root/radiance/ray/src/hd/sm_qtree.c
Revision: 3.6
Committed: Wed Sep 16 18:16:29 1998 UTC (26 years, 8 months ago) by gwlarson
Changes since 3.5: +273 -323 lines
implemented integer triangle tracing
1 /* Copyright (c) 1998 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * sm_qtree.c: adapted from octree.c from radiance code
9 */
10 /*
11 * octree.c - routines dealing with octrees and cubes.
12 *
13 * 7/28/85
14 */
15
16 #include "standard.h"
17
18 #include "sm_geom.h"
19 #include "sm_qtree.h"
20
21 QUADTREE *quad_block[QT_MAX_BLK]; /* our quadtree */
22 static QUADTREE quad_free_list = EMPTY; /* freed octree nodes */
23 static QUADTREE treetop = 0; /* next free node */
24 int4 *quad_flag= NULL;
25
26 #ifdef TEST_DRIVER
27 extern FVECT Pick_v0[500],Pick_v1[500],Pick_v2[500];
28 extern int Pick_cnt,Pick_tri,Pick_samp;
29 extern FVECT Pick_point[500];
30 #endif
31
32 QUADTREE
33 qtAlloc() /* allocate a quadtree */
34 {
35 register QUADTREE freet;
36
37 if ((freet = quad_free_list) != EMPTY)
38 {
39 quad_free_list = QT_NTH_CHILD(freet, 0);
40 return(freet);
41 }
42 freet = treetop;
43 if (QT_BLOCK_INDEX(freet) == 0)
44 {
45 if (QT_BLOCK(freet) >= QT_MAX_BLK)
46 return(EMPTY);
47 if ((quad_block[QT_BLOCK(freet)] = (QUADTREE *)malloc(
48 QT_BLOCK_SIZE*4*sizeof(QUADTREE))) == NULL)
49 return(EMPTY);
50
51 quad_flag = (int4 *)realloc((char *)quad_flag,
52 (QT_BLOCK(freet)+1)*(QT_BLOCK_SIZE/8));
53 if (quad_flag == NULL)
54 return(EMPTY);
55 }
56 treetop += 4;
57 return(freet);
58 }
59
60
61 qtClearAllFlags() /* clear all quadtree branch flags */
62 {
63 if (!treetop) return;
64 bzero((char *)quad_flag, (QT_BLOCK(treetop-4)+1)*(QT_BLOCK_SIZE/8));
65 }
66
67
68 qtFree(qt) /* free a quadtree */
69 register QUADTREE qt;
70 {
71 register int i;
72
73 if (!QT_IS_TREE(qt))
74 {
75 qtfreeleaf(qt);
76 return;
77 }
78 for (i = 0; i < 4; i++)
79 qtFree(QT_NTH_CHILD(qt, i));
80 QT_NTH_CHILD(qt, 0) = quad_free_list;
81 quad_free_list = qt;
82 }
83
84
85 qtDone() /* free EVERYTHING */
86 {
87 register int i;
88
89 qtfreeleaves();
90 for (i = 0; i < QT_MAX_BLK; i++)
91 {
92 if (quad_block[i] == NULL)
93 break;
94 free((char *)quad_block[i]);
95 quad_block[i] = NULL;
96 }
97 if (i) free((char *)quad_flag);
98 quad_flag = NULL;
99 quad_free_list = EMPTY;
100 treetop = 0;
101 }
102
103 QUADTREE
104 *qtLocate_leaf(qtptr,bcoord,t0,t1,t2)
105 QUADTREE *qtptr;
106 double bcoord[3];
107 FVECT t0,t1,t2;
108 {
109 int i;
110 QUADTREE *child;
111 FVECT a,b,c;
112
113 if(QT_IS_TREE(*qtptr))
114 {
115 i = bary_child(bcoord);
116 #ifdef DEBUG_TEST_DRIVER
117 qtSubdivide_tri(Pick_v0[Pick_cnt-1],Pick_v1[Pick_cnt-1],
118 Pick_v2[Pick_cnt-1],a,b,c);
119 qtNth_child_tri(Pick_v0[Pick_cnt-1],Pick_v1[Pick_cnt-1],
120 Pick_v2[Pick_cnt-1],a,b,c,i,
121 Pick_v0[Pick_cnt],Pick_v1[Pick_cnt],
122 Pick_v2[Pick_cnt]);
123 Pick_cnt++;
124 #endif
125
126 child = QT_NTH_CHILD_PTR(*qtptr,i);
127 if(t0)
128 {
129 qtSubdivide_tri(t0,t1,t2,a,b,c);
130 qtNth_child_tri(t0,t1,t2,a,b,c,i,t0,t1,t2);
131 }
132 return(qtLocate_leaf(child,bcoord,t0,t1,t2));
133 }
134 else
135 return(qtptr);
136 }
137
138
139 QUADTREE
140 *qtRoot_point_locate(qtptr,v0,v1,v2,pt,t0,t1,t2)
141 QUADTREE *qtptr;
142 FVECT v0,v1,v2;
143 FVECT pt;
144 FVECT t0,t1,t2;
145 {
146 int d;
147 int i,x,y;
148 QUADTREE *child;
149 FVECT n,i_pt,a,b,c;
150 double pd,bcoord[3];
151
152 /* Determine if point lies within pyramid (and therefore
153 inside a spherical quadtree cell):GT_INTERIOR, on one of the
154 pyramid sides (and on cell edge):GT_EDGE(1,2 or 3),
155 or on pyramid vertex (and on cell vertex):GT_VERTEX(1,2, or 3).
156 For each triangle edge: compare the
157 point against the plane formed by the edge and the view center
158 */
159 d = point_in_stri(v0,v1,v2,pt);
160
161
162 /* Not in this triangle */
163 if(!d)
164 return(NULL);
165
166 /* Will return lowest level triangle containing point: It the
167 point is on an edge or vertex: will return first associated
168 triangle encountered in the child traversal- the others can
169 be derived using triangle adjacency information
170 */
171 if(QT_IS_TREE(*qtptr))
172 {
173 /* Find the intersection point */
174 tri_plane_equation(v0,v1,v2,n,&pd,FALSE);
175 intersect_vector_plane(pt,n,pd,NULL,i_pt);
176
177 i = max_index(n,NULL);
178 x = (i+1)%3;
179 y = (i+2)%3;
180 /* Calculate barycentric coordinates of i_pt */
181 bary2d(v0[x],v0[y],v1[x],v1[y],v2[x],v2[y],i_pt[x],i_pt[y],bcoord);
182
183 i = bary_child(bcoord);
184 child = QT_NTH_CHILD_PTR(*qtptr,i);
185 #ifdef DEBUG_TEST_DRIVER
186 Pick_cnt = 0;
187 VCOPY(Pick_v0[0],v0);
188 VCOPY(Pick_v1[0],v1);
189 VCOPY(Pick_v2[0],v2);
190 Pick_cnt++;
191 qtSubdivide_tri(Pick_v0[Pick_cnt-1],Pick_v1[Pick_cnt-1],
192 Pick_v2[Pick_cnt-1],a,b,c);
193 qtNth_child_tri(Pick_v0[Pick_cnt-1],Pick_v1[Pick_cnt-1],
194 Pick_v2[Pick_cnt-1],a,b,c,i,
195 Pick_v0[Pick_cnt],Pick_v1[Pick_cnt],
196 Pick_v2[Pick_cnt]);
197 Pick_cnt++;
198 #endif
199 if(t0)
200 {
201 qtSubdivide_tri(v0,v1,v2,a,b,c);
202 qtNth_child_tri(v0,v1,v2,a,b,c,i,t0,t1,t2);
203 }
204 return(qtLocate_leaf(child,bcoord,t0,t1,t2));
205 }
206 else
207 {
208 if(t0)
209 {
210 VCOPY(t0,v0);
211 VCOPY(t1,v1);
212 VCOPY(t2,v2);
213 }
214 return(qtptr);
215 }
216 }
217
218
219 QUADTREE
220 qtSubdivide(qtptr)
221 QUADTREE *qtptr;
222 {
223 QUADTREE node;
224 node = qtAlloc();
225 QT_CLEAR_CHILDREN(node);
226 *qtptr = node;
227 return(node);
228 }
229
230
231 QUADTREE
232 qtSubdivide_nth_child(qt,n)
233 QUADTREE qt;
234 int n;
235 {
236 QUADTREE node;
237
238 node = qtSubdivide(&(QT_NTH_CHILD(qt,n)));
239
240 return(node);
241 }
242
243 /* for triangle v0-v1-v2- returns a,b,c: children are:
244
245 v2 0: v0,a,c
246 /\ 1: a,v1,b
247 /2 \ 2: c,b,v2
248 c/____\b 3: b,c,a
249 /\ /\
250 /0 \3 /1 \
251 v0____\/____\v1
252 a
253 */
254
255 qtSubdivide_tri(v0,v1,v2,a,b,c)
256 FVECT v0,v1,v2;
257 FVECT a,b,c;
258 {
259 EDGE_MIDPOINT_VEC3(a,v0,v1);
260 EDGE_MIDPOINT_VEC3(b,v1,v2);
261 EDGE_MIDPOINT_VEC3(c,v2,v0);
262 }
263
264 qtNth_child_tri(v0,v1,v2,a,b,c,i,r0,r1,r2)
265 FVECT v0,v1,v2;
266 FVECT a,b,c;
267 int i;
268 FVECT r0,r1,r2;
269 {
270
271 switch(i){
272 case 0:
273 VCOPY(r0,v0); VCOPY(r1,a); VCOPY(r2,c);
274 break;
275 case 1:
276 VCOPY(r0,a); VCOPY(r1,v1); VCOPY(r2,b);
277 break;
278 case 2:
279 VCOPY(r0,c); VCOPY(r1,b); VCOPY(r2,v2);
280 break;
281 case 3:
282 VCOPY(r0,b); VCOPY(r1,c); VCOPY(r2,a);
283 break;
284 }
285 }
286
287 /* Add triangle "id" to all leaf level cells that are children of
288 quadtree pointed to by "qtptr" with cell vertices "t1,t2,t3"
289 that it overlaps (vertex and edge adjacencies do not count
290 as overlapping). If the addition of the triangle causes the cell to go over
291 threshold- the cell is split- and the triangle must be recursively inserted
292 into the new child cells: it is assumed that "v1,v2,v3" are normalized
293 */
294
295 int
296 qtRoot_add_tri(qtptr,q0,q1,q2,t0,t1,t2,id,n)
297 QUADTREE *qtptr;
298 FVECT q0,q1,q2;
299 FVECT t0,t1,t2;
300 int id;
301 int n;
302 {
303 int test;
304 int found;
305
306 test = stri_intersect(q0,q1,q2,t0,t1,t2);
307 if(!test)
308 return(FALSE);
309
310 found = qtAdd_tri(qtptr,q0,q1,q2,t0,t1,t2,id,n);
311
312 return(found);
313 }
314
315 int
316 qtAdd_tri(qtptr,q0,q1,q2,t0,t1,t2,id,n)
317 QUADTREE *qtptr;
318 FVECT q0,q1,q2;
319 FVECT t0,t1,t2;
320 int id;
321 int n;
322 {
323 int i,index,test,found;
324 FVECT a,b,c;
325 OBJECT os[QT_MAXSET+1],*optr;
326 QUADTREE qt;
327 FVECT r0,r1,r2;
328
329 found = 0;
330 /* if this is tree: recurse */
331 if(QT_IS_TREE(*qtptr))
332 {
333 n++;
334 qtSubdivide_tri(q0,q1,q2,a,b,c);
335 test = stri_intersect(t0,t1,t2,q0,a,c);
336 if(test)
337 found |= qtAdd_tri(QT_NTH_CHILD_PTR(*qtptr,0),q0,a,c,t0,t1,t2,id,n);
338 test = stri_intersect(t0,t1,t2,a,q1,b);
339 if(test)
340 found |= qtAdd_tri(QT_NTH_CHILD_PTR(*qtptr,1),a,q1,b,t0,t1,t2,id,n);
341 test = stri_intersect(t0,t1,t2,c,b,q2);
342 if(test)
343 found |= qtAdd_tri(QT_NTH_CHILD_PTR(*qtptr,2),c,b,q2,t0,t1,t2,id,n);
344 test = stri_intersect(t0,t1,t2,b,c,a);
345 if(test)
346 found |= qtAdd_tri(QT_NTH_CHILD_PTR(*qtptr,3),b,c,a,t0,t1,t2,id,n);
347 }
348 else
349 {
350 /* If this leave node emptry- create a new set */
351 if(QT_IS_EMPTY(*qtptr))
352 *qtptr = qtaddelem(*qtptr,id);
353 else
354 {
355 /* If the set is too large: subdivide */
356 optr = qtqueryset(*qtptr);
357
358 if(QT_SET_CNT(optr) < QT_SET_THRESHOLD)
359 *qtptr = qtaddelem(*qtptr,id);
360 else
361 {
362 if (n < QT_MAX_LEVELS)
363 {
364 /* If set size exceeds threshold: subdivide cell and
365 reinsert set tris into cell
366 */
367 qtgetset(os,*qtptr);
368
369 n++;
370 qtfreeleaf(*qtptr);
371 qtSubdivide(qtptr);
372 found = qtAdd_tri(qtptr,q0,q1,q2,t0,t1,t2,id,n);
373
374 for(optr = QT_SET_PTR(os),i = QT_SET_CNT(os); i > 0; i--)
375 {
376 id = QT_SET_NEXT_ELEM(optr);
377 qtTri_from_id(id,r0,r1,r2,NULL,NULL,NULL,NULL,NULL,NULL);
378 found=qtAdd_tri(qtptr,q0,q1,q2,r0,r1,r2,id,n);
379 #ifdef DEBUG
380 if(!found)
381 eputs("qtAdd_tri():Reinsert-in parent but not children\n");
382 #endif
383 }
384 }
385 else
386 if(QT_SET_CNT(optr) < QT_MAXSET)
387 *qtptr = qtaddelem(*qtptr,id);
388 else
389 {
390 #ifdef DEBUG
391 eputs("qtAdd_tri():two many levels\n");
392 #endif
393 return(FALSE);
394 }
395 }
396 }
397 }
398 return(TRUE);
399 }
400
401
402 int
403 qtApply_to_tri_cells(qtptr,t0,t1,t2,v0,v1,v2,func,arg)
404 QUADTREE *qtptr;
405 FVECT t0,t1,t2;
406 FVECT v0,v1,v2;
407 int (*func)();
408 int *arg;
409 {
410 int test;
411 FVECT a,b,c;
412
413 /* test if triangle (t0,t1,t2) overlaps cell triangle (v0,v1,v2) */
414 test = stri_intersect(t0,t1,t2,v0,v1,v2);
415
416 /* If triangles do not overlap: done */
417 if(!test)
418 return(FALSE);
419
420 /* if this is tree: recurse */
421 func(qtptr,arg);
422
423 if(QT_IS_TREE(*qtptr))
424 {
425 QT_SET_FLAG(*qtptr);
426 qtSubdivide_tri(v0,v1,v2,a,b,c);
427 qtApply_to_tri_cells(QT_NTH_CHILD_PTR(*qtptr,0),t0,t1,t2,v0,a,c,func,arg);
428 qtApply_to_tri_cells(QT_NTH_CHILD_PTR(*qtptr,1),t0,t1,t2,a,v1,b,func,arg);
429 qtApply_to_tri_cells(QT_NTH_CHILD_PTR(*qtptr,2),t0,t1,t2,c,b,v2,func,arg);
430 qtApply_to_tri_cells(QT_NTH_CHILD_PTR(*qtptr,3),t0,t1,t2,b,c,a,func,arg);
431 }
432 }
433
434 int
435 qtRemove_tri(qtptr,id,t0,t1,t2,v0,v1,v2)
436 QUADTREE *qtptr;
437 int id;
438 FVECT t0,t1,t2;
439 FVECT v0,v1,v2;
440 {
441
442 int test;
443 int i;
444 FVECT a,b,c;
445 OBJECT os[QT_MAXSET+1];
446
447 /* test if triangle (t0,t1,t2) overlaps cell triangle (v0,v1,v2) */
448 test = stri_intersect(t0,t1,t2,v0,v1,v2);
449
450 /* If triangles do not overlap: done */
451 if(!test)
452 return(FALSE);
453
454 /* if this is tree: recurse */
455 if(QT_IS_TREE(*qtptr))
456 {
457 qtSubdivide_tri(v0,v1,v2,a,b,c);
458 qtRemove_tri(QT_NTH_CHILD_PTR(*qtptr,0),id,t0,t1,t2,v0,a,c);
459 qtRemove_tri(QT_NTH_CHILD_PTR(*qtptr,1),id,t0,t1,t2,a,v1,b);
460 qtRemove_tri(QT_NTH_CHILD_PTR(*qtptr,2),id,t0,t1,t2,c,b,v2);
461 qtRemove_tri(QT_NTH_CHILD_PTR(*qtptr,3),id,t0,t1,t2,b,c,a);
462 }
463 else
464 {
465 if(QT_IS_EMPTY(*qtptr))
466 {
467 #ifdef DEBUG
468 eputs("qtRemove_tri(): triangle not found\n");
469 #endif
470 }
471 /* remove id from set */
472 else
473 {
474 if(!qtinset(*qtptr,id))
475 {
476 #ifdef DEBUG
477 eputs("qtRemove_tri(): tri not in set\n");
478 #endif
479 }
480 else
481 {
482 *qtptr = qtdelelem(*qtptr,id);
483 }
484 }
485 }
486 return(TRUE);
487 }
488
489
490 int
491 move_to_nbr(b,db0,db1,db2,tptr)
492 double b[3],db0,db1,db2;
493 double *tptr;
494 {
495 double t,dt;
496 int nbr;
497
498 nbr = -1;
499 /* Advance to next node */
500 if(!ZERO(db0) && db0 < 0.0)
501 {
502 t = -b[0]/db0;
503 nbr = 0;
504 }
505 else
506 t = FHUGE;
507 if(!ZERO(db1) && db1 < 0.0 )
508 {
509 dt = -b[1]/db1;
510 if( dt < t)
511 {
512 t = dt;
513 nbr = 1;
514 }
515 }
516 if(!ZERO(db2) && db2 < 0.0 )
517 {
518 dt = -b[2]/db2;
519 if( dt < t)
520 {
521 t = dt;
522 nbr = 2;
523 }
524 }
525 *tptr = t;
526 return(nbr);
527 }
528
529 int
530 qtTrace_ray(qtptr,b,db0,db1,db2,orig,dir,func,arg1,arg2)
531 QUADTREE *qtptr;
532 double b[3],db0,db1,db2;
533 FVECT orig,dir;
534 int (*func)();
535 int *arg1,arg2;
536 {
537
538 int i,found;
539 QUADTREE *child;
540 int nbr,next;
541 double t;
542 #ifdef DEBUG_TEST_DRIVER
543
544 FVECT a1,b1,c1;
545 int Pick_parent = Pick_cnt-1;
546 qtSubdivide_tri(Pick_v0[Pick_parent],Pick_v1[Pick_parent],
547 Pick_v2[Pick_parent],a1,b1,c1);
548
549 #endif
550 if(QT_IS_TREE(*qtptr))
551 {
552 /* Find the appropriate child and reset the coord */
553 i = bary_child(b);
554
555 QT_SET_FLAG(*qtptr);
556
557 for(;;)
558 {
559 child = QT_NTH_CHILD_PTR(*qtptr,i);
560
561 if(i != 3)
562 nbr = qtTrace_ray(child,b,db0,db1,db2,orig,dir,func,arg1,arg2);
563 else
564 /* If the center cell- must flip direction signs */
565 nbr =qtTrace_ray(child,b,-db0,-db1,-db2,orig,dir,func,arg1,arg2);
566 if(nbr == QT_DONE)
567 return(nbr);
568
569 /* If in same block: traverse */
570 if(i==3)
571 next = nbr;
572 else
573 if(nbr == i)
574 next = 3;
575 else
576 {
577 /* reset the barycentric coordinates in the parents*/
578 bary_parent(b,i);
579 /* Else pop up to parent and traverse from there */
580 return(nbr);
581 }
582 bary_from_child(b,i,next);
583 i = next;
584 }
585 }
586 else
587 {
588 #ifdef DEBUG_TEST_DRIVER
589 qtNth_child_tri(Pick_v0[Pick_parent],Pick_v1[Pick_parent],
590 Pick_v2[Pick_parent],a1,b1,c1,i,
591 Pick_v0[Pick_cnt],Pick_v1[Pick_cnt],
592 Pick_v2[Pick_cnt]);
593 Pick_cnt++;
594 #endif
595
596 if(func(qtptr,orig,dir,arg1,arg2) == QT_DONE)
597 return(QT_DONE);
598
599 /* Advance to next node */
600 /* NOTE: Optimize: should only have to check 1/2 */
601 nbr = move_to_nbr(b,db0,db1,db2,&t);
602
603 if(nbr != -1)
604 {
605 b[0] += t * db0;
606 b[1] += t * db1;
607 b[2] += t * db2;
608 }
609 return(nbr);
610 }
611
612 }
613
614 int
615 qtRoot_trace_ray(qtptr,q0,q1,q2,orig,dir,func,arg1,arg2)
616 QUADTREE *qtptr;
617 FVECT q0,q1,q2;
618 FVECT orig,dir;
619 int (*func)();
620 int *arg1,arg2;
621 {
622 int i,x,y,nbr;
623 QUADTREE *child;
624 FVECT n,c,i_pt,d;
625 double pd,b[3],db[3],t;
626 /* Determine if point lies within pyramid (and therefore
627 inside a spherical quadtree cell):GT_INTERIOR, on one of the
628 pyramid sides (and on cell edge):GT_EDGE(1,2 or 3),
629 or on pyramid vertex (and on cell vertex):GT_VERTEX(1,2, or 3).
630 For each triangle edge: compare the
631 point against the plane formed by the edge and the view center
632 */
633 i = point_in_stri(q0,q1,q2,orig);
634
635 /* Not in this triangle */
636 if(!i)
637 return(INVALID);
638 /* Project the origin onto the root node plane */
639
640 /* Find the intersection point of the origin */
641 tri_plane_equation(q0,q1,q2,n,&pd,FALSE);
642 intersect_vector_plane(orig,n,pd,NULL,i_pt);
643 /* project the dir as well */
644 VADD(c,orig,dir);
645 intersect_vector_plane(c,n,pd,&t,c);
646
647 /* map to 2d by dropping maximum magnitude component of normal */
648 i = max_index(n,NULL);
649 x = (i+1)%3;
650 y = (i+2)%3;
651 /* Calculate barycentric coordinates of orig */
652 bary2d(q0[x],q0[y],q1[x],q1[y],q2[x],q2[y],i_pt[x],i_pt[y],b);
653 /* Calculate barycentric coordinates of dir */
654 bary2d(q0[x],q0[y],q1[x],q1[y],q2[x],q2[y],c[x],c[y],db);
655 if(t < 0.0)
656 VSUB(db,b,db);
657 else
658 VSUB(db,db,b);
659
660
661 #ifdef DEBUG_TEST_DRIVER
662 VCOPY(Pick_v0[Pick_cnt],q0);
663 VCOPY(Pick_v1[Pick_cnt],q1);
664 VCOPY(Pick_v2[Pick_cnt],q2);
665 Pick_cnt++;
666 #endif
667
668 /* trace the ray starting with this node */
669 nbr = qtTrace_ray(qtptr,b,db[0],db[1],db[2],orig,dir,func,arg1,arg2);
670 return(nbr);
671
672 }
673
674 qtVisit_tri_interior(qtptr,q0,q1,q2,t0,t1,t2,n,func,arg1,arg2,arg3)
675 QUADTREE *qtptr;
676 FVECT q0,q1,q2;
677 FVECT t0,t1,t2;
678 int n;
679 int (*func)();
680 int *arg1,arg2,*arg3;
681 {
682 int i,found,test;
683 QUADTREE *child;
684 FVECT c0,c1,c2,a,b,c;
685 OBJECT os[QT_MAXSET+1],*optr;
686 int w;
687
688 /* If qt Flag set, or qt vertices interior to t0t1t2-descend */
689 tree_modified:
690
691 if(QT_IS_TREE(*qtptr))
692 {
693 if(QT_IS_FLAG(*qtptr) || point_in_stri(t0,t1,t2,q0))
694 {
695 QT_SET_FLAG(*qtptr);
696 qtSubdivide_tri(q0,q1,q2,a,b,c);
697 /* descend to children */
698 for(i=0;i < 4; i++)
699 {
700 child = QT_NTH_CHILD_PTR(*qtptr,i);
701 qtNth_child_tri(q0,q1,q2,a,b,c,i,c0,c1,c2);
702 qtVisit_tri_interior(child,c0,c1,c2,t0,t1,t2,n+1,
703 func,arg1,arg2,arg3);
704 }
705 }
706 }
707 else
708 {
709 /* NOTE THIS IN TRI TEST Could be replaced by a flag */
710 if(!QT_IS_EMPTY(*qtptr))
711 {
712 if(qtinset(*qtptr,arg2))
713 if(func(qtptr,q0,q1,q2,t0,t1,t2,n,arg1,arg2,arg3)==QT_MODIFIED)
714 goto tree_modified;
715 else
716 return;
717 }
718 if(point_in_stri(t0,t1,t2,q0) )
719 if(func(qtptr,q0,q1,q2,t0,t1,t2,n,arg1,arg2,arg3)==QT_MODIFIED)
720 goto tree_modified;
721 }
722 }
723
724
725
726
727
728
729 /* NOTE: SINCE DIR could be unit: then we could use integer math */
730 int
731 qtVisit_tri_edges(qtptr,b,db0,db1,db2,
732 db,wptr,t,sign,sfactor,func,arg1,arg2,arg3)
733 QUADTREE *qtptr;
734 double b[3],db0,db1,db2,db[3][3];
735 int *wptr;
736 double t[3];
737 int sign;
738 double sfactor;
739 int (*func)();
740 int *arg1,arg2,*arg3;
741 {
742 int i,found;
743 QUADTREE *child;
744 int nbr,next,w;
745 double t_l,t_g;
746 #ifdef DEBUG_TEST_DRIVER
747 FVECT a1,b1,c1;
748 int Pick_parent = Pick_cnt-1;
749 qtSubdivide_tri(Pick_v0[Pick_parent],Pick_v1[Pick_parent],
750 Pick_v2[Pick_parent],a1,b1,c1);
751 #endif
752 if(QT_IS_TREE(*qtptr))
753 {
754 /* Find the appropriate child and reset the coord */
755 i = bary_child(b);
756
757 QT_SET_FLAG(*qtptr);
758
759 for(;;)
760 {
761 w = *wptr;
762 child = QT_NTH_CHILD_PTR(*qtptr,i);
763
764 if(i != 3)
765 nbr = qtVisit_tri_edges(child,b,db0,db1,db2,
766 db,wptr,t,sign,
767 sfactor*2.0,func,arg1,arg2,arg3);
768 else
769 /* If the center cell- must flip direction signs */
770 nbr = qtVisit_tri_edges(child,b,-db0,-db1,-db2,
771 db,wptr,t,1-sign,
772 sfactor*2.0,func,arg1,arg2,arg3);
773
774 if(nbr == QT_DONE)
775 return(nbr);
776 if(*wptr != w)
777 {
778 w = *wptr;
779 db0 = db[w][0];db1 = db[w][1];db2 = db[w][2];
780 if(sign)
781 { db0 *= -1.0;db1 *= -1.0; db2 *= -1.0;}
782 }
783 /* If in same block: traverse */
784 if(i==3)
785 next = nbr;
786 else
787 if(nbr == i)
788 next = 3;
789 else
790 {
791 /* reset the barycentric coordinates in the parents*/
792 bary_parent(b,i);
793 /* Else pop up to parent and traverse from there */
794 return(nbr);
795 }
796 bary_from_child(b,i,next);
797 i = next;
798 }
799 }
800 else
801 {
802 #ifdef DEBUG_TEST_DRIVER
803 qtNth_child_tri(Pick_v0[Pick_parent],Pick_v1[Pick_parent],
804 Pick_v2[Pick_parent],a1,b1,c1,i,Pick_v0[Pick_cnt],
805 Pick_v1[Pick_cnt],Pick_v2[Pick_cnt]);
806 Pick_cnt++;
807 #endif
808
809 if(func(qtptr,arg1,arg2,arg3) == QT_DONE)
810 return(QT_DONE);
811
812 /* Advance to next node */
813 w = *wptr;
814 while(1)
815 {
816 nbr = move_to_nbr(b,db0,db1,db2,&t_l);
817
818 t_g = t_l/sfactor;
819 #ifdef DEBUG
820 if(t[w] <= 0.0)
821 eputs("qtVisit_tri_edges():negative t\n");
822 #endif
823 if(t_g >= t[w])
824 {
825 if(w == 2)
826 return(QT_DONE);
827
828 b[0] += (t[w])*sfactor*db0;
829 b[1] += (t[w])*sfactor*db1;
830 b[2] += (t[w])*sfactor*db2;
831 w++;
832 db0 = db[w][0];
833 db1 = db[w][1];
834 db2 = db[w][2];
835 if(sign)
836 { db0 *= -1.0;db1 *= -1.0; db2 *= -1.0;}
837 }
838 else
839 if(nbr != INVALID)
840 {
841 b[0] += t_l * db0;
842 b[1] += t_l * db1;
843 b[2] += t_l * db2;
844
845 t[w] -= t_g;
846 *wptr = w;
847 return(nbr);
848 }
849 else
850 return(INVALID);
851 }
852 }
853
854 }
855
856
857 int
858 qtRoot_visit_tri_edges(qtptr,q0,q1,q2,tri,i_pt,wptr,func,arg1,arg2,arg3)
859 QUADTREE *qtptr;
860 FVECT q0,q1,q2;
861 FVECT tri[3],i_pt;
862 int *wptr;
863 int (*func)();
864 int *arg1,arg2,*arg3;
865 {
866 int x,y,z,nbr,w,i,j;
867 QUADTREE *child;
868 FVECT n,c,d,v[3];
869 double pd,b[4][3],db[3][3],et[3],t[3],exit_pt;
870
871 w = *wptr;
872
873 /* Project the origin onto the root node plane */
874
875 /* Find the intersection point of the origin */
876 tri_plane_equation(q0,q1,q2,n,&pd,FALSE);
877 /* map to 2d by dropping maximum magnitude component of normal */
878 z = max_index(n,NULL);
879 x = (z+1)%3;
880 y = (z+2)%3;
881 /* Calculate barycentric coordinates for current vertex */
882 if(w != -1)
883 {
884 bary2d(q0[x],q0[y],q1[x],q1[y],q2[x],q2[y],i_pt[x],i_pt[y],b[3]);
885 intersect_vector_plane(tri[w],n,pd,&(et[w]),v[w]);
886 bary2d(q0[x],q0[y],q1[x],q1[y],q2[x],q2[y],v[w][x],v[w][y],b[w]);
887 }
888 else
889 /* Just starting: b[0] is the origin point: guaranteed to be valid b*/
890 {
891 w = 0;
892 intersect_vector_plane(tri[0],n,pd,&(et[0]),v[0]);
893 bary2d(q0[x],q0[y],q1[x],q1[y],q2[x],q2[y],v[0][x],v[0][y],b[0]);
894 VCOPY(b[3],b[0]);
895 }
896
897
898 j = (w+1)%3;
899 intersect_vector_plane(tri[j],n,pd,&(et[j]),v[j]);
900 bary2d(q0[x],q0[y],q1[x],q1[y],q2[x],q2[y],v[j][x],v[j][y],b[j]);
901 if(et[j] < 0.0)
902 {
903 VSUB(db[w],b[3],b[j]);
904 t[w] = FHUGE;
905 }
906 else
907 {
908 /* NOTE: for stability: do not increment with ipt- use full dir and
909 calculate t: but for wrap around case: could get same problem?
910 */
911 VSUB(db[w],b[j],b[3]);
912 t[w] = 1.0;
913 move_to_nbr(b[3],db[w][0],db[w][1],db[w][2],&exit_pt);
914 if(exit_pt >= 1.0)
915 {
916 for(;j < 3;j++)
917 {
918 i = (j+1)%3;
919 if(i!= w)
920 {
921 intersect_vector_plane(tri[i],n,pd,&(et[i]),v[i]);
922 bary2d(q0[x],q0[y],q1[x],q1[y],q2[x],q2[y],v[i][x],
923 v[i][y],b[i]);
924 }
925 if(et[i] < 0.0)
926 {
927 VSUB(db[j],b[j],b[i]);
928 t[j] = FHUGE;
929 break;
930 }
931 else
932 {
933 VSUB(db[j],b[i],b[j]);
934 t[j] = 1.0;
935 }
936 move_to_nbr(b[j],db[j][0],db[j][1],db[j][2],&exit_pt);
937 if(exit_pt < 1.0)
938 break;
939 }
940 }
941 }
942 *wptr = w;
943 /* trace the ray starting with this node */
944 nbr = qtVisit_tri_edges(qtptr,b[3],db[w][0],db[w][1],db[w][2],
945 db,wptr,t,0,1.0,func,arg1,arg2,arg3);
946 if(nbr != INVALID && nbr != QT_DONE)
947 {
948 i_pt[x] = b[3][0]*q0[x] + b[3][1]*q1[x] + b[3][2]*q2[x];
949 i_pt[y] = b[3][0]*q0[y] + b[3][1]*q1[y] + b[3][2]*q2[y];
950 i_pt[z] = (-n[x]*i_pt[x] - n[y]*i_pt[y] -pd)/n[z];
951 }
952 return(nbr);
953
954 }
955
956 int
957 move_to_nbri(b,db0,db1,db2,tptr)
958 BCOORD b[3];
959 BDIR db0,db1,db2;
960 TINT *tptr;
961 {
962 TINT t,dt;
963 BCOORD bc;
964 int nbr;
965
966 nbr = -1;
967 /* Advance to next node */
968 if(db0 < 0)
969 {
970 bc = MAXBCOORD*b[0];
971 t = bc/-db0;
972 nbr = 0;
973 }
974 else
975 t = HUGET;
976 if(db1 < 0)
977 {
978 bc = MAXBCOORD*b[1];
979 dt = bc/-db1;
980 if( dt < t)
981 {
982 t = dt;
983 nbr = 1;
984 }
985 }
986 if(db2 < 0)
987 {
988 bc = MAXBCOORD*b[2];
989 dt = bc/-db2;
990 if( dt < t)
991 {
992 t = dt;
993 nbr = 2;
994 }
995 }
996 *tptr = t;
997 return(nbr);
998 }
999 /* NOTE: SINCE DIR could be unit: then we could use integer math */
1000 int
1001 qtVisit_tri_edgesi(qtptr,b,db0,db1,db2,
1002 db,wptr,t,sign,sfactor,func,arg1,arg2,arg3)
1003 QUADTREE *qtptr;
1004 BCOORD b[3];
1005 BDIR db0,db1,db2,db[3][3];
1006 int *wptr;
1007 TINT t[3];
1008 int sign;
1009 int sfactor;
1010 int (*func)();
1011 int *arg1,arg2,*arg3;
1012 {
1013 int i,found;
1014 QUADTREE *child;
1015 int nbr,next,w;
1016 TINT t_g,t_l,t_i;
1017 #ifdef DEBUG_TEST_DRIVER
1018 FVECT a1,b1,c1;
1019 int Pick_parent = Pick_cnt-1;
1020 qtSubdivide_tri(Pick_v0[Pick_parent],Pick_v1[Pick_parent],
1021 Pick_v2[Pick_parent],a1,b1,c1);
1022 #endif
1023 if(QT_IS_TREE(*qtptr))
1024 {
1025 /* Find the appropriate child and reset the coord */
1026 i = baryi_child(b);
1027
1028 QT_SET_FLAG(*qtptr);
1029
1030 for(;;)
1031 {
1032 w = *wptr;
1033 child = QT_NTH_CHILD_PTR(*qtptr,i);
1034
1035 if(i != 3)
1036 nbr = qtVisit_tri_edgesi(child,b,db0,db1,db2,
1037 db,wptr,t,sign,
1038 sfactor+1,func,arg1,arg2,arg3);
1039 else
1040 /* If the center cell- must flip direction signs */
1041 nbr = qtVisit_tri_edgesi(child,b,-db0,-db1,-db2,
1042 db,wptr,t,1-sign,
1043 sfactor+1,func,arg1,arg2,arg3);
1044
1045 if(nbr == QT_DONE)
1046 return(nbr);
1047 if(*wptr != w)
1048 {
1049 w = *wptr;
1050 db0 = db[w][0];db1 = db[w][1];db2 = db[w][2];
1051 if(sign)
1052 { db0 *= -1;db1 *= -1; db2 *= -1;}
1053 }
1054 /* If in same block: traverse */
1055 if(i==3)
1056 next = nbr;
1057 else
1058 if(nbr == i)
1059 next = 3;
1060 else
1061 {
1062 /* reset the barycentric coordinates in the parents*/
1063 baryi_parent(b,i);
1064 /* Else pop up to parent and traverse from there */
1065 return(nbr);
1066 }
1067 baryi_from_child(b,i,next);
1068 i = next;
1069 }
1070 }
1071 else
1072 {
1073 #ifdef DEBUG_TEST_DRIVER
1074 qtNth_child_tri(Pick_v0[Pick_parent],Pick_v1[Pick_parent],
1075 Pick_v2[Pick_parent],a1,b1,c1,i,Pick_v0[Pick_cnt],
1076 Pick_v1[Pick_cnt],Pick_v2[Pick_cnt]);
1077 Pick_cnt++;
1078 #endif
1079
1080 if(func(qtptr,arg1,arg2,arg3) == QT_DONE)
1081 return(QT_DONE);
1082
1083 /* Advance to next node */
1084 w = *wptr;
1085 while(1)
1086 {
1087 nbr = move_to_nbri(b,db0,db1,db2,&t_i);
1088
1089 t_g = t_i >> sfactor;
1090
1091 if(t_g >= t[w])
1092 {
1093 if(w == 2)
1094 return(QT_DONE);
1095
1096 /* The edge fits in the cell- therefore the result of shifting db by
1097 sfactor is guaranteed to be less than MAXBCOORD
1098 */
1099 /* Caution: (t[w]*db) must occur before divide by MAXBCOORD
1100 since t[w] will always be < MAXBCOORD
1101 */
1102 b[0] = b[0] + (t[w]*db0*(1 << sfactor))/MAXBCOORD;
1103 b[1] = b[1] + (t[w]*db1*(1 << sfactor))/MAXBCOORD;
1104 b[2] = b[2] + (t[w]*db2*(1 << sfactor))/MAXBCOORD;
1105 w++;
1106 db0 = db[w][0]; db1 = db[w][1]; db2 = db[w][2];
1107 if(sign)
1108 { db0 *= -1;db1 *= -1; db2 *= -1;}
1109 }
1110 else
1111 if(nbr != INVALID)
1112 {
1113 /* Caution: (t_i*db) must occur before divide by MAXBCOORD
1114 since t_i will always be < MAXBCOORD
1115 */
1116 b[0] = b[0] + (t_i *db0) / MAXBCOORD;
1117 b[1] = b[1] + (t_i *db1) / MAXBCOORD;
1118 b[2] = b[2] + (t_i *db2) / MAXBCOORD;
1119
1120 t[w] -= t_g;
1121 *wptr = w;
1122 return(nbr);
1123 }
1124 else
1125 return(INVALID);
1126 }
1127 }
1128 }
1129
1130
1131 int
1132 qtRoot_visit_tri_edgesi(qtptr,q0,q1,q2,tri,i_pt,wptr,func,arg1,arg2,arg3)
1133 QUADTREE *qtptr;
1134 FVECT q0,q1,q2;
1135 FVECT tri[3],i_pt;
1136 int *wptr;
1137 int (*func)();
1138 int *arg1,arg2,*arg3;
1139 {
1140 int x,y,z,nbr,w,i,j;
1141 QUADTREE *child;
1142 FVECT n,c,d,v[3];
1143 double pd,b[4][3],db[3][3],et[3],exit_pt;
1144 BCOORD bi[3];
1145 TINT t[3];
1146 BDIR dbi[3][3];
1147 w = *wptr;
1148
1149 /* Project the origin onto the root node plane */
1150
1151 t[0] = t[1] = t[2] = 0;
1152 /* Find the intersection point of the origin */
1153 tri_plane_equation(q0,q1,q2,n,&pd,FALSE);
1154 /* map to 2d by dropping maximum magnitude component of normal */
1155 z = max_index(n,NULL);
1156 x = (z+1)%3;
1157 y = (z+2)%3;
1158 /* Calculate barycentric coordinates for current vertex */
1159 if(w != -1)
1160 {
1161 bary2d(q0[x],q0[y],q1[x],q1[y],q2[x],q2[y],i_pt[x],i_pt[y],b[3]);
1162 intersect_vector_plane(tri[w],n,pd,&(et[w]),v[w]);
1163 bary2d(q0[x],q0[y],q1[x],q1[y],q2[x],q2[y],v[w][x],v[w][y],b[w]);
1164 }
1165 else
1166 /* Just starting: b[0] is the origin point: guaranteed to be valid b*/
1167 {
1168 w = 0;
1169 intersect_vector_plane(tri[0],n,pd,&(et[0]),v[0]);
1170 bary2d(q0[x],q0[y],q1[x],q1[y],q2[x],q2[y],v[0][x],v[0][y],b[0]);
1171 VCOPY(b[3],b[0]);
1172 }
1173
1174
1175 j = (w+1)%3;
1176 intersect_vector_plane(tri[j],n,pd,&(et[j]),v[j]);
1177 bary2d(q0[x],q0[y],q1[x],q1[y],q2[x],q2[y],v[j][x],v[j][y],b[j]);
1178 if(et[j] < 0.0)
1179 {
1180 VSUB(db[w],b[3],b[j]);
1181 t[w] = HUGET;
1182 }
1183 else
1184 {
1185 /* NOTE: for stability: do not increment with ipt- use full dir and
1186 calculate t: but for wrap around case: could get same problem?
1187 */
1188 VSUB(db[w],b[j],b[3]);
1189 /* Check if the point is out side of the triangle: if so t[w] =HUGET */
1190 if((fabs(b[j][0])>(FTINY+1.0)) ||(fabs(b[j][1])>(FTINY+1.0)) ||
1191 (fabs(b[j][2])>(FTINY+1.0)))
1192 t[w] = HUGET;
1193 else
1194 {
1195 /* The next point is in the triangle- so db values will be in valid
1196 range and t[w]= MAXT
1197 */
1198 t[w] = MAXT;
1199 if(j != 0)
1200 for(;j < 3;j++)
1201 {
1202 i = (j+1)%3;
1203 if(i!= w)
1204 {
1205 intersect_vector_plane(tri[i],n,pd,&(et[i]),v[i]);
1206 bary2d(q0[x],q0[y],q1[x],q1[y],q2[x],q2[y],v[i][x],
1207 v[i][y],b[i]);
1208 }
1209 if(et[i] < 0.0)
1210 {
1211 VSUB(db[j],b[j],b[i]);
1212 t[j] = HUGET;
1213 break;
1214 }
1215 else
1216 {
1217 VSUB(db[j],b[i],b[j]);
1218 if((fabs(b[j][0])>(FTINY+1.0)) ||
1219 (fabs(b[j][1])>(FTINY+1.0)) ||
1220 (fabs(b[j][2])>(FTINY+1.0)))
1221 {
1222 t[j] = HUGET;
1223 break;
1224 }
1225 else
1226 t[j] = MAXT;
1227 }
1228 }
1229 }
1230 }
1231 *wptr = w;
1232 bary_dtol(b[3],db,bi,dbi,t);
1233
1234 /* trace the ray starting with this node */
1235 nbr = qtVisit_tri_edgesi(qtptr,bi,dbi[w][0],dbi[w][1],dbi[w][2],
1236 dbi,wptr,t,0,0,func,arg1,arg2,arg3);
1237 if(nbr != INVALID && nbr != QT_DONE)
1238 {
1239 b[3][0] = (double)bi[0]/(double)MAXBCOORD;
1240 b[3][1] = (double)bi[1]/(double)MAXBCOORD;
1241 b[3][2] = (double)bi[2]/(double)MAXBCOORD;
1242 i_pt[x] = b[3][0]*q0[x] + b[3][1]*q1[x] + b[3][2]*q2[x];
1243 i_pt[y] = b[3][0]*q0[y] + b[3][1]*q1[y] + b[3][2]*q2[y];
1244 i_pt[z] = (-n[x]*i_pt[x] - n[y]*i_pt[y] -pd)/n[z];
1245 }
1246 return(nbr);
1247
1248 }
1249
1250
1251
1252
1253
1254
1255
1256
1257
1258
1259
1260
1261
1262
1263
1264
