr); |
1444 |
if(!*doneptr) |
1445 |
1446 |
1447 |
if(!*doneptr) |
1448 |
1449 |
if(!*doneptr) |
1450 |
1451 |
1452 |
return(qt); |
1453 |
1454 |
1455 |
else |
1456 |
1457 |
qt = f.func(f.argptr,root,qt,parent,q0,q1,q2,bc,scale,0,f,n,doneptr); |
1458 |
return(qt); |
1459 |
1460 |
1461 |
1462 |
1463 |
QUADTREE |
1464 |
qtInsert_point_rev(root,qt,parent,q0,q1,q2,bc,scale,f,n,doneptr) |
1465 |
int root; |
1466 |
1467 |
BCOORD q0[3],q1[3],q2[3],bc[3]; |
1468 |
BCOORD scale; |
1469 |
FUNC f; |
1470 |
int n,*doneptr; |
1471 |
1472 |
BCOORD a,b,c; |
1473 |
1474 |
1475 |
1476 |
1477 |
1478 |
1479 |
1480 |
if(bc[0] < a) |
1481 |
1482 |
1483 |
1484 |
QT_NTH_CHILD(qt,0) = qtInsert_point_rev(root,QT_NTH_CHILD(qt,0), |
1485 |
1486 |
if(!*doneptr) |
1487 |
1488 |
1489 |
if(!*doneptr) |
1490 |
1491 |
if(!*doneptr) |
1492 |
1493 |
1494 |
return(qt); |
1495 |
1496 |
if(bc[1] < b) |
1497 |
1498 |
1499 |
1500 |
QT_NTH_CHILD(qt,1) = qtInsert_point_rev(root,QT_NTH_CHILD(qt,1), |
1501 |
qt,vc,q1,va,bc,scale>>1,f,n+1,doneptr); |
1502 |
if(!*doneptr) |
1503 |
1504 |
1505 |
if(!*doneptr) |
1506 |
1507 |
if(!*doneptr) |
1508 |
1509 |
1510 |
return(qt); |
1511 |
1512 |
if(bc[2] < c) |
1513 |
1514 |
1515 |
1516 |
QT_NTH_CHILD(qt,2) = qtInsert_point_rev(root,QT_NTH_CHILD(qt,2), |
1517 |
1518 |
if(!*doneptr) |
1519 |
1520 |
1521 |
if(!*doneptr) |
1522 |
1523 |
if(!*doneptr) |
1524 |
1525 |
1526 |
return(qt); |
1527 |
1528 |
else |
1529 |
1530 |
1531 |
1532 |
1533 |
QT_NTH_CHILD(qt,3) = qtInsert_point(root,QT_NTH_CHILD(qt,3), |
1534 |
1535 |
if(!*doneptr) |
1536 |
1537 |
1538 |
if(!*doneptr) |
1539 |
1540 |
if(!*doneptr) |
1541 |
1542 |
1543 |
return(qt); |
1544 |
1545 |
1546 |
else |
1547 |
1548 |
qt = f.func(f.argptr,root,qt,parent,q0,q1,q2,bc,scale,1,f,n,doneptr); |
1549 |
return(qt); |
1550 |
1551 |
1552 |
1553 |
1554 |
1555 |
1556 |
1557 |
1558 |
1559 |
1560 |
1561 |
1562 |
