--- ray/src/hd/sm_qtree.c 1998/09/14 10:33:47 3.5 +++ ray/src/hd/sm_qtree.c 1998/09/16 18:16:29 3.6 @@ -174,7 +174,7 @@ FVECT t0,t1,t2; tri_plane_equation(v0,v1,v2,n,&pd,FALSE); intersect_vector_plane(pt,n,pd,NULL,i_pt); - i = max_index(n); + i = max_index(n,NULL); x = (i+1)%3; y = (i+2)%3; /* Calculate barycentric coordinates of i_pt */ @@ -374,7 +374,7 @@ int n; for(optr = QT_SET_PTR(os),i = QT_SET_CNT(os); i > 0; i--) { id = QT_SET_NEXT_ELEM(optr); - qtTri_from_id(id,NULL,NULL,NULL,r0,r1,r2,NULL,NULL,NULL); + qtTri_from_id(id,r0,r1,r2,NULL,NULL,NULL,NULL,NULL,NULL); found=qtAdd_tri(qtptr,q0,q1,q2,r0,r1,r2,id,n); #ifdef DEBUG if(!found) @@ -527,107 +527,6 @@ double *tptr; } int -qtTrace_edge(qtptr,b,db,orig,dir,max_t,func,arg1,arg2) - QUADTREE *qtptr; - double b[3],db[3]; - FVECT orig,dir; - double max_t; - int (*func)(); - int *arg1,arg2; -{ - - int i,found; - QUADTREE *child; - int nbr,next; - double t; -#ifdef DEBUG_TEST_DRIVER - - FVECT a1,b1,c1; - int Pick_parent = Pick_cnt-1; - qtSubdivide_tri(Pick_v0[Pick_parent],Pick_v1[Pick_parent], - Pick_v2[Pick_parent],a1,b1,c1); - -#endif - if(QT_IS_TREE(*qtptr)) - { - /* Find the appropriate child and reset the coord */ - i = bary_child(b); - - QT_SET_FLAG(*qtptr); - - for(;;) - { - child = QT_NTH_CHILD_PTR(*qtptr,i); - - if(i != 3) - { - - db[0] *= 2.0;db[1] *= 2.0; db[2] *= 2.0; - nbr = qtTrace_edge(child,b,db,orig,dir,max_t,func,arg1,arg2); - db[0] *= 0.5;db[1] *= 0.5; db[2] *= 0.5; - } - else - { - db[0] *=-2.0;db[1] *= -2.0; db[2] *= -2.0; - /* If the center cell- must flip direction signs */ - nbr = qtTrace_edge(child,b,db,orig,dir,max_t,func,arg1,arg2); - db[0] *=-0.5;db[1] *= -0.5; db[2] *= -0.5; - } - if(nbr == QT_DONE) - return(nbr); - - /* If in same block: traverse */ - if(i==3) - next = nbr; - else - if(nbr == i) - next = 3; - else - { - /* reset the barycentric coordinates in the parents*/ - bary_parent(b,i); - /* Else pop up to parent and traverse from there */ - return(nbr); - } - bary_from_child(b,i,next); - i = next; - } - } - else - { -#ifdef DEBUG_TEST_DRIVER - qtNth_child_tri(Pick_v0[Pick_parent],Pick_v1[Pick_parent], - Pick_v2[Pick_parent],a1,b1,c1,i, - Pick_v0[Pick_cnt],Pick_v1[Pick_cnt], - Pick_v2[Pick_cnt]); - Pick_cnt++; -#endif - - if(func(qtptr,arg1,arg2) == QT_DONE) - return(QT_DONE); - - /* Advance to next node */ - /* NOTE: Optimize: should only have to check 1/2 */ - nbr = move_to_nbr(b,db[0],db[1],db[2],&t); - - if(t >= max_t) - return(QT_DONE); - if(nbr != -1) - { - b[0] += t * db[0]; - b[1] += t * db[1]; - b[2] += t * db[2]; - db[0] *= (1.0 - t); - db[1] *= (1.0 - t); - db[2] *= (1.0 - t); - } - return(nbr); - } - -} - - -int qtTrace_ray(qtptr,b,db0,db1,db2,orig,dir,func,arg1,arg2) QUADTREE *qtptr; double b[3],db0,db1,db2; @@ -746,7 +645,7 @@ qtRoot_trace_ray(qtptr,q0,q1,q2,orig,dir,func,arg1,arg intersect_vector_plane(c,n,pd,&t,c); /* map to 2d by dropping maximum magnitude component of normal */ - i = max_index(n); + i = max_index(n,NULL); x = (i+1)%3; y = (i+2)%3; /* Calculate barycentric coordinates of orig */ @@ -772,75 +671,13 @@ qtRoot_trace_ray(qtptr,q0,q1,q2,orig,dir,func,arg1,arg } - -int -qtRoot_trace_edge(qtptr,q0,q1,q2,orig,dir,max_t,func,arg1,arg2) +qtVisit_tri_interior(qtptr,q0,q1,q2,t0,t1,t2,n,func,arg1,arg2,arg3) QUADTREE *qtptr; FVECT q0,q1,q2; - FVECT orig,dir; - double max_t; - int (*func)(); - int *arg1,arg2; -{ - int i,x,y,nbr; - QUADTREE *child; - FVECT n,c,i_pt,d; - double pd,b[3],db[3],t; - /* Determine if point lies within pyramid (and therefore - inside a spherical quadtree cell):GT_INTERIOR, on one of the - pyramid sides (and on cell edge):GT_EDGE(1,2 or 3), - or on pyramid vertex (and on cell vertex):GT_VERTEX(1,2, or 3). - For each triangle edge: compare the - point against the plane formed by the edge and the view center - */ - i = point_in_stri(q0,q1,q2,orig); - - /* Not in this triangle */ - if(!i) - return(-1); - /* Project the origin onto the root node plane */ - - /* Find the intersection point of the origin */ - tri_plane_equation(q0,q1,q2,n,&pd,FALSE); - intersect_vector_plane(orig,n,pd,NULL,i_pt); - /* project the dir as well */ - VADD(c,orig,dir); - intersect_vector_plane(c,n,pd,&t,c); - - /* map to 2d by dropping maximum magnitude component of normal */ - i = max_index(n); - x = (i+1)%3; - y = (i+2)%3; - /* Calculate barycentric coordinates of orig */ - bary2d(q0[x],q0[y],q1[x],q1[y],q2[x],q2[y],i_pt[x],i_pt[y],b); - /* Calculate barycentric coordinates of dir */ - bary2d(q0[x],q0[y],q1[x],q1[y],q2[x],q2[y],c[x],c[y],db); - if(t < 0.0) - VSUB(db,b,db); - else - VSUB(db,db,b); - - -#ifdef DEBUG_TEST_DRIVER - VCOPY(Pick_v0[Pick_cnt],q0); - VCOPY(Pick_v1[Pick_cnt],q1); - VCOPY(Pick_v2[Pick_cnt],q2); - Pick_cnt++; -#endif - /* trace the ray starting with this node */ - nbr = qtTrace_edge(qtptr,b,db,orig,d,max_t,func,arg1,arg2); - return(nbr); - -} - - -qtVisit_tri_interior(qtptr,q0,q1,q2,t0,t1,t2,n,func,arg1,arg2) - QUADTREE *qtptr; - FVECT q0,q1,q2; FVECT t0,t1,t2; int n; int (*func)(); - int *arg1,arg2; + int *arg1,arg2,*arg3; { int i,found,test; QUADTREE *child; @@ -863,7 +700,7 @@ tree_modified: child = QT_NTH_CHILD_PTR(*qtptr,i); qtNth_child_tri(q0,q1,q2,a,b,c,i,c0,c1,c2); qtVisit_tri_interior(child,c0,c1,c2,t0,t1,t2,n+1, - func,arg1,arg2); + func,arg1,arg2,arg3); } } } @@ -873,13 +710,13 @@ tree_modified: if(!QT_IS_EMPTY(*qtptr)) { if(qtinset(*qtptr,arg2)) - if(func(qtptr,q0,q1,q2,t0,t1,t2,n,arg1,arg2)==QT_MODIFIED) + if(func(qtptr,q0,q1,q2,t0,t1,t2,n,arg1,arg2,arg3)==QT_MODIFIED) goto tree_modified; else return; } if(point_in_stri(t0,t1,t2,q0) ) - if(func(qtptr,q0,q1,q2,t0,t1,t2,n,arg1,arg2)==QT_MODIFIED) + if(func(qtptr,q0,q1,q2,t0,t1,t2,n,arg1,arg2,arg3)==QT_MODIFIED) goto tree_modified; } } @@ -889,26 +726,29 @@ tree_modified: +/* NOTE: SINCE DIR could be unit: then we could use integer math */ int -qtVisit_tri_edges(qtptr,b,db,wptr,sfactor,func,arg1,arg2) +qtVisit_tri_edges(qtptr,b,db0,db1,db2, + db,wptr,t,sign,sfactor,func,arg1,arg2,arg3) QUADTREE *qtptr; - double b[3],db[3][3]; + double b[3],db0,db1,db2,db[3][3]; int *wptr; + double t[3]; + int sign; double sfactor; int (*func)(); - int *arg1,arg2; + int *arg1,arg2,*arg3; { int i,found; QUADTREE *child; int nbr,next,w; - double t; + double t_l,t_g; #ifdef DEBUG_TEST_DRIVER FVECT a1,b1,c1; int Pick_parent = Pick_cnt-1; qtSubdivide_tri(Pick_v0[Pick_parent],Pick_v1[Pick_parent], Pick_v2[Pick_parent],a1,b1,c1); #endif - if(QT_IS_TREE(*qtptr)) { /* Find the appropriate child and reset the coord */ @@ -922,26 +762,24 @@ qtVisit_tri_edges(qtptr,b,db,wptr,sfactor,func,arg1,ar child = QT_NTH_CHILD_PTR(*qtptr,i); if(i != 3) - { - - db[w][0] *= 2.0;db[w][1] *= 2.0; db[w][2] *= 2.0; - nbr = qtVisit_tri_edges(child,b,db,wptr,sfactor*2.0, - func,arg1,arg2); - w = *wptr; - db[w][0] *= 0.5;db[w][1] *= 0.5; db[w][2] *= 0.5; - } + nbr = qtVisit_tri_edges(child,b,db0,db1,db2, + db,wptr,t,sign, + sfactor*2.0,func,arg1,arg2,arg3); else - { - db[w][0] *=-2.0;db[w][1] *= -2.0; db[w][2] *= -2.0; - /* If the center cell- must flip direction signs */ - nbr = qtVisit_tri_edges(child,b,db,wptr,sfactor*(-2.0), - func,arg1,arg2); - w = *wptr; - db[w][0] *=-0.5;db[w][1] *= -0.5; db[w][2] *= -0.5; - } - if(nbr == QT_DONE) - return(nbr); + /* If the center cell- must flip direction signs */ + nbr = qtVisit_tri_edges(child,b,-db0,-db1,-db2, + db,wptr,t,1-sign, + sfactor*2.0,func,arg1,arg2,arg3); + if(nbr == QT_DONE) + return(nbr); + if(*wptr != w) + { + w = *wptr; + db0 = db[w][0];db1 = db[w][1];db2 = db[w][2]; + if(sign) + { db0 *= -1.0;db1 *= -1.0; db2 *= -1.0;} + } /* If in same block: traverse */ if(i==3) next = nbr; @@ -955,9 +793,9 @@ qtVisit_tri_edges(qtptr,b,db,wptr,sfactor,func,arg1,ar /* Else pop up to parent and traverse from there */ return(nbr); } - bary_from_child(b,i,next); - i = next; - } + bary_from_child(b,i,next); + i = next; + } } else { @@ -968,37 +806,43 @@ qtVisit_tri_edges(qtptr,b,db,wptr,sfactor,func,arg1,ar Pick_cnt++; #endif - if(func(qtptr,arg1,arg2) == QT_DONE) + if(func(qtptr,arg1,arg2,arg3) == QT_DONE) return(QT_DONE); /* Advance to next node */ - /* NOTE: Optimize: should only have to check 1/2 */ w = *wptr; while(1) { - nbr = move_to_nbr(b,db[w][0],db[w][1],db[w][2],&t); + nbr = move_to_nbr(b,db0,db1,db2,&t_l); - if(t >= 1.0) - { + t_g = t_l/sfactor; +#ifdef DEBUG + if(t[w] <= 0.0) + eputs("qtVisit_tri_edges():negative t\n"); +#endif + if(t_g >= t[w]) + { if(w == 2) return(QT_DONE); - b[0] += db[w][0]; - b[1] += db[w][1]; - b[2] += db[w][2]; + + b[0] += (t[w])*sfactor*db0; + b[1] += (t[w])*sfactor*db1; + b[2] += (t[w])*sfactor*db2; w++; - db[w][0] *= sfactor; - db[w][1] *= sfactor; - db[w][2] *= sfactor; + db0 = db[w][0]; + db1 = db[w][1]; + db2 = db[w][2]; + if(sign) + { db0 *= -1.0;db1 *= -1.0; db2 *= -1.0;} } else if(nbr != INVALID) { - b[0] += t * db[w][0]; - b[1] += t * db[w][1]; - b[2] += t * db[w][2]; - db[w][0] *= (1.0 - t); - db[w][1] *= (1.0 - t); - db[w][2] *= (1.0 - t); + b[0] += t_l * db0; + b[1] += t_l * db1; + b[2] += t_l * db2; + + t[w] -= t_g; *wptr = w; return(nbr); } @@ -1011,18 +855,18 @@ qtVisit_tri_edges(qtptr,b,db,wptr,sfactor,func,arg1,ar int -qtRoot_visit_tri_edges(qtptr,q0,q1,q2,tri,dir,wptr,func,arg1,arg2) +qtRoot_visit_tri_edges(qtptr,q0,q1,q2,tri,i_pt,wptr,func,arg1,arg2,arg3) QUADTREE *qtptr; FVECT q0,q1,q2; - FVECT tri[3],dir[3]; + FVECT tri[3],i_pt; int *wptr; int (*func)(); - int *arg1,arg2; + int *arg1,arg2,*arg3; { - int i,x,y,nbr,w; + int x,y,z,nbr,w,i,j; QUADTREE *child; - FVECT n,c,i_pt,d; - double pd,b[3][3],db[3][3],t; + FVECT n,c,d,v[3]; + double pd,b[4][3],db[3][3],et[3],t[3],exit_pt; w = *wptr; @@ -1031,60 +875,145 @@ qtRoot_visit_tri_edges(qtptr,q0,q1,q2,tri,dir,wptr,fun /* Find the intersection point of the origin */ tri_plane_equation(q0,q1,q2,n,&pd,FALSE); /* map to 2d by dropping maximum magnitude component of normal */ - i = max_index(n); - x = (i+1)%3; - y = (i+2)%3; + z = max_index(n,NULL); + x = (z+1)%3; + y = (z+2)%3; /* Calculate barycentric coordinates for current vertex */ - - for(i=0;i < 3; i++) + if(w != -1) { - /* If processing 3rd edge-dont need info for t1 */ - if(i==1 && w==2) - continue; - /* project the dir as well */ - intersect_vector_plane(tri[i],n,pd,NULL,i_pt); - bary2d(q0[x],q0[y],q1[x],q1[y],q2[x],q2[y],i_pt[x],i_pt[y],b[i]); - VADD(c,tri[i],dir[i]); - intersect_vector_plane(c,n,pd,&t,c); - /* Calculate barycentric coordinates of dir */ - bary2d(q0[x],q0[y],q1[x],q1[y],q2[x],q2[y],c[x],c[y],db[i]); - if(t < 0.0) - VSUB(db[i],b[i],db[i]); - else - VSUB(db[i],db[i],b[i]); + bary2d(q0[x],q0[y],q1[x],q1[y],q2[x],q2[y],i_pt[x],i_pt[y],b[3]); + intersect_vector_plane(tri[w],n,pd,&(et[w]),v[w]); + bary2d(q0[x],q0[y],q1[x],q1[y],q2[x],q2[y],v[w][x],v[w][y],b[w]); } -#ifdef DEBUG_TEST_DRIVER - VCOPY(Pick_v0[Pick_cnt],q0); - VCOPY(Pick_v1[Pick_cnt],q1); - VCOPY(Pick_v2[Pick_cnt],q2); - Pick_cnt++; -#endif - /* trace the ray starting with this node */ - nbr = qtVisit_tri_edges(qtptr,b[w],db,wptr,1.0,func,arg1,arg2); + else + /* Just starting: b[0] is the origin point: guaranteed to be valid b*/ + { + w = 0; + intersect_vector_plane(tri[0],n,pd,&(et[0]),v[0]); + bary2d(q0[x],q0[y],q1[x],q1[y],q2[x],q2[y],v[0][x],v[0][y],b[0]); + VCOPY(b[3],b[0]); + } + + + j = (w+1)%3; + intersect_vector_plane(tri[j],n,pd,&(et[j]),v[j]); + bary2d(q0[x],q0[y],q1[x],q1[y],q2[x],q2[y],v[j][x],v[j][y],b[j]); + if(et[j] < 0.0) + { + VSUB(db[w],b[3],b[j]); + t[w] = FHUGE; + } + else + { + /* NOTE: for stability: do not increment with ipt- use full dir and + calculate t: but for wrap around case: could get same problem? + */ + VSUB(db[w],b[j],b[3]); + t[w] = 1.0; + move_to_nbr(b[3],db[w][0],db[w][1],db[w][2],&exit_pt); + if(exit_pt >= 1.0) + { + for(;j < 3;j++) + { + i = (j+1)%3; + if(i!= w) + { + intersect_vector_plane(tri[i],n,pd,&(et[i]),v[i]); + bary2d(q0[x],q0[y],q1[x],q1[y],q2[x],q2[y],v[i][x], + v[i][y],b[i]); + } + if(et[i] < 0.0) + { + VSUB(db[j],b[j],b[i]); + t[j] = FHUGE; + break; + } + else + { + VSUB(db[j],b[i],b[j]); + t[j] = 1.0; + } + move_to_nbr(b[j],db[j][0],db[j][1],db[j][2],&exit_pt); + if(exit_pt < 1.0) + break; + } + } + } + *wptr = w; + /* trace the ray starting with this node */ + nbr = qtVisit_tri_edges(qtptr,b[3],db[w][0],db[w][1],db[w][2], + db,wptr,t,0,1.0,func,arg1,arg2,arg3); + if(nbr != INVALID && nbr != QT_DONE) + { + i_pt[x] = b[3][0]*q0[x] + b[3][1]*q1[x] + b[3][2]*q2[x]; + i_pt[y] = b[3][0]*q0[y] + b[3][1]*q1[y] + b[3][2]*q2[y]; + i_pt[z] = (-n[x]*i_pt[x] - n[y]*i_pt[y] -pd)/n[z]; + } return(nbr); } - - - +int +move_to_nbri(b,db0,db1,db2,tptr) +BCOORD b[3]; +BDIR db0,db1,db2; +TINT *tptr; +{ + TINT t,dt; + BCOORD bc; + int nbr; + + nbr = -1; + /* Advance to next node */ + if(db0 < 0) + { + bc = MAXBCOORD*b[0]; + t = bc/-db0; + nbr = 0; + } + else + t = HUGET; + if(db1 < 0) + { + bc = MAXBCOORD*b[1]; + dt = bc/-db1; + if( dt < t) + { + t = dt; + nbr = 1; + } + } + if(db2 < 0) + { + bc = MAXBCOORD*b[2]; + dt = bc/-db2; + if( dt < t) + { + t = dt; + nbr = 2; + } + } + *tptr = t; + return(nbr); +} /* NOTE: SINCE DIR could be unit: then we could use integer math */ int -qtVisit_tri_edges2(qtptr,b,db0,db1,db2, - db,wptr,t,sign,sfactor,func,arg1,arg2) +qtVisit_tri_edgesi(qtptr,b,db0,db1,db2, + db,wptr,t,sign,sfactor,func,arg1,arg2,arg3) QUADTREE *qtptr; - double b[3],db0,db1,db2,db[3][3]; + BCOORD b[3]; + BDIR db0,db1,db2,db[3][3]; int *wptr; - double t[3]; + TINT t[3]; int sign; - double sfactor; + int sfactor; int (*func)(); - int *arg1,arg2; + int *arg1,arg2,*arg3; { int i,found; QUADTREE *child; int nbr,next,w; - double t_l,t_g; + TINT t_g,t_l,t_i; #ifdef DEBUG_TEST_DRIVER FVECT a1,b1,c1; int Pick_parent = Pick_cnt-1; @@ -1094,7 +1023,7 @@ qtVisit_tri_edges2(qtptr,b,db0,db1,db2, if(QT_IS_TREE(*qtptr)) { /* Find the appropriate child and reset the coord */ - i = bary_child(b); + i = baryi_child(b); QT_SET_FLAG(*qtptr); @@ -1104,14 +1033,14 @@ qtVisit_tri_edges2(qtptr,b,db0,db1,db2, child = QT_NTH_CHILD_PTR(*qtptr,i); if(i != 3) - nbr = qtVisit_tri_edges2(child,b,db0,db1,db2, + nbr = qtVisit_tri_edgesi(child,b,db0,db1,db2, db,wptr,t,sign, - sfactor*2.0,func,arg1,arg2); + sfactor+1,func,arg1,arg2,arg3); else /* If the center cell- must flip direction signs */ - nbr = qtVisit_tri_edges2(child,b,-db0,-db1,-db2, + nbr = qtVisit_tri_edgesi(child,b,-db0,-db1,-db2, db,wptr,t,1-sign, - sfactor*2.0,func,arg1,arg2); + sfactor+1,func,arg1,arg2,arg3); if(nbr == QT_DONE) return(nbr); @@ -1120,7 +1049,7 @@ qtVisit_tri_edges2(qtptr,b,db0,db1,db2, w = *wptr; db0 = db[w][0];db1 = db[w][1];db2 = db[w][2]; if(sign) - { db0 *= -1.0;db1 *= -1.0; db2 *= -1.0;} + { db0 *= -1;db1 *= -1; db2 *= -1;} } /* If in same block: traverse */ if(i==3) @@ -1131,11 +1060,11 @@ qtVisit_tri_edges2(qtptr,b,db0,db1,db2, else { /* reset the barycentric coordinates in the parents*/ - bary_parent(b,i); + baryi_parent(b,i); /* Else pop up to parent and traverse from there */ return(nbr); } - bary_from_child(b,i,next); + baryi_from_child(b,i,next); i = next; } } @@ -1148,41 +1077,45 @@ qtVisit_tri_edges2(qtptr,b,db0,db1,db2, Pick_cnt++; #endif - if(func(qtptr,arg1,arg2) == QT_DONE) + if(func(qtptr,arg1,arg2,arg3) == QT_DONE) return(QT_DONE); /* Advance to next node */ w = *wptr; while(1) { - nbr = move_to_nbr(b,db0,db1,db2,&t_l); + nbr = move_to_nbri(b,db0,db1,db2,&t_i); - t_g = t_l/sfactor; -#ifdef DEBUG - if(t[w] <= 0.0) - eputs("qtVisit_tri_edges2():negative t\n"); -#endif + t_g = t_i >> sfactor; + if(t_g >= t[w]) { if(w == 2) return(QT_DONE); - b[0] += (t[w])*sfactor*db0; - b[1] += (t[w])*sfactor*db1; - b[2] += (t[w])*sfactor*db2; + /* The edge fits in the cell- therefore the result of shifting db by + sfactor is guaranteed to be less than MAXBCOORD + */ + /* Caution: (t[w]*db) must occur before divide by MAXBCOORD + since t[w] will always be < MAXBCOORD + */ + b[0] = b[0] + (t[w]*db0*(1 << sfactor))/MAXBCOORD; + b[1] = b[1] + (t[w]*db1*(1 << sfactor))/MAXBCOORD; + b[2] = b[2] + (t[w]*db2*(1 << sfactor))/MAXBCOORD; w++; - db0 = db[w][0]; - db1 = db[w][1]; - db2 = db[w][2]; + db0 = db[w][0]; db1 = db[w][1]; db2 = db[w][2]; if(sign) - { db0 *= -1.0;db1 *= -1.0; db2 *= -1.0;} + { db0 *= -1;db1 *= -1; db2 *= -1;} } else if(nbr != INVALID) { - b[0] += t_l * db0; - b[1] += t_l * db1; - b[2] += t_l * db2; + /* Caution: (t_i*db) must occur before divide by MAXBCOORD + since t_i will always be < MAXBCOORD + */ + b[0] = b[0] + (t_i *db0) / MAXBCOORD; + b[1] = b[1] + (t_i *db1) / MAXBCOORD; + b[2] = b[2] + (t_i *db2) / MAXBCOORD; t[w] -= t_g; *wptr = w; @@ -1191,33 +1124,35 @@ qtVisit_tri_edges2(qtptr,b,db0,db1,db2, else return(INVALID); } - } - + } } int -qtRoot_visit_tri_edges2(qtptr,q0,q1,q2,tri,i_pt,wptr,func,arg1,arg2) +qtRoot_visit_tri_edgesi(qtptr,q0,q1,q2,tri,i_pt,wptr,func,arg1,arg2,arg3) QUADTREE *qtptr; FVECT q0,q1,q2; FVECT tri[3],i_pt; int *wptr; int (*func)(); - int *arg1,arg2; + int *arg1,arg2,*arg3; { int x,y,z,nbr,w,i,j; QUADTREE *child; FVECT n,c,d,v[3]; - double pd,b[4][3],db[3][3],et[3],t[3],exit_pt; - + double pd,b[4][3],db[3][3],et[3],exit_pt; + BCOORD bi[3]; + TINT t[3]; + BDIR dbi[3][3]; w = *wptr; /* Project the origin onto the root node plane */ + t[0] = t[1] = t[2] = 0; /* Find the intersection point of the origin */ tri_plane_equation(q0,q1,q2,n,&pd,FALSE); /* map to 2d by dropping maximum magnitude component of normal */ - z = max_index(n); + z = max_index(n,NULL); x = (z+1)%3; y = (z+2)%3; /* Calculate barycentric coordinates for current vertex */ @@ -1243,7 +1178,7 @@ qtRoot_visit_tri_edges2(qtptr,q0,q1,q2,tri,i_pt,wptr,f if(et[j] < 0.0) { VSUB(db[w],b[3],b[j]); - t[w] = FHUGE; + t[w] = HUGET; } else { @@ -1251,51 +1186,66 @@ qtRoot_visit_tri_edges2(qtptr,q0,q1,q2,tri,i_pt,wptr,f calculate t: but for wrap around case: could get same problem? */ VSUB(db[w],b[j],b[3]); - t[w] = 1.0; - move_to_nbr(b[3],db[w][0],db[w][1],db[w][2],&exit_pt); - if(exit_pt >= 1.0) + /* Check if the point is out side of the triangle: if so t[w] =HUGET */ + if((fabs(b[j][0])>(FTINY+1.0)) ||(fabs(b[j][1])>(FTINY+1.0)) || + (fabs(b[j][2])>(FTINY+1.0))) + t[w] = HUGET; + else { - for(;j < 3;j++) - { - i = (j+1)%3; - if(i!= w) - { - intersect_vector_plane(tri[i],n,pd,&(et[i]),v[i]); - bary2d(q0[x],q0[y],q1[x],q1[y],q2[x],q2[y],v[i][x], - v[i][y],b[i]); - } - if(et[i] < 0.0) + /* The next point is in the triangle- so db values will be in valid + range and t[w]= MAXT + */ + t[w] = MAXT; + if(j != 0) + for(;j < 3;j++) { - VSUB(db[j],b[j],b[i]); - t[j] = FHUGE; - break; + i = (j+1)%3; + if(i!= w) + { + intersect_vector_plane(tri[i],n,pd,&(et[i]),v[i]); + bary2d(q0[x],q0[y],q1[x],q1[y],q2[x],q2[y],v[i][x], + v[i][y],b[i]); + } + if(et[i] < 0.0) + { + VSUB(db[j],b[j],b[i]); + t[j] = HUGET; + break; + } + else + { + VSUB(db[j],b[i],b[j]); + if((fabs(b[j][0])>(FTINY+1.0)) || + (fabs(b[j][1])>(FTINY+1.0)) || + (fabs(b[j][2])>(FTINY+1.0))) + { + t[j] = HUGET; + break; + } + else + t[j] = MAXT; + } } - else - { - VSUB(db[j],b[i],b[j]); - t[j] = 1.0; - } - move_to_nbr(b[j],db[j][0],db[j][1],db[j][2],&exit_pt); - if(exit_pt < 1.0) - break; - } } - } +} *wptr = w; + bary_dtol(b[3],db,bi,dbi,t); + /* trace the ray starting with this node */ - nbr = qtVisit_tri_edges2(qtptr,b[3],db[w][0],db[w][1],db[w][2], - db,wptr,t,0,1.0,func,arg1,arg2); + nbr = qtVisit_tri_edgesi(qtptr,bi,dbi[w][0],dbi[w][1],dbi[w][2], + dbi,wptr,t,0,0,func,arg1,arg2,arg3); if(nbr != INVALID && nbr != QT_DONE) { - i_pt[x] = b[3][0]*q0[x] + b[3][1]*q1[x] + b[3][2]*q2[x]; - i_pt[y] = b[3][0]*q0[y] + b[3][1]*q1[y] + b[3][2]*q2[y]; - i_pt[z] = (-n[x]*i_pt[x] - n[y]*i_pt[y] -pd)/n[z]; + b[3][0] = (double)bi[0]/(double)MAXBCOORD; + b[3][1] = (double)bi[1]/(double)MAXBCOORD; + b[3][2] = (double)bi[2]/(double)MAXBCOORD; + i_pt[x] = b[3][0]*q0[x] + b[3][1]*q1[x] + b[3][2]*q2[x]; + i_pt[y] = b[3][0]*q0[y] + b[3][1]*q1[y] + b[3][2]*q2[y]; + i_pt[z] = (-n[x]*i_pt[x] - n[y]*i_pt[y] -pd)/n[z]; } return(nbr); } - -
