root/radiance/ray/src/hd/sm_qtree.c
Revision: 3.10
Committed: Tue Jan 5 16:52:39 1999 UTC (25 years, 5 months ago) by gwlarson
Changes since 3.9: +0 -0 lines
fixed logic in smTest to handle nearby and coincident points, added base tris to rendering, made list of new triangles to speed up rendering
1 /* Copyright (c) 1998 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * sm_qtree.c: adapted from octree.c from radiance code
9 */
10 /*
11 * octree.c - routines dealing with octrees and cubes.
12 *
13 * 7/28/85
14 */
15
16 #include "standard.h"
17 #include "sm_flag.h"
18 #include "sm_geom.h"
19 #include "sm_qtree.h"
20
21 QUADTREE *quad_block[QT_MAX_BLK]; /* our quadtree */
22 static QUADTREE quad_free_list = EMPTY; /* freed octree nodes */
23 static QUADTREE treetop = 0; /* next free node */
24 int4 *quad_flag= NULL;
25
26 #ifdef TEST_DRIVER
27 extern FVECT Pick_v0[500],Pick_v1[500],Pick_v2[500];
28 extern int Pick_cnt,Pick_tri,Pick_samp;
29 extern FVECT Pick_point[500];
30 extern int Pick_q[500];
31
32 #endif
33 int Incnt=0;
34
35 QUADTREE
36 qtAlloc() /* allocate a quadtree */
37 {
38 register QUADTREE freet;
39
40 if ((freet = quad_free_list) != EMPTY)
41 {
42 quad_free_list = QT_NTH_CHILD(freet, 0);
43 return(freet);
44 }
45 freet = treetop;
46 if (QT_BLOCK_INDEX(freet) == 0)
47 {
48 if (QT_BLOCK(freet) >= QT_MAX_BLK)
49 return(EMPTY);
50 if ((quad_block[QT_BLOCK(freet)] = (QUADTREE *)malloc(
51 QT_BLOCK_SIZE*4*sizeof(QUADTREE))) == NULL)
52 error(SYSTEM,"qtAlloc(): Unable to allocate memory\n");
53
54 /* Realloc the per/node flags */
55 quad_flag = (int4 *)realloc((char *)quad_flag,
56 (QT_BLOCK(freet)+1)*((QT_BLOCK_SIZE+7)>>3));
57 if (quad_flag == NULL)
58 error(SYSTEM,"qtAlloc(): Unable to allocate memory\n");
59 }
60 treetop += 4;
61 return(freet);
62 }
63
64
65 qtClearAllFlags() /* clear all quadtree branch flags */
66 {
67 if (!treetop)
68 return;
69
70 /* Clear the node flags*/
71 bzero((char *)quad_flag, (QT_BLOCK(treetop-4)+1)*((QT_BLOCK_SIZE+7)>>3));
72 /* Clear set flags */
73 qtclearsetflags();
74 }
75
76 qtFree(qt) /* free a quadtree */
77 register QUADTREE qt;
78 {
79 register int i;
80
81 if (!QT_IS_TREE(qt))
82 {
83 qtfreeleaf(qt);
84 return;
85 }
86 for (i = 0; i < 4; i++)
87 qtFree(QT_NTH_CHILD(qt, i));
88 QT_NTH_CHILD(qt, 0) = quad_free_list;
89 quad_free_list = qt;
90 }
91
92
93 qtDone() /* free EVERYTHING */
94 {
95 register int i;
96
97 qtfreeleaves();
98 for (i = 0; i < QT_MAX_BLK; i++)
99 {
100 if (quad_block[i] == NULL)
101 break;
102 free((char *)quad_block[i]);
103 quad_block[i] = NULL;
104 }
105 /* Free the flags */
106 if (i) free((char *)quad_flag);
107 quad_flag = NULL;
108 quad_free_list = EMPTY;
109 treetop = 0;
110 }
111
112 QUADTREE
113 qtLocate(qt,bcoord)
114 QUADTREE qt;
115 BCOORD bcoord[3];
116 {
117 int i;
118
119 if(QT_IS_TREE(qt))
120 {
121 i = bary_child(bcoord);
122
123 return(qtLocate(QT_NTH_CHILD(qt,i),bcoord));
124 }
125 else
126 return(qt);
127 }
128
129 int
130 move_to_nbr(b,db0,db1,db2,tptr)
131 BCOORD b[3];
132 BDIR db0,db1,db2;
133 double *tptr;
134 {
135 double t,dt;
136 BCOORD bc;
137 int nbr;
138
139 nbr = -1;
140 *tptr = 0.0;
141 /* Advance to next node */
142 if(b[0]==0 && db0 < 0)
143 return(0);
144 if(b[1]==0 && db1 < 0)
145 return(1);
146 if(b[2]==0 && db2 < 0)
147 return(2);
148 if(db0 < 0)
149 {
150 t = ((double)b[0])/-db0;
151 nbr = 0;
152 }
153 else
154 t = MAXFLOAT;
155 if(db1 < 0)
156 {
157 dt = ((double)b[1])/-db1;
158 if( dt < t)
159 {
160 t = dt;
161 nbr = 1;
162 }
163 }
164 if(db2 < 0)
165 {
166 dt = ((double)b[2])/-db2;
167 if( dt < t)
168 {
169 t = dt;
170 nbr = 2;
171 }
172 }
173 *tptr = t;
174 return(nbr);
175 }
176
177 qtTrace_ray(qt,b,db0,db1,db2,nextptr,sign,sfactor,func,f)
178 QUADTREE qt;
179 BCOORD b[3];
180 BDIR db0,db1,db2;
181 int *nextptr;
182 int sign,sfactor;
183 FUNC func;
184 int *f;
185 {
186 int i,found;
187 QUADTREE child;
188 int nbr,next,w;
189 double t;
190
191 if(QT_IS_TREE(qt))
192 {
193 /* Find the appropriate child and reset the coord */
194 i = bary_child(b);
195
196 for(;;)
197 {
198 child = QT_NTH_CHILD(qt,i);
199 if(i != 3)
200 qtTrace_ray(child,b,db0,db1,db2,nextptr,sign,sfactor+1,func,f);
201 else
202 /* If the center cell- must flip direction signs */
203 qtTrace_ray(child,b,-db0,-db1,-db2,nextptr,1-sign,sfactor+1,func,f);
204
205 if(QT_FLAG_IS_DONE(*f))
206 return;
207 /* If in same block: traverse */
208 if(i==3)
209 next = *nextptr;
210 else
211 if(*nextptr == i)
212 next = 3;
213 else
214 {
215 /* reset the barycentric coordinates in the parents*/
216 bary_parent(b,i);
217 /* Else pop up to parent and traverse from there */
218 return(qt);
219 }
220 bary_from_child(b,i,next);
221 i = next;
222 }
223 }
224 else
225 {
226 #ifdef TEST_DRIVER
227 if(Pick_cnt < 500)
228 Pick_q[Pick_cnt++]=qt;
229 #endif;
230 F_FUNC(func)(qt,F_ARGS(func),f);
231 if(QT_FLAG_IS_DONE(*f))
232 return;
233 /* Advance to next node */
234 nbr = move_to_nbr(b,db0,db1,db2,&t);
235
236 if(nbr==-1)
237 {
238 QT_FLAG_SET_DONE(*f);
239 return;
240 }
241 b[0] += (BCOORD)(t *db0);
242 b[1] += (BCOORD)(t *db1);
243 b[2] += (BCOORD)(t *db2);
244 *nextptr = nbr;
245 return;
246
247 }
248 }
249
250
251
252
253
254
255
256
257 #define TEST_INT(tl,th,d,q0,q1,h,l) \
258 tl=d>q0;th=d<q1; if(tl&&th) goto Lfunc_call; \
259 if(tl) if(l) goto Lfunc_call; else h=TRUE; \
260 if(th) if(h) goto Lfunc_call; else l = TRUE; \
261 if(th) if(h) goto Lfunc_call; else l = TRUE;
262
263 /* Leaf node: Do definitive test */
264 QUADTREE
265 qtLeaf_insert_tri(root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02,
266 scale, s0,s1,s2,sq0,sq1,sq2,f,n)
267 int root;
268 QUADTREE qt;
269 BCOORD q0[3],q1[3],q2[3];
270 BCOORD t0[3],t1[3],t2[3];
271 BCOORD dt10[3],dt21[3],dt02[3];
272 unsigned int scale,s0,s1,s2,sq0,sq1,sq2;
273 FUNC f;
274 int n;
275 {
276 double db;
277 unsigned int e0,e1,e2;
278 char al,ah,bl,bh,cl,ch,testl,testh;
279 char test_t0t1,test_t1t2,test_t2t0;
280 BCOORD a,b,c;
281
282 /* First check if can trivial accept: if vertex in cell */
283 if(s0 & s1 & s2)
284 goto Lfunc_call;
285
286 /* Assumption: Could not trivial reject*/
287 /* IF any coords lie on edge- must be in if couldnt reject */
288 a = q1[0];b= q0[1]; c= q0[2];
289 if(t0[0]== a || t0[1] == b || t0[2] == c)
290 goto Lfunc_call;
291 if(t1[0]== a || t1[1] == b || t1[2] == c)
292 goto Lfunc_call;
293 if(t2[0]== a || t2[1] == b || t2[2] == c)
294 goto Lfunc_call;
295
296 /* Test for edge crossings */
297 /* Test t0t1,t1t2,t2t0 against a */
298 /* Calculate edge crossings */
299 e0 = (s0 ^ ((s0 >> 1) | (s0 << 2 & 4)));
300 /* See if edge can be trivially rejected from intersetion testing */
301 test_t0t1 = !(((s0 & 6)==0) || ((s1 & 6)==0)|| ((s2 & 6)==0) ||
302 ((sq0 & 6)==6) ||((sq1 & 6)==6)|| ((sq2 & 6)==6));
303 bl=bh=0;
304 if(test_t0t1 && (e0 & 2) )
305 {
306 /* Must do double calculation to avoid overflow */
307 db = t0[1] + dt10[1]*((double)(a-t0[0]))/dt10[0];
308 TEST_INT(testl,testh,db,b,q1[1],bl,bh)
309 }
310 test_t1t2= !(((s0 & 3)==0) || ((s1 & 3)==0)|| ((s2 & 3)==0) ||
311 ((sq0 & 3)==3) ||((sq1 & 3)==3)|| ((sq2 & 3)==3));
312 if(test_t1t2 && (e0 & 1))
313 { /* test t1t2 against a */
314 db = t1[1] + dt21[1]*((double)(a - t1[0]))/dt21[0];
315 TEST_INT(testl,testh,db,b,q1[1],bl,bh)
316 }
317 test_t2t0 = !(((s0 & 5)==0) || ((s1 & 5)==0)|| ((s2 & 5)==0) ||
318 ((sq0 & 5)==5) ||((sq1 & 5)==5)|| ((sq2 & 5)==5));
319 if(test_t2t0 && (e0 & 4))
320 {
321 db = t2[1] + dt02[1]*((double)(a - t2[0]))/dt02[0];
322 TEST_INT(testl,testh,db,b,q1[1],bl,bh)
323 }
324 e1 = (s1 ^ ((s1 >> 1) | (s1 << 2 & 4)));
325 cl = ch = 0;
326 if(test_t0t1 && (e1 & 2))
327 {/* test t0t1 against b */
328 db = t0[2] + dt10[2]*((double)(b-t0[1]))/dt10[1];
329 TEST_INT(testl,testh,db,c,q2[2],cl,ch)
330 }
331 if(test_t1t2 && (e1 & 1))
332 {/* test t1t2 against b */
333 db = t1[2] + dt21[2]*((double)(q0[1] - t1[1]))/dt21[1];
334 TEST_INT(testl,testh,db,c,q2[2],cl,ch)
335 }
336 if(test_t2t0 && (e1 & 4))
337 {/* test t2t0 against b */
338 db = t2[2] + dt02[2]*((double)(q0[1] - t2[1]))/dt02[1];
339 TEST_INT(testl,testh,db,c,q2[2],cl,ch)
340 }
341
342 /* test edges against c */
343 e2 = (s2 ^ ((s2 >> 1) | (s2 << 2 & 4)));
344 al = ah = 0;
345 if(test_t0t1 && (e2 & 2))
346 { /* test t0t1 against c */
347 db = t0[0] + dt10[0]*((double)(c-t0[2]))/dt10[2];
348 TEST_INT(testl,testh,db,a,q0[0],al,ah)
349 }
350 if(test_t1t2 && (e2 & 1))
351 {
352 db = t1[0] + dt21[0]*((double)(c - t1[2]))/dt21[2];
353 TEST_INT(testl,testh,db,a,q0[0],al,ah)
354 }
355 if(test_t2t0 && (e2 & 4))
356 { /* test t2t0 against c */
357 db = t2[0] + dt02[0]*((double)(c - t2[2]))/dt02[2];
358 TEST_INT(testl,testh,db,a,q0[0],al,ah)
359 }
360 /* Only remaining case is if some edge trivially rejected */
361 if(!e0 || !e1 || !e2)
362 return(qt);
363
364 /* Only one/none got tested - pick either of other two/any two */
365 /* Only need to test one edge */
366 if(!test_t0t1 && (e0 & 2))
367 {
368 db = t0[1] + dt10[1]*((double)(a-t0[0]))/dt10[0];
369 TEST_INT(testl,testh,db,b,q1[1],bl,bh)
370 }
371 if(!test_t1t2 && (e0 & 1))
372 {/* test t1t2 against a */
373 db = t1[1] + dt21[1]*((double)(a - t1[0]))/dt21[0];
374 TEST_INT(testl,testh,db,b,q1[1],bl,bh)
375 }
376 if(!test_t2t0 && (e0 & 4))
377 {
378 db = t2[1] + dt02[1]*((double)(a - t2[0]))/dt02[0];
379 TEST_INT(testl,testh,db,b,q1[1],bl,bh)
380 }
381
382 return(qt);
383
384 Lfunc_call:
385 qt = f.func(f.argptr,root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02,scale,
386 s0,s1,s2,sq0,sq1,sq2,0,f,n);
387 return(qt);
388
389 }
390
391
392
393 /* Leaf node: Do definitive test */
394 QUADTREE
395 qtLeaf_insert_tri_rev(root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02,
396 scale, s0,s1,s2,sq0,sq1,sq2,f,n)
397 int root;
398 QUADTREE qt;
399 BCOORD q0[3],q1[3],q2[3];
400 BCOORD t0[3],t1[3],t2[3];
401 BCOORD dt10[3],dt21[3],dt02[3];
402 unsigned int scale,s0,s1,s2,sq0,sq1,sq2;
403 FUNC f;
404 int n;
405 {
406 double db;
407 unsigned int e0,e1,e2;
408 BCOORD a,b,c;
409 double p0[2], p1[2],cp;
410 char al,ah,bl,bh,cl,ch;
411 char testl,testh,test_t0t1,test_t1t2,test_t2t0;
412 unsigned int ls0,ls1,ls2;
413
414 /* May have gotten passed trivial reject if one/two vertices are ON */
415 a = q1[0];b= q0[1]; c= q0[2];
416 SIDES_LESS(t0,t1,t2,ls0,ls1,ls2,a,b,c);
417
418 /* First check if can trivial accept: if vertex in cell */
419 if(ls0 & ls1 & ls2)
420 goto Lfunc_call;
421
422 if(ls0==0 || ls1 == 0 || ls2 ==0)
423 return(qt);
424 /* Assumption: Could not trivial reject*/
425 /* IF any coords lie on edge- must be in if couldnt reject */
426
427 if(t0[0]== a || t0[1] == b || t0[2] == c)
428 goto Lfunc_call;
429 if(t1[0]== a || t1[1] == b || t1[2] == c)
430 goto Lfunc_call;
431 if(t2[0]== a || t2[1] == b || t2[2] == c)
432 goto Lfunc_call;
433
434 /* Test for edge crossings */
435 /* Test t0t1 against a,b,c */
436 /* First test if t0t1 can be trivially rejected */
437 /* If both edges are outside bounds- dont need to test */
438
439 /* Test t0t1,t1t2,t2t0 against a */
440 test_t0t1 = !(((ls0 & 6)==0) || ((ls1 & 6)==0)|| ((ls2 & 6)==0) ||
441 ((sq0 & 6)==0) ||((sq1 & 6)==0)|| ((sq2 & 6)==0));
442 e0 = (ls0 ^ ((ls0 >> 1) | (ls0 << 2 & 4)));
443 bl=bh=0;
444 /* Test t0t1,t1t2,t2t0 against a */
445 if(test_t0t1 && (e0 & 2) )
446 {
447 db = t0[1] + dt10[1]*((double)(a-t0[0])/dt10[0]);
448 TEST_INT(testl,testh,db,q1[1],b,bl,bh)
449 }
450 test_t1t2= !(((ls0 & 3)==0) || ((ls1 & 3)==0)|| ((ls2 & 3)==0) ||
451 ((sq0 & 3)==0) ||((sq1 & 3)==0)|| ((sq2 & 3)==0));
452 if(test_t1t2 && (e0 & 1))
453 { /* test t1t2 against a */
454 db = t1[1] + dt21[1]*((double)(a - t1[0]))/dt21[0];
455 TEST_INT(testl,testh,db,q1[1],b,bl,bh)
456 }
457 test_t2t0 = !(((ls0 & 5)==0) || ((ls1 & 5)==0)|| ((ls2 & 5)==0) ||
458 ((sq0 & 5)==0) ||((sq1 & 5)==0)|| ((sq2 & 5)==0));
459 if(test_t2t0 && (e0 & 4))
460 {
461 db = t2[1] + dt02[1]*((double)(a - t2[0]))/dt02[0];
462 TEST_INT(testl,testh,db,q1[1],b,bl,bh)
463 }
464 cl = ch = 0;
465 e1 = (ls1 ^ ((ls1 >> 1) | (ls1 << 2 & 4)));
466 if(test_t0t1 && (e1 & 2))
467 {/* test t0t1 against b */
468 db = t0[2] + dt10[2]*(((double)(b-t0[1]))/dt10[1]);
469 TEST_INT(testl,testh,db,q1[2],c,cl,ch)
470 }
471 if(test_t1t2 && (e1 & 1))
472 {/* test t1t2 against b */
473 db = t1[2] + dt21[2]*((double)(b - t1[1]))/dt21[1];
474 TEST_INT(testl,testh,db,q1[2],c,cl,ch)
475 }
476 if(test_t2t0 && (e1 & 4))
477 {/* test t2t0 against b */
478 db = t2[2] + dt02[2]*((double)(b - t2[1]))/dt02[1];
479 TEST_INT(testl,testh,db,q1[2],c,cl,ch)
480 }
481 al = ah = 0;
482 e2 = (ls2 ^ ((ls2 >> 1) | (ls2 << 2 & 4)));
483 if(test_t0t1 && (e2 & 2))
484 { /* test t0t1 against c */
485 db = t0[0] + dt10[0]*(((double)(c-t0[2]))/dt10[2]);
486 TEST_INT(testl,testh,db,q0[0],a,al,ah)
487 }
488 if(test_t1t2 && (e2 & 1))
489 {
490 db = t1[0] + dt21[0]*((double)(c - t1[2]))/dt21[2];
491 TEST_INT(testl,testh,db,q0[0],a,al,ah)
492 }
493 if(test_t2t0 && (e2 & 4))
494 { /* test t2t0 against c */
495 db = t2[0] + dt02[0]*((double)(c - t2[2]))/dt02[2];
496 TEST_INT(testl,testh,db,q0[0],a,al,ah)
497 }
498 /* Only remaining case is if some edge trivially rejected */
499 if(!e0 || !e1 || !e2)
500 return(qt);
501
502 /* Only one/none got tested - pick either of other two/any two */
503 /* Only need to test one edge */
504 if(!test_t0t1 && (e0 & 2))
505 {
506 db = t0[1] + dt10[1]*((double)(a-t0[0]))/dt10[0];
507 TEST_INT(testl,testh,db,q1[1],b,bl,bh)
508 }
509 if(!test_t1t2 && (e0 & 1))
510 {/* test t1t2 against a */
511 db = t1[1] + dt21[1]*((double)(a - t1[0]))/dt21[0];
512 TEST_INT(testl,testh,db,q1[1],b,bl,bh)
513 }
514 if(!test_t2t0 && (e0 & 4))
515 {
516 db = t2[1] + dt02[1]*((double)(a - t2[0]))/dt02[0];
517 TEST_INT(testl,testh,db,q1[1],b,bl,bh)
518 }
519
520 return(qt);
521 Lfunc_call:
522
523 qt = f.func(f.argptr,root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02,scale,
524 s0,s1,s2,sq0,sq1,sq2,1,f,n);
525 return(qt);
526 }
527
528
529
530 /* ASSUMPTION: that triangle t0,t1,t2 intersects quad cell q0,q1,q2 */
531
532 /*-------q2--------- sq2
533 / \
534 s1 /sc \ s0
535 qb_____qa
536 / \ / \
537 \sq0/sa \ /sb \ /sq1
538 \ q0____qc____q1/
539 \ /
540 \ s2 /
541 */
542
543 int Find_id=0;
544
545 QUADTREE
546 qtInsert_tri(root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02,scale,
547 s0,s1,s2,sq0,sq1,sq2,f,n)
548 int root;
549 QUADTREE qt;
550 BCOORD q0[3],q1[3],q2[3];
551 BCOORD t0[3],t1[3],t2[3];
552 BCOORD dt10[3],dt21[3],dt02[3];
553 BCOORD scale;
554 unsigned int s0,s1,s2,sq0,sq1,sq2;
555 FUNC f;
556 int n;
557 {
558 BCOORD a,b,c;
559 BCOORD va[3],vb[3],vc[3];
560 unsigned int sa,sb,sc;
561
562 /* If a tree: trivial reject and recurse on potential children */
563 if(QT_IS_TREE(qt))
564 {
565 /* Test against new a edge: if entirely to left: only need
566 to visit child 0
567 */
568 a = q1[0] + scale;
569 b = q0[1] + scale;
570 c = q0[2] + scale;
571
572 SIDES_GTR(t0,t1,t2,sa,sb,sc,a,b,c);
573
574 if(sa==7)
575 {
576 vb[1] = q0[1];
577 vc[2] = q0[2];
578 vc[1] = b;
579 vb[2] = c;
580 vb[0] = vc[0] = a;
581 QT_NTH_CHILD(qt,0) = qtInsert_tri(root,QT_NTH_CHILD(qt,0),q0,vc,
582 vb,t0,t1,t2,dt10,dt21,dt02, scale>>1,sa,s1,s2,sq0,sb,sc,f,n+1);
583 return(qt);
584 }
585 if(sb==7)
586 {
587 va[0] = q1[0];
588 vc[2] = q0[2];
589 va[1] = vc[1] = b;
590 va[2] = c;
591 vc[0] = a;
592 QT_NTH_CHILD(qt,1) = qtInsert_tri(root,QT_NTH_CHILD(qt,1),vc,q1,va,
593 t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,sb,s2,sa,sq1,sc,f,n+1);
594 return(qt);
595 }
596 if(sc==7)
597 {
598 va[0] = q1[0];
599 vb[1] = q0[1];
600 va[1] = b;
601 va[2] = vb[2] = c;
602 vb[0] = a;
603 QT_NTH_CHILD(qt,2) = qtInsert_tri(root,QT_NTH_CHILD(qt,2),vb,va,
604 q2,t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,s1,sc,sa,sb,sq2,f,n+1);
605 return(qt);
606 }
607
608 va[0] = q1[0];
609 vb[1] = q0[1];
610 vc[2] = q0[2];
611 va[1] = vc[1] = b;
612 va[2] = vb[2] = c;
613 vb[0] = vc[0] = a;
614 /* If outside of all edges: only need to Visit 3 */
615 if(sa==0 && sb==0 && sc==0)
616 {
617 QT_NTH_CHILD(qt,3) = qtInsert_tri_rev(root,QT_NTH_CHILD(qt,3),va,vb,
618 vc,t0,t1,t2,dt10,dt21,dt02, scale>>1,sa,sb,sc,s0,s1,s2,f,n+1);
619 return(qt);
620 }
621
622 if(sa)
623 QT_NTH_CHILD(qt,0) = qtInsert_tri(root,QT_NTH_CHILD(qt,0),q0,vc,vb,t0,
624 t1,t2,dt10,dt21,dt02,scale>>1,sa,s1,s2,sq0,sb,sc,f,n+1);
625 if(sb)
626 QT_NTH_CHILD(qt,1) = qtInsert_tri(root,QT_NTH_CHILD(qt,1),vc,q1,va,t0,
627 t1,t2,dt10,dt21,dt02,scale>>1,s0,sb,s2,sa,sq1,sc,f,n+1);
628 if(sc)
629 QT_NTH_CHILD(qt,2) = qtInsert_tri(root,QT_NTH_CHILD(qt,2),vb,va,q2,t0,
630 t1,t2,dt10,dt21,dt02,scale>>1,s0,s1,sc,sa,sb,sq2,f,n+1);
631 QT_NTH_CHILD(qt,3) = qtInsert_tri_rev(root,QT_NTH_CHILD(qt,3),va,vb,vc,t0,
632 t1,t2,dt10,dt21,dt02,scale>>1,sa,sb,sc,s0,s1,s2,f,n+1);
633 return(qt);
634 }
635 /* Leaf node: Do definitive test */
636 else
637 return(qt = qtLeaf_insert_tri(root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02,
638 scale,s0,s1,s2,sq0,sq1,sq2,f,n));
639 }
640
641
642 QUADTREE
643 qtInsert_tri_rev(root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02,scale,
644 s0,s1,s2,sq0,sq1,sq2,f,n)
645 int root;
646 QUADTREE qt;
647 BCOORD q0[3],q1[3],q2[3];
648 BCOORD t0[3],t1[3],t2[3];
649 BCOORD dt10[3],dt21[3],dt02[3];
650 BCOORD scale;
651 unsigned int s0,s1,s2,sq0,sq1,sq2;
652 FUNC f;
653 {
654 BCOORD a,b,c;
655 BCOORD va[3],vb[3],vc[3];
656 unsigned int sa,sb,sc;
657
658 /* If a tree: trivial reject and recurse on potential children */
659 if(QT_IS_TREE(qt))
660 {
661 /* Test against new a edge: if entirely to left: only need
662 to visit child 0
663 */
664 a = q1[0] - scale;
665 b = q0[1] - scale;
666 c = q0[2] - scale;
667
668 SIDES_GTR(t0,t1,t2,sa,sb,sc,a,b,c);
669
670 if(sa==0)
671 {
672 vb[1] = q0[1];
673 vc[2] = q0[2];
674 vc[1] = b;
675 vb[2] = c;
676 vb[0] = vc[0] = a;
677
678 QT_NTH_CHILD(qt,0) = qtInsert_tri_rev(root,QT_NTH_CHILD(qt,0),q0,vc,
679 vb,t0,t1,t2,dt10,dt21,dt02, scale>>1,sa,s1,s2,sq0,sb,sc,f,n+1);
680 return(qt);
681 }
682 if(sb==0)
683 {
684 va[0] = q1[0];
685 vc[2] = q0[2];
686 va[1] = vc[1] = b;
687 va[2] = c;
688 vc[0] = a;
689 QT_NTH_CHILD(qt,1) = qtInsert_tri_rev(root,QT_NTH_CHILD(qt,1),vc,q1,va,
690 t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,sb,s2,sa,sq1,sc,f,n+1);
691 return(qt);
692 }
693 if(sc==0)
694 {
695 va[0] = q1[0];
696 vb[1] = q0[1];
697 va[1] = b;
698 va[2] = vb[2] = c;
699 vb[0] = a;
700 QT_NTH_CHILD(qt,2) = qtInsert_tri_rev(root,QT_NTH_CHILD(qt,2),vb,va,
701 q2,t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,s1,sc,sa,sb,sq2,f,n+1);
702 return(qt);
703 }
704 va[0] = q1[0];
705 vb[1] = q0[1];
706 vc[2] = q0[2];
707 va[1] = vc[1] = b;
708 va[2] = vb[2] = c;
709 vb[0] = vc[0] = a;
710 /* If outside of all edges: only need to Visit 3 */
711 if(sa==7 && sb==7 && sc==7)
712 {
713 QT_NTH_CHILD(qt,3) = qtInsert_tri(root,QT_NTH_CHILD(qt,3),va,vb,
714 vc,t0,t1,t2,dt10,dt21,dt02, scale>>1,sa,sb,sc,s0,s1,s2,f,n+1);
715 return(qt);
716 }
717 if(sa!=7)
718 QT_NTH_CHILD(qt,0) = qtInsert_tri_rev(root,QT_NTH_CHILD(qt,0),q0,vc,vb,
719 t0,t1,t2,dt10,dt21,dt02,scale>>1,sa,s1,s2,sq0,sb,sc,f,n+1);
720 if(sb!=7)
721 QT_NTH_CHILD(qt,1) = qtInsert_tri_rev(root,QT_NTH_CHILD(qt,1),vc,q1,va,
722 t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,sb,s2,sa,sq1,sc,f,n+1);
723 if(sc!=7)
724 QT_NTH_CHILD(qt,2) = qtInsert_tri_rev(root,QT_NTH_CHILD(qt,2),vb,va,q2,
725 t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,s1,sc,sa,sb,sq2,f,n+1);
726
727 QT_NTH_CHILD(qt,3) = qtInsert_tri(root,QT_NTH_CHILD(qt,3),va,vb,vc,t0,t1,
728 t2,dt10,dt21,dt02,scale>>1,sa,sb,sc,s0,s1,s2,f,n+1);
729 return(qt);
730 }
731 /* Leaf node: Do definitive test */
732 else
733 return(qt = qtLeaf_insert_tri_rev(root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02,
734 scale,s0,s1,s2,sq0,sq1,sq2,f,n));
735 }
736
737
738
739
740 /*************************************************************************/
741 /* Visit code for applying functions: NOTE THIS IS THE SAME AS INSERT CODE:
742 except sets flags: wanted insert to be as efficient as possible: so
743 broke into two sets of routines
744 */
745
746 qtVisit_tri(root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02,scale,
747 s0,s1,s2,sq0,sq1,sq2,f)
748 int root;
749 QUADTREE qt;
750 BCOORD q0[3],q1[3],q2[3];
751 BCOORD t0[3],t1[3],t2[3];
752 BCOORD dt10[3],dt21[3],dt02[3];
753 BCOORD scale;
754 unsigned int s0,s1,s2,sq0,sq1,sq2;
755 FUNC f;
756 {
757 BCOORD a,b,c;
758 BCOORD va[3],vb[3],vc[3];
759 unsigned int sa,sb,sc;
760
761 /* If a tree: trivial reject and recurse on potential children */
762 if(QT_IS_TREE(qt))
763 {
764 QT_SET_FLAG(qt);
765
766 /* Test against new a edge: if entirely to left: only need
767 to visit child 0
768 */
769 a = q1[0] + scale;
770 b = q0[1] + scale;
771 c = q0[2] + scale;
772
773 SIDES_GTR(t0,t1,t2,sa,sb,sc,a,b,c);
774
775 if(sa==7)
776 {
777 vb[1] = q0[1];
778 vc[2] = q0[2];
779 vc[1] = b;
780 vb[2] = c;
781 vb[0] = vc[0] = a;
782 qtVisit_tri(root,QT_NTH_CHILD(qt,0),q0,vc,
783 vb,t0,t1,t2,dt10,dt21,dt02, scale>>1,sa,s1,s2,sq0,sb,sc,f);
784 return;
785 }
786 if(sb==7)
787 {
788 va[0] = q1[0];
789 vc[2] = q0[2];
790 va[1] = vc[1] = b;
791 va[2] = c;
792 vc[0] = a;
793 qtVisit_tri(root,QT_NTH_CHILD(qt,1),vc,q1,va,
794 t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,sb,s2,sa,sq1,sc,f);
795 return;
796 }
797 if(sc==7)
798 {
799 va[0] = q1[0];
800 vb[1] = q0[1];
801 va[1] = b;
802 va[2] = vb[2] = c;
803 vb[0] = a;
804 qtVisit_tri(root,QT_NTH_CHILD(qt,2),vb,va,
805 q2,t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,s1,sc,sa,sb,sq2,f);
806 return;
807 }
808
809 va[0] = q1[0];
810 vb[1] = q0[1];
811 vc[2] = q0[2];
812 va[1] = vc[1] = b;
813 va[2] = vb[2] = c;
814 vb[0] = vc[0] = a;
815 /* If outside of all edges: only need to Visit 3 */
816 if(sa==0 && sb==0 && sc==0)
817 {
818 qtVisit_tri_rev(root,QT_NTH_CHILD(qt,3),va,vb,
819 vc,t0,t1,t2,dt10,dt21,dt02, scale>>1,sa,sb,sc,s0,s1,s2,f);
820 return;
821 }
822
823 if(sa)
824 qtVisit_tri(root,QT_NTH_CHILD(qt,0),q0,vc,vb,t0,
825 t1,t2,dt10,dt21,dt02,scale>>1,sa,s1,s2,sq0,sb,sc,f);
826 if(sb)
827 qtVisit_tri(root,QT_NTH_CHILD(qt,1),vc,q1,va,t0,
828 t1,t2,dt10,dt21,dt02,scale>>1,s0,sb,s2,sa,sq1,sc,f);
829 if(sc)
830 qtVisit_tri(root,QT_NTH_CHILD(qt,2),vb,va,q2,t0,
831 t1,t2,dt10,dt21,dt02,scale>>1,s0,s1,sc,sa,sb,sq2,f);
832 qtVisit_tri_rev(root,QT_NTH_CHILD(qt,3),va,vb,vc,t0,
833 t1,t2,dt10,dt21,dt02,scale>>1,sa,sb,sc,s0,s1,s2,f);
834 }
835 /* Leaf node: Do definitive test */
836 else
837 qtLeaf_visit_tri(root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02,
838 scale,s0,s1,s2,sq0,sq1,sq2,f);
839
840 }
841
842
843 qtVisit_tri_rev(root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02,scale,
844 s0,s1,s2,sq0,sq1,sq2,f)
845 int root;
846 QUADTREE qt;
847 BCOORD q0[3],q1[3],q2[3];
848 BCOORD t0[3],t1[3],t2[3];
849 BCOORD dt10[3],dt21[3],dt02[3];
850 BCOORD scale;
851 unsigned int s0,s1,s2,sq0,sq1,sq2;
852 FUNC f;
853 {
854 BCOORD a,b,c;
855 BCOORD va[3],vb[3],vc[3];
856 unsigned int sa,sb,sc;
857
858 /* If a tree: trivial reject and recurse on potential children */
859 if(QT_IS_TREE(qt))
860 {
861 QT_SET_FLAG(qt);
862 /* Test against new a edge: if entirely to left: only need
863 to visit child 0
864 */
865 a = q1[0] - scale;
866 b = q0[1] - scale;
867 c = q0[2] - scale;
868
869 SIDES_GTR(t0,t1,t2,sa,sb,sc,a,b,c);
870
871 if(sa==0)
872 {
873 vb[1] = q0[1];
874 vc[2] = q0[2];
875 vc[1] = b;
876 vb[2] = c;
877 vb[0] = vc[0] = a;
878 qtVisit_tri_rev(root,QT_NTH_CHILD(qt,0),q0,vc,
879 vb,t0,t1,t2,dt10,dt21,dt02, scale>>1,sa,s1,s2,sq0,sb,sc,f);
880 return;
881 }
882 if(sb==0)
883 {
884 va[0] = q1[0];
885 vc[2] = q0[2];
886 va[1] = vc[1] = b;
887 va[2] = c;
888 vc[0] = a;
889 qtVisit_tri_rev(root,QT_NTH_CHILD(qt,1),vc,q1,va,
890 t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,sb,s2,sa,sq1,sc,f);
891 return;
892 }
893 if(sc==0)
894 {
895 va[0] = q1[0];
896 vb[1] = q0[1];
897 va[1] = b;
898 va[2] = vb[2] = c;
899 vb[0] = a;
900 qtVisit_tri_rev(root,QT_NTH_CHILD(qt,2),vb,va,
901 q2,t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,s1,sc,sa,sb,sq2,f);
902 return;
903 }
904 va[0] = q1[0];
905 vb[1] = q0[1];
906 vc[2] = q0[2];
907 va[1] = vc[1] = b;
908 va[2] = vb[2] = c;
909 vb[0] = vc[0] = a;
910 /* If outside of all edges: only need to Visit 3 */
911 if(sa==7 && sb==7 && sc==7)
912 {
913 qtVisit_tri(root,QT_NTH_CHILD(qt,3),va,vb,
914 vc,t0,t1,t2,dt10,dt21,dt02, scale>>1,sa,sb,sc,s0,s1,s2,f);
915 return;
916 }
917 if(sa!=7)
918 qtVisit_tri_rev(root,QT_NTH_CHILD(qt,0),q0,vc,vb,
919 t0,t1,t2,dt10,dt21,dt02,scale>>1,sa,s1,s2,sq0,sb,sc,f);
920 if(sb!=7)
921 qtVisit_tri_rev(root,QT_NTH_CHILD(qt,1),vc,q1,va,
922 t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,sb,s2,sa,sq1,sc,f);
923 if(sc!=7)
924 qtVisit_tri_rev(root,QT_NTH_CHILD(qt,2),vb,va,q2,
925 t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,s1,sc,sa,sb,sq2,f);
926
927 qtVisit_tri(root,QT_NTH_CHILD(qt,3),va,vb,vc,t0,t1,
928 t2,dt10,dt21,dt02,scale>>1,sa,sb,sc,s0,s1,s2,f);
929 return;
930 }
931 /* Leaf node: Do definitive test */
932 else
933 qtLeaf_visit_tri_rev(root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02,
934 scale,s0,s1,s2,sq0,sq1,sq2,f);
935 }
936
937
938
939 qtLeaf_visit_tri(root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02,
940 scale, s0,s1,s2,sq0,sq1,sq2,f)
941 int root;
942 QUADTREE qt;
943 BCOORD q0[3],q1[3],q2[3];
944 BCOORD t0[3],t1[3],t2[3];
945 BCOORD dt10[3],dt21[3],dt02[3];
946 unsigned int scale,s0,s1,s2,sq0,sq1,sq2;
947 FUNC f;
948 {
949 double db;
950 unsigned int e0,e1,e2;
951 char al,ah,bl,bh,cl,ch,testl,testh;
952 char test_t0t1,test_t1t2,test_t2t0;
953 BCOORD a,b,c;
954
955 /* First check if can trivial accept: if vertex in cell */
956 if(s0 & s1 & s2)
957 goto Lfunc_call;
958
959 /* Assumption: Could not trivial reject*/
960 /* IF any coords lie on edge- must be in if couldnt reject */
961 a = q1[0];b= q0[1]; c= q0[2];
962 if(t0[0]== a || t0[1] == b || t0[2] == c)
963 goto Lfunc_call;
964 if(t1[0]== a || t1[1] == b || t1[2] == c)
965 goto Lfunc_call;
966 if(t2[0]== a || t2[1] == b || t2[2] == c)
967 goto Lfunc_call;
968
969 /* Test for edge crossings */
970 /* Test t0t1,t1t2,t2t0 against a */
971 /* Calculate edge crossings */
972 e0 = (s0 ^ ((s0 >> 1) | (s0 << 2 & 4)));
973 /* See if edge can be trivially rejected from intersetion testing */
974 test_t0t1 = !(((s0 & 6)==0) || ((s1 & 6)==0)|| ((s2 & 6)==0) ||
975 ((sq0 & 6)==6) ||((sq1 & 6)==6)|| ((sq2 & 6)==6));
976 bl=bh=0;
977 if(test_t0t1 && (e0 & 2) )
978 {
979 /* Must do double calculation to avoid overflow */
980 db = t0[1] + dt10[1]*((double)(a-t0[0]))/dt10[0];
981 TEST_INT(testl,testh,db,b,q1[1],bl,bh)
982 }
983 test_t1t2= !(((s0 & 3)==0) || ((s1 & 3)==0)|| ((s2 & 3)==0) ||
984 ((sq0 & 3)==3) ||((sq1 & 3)==3)|| ((sq2 & 3)==3));
985 if(test_t1t2 && (e0 & 1))
986 { /* test t1t2 against a */
987 db = t1[1] + dt21[1]*((double)(a - t1[0]))/dt21[0];
988 TEST_INT(testl,testh,db,b,q1[1],bl,bh)
989 }
990 test_t2t0 = !(((s0 & 5)==0) || ((s1 & 5)==0)|| ((s2 & 5)==0) ||
991 ((sq0 & 5)==5) ||((sq1 & 5)==5)|| ((sq2 & 5)==5));
992 if(test_t2t0 && (e0 & 4))
993 {
994 db = t2[1] + dt02[1]*((double)(a - t2[0]))/dt02[0];
995 TEST_INT(testl,testh,db,b,q1[1],bl,bh)
996 }
997 e1 = (s1 ^ ((s1 >> 1) | (s1 << 2 & 4)));
998 cl = ch = 0;
999 if(test_t0t1 && (e1 & 2))
1000 {/* test t0t1 against b */
1001 db = t0[2] + dt10[2]*((double)(b-t0[1]))/dt10[1];
1002 TEST_INT(testl,testh,db,c,q2[2],cl,ch)
1003 }
1004 if(test_t1t2 && (e1 & 1))
1005 {/* test t1t2 against b */
1006 db = t1[2] + dt21[2]*((double)(q0[1] - t1[1]))/dt21[1];
1007 TEST_INT(testl,testh,db,c,q2[2],cl,ch)
1008 }
1009 if(test_t2t0 && (e1 & 4))
1010 {/* test t2t0 against b */
1011 db = t2[2] + dt02[2]*((double)(q0[1] - t2[1]))/dt02[1];
1012 TEST_INT(testl,testh,db,c,q2[2],cl,ch)
1013 }
1014
1015 /* test edges against c */
1016 e2 = (s2 ^ ((s2 >> 1) | (s2 << 2 & 4)));
1017 al = ah = 0;
1018 if(test_t0t1 && (e2 & 2))
1019 { /* test t0t1 against c */
1020 db = t0[0] + dt10[0]*((double)(c-t0[2]))/dt10[2];
1021 TEST_INT(testl,testh,db,a,q0[0],al,ah)
1022 }
1023 if(test_t1t2 && (e2 & 1))
1024 {
1025 db = t1[0] + dt21[0]*((double)(c - t1[2]))/dt21[2];
1026 TEST_INT(testl,testh,db,a,q0[0],al,ah)
1027 }
1028 if(test_t2t0 && (e2 & 4))
1029 { /* test t2t0 against c */
1030 db = t2[0] + dt02[0]*((double)(c - t2[2]))/dt02[2];
1031 TEST_INT(testl,testh,db,a,q0[0],al,ah)
1032 }
1033 /* Only remaining case is if some edge trivially rejected */
1034 if(!e0 || !e1 || !e2)
1035 return;
1036
1037 /* Only one/none got tested - pick either of other two/any two */
1038 /* Only need to test one edge */
1039 if(!test_t0t1 && (e0 & 2))
1040 {
1041 db = t0[1] + dt10[1]*((double)(a-t0[0]))/dt10[0];
1042 TEST_INT(testl,testh,db,b,q1[1],bl,bh)
1043 }
1044 if(!test_t1t2 && (e0 & 1))
1045 {/* test t1t2 against a */
1046 db = t1[1] + dt21[1]*((double)(a - t1[0]))/dt21[0];
1047 TEST_INT(testl,testh,db,b,q1[1],bl,bh)
1048 }
1049 if(!test_t2t0 && (e0 & 4))
1050 {
1051 db = t2[1] + dt02[1]*((double)(a - t2[0]))/dt02[0];
1052 TEST_INT(testl,testh,db,b,q1[1],bl,bh)
1053 }
1054
1055 return;
1056
1057 Lfunc_call:
1058 f.func(f.argptr,root,qt);
1059 if(!QT_IS_EMPTY(qt))
1060 QT_LEAF_SET_FLAG(qt);
1061 }
1062
1063
1064
1065 /* Leaf node: Do definitive test */
1066 QUADTREE
1067 qtLeaf_visit_tri_rev(root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02,
1068 scale, s0,s1,s2,sq0,sq1,sq2,f)
1069 int root;
1070 QUADTREE qt;
1071 BCOORD q0[3],q1[3],q2[3];
1072 BCOORD t0[3],t1[3],t2[3];
1073 BCOORD dt10[3],dt21[3],dt02[3];
1074 unsigned int scale,s0,s1,s2,sq0,sq1,sq2;
1075 FUNC f;
1076 {
1077 double db;
1078 unsigned int e0,e1,e2;
1079 BCOORD a,b,c;
1080 double p0[2], p1[2],cp;
1081 char al,ah,bl,bh,cl,ch;
1082 char testl,testh,test_t0t1,test_t1t2,test_t2t0;
1083 unsigned int ls0,ls1,ls2;
1084
1085 /* May have gotten passed trivial reject if one/two vertices are ON */
1086 a = q1[0];b= q0[1]; c= q0[2];
1087 SIDES_LESS(t0,t1,t2,ls0,ls1,ls2,a,b,c);
1088
1089 /* First check if can trivial accept: if vertex in cell */
1090 if(ls0 & ls1 & ls2)
1091 goto Lfunc_call;
1092
1093 if(ls0==0 || ls1 == 0 || ls2 ==0)
1094 return;
1095 /* Assumption: Could not trivial reject*/
1096 /* IF any coords lie on edge- must be in if couldnt reject */
1097
1098 if(t0[0]== a || t0[1] == b || t0[2] == c)
1099 goto Lfunc_call;
1100 if(t1[0]== a || t1[1] == b || t1[2] == c)
1101 goto Lfunc_call;
1102 if(t2[0]== a || t2[1] == b || t2[2] == c)
1103 goto Lfunc_call;
1104
1105 /* Test for edge crossings */
1106 /* Test t0t1 against a,b,c */
1107 /* First test if t0t1 can be trivially rejected */
1108 /* If both edges are outside bounds- dont need to test */
1109
1110 /* Test t0t1,t1t2,t2t0 against a */
1111 test_t0t1 = !(((ls0 & 6)==0) || ((ls1 & 6)==0)|| ((ls2 & 6)==0) ||
1112 ((sq0 & 6)==0) ||((sq1 & 6)==0)|| ((sq2 & 6)==0));
1113 e0 = (ls0 ^ ((ls0 >> 1) | (ls0 << 2 & 4)));
1114 bl=bh=0;
1115 /* Test t0t1,t1t2,t2t0 against a */
1116 if(test_t0t1 && (e0 & 2) )
1117 {
1118 db = t0[1] + dt10[1]*((double)(a-t0[0])/dt10[0]);
1119 TEST_INT(testl,testh,db,q1[1],b,bl,bh)
1120 }
1121 test_t1t2= !(((ls0 & 3)==0) || ((ls1 & 3)==0)|| ((ls2 & 3)==0) ||
1122 ((sq0 & 3)==0) ||((sq1 & 3)==0)|| ((sq2 & 3)==0));
1123 if(test_t1t2 && (e0 & 1))
1124 { /* test t1t2 against a */
1125 db = t1[1] + dt21[1]*((double)(a - t1[0]))/dt21[0];
1126 TEST_INT(testl,testh,db,q1[1],b,bl,bh)
1127 }
1128 test_t2t0 = !(((ls0 & 5)==0) || ((ls1 & 5)==0)|| ((ls2 & 5)==0) ||
1129 ((sq0 & 5)==0) ||((sq1 & 5)==0)|| ((sq2 & 5)==0));
1130 if(test_t2t0 && (e0 & 4))
1131 {
1132 db = t2[1] + dt02[1]*((double)(a - t2[0]))/dt02[0];
1133 TEST_INT(testl,testh,db,q1[1],b,bl,bh)
1134 }
1135 cl = ch = 0;
1136 e1 = (ls1 ^ ((ls1 >> 1) | (ls1 << 2 & 4)));
1137 if(test_t0t1 && (e1 & 2))
1138 {/* test t0t1 against b */
1139 db = t0[2] + dt10[2]*(((double)(b-t0[1]))/dt10[1]);
1140 TEST_INT(testl,testh,db,q1[2],c,cl,ch)
1141 }
1142 if(test_t1t2 && (e1 & 1))
1143 {/* test t1t2 against b */
1144 db = t1[2] + dt21[2]*((double)(b - t1[1]))/dt21[1];
1145 TEST_INT(testl,testh,db,q1[2],c,cl,ch)
1146 }
1147 if(test_t2t0 && (e1 & 4))
1148 {/* test t2t0 against b */
1149 db = t2[2] + dt02[2]*((double)(b - t2[1]))/dt02[1];
1150 TEST_INT(testl,testh,db,q1[2],c,cl,ch)
1151 }
1152 al = ah = 0;
1153 e2 = (ls2 ^ ((ls2 >> 1) | (ls2 << 2 & 4)));
1154 if(test_t0t1 && (e2 & 2))
1155 { /* test t0t1 against c */
1156 db = t0[0] + dt10[0]*(((double)(c-t0[2]))/dt10[2]);
1157 TEST_INT(testl,testh,db,q0[0],a,al,ah)
1158 }
1159 if(test_t1t2 && (e2 & 1))
1160 {
1161 db = t1[0] + dt21[0]*((double)(c - t1[2]))/dt21[2];
1162 TEST_INT(testl,testh,db,q0[0],a,al,ah)
1163 }
1164 if(test_t2t0 && (e2 & 4))
1165 { /* test t2t0 against c */
1166 db = t2[0] + dt02[0]*((double)(c - t2[2]))/dt02[2];
1167 TEST_INT(testl,testh,db,q0[0],a,al,ah)
1168 }
1169 /* Only remaining case is if some edge trivially rejected */
1170 if(!e0 || !e1 || !e2)
1171 return;
1172
1173 /* Only one/none got tested - pick either of other two/any two */
1174 /* Only need to test one edge */
1175 if(!test_t0t1 && (e0 & 2))
1176 {
1177 db = t0[1] + dt10[1]*((double)(a-t0[0]))/dt10[0];
1178 TEST_INT(testl,testh,db,q1[1],b,bl,bh)
1179 }
1180 if(!test_t1t2 && (e0 & 1))
1181 {/* test t1t2 against a */
1182 db = t1[1] + dt21[1]*((double)(a - t1[0]))/dt21[0];
1183 TEST_INT(testl,testh,db,q1[1],b,bl,bh)
1184 }
1185 if(!test_t2t0 && (e0 & 4))
1186 {
1187 db = t2[1] + dt02[1]*((double)(a - t2[0]))/dt02[0];
1188 TEST_INT(testl,testh,db,q1[1],b,bl,bh)
1189 }
1190
1191 return;
1192
1193 Lfunc_call:
1194 f.func(f.argptr,root,qt);
1195 if(!QT_IS_EMPTY(qt))
1196 QT_LEAF_SET_FLAG(qt);
1197 }
1198
1199
1200
