1 |
/* Copyright (c) 1998 Silicon Graphics, Inc. */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ SGI"; |
5 |
#endif |
6 |
7 |
8 |
* sm_qtree.c: adapted from octree.c from radiance code |
9 |
10 |
11 |
* octree.c - routines dealing with octrees and cubes. |
12 |
13 |
* 7/28/85 |
14 |
15 |
16 |
#include "standard.h" |
17 |
18 |
#include "sm_geom.h" |
19 |
#include "sm_qtree.h" |
20 |
#include "object.h" |
21 |
22 |
QUADTREE *quad_block[QT_MAX_BLK]; /* our quadtree */ |
23 |
static QUADTREE quad_free_list = EMPTY; /* freed octree nodes */ |
24 |
static QUADTREE treetop = 0; /* next free node */ |
25 |
26 |
27 |
28 |
QUADTREE |
29 |
qtAlloc() /* allocate a quadtree */ |
30 |
31 |
register QUADTREE freet; |
32 |
33 |
if ((freet = quad_free_list) != EMPTY) |
34 |
35 |
quad_free_list = QT_NTH_CHILD(freet, 0); |
36 |
return(freet); |
37 |
38 |
freet = treetop; |
39 |
if (QT_BLOCK_INDEX(freet) == 0) |
40 |
41 |
if (QT_BLOCK(freet) >= QT_MAX_BLK) |
42 |
return(EMPTY); |
43 |
if ((quad_block[QT_BLOCK(freet)] = (QUADTREE *)malloc( |
44 |
(unsigned)QT_BLOCK_SIZE*4*sizeof(QUADTREE))) == NULL) |
45 |
return(EMPTY); |
46 |
47 |
treetop += 4; |
48 |
return(freet); |
49 |
50 |
51 |
52 |
qtFree(qt) /* free a quadtree */ |
53 |
register QUADTREE qt; |
54 |
55 |
register int i; |
56 |
57 |
if (!QT_IS_TREE(qt)) |
58 |
59 |
qtfreeleaf(qt); |
60 |
return; |
61 |
62 |
for (i = 0; i < 4; i++) |
63 |
qtFree(QT_NTH_CHILD(qt, i)); |
64 |
QT_NTH_CHILD(qt, 0) = quad_free_list; |
65 |
quad_free_list = qt; |
66 |
67 |
68 |
69 |
qtDone() /* free EVERYTHING */ |
70 |
71 |
register int i; |
72 |
73 |
for (i = 0; i < QT_MAX_BLK; i++) |
74 |
75 |
free((char *)quad_block[i], |
76 |
(unsigned)QT_BLOCK_SIZE*4*sizeof(QUADTREE)); |
77 |
quad_block[i] = NULL; |
78 |
79 |
quad_free_list = EMPTY; |
80 |
treetop = 0; |
81 |
82 |
83 |
QUADTREE |
84 |
qtCompress(qt) /* recursively combine nodes */ |
85 |
86 |
87 |
register int i; |
88 |
register QUADTREE qres; |
89 |
90 |
if (!QT_IS_TREE(qt)) /* not a tree */ |
91 |
return(qt); |
92 |
qres = QT_NTH_CHILD(qt,0) = qtCompress(QT_NTH_CHILD(qt,0)); |
93 |
for (i = 1; i < 4; i++) |
94 |
if((QT_NTH_CHILD(qt,i) = qtCompress(QT_NTH_CHILD(qt,i))) != qres) |
95 |
qres = qt; |
96 |
if(!QT_IS_TREE(qres)) |
97 |
{ /* all were identical leaves */ |
98 |
QT_NTH_CHILD(qt,0) = quad_free_list; |
99 |
100 |
101 |
return(qres); |
102 |
103 |
104 |
QUADTREE |
105 |
qtPoint_locate(qtptr,v1,v2,v3,pt,type,which,p0,p1,p2) |
106 |
QUADTREE *qtptr; |
107 |
FVECT v1,v2,v3; |
108 |
FVECT pt; |
109 |
char *type,*which; |
110 |
FVECT p0,p1,p2; |
111 |
112 |
char d,w; |
113 |
int i; |
114 |
QUADTREE *child; |
115 |
QUADTREE qt; |
116 |
FVECT a,b,c; |
117 |
FVECT t1,t2,t3; |
118 |
119 |
/* Determine if point lies within pyramid (and therefore |
120 |
inside a spherical quadtree cell):GT_INTERIOR, on one of the |
121 |
pyramid sides (and on cell edge):GT_EDGE(1,2 or 3), |
122 |
or on pyramid vertex (and on cell vertex):GT_VERTEX(1,2, or 3). |
123 |
For each triangle edge: compare the |
124 |
point against the plane formed by the edge and the view center |
125 |
126 |
d = test_single_point_against_spherical_tri(v1,v2,v3,pt,&w); |
127 |
128 |
/* Not in this triangle */ |
129 |
if(!d) |
130 |
131 |
if(which) |
132 |
*which = 0; |
133 |
return(EMPTY); |
134 |
135 |
136 |
/* Will return lowest level triangle containing point: It the |
137 |
point is on an edge or vertex: will return first associated |
138 |
triangle encountered in the child traversal- the others can |
139 |
be derived using triangle adjacency information |
140 |
141 |
142 |
if(QT_IS_TREE(*qtptr)) |
143 |
144 |
qtSubdivide_tri(v1,v2,v3,a,b,c); |
145 |
child = QT_NTH_CHILD_PTR(*qtptr,0); |
146 |
if(!QT_IS_EMPTY(*child)) |
147 |
148 |
qt = qtPoint_locate(child,v1,a,c,pt,type,which,p0,p1,p2); |
149 |
if(!QT_IS_EMPTY(qt)) |
150 |
return(qt); |
151 |
152 |
child = QT_NTH_CHILD_PTR(*qtptr,1); |
153 |
154 |
155 |
qt = qtPoint_locate(child,a,b,c,pt,type,which,p0,p1,p2); |
156 |
157 |
return(qt); |
158 |
159 |
child = QT_NTH_CHILD_PTR(*qtptr,2); |
160 |
161 |
162 |
qt = qtPoint_locate(child,a,v2,b,pt,type,which,p0,p1,p2); |
163 |
164 |
return(qt); |
165 |
166 |
child = QT_NTH_CHILD_PTR(*qtptr,3); |
167 |
168 |
169 |
qt = qtPoint_locate(child,c,b,v3,pt,type,which,p0,p1,p2); |
170 |
171 |
return(qt); |
172 |
173 |
174 |
else |
175 |
if(!QT_IS_EMPTY(*qtptr)) |
176 |
177 |
/* map GT_VERTEX,GT_EDGE,GT_FACE GT_INTERIOR of pyramid to |
178 |
spherical triangle primitives |
179 |
180 |
if(type) |
181 |
*type = d; |
182 |
if(which) |
183 |
*which = w; |
184 |
VCOPY(p0,v1); |
185 |
VCOPY(p1,v2); |
186 |
VCOPY(p2,v3); |
187 |
return(*qtptr); |
188 |
189 |
return(EMPTY); |
190 |
191 |
192 |
int |
193 |
qtPoint_in_tri(qtptr,v0,v1,v2,pt,type,which) |
194 |
QUADTREE *qtptr; |
195 |
FVECT v0,v1,v2; |
196 |
FVECT pt; |
197 |
198 |
199 |
QUADTREE qt; |
200 |
OBJECT os[MAXSET+1],*optr; |
201 |
char d,w; |
202 |
int i,id; |
203 |
FVECT p0,p1,p2; |
204 |
205 |
qt = qtPoint_locate(qtptr,v0,v1,v2,pt,type,which,p0,p1,p2); |
206 |
if(QT_IS_EMPTY(qt)) |
207 |
return(EMPTY); |
208 |
209 |
/* Get the set */ |
210 |
qtgetset(os,qt); |
211 |
for (i = QT_SET_CNT(os),optr = QT_SET_PTR(os); i > 0; i--) |
212 |
213 |
/* Find the triangle that pt falls in (NOTE:FOR now return first 1) */ |
214 |
id = QT_SET_NEXT_ELEM(optr); |
215 |
qtTri_verts_from_id(id,p0,p1,p2); |
216 |
d = test_single_point_against_spherical_tri(p0,p1,p2,pt,&w); |
217 |
if(d) |
218 |
219 |
if(type) |
220 |
*type = d; |
221 |
if(which) |
222 |
*which = w; |
223 |
return(id); |
224 |
225 |
226 |
return(EMPTY); |
227 |
228 |
229 |
QUADTREE |
230 |
qtSubdivide(qtptr) |
231 |
QUADTREE *qtptr; |
232 |
233 |
QUADTREE node; |
234 |
node = qtAlloc(); |
235 |
QT_CLEAR_CHILDREN(node); |
236 |
*qtptr = node; |
237 |
return(node); |
238 |
239 |
240 |
241 |
QUADTREE |
242 |
qtSubdivide_nth_child(qt,n) |
243 |
QUADTREE qt; |
244 |
int n; |
245 |
246 |
QUADTREE node; |
247 |
248 |
node = qtSubdivide(&(QT_NTH_CHILD(qt,n))); |
249 |
250 |
return(node); |
251 |
252 |
253 |
/* for triangle v1-v2-v3- returns a,b,c: children are: |
254 |
255 |
v3 0: v1,a,c |
256 |
/\ 1: a,b,c |
257 |
/3 \ 2: a,v2,b |
258 |
c/____\b 3: c,b,v3 |
259 |
260 |
/0 \1 /2 \ |
261 |
v1/____\/____\v2 |
262 |
a |
263 |
264 |
265 |
qtSubdivide_tri(v1,v2,v3,a,b,c) |
266 |
FVECT v1,v2,v3; |
267 |
FVECT a,b,c; |
268 |
269 |
EDGE_MIDPOINT_VEC3(a,v1,v2); |
270 |
normalize(a); |
271 |
EDGE_MIDPOINT_VEC3(b,v2,v3); |
272 |
normalize(b); |
273 |
EDGE_MIDPOINT_VEC3(c,v3,v1); |
274 |
normalize(c); |
275 |
276 |
277 |
qtNth_child_tri(v1,v2,v3,a,b,c,i,r1,r2,r3) |
278 |
FVECT v1,v2,v3; |
279 |
FVECT a,b,c; |
280 |
int i; |
281 |
FVECT r1,r2,r3; |
282 |
283 |
VCOPY(r1,a); VCOPY(r2,b); VCOPY(r3,c); |
284 |
switch(i){ |
285 |
case 0: |
286 |
VCOPY(r2,r1); |
287 |
VCOPY(r1,v1); |
288 |
break; |
289 |
case 1: |
290 |
break; |
291 |
case 2: |
292 |
VCOPY(r3,r2); |
293 |
VCOPY(r2,v2); |
294 |
break; |
295 |
case 3: |
296 |
VCOPY(r1,r3); |
297 |
VCOPY(r3,v3); |
298 |
break; |
299 |
300 |
301 |
302 |
/* Add triangle "id" to all leaf level cells that are children of |
303 |
quadtree pointed to by "qtptr" with cell vertices "t1,t2,t3" |
304 |
that it overlaps (vertex and edge adjacencies do not count |
305 |
as overlapping). If the addition of the triangle causes the cell to go over |
306 |
threshold- the cell is split- and the triangle must be recursively inserted |
307 |
into the new child cells: it is assumed that "v1,v2,v3" are normalized |
308 |
309 |
310 |
int |
311 |
qtAdd_tri(qtptr,id,t1,t2,t3,v1,v2,v3,n) |
312 |
QUADTREE *qtptr; |
313 |
int id; |
314 |
FVECT t1,t2,t3; |
315 |
FVECT v1,v2,v3; |
316 |
int n; |
317 |
318 |
319 |
char test; |
320 |
int i,index; |
321 |
FVECT a,b,c; |
322 |
323 |
QUADTREE qt; |
324 |
int found; |
325 |
FVECT r1,r2,r3; |
326 |
327 |
/* test if triangle (t1,t2,t3) overlaps cell triangle (v1,v2,v3) */ |
328 |
test = spherical_tri_intersect(t1,t2,t3,v1,v2,v3); |
329 |
330 |
/* If triangles do not overlap: done */ |
331 |
if(!test) |
332 |
return(FALSE); |
333 |
found = 0; |
334 |
335 |
/* if this is tree: recurse */ |
336 |
337 |
338 |
n++; |
339 |
340 |
found |= qtAdd_tri(QT_NTH_CHILD_PTR(*qtptr,0),id,t1,t2,t3,v1,a,c,n); |
341 |
found |= qtAdd_tri(QT_NTH_CHILD_PTR(*qtptr,1),id,t1,t2,t3,a,b,c,n); |
342 |
found |= qtAdd_tri(QT_NTH_CHILD_PTR(*qtptr,2),id,t1,t2,t3,a,v2,b,n); |
343 |
found |= qtAdd_tri(QT_NTH_CHILD_PTR(*qtptr,3),id,t1,t2,t3,c,b,v3,n); |
344 |
345 |
#if 0 |
346 |
if(!found) |
347 |
348 |
#ifdef TEST_DRIVER |
349 |
HANDLE_ERROR("qtAdd_tri():Found in parent but not children\n"); |
350 |
#else |
351 |
eputs("qtAdd_tri():Found in parent but not children\n"); |
352 |
#endif |
353 |
354 |
#endif |
355 |
356 |
else |
357 |
358 |
/* If this leave node emptry- create a new set */ |
359 |
if(QT_IS_EMPTY(*qtptr)) |
360 |
361 |
*qtptr = qtaddelem(*qtptr,id); |
362 |
#if 0 |
363 |
364 |
int k; |
365 |
qtgetset(os,*qtptr); |
366 |
printf("\n%d:\n",os[0]); |
367 |
for(k=1; k <= os[0];k++) |
368 |
printf("%d ",os[k]); |
369 |
printf("\n"); |
370 |
371 |
#endif |
372 |
373 |
os[0] = 0; |
374 |
insertelem(os,id); |
375 |
qt = fullnode(os); |
376 |
*qtptr = qt; |
377 |
378 |
379 |
else |
380 |
381 |
382 |
/* If the set is too large: subdivide */ |
383 |
if(QT_SET_CNT(os) < QT_SET_THRESHOLD) |
384 |
385 |
386 |
#if 0 |
387 |
388 |
int k; |
389 |
390 |
391 |
392 |
393 |
printf("\n"); |
394 |
395 |
#endif |
396 |
397 |
398 |
*qtptr = fullnode(os); |
399 |
400 |
401 |
else |
402 |
403 |
if (n < QT_MAX_LEVELS) |
404 |
405 |
/* If set size exceeds threshold: subdivide cell and |
406 |
reinsert set tris into cell |
407 |
408 |
n++; |
409 |
qtfreeleaf(*qtptr); |
410 |
qtSubdivide(qtptr); |
411 |
found = qtAdd_tri(qtptr,id,t1,t2,t3,v1,v2,v3,n); |
412 |
#if 0 |
413 |
if(!found) |
414 |
415 |
416 |
417 |
#else |
418 |
419 |
#endif |
420 |
421 |
#endif |
422 |
for(optr = &(os[1]),i = QT_SET_CNT(os); i > 0; i--) |
423 |
424 |
425 |
qtTri_verts_from_id(id,r1,r2,r3); |
426 |
found=qtAdd_tri(qtptr,id,r1,r2,r3,v1,v2,v3,n); |
427 |
#ifdef DEBUG |
428 |
if(!found) |
429 |
eputs("qtAdd_tri():Reinsert-in parent but not children\n"); |
430 |
#endif |
431 |
432 |
433 |
else |
434 |
if(QT_SET_CNT(os) < QT_MAX_SET) |
435 |
436 |
437 |
#if 0 |
438 |
439 |
int k; |
440 |
441 |
442 |
443 |
444 |
printf("\n"); |
445 |
446 |
#endif |
447 |
448 |
449 |
450 |
451 |
452 |
else |
453 |
454 |
#ifdef DEBUG |
455 |
eputs("qtAdd_tri():two many levels\n"); |
456 |
#endif |
457 |
return(FALSE); |
458 |
459 |
460 |
461 |
462 |
return(TRUE); |
463 |
464 |
465 |
466 |
int |
467 |
qtApply_to_tri_cells(qtptr,t1,t2,t3,v1,v2,v3,func,arg) |
468 |
QUADTREE *qtptr; |
469 |
FVECT t1,t2,t3; |
470 |
FVECT v1,v2,v3; |
471 |
int (*func)(); |
472 |
char *arg; |
473 |
474 |
char test; |
475 |
FVECT a,b,c; |
476 |
477 |
478 |
479 |
480 |
481 |
if(!test) |
482 |
return(FALSE); |
483 |
484 |
485 |
486 |
487 |
488 |
qtApply_to_tri_cells(QT_NTH_CHILD_PTR(*qtptr,0),t1,t2,t3,v1,a,c,func,arg); |
489 |
qtApply_to_tri_cells(QT_NTH_CHILD_PTR(*qtptr,1),t1,t2,t3,a,b,c,func,arg); |
490 |
qtApply_to_tri_cells(QT_NTH_CHILD_PTR(*qtptr,2),t1,t2,t3,a,v2,b,func,arg); |
491 |
qtApply_to_tri_cells(QT_NTH_CHILD_PTR(*qtptr,3),t1,t2,t3,c,b,v3,func,arg); |
492 |
493 |
else |
494 |
return(func(qtptr,arg)); |
495 |
496 |
497 |
498 |
int |
499 |
qtRemove_tri(qtptr,id,t1,t2,t3,v1,v2,v3) |
500 |
QUADTREE *qtptr; |
501 |
int id; |
502 |
FVECT t1,t2,t3; |
503 |
FVECT v1,v2,v3; |
504 |
505 |
506 |
char test; |
507 |
int i; |
508 |
FVECT a,b,c; |
509 |
OBJECT os[MAXSET+1]; |
510 |
511 |
512 |
513 |
514 |
515 |
if(!test) |
516 |
return(FALSE); |
517 |
518 |
519 |
520 |
521 |
522 |
qtRemove_tri(QT_NTH_CHILD_PTR(*qtptr,0),id,t1,t2,t3,v1,a,c); |
523 |
qtRemove_tri(QT_NTH_CHILD_PTR(*qtptr,1),id,t1,t2,t3,a,b,c); |
524 |
qtRemove_tri(QT_NTH_CHILD_PTR(*qtptr,2),id,t1,t2,t3,a,v2,b); |
525 |
qtRemove_tri(QT_NTH_CHILD_PTR(*qtptr,3),id,t1,t2,t3,c,b,v3); |
526 |
527 |
else |
528 |
529 |
530 |
531 |
#ifdef DEBUG |
532 |
eputs("qtRemove_tri(): triangle not found\n"); |
533 |
#endif |
534 |
535 |
/* remove id from set */ |
536 |
else |
537 |
538 |
539 |
if(!inset(os,id)) |
540 |
541 |
#ifdef DEBUG |
542 |
eputs("qtRemove_tri(): tri not in set\n"); |
543 |
#endif |
544 |
545 |
else |
546 |
547 |
*qtptr = qtdelelem(*qtptr,id); |
548 |
#if 0 |
549 |
550 |
int k; |
551 |
552 |
{qtgetset(os,*qtptr); |
553 |
554 |
555 |
556 |
printf("\n"); |
557 |
558 |
559 |
560 |
#endif |
561 |
562 |
563 |
564 |
return(TRUE); |
565 |
