--- ray/src/hd/sm_qtree.c 1998/10/06 18:18:54 3.7 +++ ray/src/hd/sm_qtree.c 1998/12/28 18:07:36 3.9 @@ -27,8 +27,8 @@ int4 *quad_flag= NULL; extern FVECT Pick_v0[500],Pick_v1[500],Pick_v2[500]; extern int Pick_cnt,Pick_tri,Pick_samp; extern FVECT Pick_point[500]; +extern int Pick_q[500]; - #endif int Incnt=0; @@ -110,7 +110,7 @@ qtDone() /* free EVERYTHING */ } QUADTREE -qtLocate_leaf(qt,bcoord) +qtLocate(qt,bcoord) QUADTREE qt; BCOORD bcoord[3]; { @@ -118,361 +118,26 @@ BCOORD bcoord[3]; if(QT_IS_TREE(qt)) { - i = baryi_child(bcoord); + i = bary_child(bcoord); - return(qtLocate_leaf(QT_NTH_CHILD(qt,i),bcoord)); + return(qtLocate(QT_NTH_CHILD(qt,i),bcoord)); } else return(qt); } -/* - Return the quadtree node containing pt. It is assumed that pt is in - the root node qt with ws vertices q0,q1,q2 and plane equation peq. -*/ -QUADTREE -qtRoot_point_locate(qt,q0,q1,q2,peq,pt) -QUADTREE qt; -FVECT q0,q1,q2; -FPEQ peq; -FVECT pt; -{ - int i,x,y; - FVECT i_pt; - double bcoord[3]; - BCOORD bcoordi[3]; - - /* Will return lowest level triangle containing point: It the - point is on an edge or vertex: will return first associated - triangle encountered in the child traversal- the others can - be derived using triangle adjacency information - */ - if(QT_IS_TREE(qt)) - { - /* Find the intersection point */ - intersect_vector_plane(pt,peq,NULL,i_pt); - - x = FP_X(peq); - y = FP_Y(peq); - /* Calculate barycentric coordinates of i_pt */ - bary2d(q0[x],q0[y],q1[x],q1[y],q2[x],q2[y],i_pt[x],i_pt[y],bcoord); - - /* convert to integer coordinate */ - convert_dtol(bcoord,bcoordi); - - i = baryi_child(bcoordi); - - return(qtLocate_leaf(QT_NTH_CHILD(qt,i),bcoordi)); - } - else - return(qt); -} - - - - -/* for triangle v0-v1-v2- returns a,b,c: children are: - - v2 0: v0,a,c - /\ 1: a,v1,b - /2 \ 2: c,b,v2 - c/____\b 3: b,c,a - /\ /\ - /0 \3 /1 \ - v0____\/____\v1 - a - */ - - -qtNth_child_tri(v0,v1,v2,a,b,c,i,r0,r1,r2) -FVECT v0,v1,v2; -FVECT a,b,c; -int i; -FVECT r0,r1,r2; -{ - - if(!a) - { - /* Caution: r's must not be equal to v's:will be incorrect */ - switch(i){ - case 0: - VCOPY(r0,v0); - EDGE_MIDPOINT_VEC3(r1,v0,v1); - EDGE_MIDPOINT_VEC3(r2,v2,v0); - break; - case 1: - EDGE_MIDPOINT_VEC3(r0,v0,v1); - VCOPY(r1,v1); - EDGE_MIDPOINT_VEC3(r2,v1,v2); - break; - case 2: - EDGE_MIDPOINT_VEC3(r0,v2,v0); - EDGE_MIDPOINT_VEC3(r1,v1,v2); - VCOPY(r2,v2); - break; - case 3: - EDGE_MIDPOINT_VEC3(r0,v1,v2); - EDGE_MIDPOINT_VEC3(r1,v2,v0); - EDGE_MIDPOINT_VEC3(r2,v0,v1); - break; - } - } - else - { - switch(i){ - case 0: - VCOPY(r0,v0); VCOPY(r1,a); VCOPY(r2,c); - break; - case 1: - VCOPY(r0,a); VCOPY(r1,v1); VCOPY(r2,b); - break; - case 2: - VCOPY(r0,c); VCOPY(r1,b); VCOPY(r2,v2); - break; - case 3: - VCOPY(r0,b); VCOPY(r1,c); VCOPY(r2,a); - break; - } - } -} - -/* Add triangle "id" to all leaf level cells that are children of -quadtree pointed to by "qtptr" with cell vertices "t1,t2,t3" -that it overlaps (vertex and edge adjacencies do not count -as overlapping). If the addition of the triangle causes the cell to go over -threshold- the cell is split- and the triangle must be recursively inserted -into the new child cells: it is assumed that "v1,v2,v3" are normalized -*/ - -QUADTREE -qtRoot_add_tri(qt,q0,q1,q2,t0,t1,t2,id,n) -QUADTREE qt; -FVECT q0,q1,q2; -FVECT t0,t1,t2; -int id,n; -{ - if(stri_intersect(q0,q1,q2,t0,t1,t2)) - qt = qtAdd_tri(qt,q0,q1,q2,t0,t1,t2,id,n); - - return(qt); -} - -QUADTREE -qtRoot_remove_tri(qt,q0,q1,q2,t0,t1,t2,id,n) -QUADTREE qt; -FVECT q0,q1,q2; -FVECT t0,t1,t2; -int id,n; -{ - - if(stri_intersect(q0,q1,q2,t0,t1,t2)) - qt = qtRemove_tri(qt,q0,q1,q2,t0,t1,t2,id,n); - return(qt); -} - - -QUADTREE -qtAdd_tri(qt,q0,q1,q2,t0,t1,t2,id,n) -QUADTREE qt; -FVECT q0,q1,q2; -FVECT t0,t1,t2; -int id; -int n; -{ - FVECT a,b,c; - OBJECT tset[QT_MAXSET+1],*optr,*tptr; - FVECT r0,r1,r2; - int i; - - /* if this is tree: recurse */ - if(QT_IS_TREE(qt)) - { - QT_SET_FLAG(qt); - n++; - qtSubdivide_tri(q0,q1,q2,a,b,c); - - if(stri_intersect(t0,t1,t2,q0,a,c)) - QT_NTH_CHILD(qt,0) = qtAdd_tri(QT_NTH_CHILD(qt,0),q0,a,c,t0,t1,t2,id,n); - if(stri_intersect(t0,t1,t2,a,q1,b)) - QT_NTH_CHILD(qt,1) = qtAdd_tri(QT_NTH_CHILD(qt,1),a,q1,b,t0,t1,t2,id,n); - if(stri_intersect(t0,t1,t2,c,b,q2)) - QT_NTH_CHILD(qt,2) = qtAdd_tri(QT_NTH_CHILD(qt,2),c,b,q2,t0,t1,t2,id,n); - if(stri_intersect(t0,t1,t2,b,c,a)) - QT_NTH_CHILD(qt,3) = qtAdd_tri(QT_NTH_CHILD(qt,3),b,c,a,t0,t1,t2,id,n); - return(qt); - } - else - { - /* If this leave node emptry- create a new set */ - if(QT_IS_EMPTY(qt)) - qt = qtaddelem(qt,id); - else - { - /* If the set is too large: subdivide */ - optr = qtqueryset(qt); - - if(QT_SET_CNT(optr) < QT_SET_THRESHOLD) - qt = qtaddelem(qt,id); - else - { - if (n < QT_MAX_LEVELS) - { - /* If set size exceeds threshold: subdivide cell and - reinsert set tris into cell - */ - /* CAUTION:If QT_SET_THRESHOLD << QT_MAXSET, and dont add - more than a few triangles before expanding: then are safe here - otherwise must check to make sure set size is < MAXSET, - or qtgetset could overflow os. - */ - tptr = qtqueryset(qt); - if(QT_SET_CNT(tptr) > QT_MAXSET) - tptr = (OBJECT *)malloc((QT_SET_CNT(tptr)+1)*sizeof(OBJECT)); - else - tptr = tset; - if(!tptr) - goto memerr; - - qtgetset(tptr,qt); - n++; - qtfreeleaf(qt); - qtSubdivide(qt); - qt = qtAdd_tri(qt,q0,q1,q2,t0,t1,t2,id,n); - - for(optr = QT_SET_PTR(tptr),i = QT_SET_CNT(tptr); i > 0; i--) - { - id = QT_SET_NEXT_ELEM(optr); - if(!qtTri_from_id(id,r0,r1,r2)) - continue; - qt = qtAdd_tri(qt,q0,q1,q2,r0,r1,r2,id,n); - } - if(tptr != tset) - free(tptr); - } - else - qt = qtaddelem(qt,id); - } - } - } - return(qt); -memerr: - error(SYSTEM,"qtAdd_tri():Unable to allocate memory"); -} - - -QUADTREE -qtRemove_tri(qt,id,q0,q1,q2,t0,t1,t2) -QUADTREE qt; -int id; -FVECT q0,q1,q2; -FVECT t0,t1,t2; -{ - FVECT a,b,c; - - /* test if triangle (t0,t1,t2) overlaps cell triangle (v0,v1,v2) */ - if(!stri_intersect(t0,t1,t2,q0,q1,q2)) - return(qt); - - /* if this is tree: recurse */ - if(QT_IS_TREE(qt)) - { - qtSubdivide_tri(q0,q1,q2,a,b,c); - QT_NTH_CHILD(qt,0) = qtRemove_tri(QT_NTH_CHILD(qt,0),id,t0,t1,t2,q0,a,c); - QT_NTH_CHILD(qt,1) = qtRemove_tri(QT_NTH_CHILD(qt,1),id,t0,t1,t2,a,q1,b); - QT_NTH_CHILD(qt,2) = qtRemove_tri(QT_NTH_CHILD(qt,2),id,t0,t1,t2,c,b,q2); - QT_NTH_CHILD(qt,3) = qtRemove_tri(QT_NTH_CHILD(qt,3),id,t0,t1,t2,b,c,a); - return(qt); - } - else - { - if(QT_IS_EMPTY(qt)) - { -#ifdef DEBUG - eputs("qtRemove_tri(): triangle not found\n"); -#endif - } - /* remove id from set */ - else - { - if(!qtinset(qt,id)) - { -#ifdef DEBUG - eputs("qtRemove_tri(): tri not in set\n"); -#endif - } - else - qt = qtdelelem(qt,id); - } - } - return(qt); -} - - -QUADTREE -qtVisit_tri_interior(qt,q0,q1,q2,t0,t1,t2,n0,n1,n2,n,func,f,argptr) - QUADTREE qt; - FVECT q0,q1,q2; - FVECT t0,t1,t2; - FVECT n0,n1,n2; - int n; - int (*func)(),*f; - int *argptr; -{ - FVECT a,b,c; - - /* If qt Flag set, or qt vertices interior to t0t1t2-descend */ -tree_modified: - - if(QT_IS_TREE(qt)) - { - if(QT_IS_FLAG(qt) || point_in_stri_n(n0,n1,n2,q0)) - { - QT_SET_FLAG(qt); - qtSubdivide_tri(q0,q1,q2,a,b,c); - /* descend to children */ - QT_NTH_CHILD(qt,0) = qtVisit_tri_interior(QT_NTH_CHILD(qt,0), - q0,a,c,t0,t1,t2,n0,n1,n2,n+1,func,f,argptr); - QT_NTH_CHILD(qt,1) = qtVisit_tri_interior(QT_NTH_CHILD(qt,1), - a,q1,b,t0,t1,t2,n0,n1,n2,n+1,func,f,argptr); - QT_NTH_CHILD(qt,2) = qtVisit_tri_interior(QT_NTH_CHILD(qt,2), - c,b,q2,t0,t1,t2,n0,n1,n2,n+1,func,f,argptr); - QT_NTH_CHILD(qt,3) = qtVisit_tri_interior(QT_NTH_CHILD(qt,3), - b,c,a,t0,t1,t2,n0,n1,n2,n+1,func,f,argptr); - } - } - else - if((!QT_IS_EMPTY(qt) && QT_LEAF_IS_FLAG(qt)) || - point_in_stri_n(n0,n1,n2,q0)) - { - func(&qt,f,argptr,q0,q1,q2,t0,t1,t2,n); - if(QT_FLAG_IS_MODIFIED(*f)) - { - QT_SET_FLAG(qt); - goto tree_modified; - } - if(QT_IS_LEAF(qt)) - QT_LEAF_SET_FLAG(qt); - else - if(QT_IS_TREE(qt)) - QT_SET_FLAG(qt); - } - return(qt); -} - - - int -move_to_nbri(b,db0,db1,db2,tptr) +move_to_nbr(b,db0,db1,db2,tptr) BCOORD b[3]; BDIR db0,db1,db2; -TINT *tptr; +double *tptr; { - TINT t,dt; + double t,dt; BCOORD bc; int nbr; nbr = -1; - *tptr = 0; + *tptr = 0.0; /* Advance to next node */ if(b[0]==0 && db0 < 0) return(0); @@ -480,19 +145,16 @@ TINT *tptr; return(1); if(b[2]==0 && db2 < 0) return(2); - if(db0 < 0) { - bc = b[0]<> sfactor; - - if(t_g >= t[w]) - { - if(w == 2) - { - QT_FLAG_SET_DONE(*f); - return(qt); - } - /* The edge fits in the cell- therefore the result of shifting - db by sfactor is guaranteed to be less than MAXBCOORD - */ - /* Caution: (t[w]*db) must occur before divide by MAXBCOORD - since t[w] will always be < MAXBCOORD - */ - l = t[w] << sfactor; - /* NOTE: Change divides to Shift and multiply by sign*/ - b[0] += (l*db0)/MAXBCOORD; - b[1] += (l*db1)/MAXBCOORD; - b[2] += (l*db2)/MAXBCOORD; - w++; - db0 = db[w][0]; db1 = db[w][1]; db2 = db[w][2]; - if(sign) - { db0 *= -1;db1 *= -1; db2 *= -1;} - } - else - { - /* Caution: (t_i*db) must occur before divide by MAXBCOORD - since t_i will always be < MAXBCOORD*/ - /* NOTE: Change divides to Shift and by sign*/ - b[0] += (t_i *db0) / MAXBCOORD; - b[1] += (t_i *db1) / MAXBCOORD; - b[2] += (t_i *db2) / MAXBCOORD; - - t[w] -= t_g; - *wptr = w; - *nextptr = nbr; - return(qt); - } - } - } -} + } +} + + + + + + +#define TEST_INT(tl,th,d,q0,q1,h,l) \ + tl=d>q0;th=d> 1) | (s0 << 2 & 4))); + /* See if edge can be trivially rejected from intersetion testing */ + test_t0t1 = !(((s0 & 6)==0) || ((s1 & 6)==0)|| ((s2 & 6)==0) || + ((sq0 & 6)==6) ||((sq1 & 6)==6)|| ((sq2 & 6)==6)); + bl=bh=0; + if(test_t0t1 && (e0 & 2) ) { - first = 1; - *wptr = w = 0; + /* Must do double calculation to avoid overflow */ + db = t0[1] + dt10[1]*((double)(a-t0[0]))/dt10[0]; + TEST_INT(testl,testh,db,b,q1[1],bl,bh) } - /* Project the origin onto the root node plane */ + test_t1t2= !(((s0 & 3)==0) || ((s1 & 3)==0)|| ((s2 & 3)==0) || + ((sq0 & 3)==3) ||((sq1 & 3)==3)|| ((sq2 & 3)==3)); + if(test_t1t2 && (e0 & 1)) + { /* test t1t2 against a */ + db = t1[1] + dt21[1]*((double)(a - t1[0]))/dt21[0]; + TEST_INT(testl,testh,db,b,q1[1],bl,bh) + } + test_t2t0 = !(((s0 & 5)==0) || ((s1 & 5)==0)|| ((s2 & 5)==0) || + ((sq0 & 5)==5) ||((sq1 & 5)==5)|| ((sq2 & 5)==5)); + if(test_t2t0 && (e0 & 4)) + { + db = t2[1] + dt02[1]*((double)(a - t2[0]))/dt02[0]; + TEST_INT(testl,testh,db,b,q1[1],bl,bh) + } + e1 = (s1 ^ ((s1 >> 1) | (s1 << 2 & 4))); + cl = ch = 0; + if(test_t0t1 && (e1 & 2)) + {/* test t0t1 against b */ + db = t0[2] + dt10[2]*((double)(b-t0[1]))/dt10[1]; + TEST_INT(testl,testh,db,c,q2[2],cl,ch) + } + if(test_t1t2 && (e1 & 1)) + {/* test t1t2 against b */ + db = t1[2] + dt21[2]*((double)(q0[1] - t1[1]))/dt21[1]; + TEST_INT(testl,testh,db,c,q2[2],cl,ch) + } + if(test_t2t0 && (e1 & 4)) + {/* test t2t0 against b */ + db = t2[2] + dt02[2]*((double)(q0[1] - t2[1]))/dt02[1]; + TEST_INT(testl,testh,db,c,q2[2],cl,ch) + } + + /* test edges against c */ + e2 = (s2 ^ ((s2 >> 1) | (s2 << 2 & 4))); + al = ah = 0; + if(test_t0t1 && (e2 & 2)) + { /* test t0t1 against c */ + db = t0[0] + dt10[0]*((double)(c-t0[2]))/dt10[2]; + TEST_INT(testl,testh,db,a,q0[0],al,ah) + } + if(test_t1t2 && (e2 & 1)) + { + db = t1[0] + dt21[0]*((double)(c - t1[2]))/dt21[2]; + TEST_INT(testl,testh,db,a,q0[0],al,ah) + } + if(test_t2t0 && (e2 & 4)) + { /* test t2t0 against c */ + db = t2[0] + dt02[0]*((double)(c - t2[2]))/dt02[2]; + TEST_INT(testl,testh,db,a,q0[0],al,ah) + } + /* Only remaining case is if some edge trivially rejected */ + if(!e0 || !e1 || !e2) + return(qt); - t[0] = t[1] = t[2] = 0; - /* Find the intersection point of the origin */ - /* map to 2d by dropping maximum magnitude component of normal */ + /* Only one/none got tested - pick either of other two/any two */ + /* Only need to test one edge */ + if(!test_t0t1 && (e0 & 2)) + { + db = t0[1] + dt10[1]*((double)(a-t0[0]))/dt10[0]; + TEST_INT(testl,testh,db,b,q1[1],bl,bh) + } + if(!test_t1t2 && (e0 & 1)) + {/* test t1t2 against a */ + db = t1[1] + dt21[1]*((double)(a - t1[0]))/dt21[0]; + TEST_INT(testl,testh,db,b,q1[1],bl,bh) + } + if(!test_t2t0 && (e0 & 4)) + { + db = t2[1] + dt02[1]*((double)(a - t2[0]))/dt02[0]; + TEST_INT(testl,testh,db,b,q1[1],bl,bh) + } - x = FP_X(peq); - y = FP_Y(peq); - z = FP_Z(peq); - /* Calculate barycentric coordinates for current vertex */ - if(!first) - bary2d(q0[x],q0[y],q1[x],q1[y],q2[x],q2[y],i_pt[x],i_pt[y],b[3]); - else - /* Just starting: b[0] is the origin point: guaranteed to be valid b*/ + return(qt); + +Lfunc_call: + qt = f.func(f.argptr,root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02,scale, + s0,s1,s2,sq0,sq1,sq2,0,f,n); + return(qt); + +} + + + +/* Leaf node: Do definitive test */ +QUADTREE +qtLeaf_insert_tri_rev(root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02, + scale, s0,s1,s2,sq0,sq1,sq2,f,n) +int root; +QUADTREE qt; +BCOORD q0[3],q1[3],q2[3]; +BCOORD t0[3],t1[3],t2[3]; +BCOORD dt10[3],dt21[3],dt02[3]; +unsigned int scale,s0,s1,s2,sq0,sq1,sq2; +FUNC f; +int n; +{ + double db; + unsigned int e0,e1,e2; + BCOORD a,b,c; + double p0[2], p1[2],cp; + char al,ah,bl,bh,cl,ch; + char testl,testh,test_t0t1,test_t1t2,test_t2t0; + unsigned int ls0,ls1,ls2; + + /* May have gotten passed trivial reject if one/two vertices are ON */ + a = q1[0];b= q0[1]; c= q0[2]; + SIDES_LESS(t0,t1,t2,ls0,ls1,ls2,a,b,c); + + /* First check if can trivial accept: if vertex in cell */ + if(ls0 & ls1 & ls2) + goto Lfunc_call; + + if(ls0==0 || ls1 == 0 || ls2 ==0) + return(qt); + /* Assumption: Could not trivial reject*/ + /* IF any coords lie on edge- must be in if couldnt reject */ + + if(t0[0]== a || t0[1] == b || t0[2] == c) + goto Lfunc_call; + if(t1[0]== a || t1[1] == b || t1[2] == c) + goto Lfunc_call; + if(t2[0]== a || t2[1] == b || t2[2] == c) + goto Lfunc_call; + + /* Test for edge crossings */ + /* Test t0t1 against a,b,c */ + /* First test if t0t1 can be trivially rejected */ + /* If both edges are outside bounds- dont need to test */ + + /* Test t0t1,t1t2,t2t0 against a */ + test_t0t1 = !(((ls0 & 6)==0) || ((ls1 & 6)==0)|| ((ls2 & 6)==0) || + ((sq0 & 6)==0) ||((sq1 & 6)==0)|| ((sq2 & 6)==0)); + e0 = (ls0 ^ ((ls0 >> 1) | (ls0 << 2 & 4))); + bl=bh=0; + /* Test t0t1,t1t2,t2t0 against a */ + if(test_t0t1 && (e0 & 2) ) { - intersect_vector_plane(tri[0],peq,&(et[0]),v[0]); - bary2d(q0[x],q0[y],q1[x],q1[y],q2[x],q2[y],v[0][x],v[0][y],b[0]); - VCOPY(b[3],b[0]); + db = t0[1] + dt10[1]*((double)(a-t0[0])/dt10[0]); + TEST_INT(testl,testh,db,q1[1],b,bl,bh) } + test_t1t2= !(((ls0 & 3)==0) || ((ls1 & 3)==0)|| ((ls2 & 3)==0) || + ((sq0 & 3)==0) ||((sq1 & 3)==0)|| ((sq2 & 3)==0)); + if(test_t1t2 && (e0 & 1)) + { /* test t1t2 against a */ + db = t1[1] + dt21[1]*((double)(a - t1[0]))/dt21[0]; + TEST_INT(testl,testh,db,q1[1],b,bl,bh) + } + test_t2t0 = !(((ls0 & 5)==0) || ((ls1 & 5)==0)|| ((ls2 & 5)==0) || + ((sq0 & 5)==0) ||((sq1 & 5)==0)|| ((sq2 & 5)==0)); + if(test_t2t0 && (e0 & 4)) + { + db = t2[1] + dt02[1]*((double)(a - t2[0]))/dt02[0]; + TEST_INT(testl,testh,db,q1[1],b,bl,bh) + } + cl = ch = 0; + e1 = (ls1 ^ ((ls1 >> 1) | (ls1 << 2 & 4))); + if(test_t0t1 && (e1 & 2)) + {/* test t0t1 against b */ + db = t0[2] + dt10[2]*(((double)(b-t0[1]))/dt10[1]); + TEST_INT(testl,testh,db,q1[2],c,cl,ch) + } + if(test_t1t2 && (e1 & 1)) + {/* test t1t2 against b */ + db = t1[2] + dt21[2]*((double)(b - t1[1]))/dt21[1]; + TEST_INT(testl,testh,db,q1[2],c,cl,ch) + } + if(test_t2t0 && (e1 & 4)) + {/* test t2t0 against b */ + db = t2[2] + dt02[2]*((double)(b - t2[1]))/dt02[1]; + TEST_INT(testl,testh,db,q1[2],c,cl,ch) + } + al = ah = 0; + e2 = (ls2 ^ ((ls2 >> 1) | (ls2 << 2 & 4))); + if(test_t0t1 && (e2 & 2)) + { /* test t0t1 against c */ + db = t0[0] + dt10[0]*(((double)(c-t0[2]))/dt10[2]); + TEST_INT(testl,testh,db,q0[0],a,al,ah) + } + if(test_t1t2 && (e2 & 1)) + { + db = t1[0] + dt21[0]*((double)(c - t1[2]))/dt21[2]; + TEST_INT(testl,testh,db,q0[0],a,al,ah) + } + if(test_t2t0 && (e2 & 4)) + { /* test t2t0 against c */ + db = t2[0] + dt02[0]*((double)(c - t2[2]))/dt02[2]; + TEST_INT(testl,testh,db,q0[0],a,al,ah) + } + /* Only remaining case is if some edge trivially rejected */ + if(!e0 || !e1 || !e2) + return(qt); - j = (w+1)%3; - intersect_vector_plane(tri[j],peq,&(et[j]),v[j]); - bary2d(q0[x],q0[y],q1[x],q1[y],q2[x],q2[y],v[j][x],v[j][y],b[j]); - if(et[j] < 0.0) + /* Only one/none got tested - pick either of other two/any two */ + /* Only need to test one edge */ + if(!test_t0t1 && (e0 & 2)) { - VSUB(db[w],b[3],b[j]); - t[w] = HUGET; + db = t0[1] + dt10[1]*((double)(a-t0[0]))/dt10[0]; + TEST_INT(testl,testh,db,q1[1],b,bl,bh) } - else - { - /* NOTE: for stability: do not increment with ipt- use full dir and - calculate t: but for wrap around case: could get same problem? - */ - VSUB(db[w],b[j],b[3]); - /* Check if the point is out side of the triangle: if so t[w] =HUGET */ - if((fabs(b[j][0])>(FTINY+1.0)) ||(fabs(b[j][1])>(FTINY+1.0)) || - (fabs(b[j][2])>(FTINY+1.0))||(b[j][0] <-FTINY) || - (b[j][1]<-FTINY) ||(b[j][2]<-FTINY)) - t[w] = HUGET; - else - { - /* The next point is in the triangle- so db values will be in valid - range and t[w]= MAXT - */ - t[w] = MAXT; - if(j != 0) - for(;j < 3;j++) - { - i = (j+1)%3; - if(!first || i != 0) - { - intersect_vector_plane(tri[i],peq,&(et[i]),v[i]); - bary2d(q0[x],q0[y],q1[x],q1[y],q2[x],q2[y],v[i][x], - v[i][y],b[i]); - } - if(et[i] < 0.0) - { - VSUB(db[j],b[j],b[i]); - t[j] = HUGET; - break; - } - else - { - VSUB(db[j],b[i],b[j]); - if((fabs(b[j][0])>(FTINY+1.0))||(fabs(b[j][1])>(FTINY+1.0)) || - (fabs(b[j][2])>(FTINY+1.0))||(b[i][0] <-FTINY) || - (b[i][1]<-FTINY) ||(b[i][2]<-FTINY)) - { - t[j] = HUGET; - break; - } - else - t[j] = MAXT; - } - } + if(!test_t1t2 && (e0 & 1)) + {/* test t1t2 against a */ + db = t1[1] + dt21[1]*((double)(a - t1[0]))/dt21[0]; + TEST_INT(testl,testh,db,q1[1],b,bl,bh) } - } - bary_dtol(b[3],db,bi,dbi,t,w); - - /* trace the ray starting with this node */ - qt = qtVisit_tri_edges(qt,bi,dbi[w][0],dbi[w][1],dbi[w][2], - dbi,wptr,nextptr,t,0,0,func,f,argptr); - if(!QT_FLAG_IS_DONE(*f)) + if(!test_t2t0 && (e0 & 4)) { - b[3][0] = (double)bi[0]/(double)MAXBCOORD; - b[3][1] = (double)bi[1]/(double)MAXBCOORD; - b[3][2] = (double)bi[2]/(double)MAXBCOORD; - i_pt[x] = b[3][0]*q0[x] + b[3][1]*q1[x] + b[3][2]*q2[x]; - i_pt[y] = b[3][0]*q0[y] + b[3][1]*q1[y] + b[3][2]*q2[y]; - i_pt[z] = (-FP_N(peq)[x]*i_pt[x] - FP_N(peq)[y]*i_pt[y]-FP_D(peq))/FP_N(peq)[z]; + db = t2[1] + dt02[1]*((double)(a - t2[0]))/dt02[0]; + TEST_INT(testl,testh,db,q1[1],b,bl,bh) } + return(qt); - +Lfunc_call: + + qt = f.func(f.argptr,root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02,scale, + s0,s1,s2,sq0,sq1,sq2,1,f,n); + return(qt); + } + + + +/* ASSUMPTION: that triangle t0,t1,t2 intersects quad cell q0,q1,q2 */ + +/*-------q2--------- sq2 + / \ +s1 /sc \ s0 + qb_____qa + / \ / \ +\sq0/sa \ /sb \ /sq1 + \ q0____qc____q1/ + \ / + \ s2 / +*/ + +int Find_id=0; + +QUADTREE +qtInsert_tri(root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02,scale, + s0,s1,s2,sq0,sq1,sq2,f,n) +int root; +QUADTREE qt; +BCOORD q0[3],q1[3],q2[3]; +BCOORD t0[3],t1[3],t2[3]; +BCOORD dt10[3],dt21[3],dt02[3]; +BCOORD scale; +unsigned int s0,s1,s2,sq0,sq1,sq2; +FUNC f; +int n; +{ + BCOORD a,b,c; + BCOORD va[3],vb[3],vc[3]; + unsigned int sa,sb,sc; + + /* If a tree: trivial reject and recurse on potential children */ + if(QT_IS_TREE(qt)) + { + /* Test against new a edge: if entirely to left: only need + to visit child 0 + */ + a = q1[0] + scale; + b = q0[1] + scale; + c = q0[2] + scale; + + SIDES_GTR(t0,t1,t2,sa,sb,sc,a,b,c); + + if(sa==7) + { + vb[1] = q0[1]; + vc[2] = q0[2]; + vc[1] = b; + vb[2] = c; + vb[0] = vc[0] = a; + QT_NTH_CHILD(qt,0) = qtInsert_tri(root,QT_NTH_CHILD(qt,0),q0,vc, + vb,t0,t1,t2,dt10,dt21,dt02, scale>>1,sa,s1,s2,sq0,sb,sc,f,n+1); + return(qt); + } + if(sb==7) + { + va[0] = q1[0]; + vc[2] = q0[2]; + va[1] = vc[1] = b; + va[2] = c; + vc[0] = a; + QT_NTH_CHILD(qt,1) = qtInsert_tri(root,QT_NTH_CHILD(qt,1),vc,q1,va, + t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,sb,s2,sa,sq1,sc,f,n+1); + return(qt); + } + if(sc==7) + { + va[0] = q1[0]; + vb[1] = q0[1]; + va[1] = b; + va[2] = vb[2] = c; + vb[0] = a; + QT_NTH_CHILD(qt,2) = qtInsert_tri(root,QT_NTH_CHILD(qt,2),vb,va, + q2,t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,s1,sc,sa,sb,sq2,f,n+1); + return(qt); + } + + va[0] = q1[0]; + vb[1] = q0[1]; + vc[2] = q0[2]; + va[1] = vc[1] = b; + va[2] = vb[2] = c; + vb[0] = vc[0] = a; + /* If outside of all edges: only need to Visit 3 */ + if(sa==0 && sb==0 && sc==0) + { + QT_NTH_CHILD(qt,3) = qtInsert_tri_rev(root,QT_NTH_CHILD(qt,3),va,vb, + vc,t0,t1,t2,dt10,dt21,dt02, scale>>1,sa,sb,sc,s0,s1,s2,f,n+1); + return(qt); + } + + if(sa) + QT_NTH_CHILD(qt,0) = qtInsert_tri(root,QT_NTH_CHILD(qt,0),q0,vc,vb,t0, + t1,t2,dt10,dt21,dt02,scale>>1,sa,s1,s2,sq0,sb,sc,f,n+1); + if(sb) + QT_NTH_CHILD(qt,1) = qtInsert_tri(root,QT_NTH_CHILD(qt,1),vc,q1,va,t0, + t1,t2,dt10,dt21,dt02,scale>>1,s0,sb,s2,sa,sq1,sc,f,n+1); + if(sc) + QT_NTH_CHILD(qt,2) = qtInsert_tri(root,QT_NTH_CHILD(qt,2),vb,va,q2,t0, + t1,t2,dt10,dt21,dt02,scale>>1,s0,s1,sc,sa,sb,sq2,f,n+1); + QT_NTH_CHILD(qt,3) = qtInsert_tri_rev(root,QT_NTH_CHILD(qt,3),va,vb,vc,t0, + t1,t2,dt10,dt21,dt02,scale>>1,sa,sb,sc,s0,s1,s2,f,n+1); + return(qt); + } + /* Leaf node: Do definitive test */ + else + return(qt = qtLeaf_insert_tri(root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02, + scale,s0,s1,s2,sq0,sq1,sq2,f,n)); } QUADTREE -qtRoot_trace_ray(qt,q0,q1,q2,peq,orig,dir,nextptr,func,f,argptr) - QUADTREE qt; - FVECT q0,q1,q2; - FPEQ peq; - FVECT orig,dir; - int *nextptr; - int (*func)(); - int *f,*argptr; +qtInsert_tri_rev(root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02,scale, + s0,s1,s2,sq0,sq1,sq2,f,n) +int root; +QUADTREE qt; +BCOORD q0[3],q1[3],q2[3]; +BCOORD t0[3],t1[3],t2[3]; +BCOORD dt10[3],dt21[3],dt02[3]; +BCOORD scale; +unsigned int s0,s1,s2,sq0,sq1,sq2; +FUNC f; { - int x,y,z,nbr,w,i; - QUADTREE child; - FVECT v,i_pt; - double b[2][3],db[3],et[2],d,br[3]; - BCOORD bi[3]; - TINT t[3]; - BDIR dbi[3][3]; - - /* Project the origin onto the root node plane */ - t[0] = t[1] = t[2] = 0; + BCOORD a,b,c; + BCOORD va[3],vb[3],vc[3]; + unsigned int sa,sb,sc; - VADD(v,orig,dir); - /* Find the intersection point of the origin */ - /* map to 2d by dropping maximum magnitude component of normal */ - x = FP_X(peq); - y = FP_Y(peq); - z = FP_Z(peq); + /* If a tree: trivial reject and recurse on potential children */ + if(QT_IS_TREE(qt)) + { + /* Test against new a edge: if entirely to left: only need + to visit child 0 + */ + a = q1[0] - scale; + b = q0[1] - scale; + c = q0[2] - scale; - /* Calculate barycentric coordinates for current vertex */ - intersect_vector_plane(orig,peq,&(et[0]),i_pt); - bary2d(q0[x],q0[y],q1[x],q1[y],q2[x],q2[y],i_pt[x],i_pt[y],b[0]); + SIDES_GTR(t0,t1,t2,sa,sb,sc,a,b,c); - intersect_vector_plane(v,peq,&(et[1]),i_pt); - bary2d(q0[x],q0[y],q1[x],q1[y],q2[x],q2[y],i_pt[x],i_pt[y],b[1]); - if(et[1] < 0.0) - VSUB(db,b[0],b[1]); + if(sa==0) + { + vb[1] = q0[1]; + vc[2] = q0[2]; + vc[1] = b; + vb[2] = c; + vb[0] = vc[0] = a; + + QT_NTH_CHILD(qt,0) = qtInsert_tri_rev(root,QT_NTH_CHILD(qt,0),q0,vc, + vb,t0,t1,t2,dt10,dt21,dt02, scale>>1,sa,s1,s2,sq0,sb,sc,f,n+1); + return(qt); + } + if(sb==0) + { + va[0] = q1[0]; + vc[2] = q0[2]; + va[1] = vc[1] = b; + va[2] = c; + vc[0] = a; + QT_NTH_CHILD(qt,1) = qtInsert_tri_rev(root,QT_NTH_CHILD(qt,1),vc,q1,va, + t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,sb,s2,sa,sq1,sc,f,n+1); + return(qt); + } + if(sc==0) + { + va[0] = q1[0]; + vb[1] = q0[1]; + va[1] = b; + va[2] = vb[2] = c; + vb[0] = a; + QT_NTH_CHILD(qt,2) = qtInsert_tri_rev(root,QT_NTH_CHILD(qt,2),vb,va, + q2,t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,s1,sc,sa,sb,sq2,f,n+1); + return(qt); + } + va[0] = q1[0]; + vb[1] = q0[1]; + vc[2] = q0[2]; + va[1] = vc[1] = b; + va[2] = vb[2] = c; + vb[0] = vc[0] = a; + /* If outside of all edges: only need to Visit 3 */ + if(sa==7 && sb==7 && sc==7) + { + QT_NTH_CHILD(qt,3) = qtInsert_tri(root,QT_NTH_CHILD(qt,3),va,vb, + vc,t0,t1,t2,dt10,dt21,dt02, scale>>1,sa,sb,sc,s0,s1,s2,f,n+1); + return(qt); + } + if(sa!=7) + QT_NTH_CHILD(qt,0) = qtInsert_tri_rev(root,QT_NTH_CHILD(qt,0),q0,vc,vb, + t0,t1,t2,dt10,dt21,dt02,scale>>1,sa,s1,s2,sq0,sb,sc,f,n+1); + if(sb!=7) + QT_NTH_CHILD(qt,1) = qtInsert_tri_rev(root,QT_NTH_CHILD(qt,1),vc,q1,va, + t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,sb,s2,sa,sq1,sc,f,n+1); + if(sc!=7) + QT_NTH_CHILD(qt,2) = qtInsert_tri_rev(root,QT_NTH_CHILD(qt,2),vb,va,q2, + t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,s1,sc,sa,sb,sq2,f,n+1); + + QT_NTH_CHILD(qt,3) = qtInsert_tri(root,QT_NTH_CHILD(qt,3),va,vb,vc,t0,t1, + t2,dt10,dt21,dt02,scale>>1,sa,sb,sc,s0,s1,s2,f,n+1); + return(qt); + } + /* Leaf node: Do definitive test */ else - VSUB(db,b[1],b[0]); - t[0] = HUGET; - convert_dtol(b[0],bi); - if(et[1]<0.0 || (fabs(b[1][0])>(FTINY+1.0)) ||(fabs(b[1][1])>(FTINY+1.0)) || - (fabs(b[1][2])>(FTINY+1.0))||(b[1][0] <-FTINY) || - (b[1][1]<-FTINY) ||(b[1][2]<-FTINY)) - { - max_index(db,&d); - for(i=0; i< 3; i++) - dbi[0][i] = (BDIR)(db[i]/d*MAXBDIR); - } - else - for(i=0; i< 3; i++) - dbi[0][i] = (BDIR)(db[i]*MAXBDIR); - w=0; - /* trace the ray starting with this node */ - qt = qtVisit_tri_edges(qt,bi,dbi[0][0],dbi[0][1],dbi[0][2], dbi,&w, - nextptr,t,0,0,func,f,argptr); - if(!QT_FLAG_IS_DONE(*f)) + return(qt = qtLeaf_insert_tri_rev(root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02, + scale,s0,s1,s2,sq0,sq1,sq2,f,n)); +} + + + + +/*************************************************************************/ +/* Visit code for applying functions: NOTE THIS IS THE SAME AS INSERT CODE: + except sets flags: wanted insert to be as efficient as possible: so + broke into two sets of routines +*/ + +qtVisit_tri(root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02,scale, + s0,s1,s2,sq0,sq1,sq2,f) +int root; +QUADTREE qt; +BCOORD q0[3],q1[3],q2[3]; +BCOORD t0[3],t1[3],t2[3]; +BCOORD dt10[3],dt21[3],dt02[3]; +BCOORD scale; +unsigned int s0,s1,s2,sq0,sq1,sq2; +FUNC f; +{ + BCOORD a,b,c; + BCOORD va[3],vb[3],vc[3]; + unsigned int sa,sb,sc; + + /* If a tree: trivial reject and recurse on potential children */ + if(QT_IS_TREE(qt)) { - br[0] = (double)bi[0]/(double)MAXBCOORD; - br[1] = (double)bi[1]/(double)MAXBCOORD; - br[2] = (double)bi[2]/(double)MAXBCOORD; - orig[x] = br[0]*q0[x] + br[1]*q1[x] + br[2]*q2[x]; - orig[y] = br[0]*q0[y] + br[1]*q1[y] + br[2]*q2[y]; - orig[z]=(-FP_N(peq)[x]*orig[x] - - FP_N(peq)[y]*orig[y]-FP_D(peq))/FP_N(peq)[z]; + QT_SET_FLAG(qt); + + /* Test against new a edge: if entirely to left: only need + to visit child 0 + */ + a = q1[0] + scale; + b = q0[1] + scale; + c = q0[2] + scale; + + SIDES_GTR(t0,t1,t2,sa,sb,sc,a,b,c); + + if(sa==7) + { + vb[1] = q0[1]; + vc[2] = q0[2]; + vc[1] = b; + vb[2] = c; + vb[0] = vc[0] = a; + qtVisit_tri(root,QT_NTH_CHILD(qt,0),q0,vc, + vb,t0,t1,t2,dt10,dt21,dt02, scale>>1,sa,s1,s2,sq0,sb,sc,f); + return; + } + if(sb==7) + { + va[0] = q1[0]; + vc[2] = q0[2]; + va[1] = vc[1] = b; + va[2] = c; + vc[0] = a; + qtVisit_tri(root,QT_NTH_CHILD(qt,1),vc,q1,va, + t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,sb,s2,sa,sq1,sc,f); + return; + } + if(sc==7) + { + va[0] = q1[0]; + vb[1] = q0[1]; + va[1] = b; + va[2] = vb[2] = c; + vb[0] = a; + qtVisit_tri(root,QT_NTH_CHILD(qt,2),vb,va, + q2,t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,s1,sc,sa,sb,sq2,f); + return; + } + + va[0] = q1[0]; + vb[1] = q0[1]; + vc[2] = q0[2]; + va[1] = vc[1] = b; + va[2] = vb[2] = c; + vb[0] = vc[0] = a; + /* If outside of all edges: only need to Visit 3 */ + if(sa==0 && sb==0 && sc==0) + { + qtVisit_tri_rev(root,QT_NTH_CHILD(qt,3),va,vb, + vc,t0,t1,t2,dt10,dt21,dt02, scale>>1,sa,sb,sc,s0,s1,s2,f); + return; + } + + if(sa) + qtVisit_tri(root,QT_NTH_CHILD(qt,0),q0,vc,vb,t0, + t1,t2,dt10,dt21,dt02,scale>>1,sa,s1,s2,sq0,sb,sc,f); + if(sb) + qtVisit_tri(root,QT_NTH_CHILD(qt,1),vc,q1,va,t0, + t1,t2,dt10,dt21,dt02,scale>>1,s0,sb,s2,sa,sq1,sc,f); + if(sc) + qtVisit_tri(root,QT_NTH_CHILD(qt,2),vb,va,q2,t0, + t1,t2,dt10,dt21,dt02,scale>>1,s0,s1,sc,sa,sb,sq2,f); + qtVisit_tri_rev(root,QT_NTH_CHILD(qt,3),va,vb,vc,t0, + t1,t2,dt10,dt21,dt02,scale>>1,sa,sb,sc,s0,s1,s2,f); } - return(qt); - + /* Leaf node: Do definitive test */ + else + qtLeaf_visit_tri(root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02, + scale,s0,s1,s2,sq0,sq1,sq2,f); + } +qtVisit_tri_rev(root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02,scale, + s0,s1,s2,sq0,sq1,sq2,f) +int root; +QUADTREE qt; +BCOORD q0[3],q1[3],q2[3]; +BCOORD t0[3],t1[3],t2[3]; +BCOORD dt10[3],dt21[3],dt02[3]; +BCOORD scale; +unsigned int s0,s1,s2,sq0,sq1,sq2; +FUNC f; +{ + BCOORD a,b,c; + BCOORD va[3],vb[3],vc[3]; + unsigned int sa,sb,sc; + /* If a tree: trivial reject and recurse on potential children */ + if(QT_IS_TREE(qt)) + { + QT_SET_FLAG(qt); + /* Test against new a edge: if entirely to left: only need + to visit child 0 + */ + a = q1[0] - scale; + b = q0[1] - scale; + c = q0[2] - scale; + SIDES_GTR(t0,t1,t2,sa,sb,sc,a,b,c); + if(sa==0) + { + vb[1] = q0[1]; + vc[2] = q0[2]; + vc[1] = b; + vb[2] = c; + vb[0] = vc[0] = a; + qtVisit_tri_rev(root,QT_NTH_CHILD(qt,0),q0,vc, + vb,t0,t1,t2,dt10,dt21,dt02, scale>>1,sa,s1,s2,sq0,sb,sc,f); + return; + } + if(sb==0) + { + va[0] = q1[0]; + vc[2] = q0[2]; + va[1] = vc[1] = b; + va[2] = c; + vc[0] = a; + qtVisit_tri_rev(root,QT_NTH_CHILD(qt,1),vc,q1,va, + t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,sb,s2,sa,sq1,sc,f); + return; + } + if(sc==0) + { + va[0] = q1[0]; + vb[1] = q0[1]; + va[1] = b; + va[2] = vb[2] = c; + vb[0] = a; + qtVisit_tri_rev(root,QT_NTH_CHILD(qt,2),vb,va, + q2,t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,s1,sc,sa,sb,sq2,f); + return; + } + va[0] = q1[0]; + vb[1] = q0[1]; + vc[2] = q0[2]; + va[1] = vc[1] = b; + va[2] = vb[2] = c; + vb[0] = vc[0] = a; + /* If outside of all edges: only need to Visit 3 */ + if(sa==7 && sb==7 && sc==7) + { + qtVisit_tri(root,QT_NTH_CHILD(qt,3),va,vb, + vc,t0,t1,t2,dt10,dt21,dt02, scale>>1,sa,sb,sc,s0,s1,s2,f); + return; + } + if(sa!=7) + qtVisit_tri_rev(root,QT_NTH_CHILD(qt,0),q0,vc,vb, + t0,t1,t2,dt10,dt21,dt02,scale>>1,sa,s1,s2,sq0,sb,sc,f); + if(sb!=7) + qtVisit_tri_rev(root,QT_NTH_CHILD(qt,1),vc,q1,va, + t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,sb,s2,sa,sq1,sc,f); + if(sc!=7) + qtVisit_tri_rev(root,QT_NTH_CHILD(qt,2),vb,va,q2, + t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,s1,sc,sa,sb,sq2,f); + qtVisit_tri(root,QT_NTH_CHILD(qt,3),va,vb,vc,t0,t1, + t2,dt10,dt21,dt02,scale>>1,sa,sb,sc,s0,s1,s2,f); + return; + } + /* Leaf node: Do definitive test */ + else + qtLeaf_visit_tri_rev(root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02, + scale,s0,s1,s2,sq0,sq1,sq2,f); +} +qtLeaf_visit_tri(root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02, + scale, s0,s1,s2,sq0,sq1,sq2,f) +int root; +QUADTREE qt; +BCOORD q0[3],q1[3],q2[3]; +BCOORD t0[3],t1[3],t2[3]; +BCOORD dt10[3],dt21[3],dt02[3]; +unsigned int scale,s0,s1,s2,sq0,sq1,sq2; +FUNC f; +{ + double db; + unsigned int e0,e1,e2; + char al,ah,bl,bh,cl,ch,testl,testh; + char test_t0t1,test_t1t2,test_t2t0; + BCOORD a,b,c; + /* First check if can trivial accept: if vertex in cell */ + if(s0 & s1 & s2) + goto Lfunc_call; + + /* Assumption: Could not trivial reject*/ + /* IF any coords lie on edge- must be in if couldnt reject */ + a = q1[0];b= q0[1]; c= q0[2]; + if(t0[0]== a || t0[1] == b || t0[2] == c) + goto Lfunc_call; + if(t1[0]== a || t1[1] == b || t1[2] == c) + goto Lfunc_call; + if(t2[0]== a || t2[1] == b || t2[2] == c) + goto Lfunc_call; + + /* Test for edge crossings */ + /* Test t0t1,t1t2,t2t0 against a */ + /* Calculate edge crossings */ + e0 = (s0 ^ ((s0 >> 1) | (s0 << 2 & 4))); + /* See if edge can be trivially rejected from intersetion testing */ + test_t0t1 = !(((s0 & 6)==0) || ((s1 & 6)==0)|| ((s2 & 6)==0) || + ((sq0 & 6)==6) ||((sq1 & 6)==6)|| ((sq2 & 6)==6)); + bl=bh=0; + if(test_t0t1 && (e0 & 2) ) + { + /* Must do double calculation to avoid overflow */ + db = t0[1] + dt10[1]*((double)(a-t0[0]))/dt10[0]; + TEST_INT(testl,testh,db,b,q1[1],bl,bh) + } + test_t1t2= !(((s0 & 3)==0) || ((s1 & 3)==0)|| ((s2 & 3)==0) || + ((sq0 & 3)==3) ||((sq1 & 3)==3)|| ((sq2 & 3)==3)); + if(test_t1t2 && (e0 & 1)) + { /* test t1t2 against a */ + db = t1[1] + dt21[1]*((double)(a - t1[0]))/dt21[0]; + TEST_INT(testl,testh,db,b,q1[1],bl,bh) + } + test_t2t0 = !(((s0 & 5)==0) || ((s1 & 5)==0)|| ((s2 & 5)==0) || + ((sq0 & 5)==5) ||((sq1 & 5)==5)|| ((sq2 & 5)==5)); + if(test_t2t0 && (e0 & 4)) + { + db = t2[1] + dt02[1]*((double)(a - t2[0]))/dt02[0]; + TEST_INT(testl,testh,db,b,q1[1],bl,bh) + } + e1 = (s1 ^ ((s1 >> 1) | (s1 << 2 & 4))); + cl = ch = 0; + if(test_t0t1 && (e1 & 2)) + {/* test t0t1 against b */ + db = t0[2] + dt10[2]*((double)(b-t0[1]))/dt10[1]; + TEST_INT(testl,testh,db,c,q2[2],cl,ch) + } + if(test_t1t2 && (e1 & 1)) + {/* test t1t2 against b */ + db = t1[2] + dt21[2]*((double)(q0[1] - t1[1]))/dt21[1]; + TEST_INT(testl,testh,db,c,q2[2],cl,ch) + } + if(test_t2t0 && (e1 & 4)) + {/* test t2t0 against b */ + db = t2[2] + dt02[2]*((double)(q0[1] - t2[1]))/dt02[1]; + TEST_INT(testl,testh,db,c,q2[2],cl,ch) + } + + /* test edges against c */ + e2 = (s2 ^ ((s2 >> 1) | (s2 << 2 & 4))); + al = ah = 0; + if(test_t0t1 && (e2 & 2)) + { /* test t0t1 against c */ + db = t0[0] + dt10[0]*((double)(c-t0[2]))/dt10[2]; + TEST_INT(testl,testh,db,a,q0[0],al,ah) + } + if(test_t1t2 && (e2 & 1)) + { + db = t1[0] + dt21[0]*((double)(c - t1[2]))/dt21[2]; + TEST_INT(testl,testh,db,a,q0[0],al,ah) + } + if(test_t2t0 && (e2 & 4)) + { /* test t2t0 against c */ + db = t2[0] + dt02[0]*((double)(c - t2[2]))/dt02[2]; + TEST_INT(testl,testh,db,a,q0[0],al,ah) + } + /* Only remaining case is if some edge trivially rejected */ + if(!e0 || !e1 || !e2) + return; + + /* Only one/none got tested - pick either of other two/any two */ + /* Only need to test one edge */ + if(!test_t0t1 && (e0 & 2)) + { + db = t0[1] + dt10[1]*((double)(a-t0[0]))/dt10[0]; + TEST_INT(testl,testh,db,b,q1[1],bl,bh) + } + if(!test_t1t2 && (e0 & 1)) + {/* test t1t2 against a */ + db = t1[1] + dt21[1]*((double)(a - t1[0]))/dt21[0]; + TEST_INT(testl,testh,db,b,q1[1],bl,bh) + } + if(!test_t2t0 && (e0 & 4)) + { + db = t2[1] + dt02[1]*((double)(a - t2[0]))/dt02[0]; + TEST_INT(testl,testh,db,b,q1[1],bl,bh) + } + + return; + +Lfunc_call: + f.func(f.argptr,root,qt); + if(!QT_IS_EMPTY(qt)) + QT_LEAF_SET_FLAG(qt); +} + + + +/* Leaf node: Do definitive test */ +QUADTREE +qtLeaf_visit_tri_rev(root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02, + scale, s0,s1,s2,sq0,sq1,sq2,f) +int root; +QUADTREE qt; +BCOORD q0[3],q1[3],q2[3]; +BCOORD t0[3],t1[3],t2[3]; +BCOORD dt10[3],dt21[3],dt02[3]; +unsigned int scale,s0,s1,s2,sq0,sq1,sq2; +FUNC f; +{ + double db; + unsigned int e0,e1,e2; + BCOORD a,b,c; + double p0[2], p1[2],cp; + char al,ah,bl,bh,cl,ch; + char testl,testh,test_t0t1,test_t1t2,test_t2t0; + unsigned int ls0,ls1,ls2; + + /* May have gotten passed trivial reject if one/two vertices are ON */ + a = q1[0];b= q0[1]; c= q0[2]; + SIDES_LESS(t0,t1,t2,ls0,ls1,ls2,a,b,c); + + /* First check if can trivial accept: if vertex in cell */ + if(ls0 & ls1 & ls2) + goto Lfunc_call; + + if(ls0==0 || ls1 == 0 || ls2 ==0) + return; + /* Assumption: Could not trivial reject*/ + /* IF any coords lie on edge- must be in if couldnt reject */ + + if(t0[0]== a || t0[1] == b || t0[2] == c) + goto Lfunc_call; + if(t1[0]== a || t1[1] == b || t1[2] == c) + goto Lfunc_call; + if(t2[0]== a || t2[1] == b || t2[2] == c) + goto Lfunc_call; + + /* Test for edge crossings */ + /* Test t0t1 against a,b,c */ + /* First test if t0t1 can be trivially rejected */ + /* If both edges are outside bounds- dont need to test */ + + /* Test t0t1,t1t2,t2t0 against a */ + test_t0t1 = !(((ls0 & 6)==0) || ((ls1 & 6)==0)|| ((ls2 & 6)==0) || + ((sq0 & 6)==0) ||((sq1 & 6)==0)|| ((sq2 & 6)==0)); + e0 = (ls0 ^ ((ls0 >> 1) | (ls0 << 2 & 4))); + bl=bh=0; + /* Test t0t1,t1t2,t2t0 against a */ + if(test_t0t1 && (e0 & 2) ) + { + db = t0[1] + dt10[1]*((double)(a-t0[0])/dt10[0]); + TEST_INT(testl,testh,db,q1[1],b,bl,bh) + } + test_t1t2= !(((ls0 & 3)==0) || ((ls1 & 3)==0)|| ((ls2 & 3)==0) || + ((sq0 & 3)==0) ||((sq1 & 3)==0)|| ((sq2 & 3)==0)); + if(test_t1t2 && (e0 & 1)) + { /* test t1t2 against a */ + db = t1[1] + dt21[1]*((double)(a - t1[0]))/dt21[0]; + TEST_INT(testl,testh,db,q1[1],b,bl,bh) + } + test_t2t0 = !(((ls0 & 5)==0) || ((ls1 & 5)==0)|| ((ls2 & 5)==0) || + ((sq0 & 5)==0) ||((sq1 & 5)==0)|| ((sq2 & 5)==0)); + if(test_t2t0 && (e0 & 4)) + { + db = t2[1] + dt02[1]*((double)(a - t2[0]))/dt02[0]; + TEST_INT(testl,testh,db,q1[1],b,bl,bh) + } + cl = ch = 0; + e1 = (ls1 ^ ((ls1 >> 1) | (ls1 << 2 & 4))); + if(test_t0t1 && (e1 & 2)) + {/* test t0t1 against b */ + db = t0[2] + dt10[2]*(((double)(b-t0[1]))/dt10[1]); + TEST_INT(testl,testh,db,q1[2],c,cl,ch) + } + if(test_t1t2 && (e1 & 1)) + {/* test t1t2 against b */ + db = t1[2] + dt21[2]*((double)(b - t1[1]))/dt21[1]; + TEST_INT(testl,testh,db,q1[2],c,cl,ch) + } + if(test_t2t0 && (e1 & 4)) + {/* test t2t0 against b */ + db = t2[2] + dt02[2]*((double)(b - t2[1]))/dt02[1]; + TEST_INT(testl,testh,db,q1[2],c,cl,ch) + } + al = ah = 0; + e2 = (ls2 ^ ((ls2 >> 1) | (ls2 << 2 & 4))); + if(test_t0t1 && (e2 & 2)) + { /* test t0t1 against c */ + db = t0[0] + dt10[0]*(((double)(c-t0[2]))/dt10[2]); + TEST_INT(testl,testh,db,q0[0],a,al,ah) + } + if(test_t1t2 && (e2 & 1)) + { + db = t1[0] + dt21[0]*((double)(c - t1[2]))/dt21[2]; + TEST_INT(testl,testh,db,q0[0],a,al,ah) + } + if(test_t2t0 && (e2 & 4)) + { /* test t2t0 against c */ + db = t2[0] + dt02[0]*((double)(c - t2[2]))/dt02[2]; + TEST_INT(testl,testh,db,q0[0],a,al,ah) + } + /* Only remaining case is if some edge trivially rejected */ + if(!e0 || !e1 || !e2) + return; + + /* Only one/none got tested - pick either of other two/any two */ + /* Only need to test one edge */ + if(!test_t0t1 && (e0 & 2)) + { + db = t0[1] + dt10[1]*((double)(a-t0[0]))/dt10[0]; + TEST_INT(testl,testh,db,q1[1],b,bl,bh) + } + if(!test_t1t2 && (e0 & 1)) + {/* test t1t2 against a */ + db = t1[1] + dt21[1]*((double)(a - t1[0]))/dt21[0]; + TEST_INT(testl,testh,db,q1[1],b,bl,bh) + } + if(!test_t2t0 && (e0 & 4)) + { + db = t2[1] + dt02[1]*((double)(a - t2[0]))/dt02[0]; + TEST_INT(testl,testh,db,q1[1],b,bl,bh) + } + + return; + +Lfunc_call: + f.func(f.argptr,root,qt); + if(!QT_IS_EMPTY(qt)) + QT_LEAF_SET_FLAG(qt); +}
