--- ray/src/hd/sm_qtree.c 1999/01/10 10:27:45 3.11 +++ ray/src/hd/sm_qtree.c 1999/03/05 16:32:49 3.12 @@ -744,7 +744,7 @@ FUNC f; */ qtVisit_tri(root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02,scale, - s0,s1,s2,sq0,sq1,sq2,f) + s0,s1,s2,sq0,sq1,sq2,f,n) int root; QUADTREE qt; BCOORD q0[3],q1[3],q2[3]; @@ -753,11 +753,14 @@ BCOORD dt10[3],dt21[3],dt02[3]; BCOORD scale; unsigned int s0,s1,s2,sq0,sq1,sq2; FUNC f; +int n; { BCOORD a,b,c; BCOORD va[3],vb[3],vc[3]; unsigned int sa,sb,sc; + if(n == 0) + return; /* If a tree: trivial reject and recurse on potential children */ if(QT_IS_TREE(qt)) { @@ -780,7 +783,7 @@ FUNC f; vb[2] = c; vb[0] = vc[0] = a; qtVisit_tri(root,QT_NTH_CHILD(qt,0),q0,vc, - vb,t0,t1,t2,dt10,dt21,dt02, scale>>1,sa,s1,s2,sq0,sb,sc,f); + vb,t0,t1,t2,dt10,dt21,dt02, scale>>1,sa,s1,s2,sq0,sb,sc,f,n-1); return; } if(sb==7) @@ -791,7 +794,7 @@ FUNC f; va[2] = c; vc[0] = a; qtVisit_tri(root,QT_NTH_CHILD(qt,1),vc,q1,va, - t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,sb,s2,sa,sq1,sc,f); + t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,sb,s2,sa,sq1,sc,f,n-1); return; } if(sc==7) @@ -802,7 +805,7 @@ FUNC f; va[2] = vb[2] = c; vb[0] = a; qtVisit_tri(root,QT_NTH_CHILD(qt,2),vb,va, - q2,t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,s1,sc,sa,sb,sq2,f); + q2,t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,s1,sc,sa,sb,sq2,f,n-1); return; } @@ -816,32 +819,32 @@ FUNC f; if(sa==0 && sb==0 && sc==0) { qtVisit_tri_rev(root,QT_NTH_CHILD(qt,3),va,vb, - vc,t0,t1,t2,dt10,dt21,dt02, scale>>1,sa,sb,sc,s0,s1,s2,f); + vc,t0,t1,t2,dt10,dt21,dt02, scale>>1,sa,sb,sc,s0,s1,s2,f,n-1); return; } if(sa) qtVisit_tri(root,QT_NTH_CHILD(qt,0),q0,vc,vb,t0, - t1,t2,dt10,dt21,dt02,scale>>1,sa,s1,s2,sq0,sb,sc,f); + t1,t2,dt10,dt21,dt02,scale>>1,sa,s1,s2,sq0,sb,sc,f,n-1); if(sb) qtVisit_tri(root,QT_NTH_CHILD(qt,1),vc,q1,va,t0, - t1,t2,dt10,dt21,dt02,scale>>1,s0,sb,s2,sa,sq1,sc,f); + t1,t2,dt10,dt21,dt02,scale>>1,s0,sb,s2,sa,sq1,sc,f,n-1); if(sc) qtVisit_tri(root,QT_NTH_CHILD(qt,2),vb,va,q2,t0, - t1,t2,dt10,dt21,dt02,scale>>1,s0,s1,sc,sa,sb,sq2,f); + t1,t2,dt10,dt21,dt02,scale>>1,s0,s1,sc,sa,sb,sq2,f,n-1); qtVisit_tri_rev(root,QT_NTH_CHILD(qt,3),va,vb,vc,t0, - t1,t2,dt10,dt21,dt02,scale>>1,sa,sb,sc,s0,s1,s2,f); + t1,t2,dt10,dt21,dt02,scale>>1,sa,sb,sc,s0,s1,s2,f,n-1); } /* Leaf node: Do definitive test */ else qtLeaf_visit_tri(root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02, - scale,s0,s1,s2,sq0,sq1,sq2,f); + scale,s0,s1,s2,sq0,sq1,sq2,f,n); } qtVisit_tri_rev(root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02,scale, - s0,s1,s2,sq0,sq1,sq2,f) + s0,s1,s2,sq0,sq1,sq2,f,n) int root; QUADTREE qt; BCOORD q0[3],q1[3],q2[3]; @@ -850,11 +853,14 @@ BCOORD dt10[3],dt21[3],dt02[3]; BCOORD scale; unsigned int s0,s1,s2,sq0,sq1,sq2; FUNC f; +int n; { BCOORD a,b,c; BCOORD va[3],vb[3],vc[3]; unsigned int sa,sb,sc; + if(n==0) + return; /* If a tree: trivial reject and recurse on potential children */ if(QT_IS_TREE(qt)) { @@ -876,7 +882,7 @@ FUNC f; vb[2] = c; vb[0] = vc[0] = a; qtVisit_tri_rev(root,QT_NTH_CHILD(qt,0),q0,vc, - vb,t0,t1,t2,dt10,dt21,dt02, scale>>1,sa,s1,s2,sq0,sb,sc,f); + vb,t0,t1,t2,dt10,dt21,dt02, scale>>1,sa,s1,s2,sq0,sb,sc,f,n-1); return; } if(sb==0) @@ -887,7 +893,7 @@ FUNC f; va[2] = c; vc[0] = a; qtVisit_tri_rev(root,QT_NTH_CHILD(qt,1),vc,q1,va, - t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,sb,s2,sa,sq1,sc,f); + t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,sb,s2,sa,sq1,sc,f,n-1); return; } if(sc==0) @@ -898,7 +904,7 @@ FUNC f; va[2] = vb[2] = c; vb[0] = a; qtVisit_tri_rev(root,QT_NTH_CHILD(qt,2),vb,va, - q2,t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,s1,sc,sa,sb,sq2,f); + q2,t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,s1,sc,sa,sb,sq2,f,n-1); return; } va[0] = q1[0]; @@ -911,33 +917,33 @@ FUNC f; if(sa==7 && sb==7 && sc==7) { qtVisit_tri(root,QT_NTH_CHILD(qt,3),va,vb, - vc,t0,t1,t2,dt10,dt21,dt02, scale>>1,sa,sb,sc,s0,s1,s2,f); + vc,t0,t1,t2,dt10,dt21,dt02, scale>>1,sa,sb,sc,s0,s1,s2,f,n-1); return; } if(sa!=7) qtVisit_tri_rev(root,QT_NTH_CHILD(qt,0),q0,vc,vb, - t0,t1,t2,dt10,dt21,dt02,scale>>1,sa,s1,s2,sq0,sb,sc,f); + t0,t1,t2,dt10,dt21,dt02,scale>>1,sa,s1,s2,sq0,sb,sc,f,n-1); if(sb!=7) qtVisit_tri_rev(root,QT_NTH_CHILD(qt,1),vc,q1,va, - t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,sb,s2,sa,sq1,sc,f); + t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,sb,s2,sa,sq1,sc,f,n-1); if(sc!=7) qtVisit_tri_rev(root,QT_NTH_CHILD(qt,2),vb,va,q2, - t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,s1,sc,sa,sb,sq2,f); + t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,s1,sc,sa,sb,sq2,f,n-1); qtVisit_tri(root,QT_NTH_CHILD(qt,3),va,vb,vc,t0,t1, - t2,dt10,dt21,dt02,scale>>1,sa,sb,sc,s0,s1,s2,f); + t2,dt10,dt21,dt02,scale>>1,sa,sb,sc,s0,s1,s2,f,n-1); return; } /* Leaf node: Do definitive test */ else qtLeaf_visit_tri_rev(root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02, - scale,s0,s1,s2,sq0,sq1,sq2,f); + scale,s0,s1,s2,sq0,sq1,sq2,f,n); } qtLeaf_visit_tri(root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02, - scale, s0,s1,s2,sq0,sq1,sq2,f) + scale, s0,s1,s2,sq0,sq1,sq2,f,n) int root; QUADTREE qt; BCOORD q0[3],q1[3],q2[3]; @@ -945,13 +951,14 @@ BCOORD t0[3],t1[3],t2[3]; BCOORD dt10[3],dt21[3],dt02[3]; unsigned int scale,s0,s1,s2,sq0,sq1,sq2; FUNC f; +int n; { double db; unsigned int e0,e1,e2; char al,ah,bl,bh,cl,ch,testl,testh; char test_t0t1,test_t1t2,test_t2t0; BCOORD a,b,c; - + /* First check if can trivial accept: if vertex in cell */ if(s0 & s1 & s2) goto Lfunc_call; @@ -1055,9 +1062,11 @@ FUNC f; return; Lfunc_call: - f.func(f.argptr,root,qt); + + f.func(f.argptr,root,qt,n); if(!QT_IS_EMPTY(qt)) QT_LEAF_SET_FLAG(qt); + } @@ -1065,7 +1074,7 @@ Lfunc_call: /* Leaf node: Do definitive test */ QUADTREE qtLeaf_visit_tri_rev(root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02, - scale, s0,s1,s2,sq0,sq1,sq2,f) + scale, s0,s1,s2,sq0,sq1,sq2,f,n) int root; QUADTREE qt; BCOORD q0[3],q1[3],q2[3]; @@ -1073,6 +1082,7 @@ BCOORD t0[3],t1[3],t2[3]; BCOORD dt10[3],dt21[3],dt02[3]; unsigned int scale,s0,s1,s2,sq0,sq1,sq2; FUNC f; +int n; { double db; unsigned int e0,e1,e2; @@ -1191,7 +1201,7 @@ FUNC f; return; Lfunc_call: - f.func(f.argptr,root,qt); + f.func(f.argptr,root,qt,n); if(!QT_IS_EMPTY(qt)) QT_LEAF_SET_FLAG(qt); }
