--- ray/src/hd/sm_qtree.c 1999/01/05 16:52:39 3.10 +++ ray/src/hd/sm_qtree.c 2003/06/30 14:59:12 3.17 @@ -1,9 +1,6 @@ -/* Copyright (c) 1998 Silicon Graphics, Inc. */ - #ifndef lint -static char SCCSid[] = "$SunId$ SGI"; +static const char RCSid[] = "$Id: sm_qtree.c,v 3.17 2003/06/30 14:59:12 schorsch Exp $"; #endif - /* * sm_qtree.c: adapted from octree.c from radiance code */ @@ -13,25 +10,30 @@ static char SCCSid[] = "$SunId$ SGI"; * 7/28/85 */ +#include + #include "standard.h" #include "sm_flag.h" #include "sm_geom.h" +#include "object.h" #include "sm_qtree.h" -QUADTREE *quad_block[QT_MAX_BLK]; /* our quadtree */ +QUADTREE *quad_block[QT_MAX_BLK]; /* our quadtree */ static QUADTREE quad_free_list = EMPTY; /* freed octree nodes */ -static QUADTREE treetop = 0; /* next free node */ -int4 *quad_flag= NULL; +static QUADTREE treetop = 0; /* next free node */ +int32 *quad_flag= NULL; /* quadtree flags */ -#ifdef TEST_DRIVER -extern FVECT Pick_v0[500],Pick_v1[500],Pick_v2[500]; -extern int Pick_cnt,Pick_tri,Pick_samp; -extern FVECT Pick_point[500]; -extern int Pick_q[500]; +qtremovelast(qt,id) +QUADTREE qt; +OBJECT id; +{ +#ifdef DEBUG + if(qtqueryset(qt)[(*(qtqueryset(qt)))] != id) + error(CONSISTENCY,"not removed\n"); #endif -int Incnt=0; - + ((*(qtqueryset(qt)))--); +} QUADTREE qtAlloc() /* allocate a quadtree */ { @@ -52,7 +54,7 @@ qtAlloc() /* allocate a quadtree */ error(SYSTEM,"qtAlloc(): Unable to allocate memory\n"); /* Realloc the per/node flags */ - quad_flag = (int4 *)realloc((char *)quad_flag, + quad_flag = (int32 *)realloc((void *)quad_flag, (QT_BLOCK(freet)+1)*((QT_BLOCK_SIZE+7)>>3)); if (quad_flag == NULL) error(SYSTEM,"qtAlloc(): Unable to allocate memory\n"); @@ -68,7 +70,8 @@ qtClearAllFlags() /* clear all quadtree branch flags return; /* Clear the node flags*/ - bzero((char *)quad_flag, (QT_BLOCK(treetop-4)+1)*((QT_BLOCK_SIZE+7)>>3)); + memset((char *)quad_flag, '\0', + (QT_BLOCK(treetop-4)+1)*((QT_BLOCK_SIZE+7)>>3)); /* Clear set flags */ qtclearsetflags(); } @@ -99,16 +102,173 @@ qtDone() /* free EVERYTHING */ { if (quad_block[i] == NULL) break; - free((char *)quad_block[i]); + free((void *)quad_block[i]); quad_block[i] = NULL; } /* Free the flags */ - if (i) free((char *)quad_flag); + if (i) free((void *)quad_flag); quad_flag = NULL; quad_free_list = EMPTY; treetop = 0; } +/* + * bary_parent(coord,i) : Set coord to be value of pt at one level up in + * quadtree, given it was the ith child + * BCOORD coord[3]; :barycentric coordinates of point, also will hold + * result as side effect + * int i; :designates which child coord was + */ +bary_parent(coord,i) +BCOORD coord[3]; +int i; +{ + switch(i) { + case 0: + /* update bary for child */ + coord[0] = (coord[0] >> 1) + MAXBCOORD4; + coord[1] >>= 1; + coord[2] >>= 1; + break; + case 1: + coord[0] >>= 1; + coord[1] = (coord[1] >> 1) + MAXBCOORD4; + coord[2] >>= 1; + break; + + case 2: + coord[0] >>= 1; + coord[1] >>= 1; + coord[2] = (coord[2] >> 1) + MAXBCOORD4; + break; + + case 3: + coord[0] = MAXBCOORD4 - (coord[0] >> 1); + coord[1] = MAXBCOORD4 - (coord[1] >> 1); + coord[2] = MAXBCOORD4 - (coord[2] >> 1); + break; +#ifdef DEBUG + default: + eputs("bary_parent():Invalid child\n"); + break; +#endif + } +} + +/* + * bary_from_child(coord,child,next): Given that coord was the (child) child + * of the quadtree node, calculate what the (next) child + * is at the same level. + * BCOORD coord[3]; :At current level (child)th child of node,will also hold + * result as side effect + * int child,next; :Which child coord was (child), and which one + * is now desired(next) + */ +bary_from_child(coord,child,next) +BCOORD coord[3]; +int child,next; +{ +#ifdef DEBUG + if(child <0 || child > 3) + { + eputs("bary_from_child():Invalid child\n"); + return; + } + if(next <0 || next > 3) + { + eputs("bary_from_child():Invalid next\n"); + return; + } +#endif + if(next == child) + return; + + switch(child){ + case 0: + coord[0] = 0; + coord[1] = MAXBCOORD2 - coord[1]; + coord[2] = MAXBCOORD2 - coord[2]; + break; + case 1: + coord[0] = MAXBCOORD2 - coord[0]; + coord[1] = 0; + coord[2] = MAXBCOORD2 - coord[2]; + break; + case 2: + coord[0] = MAXBCOORD2 - coord[0]; + coord[1] = MAXBCOORD2 - coord[1]; + coord[2] = 0; + break; + case 3: + switch(next){ + case 0: + coord[0] = 0; + coord[1] = MAXBCOORD2 - coord[1]; + coord[2] = MAXBCOORD2 - coord[2]; + break; + case 1: + coord[0] = MAXBCOORD2 - coord[0]; + coord[1] = 0; + coord[2] = MAXBCOORD2 - coord[2]; + break; + case 2: + coord[0] = MAXBCOORD2 - coord[0]; + coord[1] = MAXBCOORD2 - coord[1]; + coord[2] = 0; + break; + } + break; + } +} + +/* + * int + * bary_child(coord): Return which child coord is of node at current level + * As side effect recalculate coord at next level + * BCOORD coord[3]; :At current level coordinates of point, will also set + * to coords at next level as side effect + */ +int +bary_child(coord) +BCOORD coord[3]; +{ + int i; + + if(coord[0] > MAXBCOORD4) + { + /* update bary for child */ + coord[0] = (coord[0]<< 1) - MAXBCOORD2; + coord[1] <<= 1; + coord[2] <<= 1; + return(0); + } + else + if(coord[1] > MAXBCOORD4) + { + coord[0] <<= 1; + coord[1] = (coord[1] << 1) - MAXBCOORD2; + coord[2] <<= 1; + return(1); + } + else + if(coord[2] > MAXBCOORD4) + { + coord[0] <<= 1; + coord[1] <<= 1; + coord[2] = (coord[2] << 1) - MAXBCOORD2; + return(2); + } + else + { + coord[0] = MAXBCOORD2 - (coord[0] << 1); + coord[1] = MAXBCOORD2 - (coord[1] << 1); + coord[2] = MAXBCOORD2 - (coord[2] << 1); + return(3); + } +} + + + QUADTREE qtLocate(qt,bcoord) QUADTREE qt; @@ -247,13 +407,6 @@ qtTrace_ray(qt,b,db0,db1,db2,nextptr,sign,sfactor,func } } - - - - - - - #define TEST_INT(tl,th,d,q0,q1,h,l) \ tl=d>q0;th=d>1,sa,s1,s2,sq0,sb,sc,f); + vb,t0,t1,t2,dt10,dt21,dt02, scale>>1,sa,s1,s2,sq0,sb,sc,f,n-1); return; } if(sb==7) @@ -791,7 +960,7 @@ FUNC f; va[2] = c; vc[0] = a; qtVisit_tri(root,QT_NTH_CHILD(qt,1),vc,q1,va, - t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,sb,s2,sa,sq1,sc,f); + t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,sb,s2,sa,sq1,sc,f,n-1); return; } if(sc==7) @@ -802,7 +971,7 @@ FUNC f; va[2] = vb[2] = c; vb[0] = a; qtVisit_tri(root,QT_NTH_CHILD(qt,2),vb,va, - q2,t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,s1,sc,sa,sb,sq2,f); + q2,t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,s1,sc,sa,sb,sq2,f,n-1); return; } @@ -816,32 +985,32 @@ FUNC f; if(sa==0 && sb==0 && sc==0) { qtVisit_tri_rev(root,QT_NTH_CHILD(qt,3),va,vb, - vc,t0,t1,t2,dt10,dt21,dt02, scale>>1,sa,sb,sc,s0,s1,s2,f); + vc,t0,t1,t2,dt10,dt21,dt02, scale>>1,sa,sb,sc,s0,s1,s2,f,n-1); return; } if(sa) qtVisit_tri(root,QT_NTH_CHILD(qt,0),q0,vc,vb,t0, - t1,t2,dt10,dt21,dt02,scale>>1,sa,s1,s2,sq0,sb,sc,f); + t1,t2,dt10,dt21,dt02,scale>>1,sa,s1,s2,sq0,sb,sc,f,n-1); if(sb) qtVisit_tri(root,QT_NTH_CHILD(qt,1),vc,q1,va,t0, - t1,t2,dt10,dt21,dt02,scale>>1,s0,sb,s2,sa,sq1,sc,f); + t1,t2,dt10,dt21,dt02,scale>>1,s0,sb,s2,sa,sq1,sc,f,n-1); if(sc) qtVisit_tri(root,QT_NTH_CHILD(qt,2),vb,va,q2,t0, - t1,t2,dt10,dt21,dt02,scale>>1,s0,s1,sc,sa,sb,sq2,f); + t1,t2,dt10,dt21,dt02,scale>>1,s0,s1,sc,sa,sb,sq2,f,n-1); qtVisit_tri_rev(root,QT_NTH_CHILD(qt,3),va,vb,vc,t0, - t1,t2,dt10,dt21,dt02,scale>>1,sa,sb,sc,s0,s1,s2,f); + t1,t2,dt10,dt21,dt02,scale>>1,sa,sb,sc,s0,s1,s2,f,n-1); } /* Leaf node: Do definitive test */ else qtLeaf_visit_tri(root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02, - scale,s0,s1,s2,sq0,sq1,sq2,f); + scale,s0,s1,s2,sq0,sq1,sq2,f,n); } qtVisit_tri_rev(root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02,scale, - s0,s1,s2,sq0,sq1,sq2,f) + s0,s1,s2,sq0,sq1,sq2,f,n) int root; QUADTREE qt; BCOORD q0[3],q1[3],q2[3]; @@ -850,11 +1019,14 @@ BCOORD dt10[3],dt21[3],dt02[3]; BCOORD scale; unsigned int s0,s1,s2,sq0,sq1,sq2; FUNC f; +int n; { BCOORD a,b,c; BCOORD va[3],vb[3],vc[3]; unsigned int sa,sb,sc; + if(n==0) + return; /* If a tree: trivial reject and recurse on potential children */ if(QT_IS_TREE(qt)) { @@ -876,7 +1048,7 @@ FUNC f; vb[2] = c; vb[0] = vc[0] = a; qtVisit_tri_rev(root,QT_NTH_CHILD(qt,0),q0,vc, - vb,t0,t1,t2,dt10,dt21,dt02, scale>>1,sa,s1,s2,sq0,sb,sc,f); + vb,t0,t1,t2,dt10,dt21,dt02, scale>>1,sa,s1,s2,sq0,sb,sc,f,n-1); return; } if(sb==0) @@ -887,7 +1059,7 @@ FUNC f; va[2] = c; vc[0] = a; qtVisit_tri_rev(root,QT_NTH_CHILD(qt,1),vc,q1,va, - t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,sb,s2,sa,sq1,sc,f); + t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,sb,s2,sa,sq1,sc,f,n-1); return; } if(sc==0) @@ -898,7 +1070,7 @@ FUNC f; va[2] = vb[2] = c; vb[0] = a; qtVisit_tri_rev(root,QT_NTH_CHILD(qt,2),vb,va, - q2,t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,s1,sc,sa,sb,sq2,f); + q2,t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,s1,sc,sa,sb,sq2,f,n-1); return; } va[0] = q1[0]; @@ -911,33 +1083,33 @@ FUNC f; if(sa==7 && sb==7 && sc==7) { qtVisit_tri(root,QT_NTH_CHILD(qt,3),va,vb, - vc,t0,t1,t2,dt10,dt21,dt02, scale>>1,sa,sb,sc,s0,s1,s2,f); + vc,t0,t1,t2,dt10,dt21,dt02, scale>>1,sa,sb,sc,s0,s1,s2,f,n-1); return; } if(sa!=7) qtVisit_tri_rev(root,QT_NTH_CHILD(qt,0),q0,vc,vb, - t0,t1,t2,dt10,dt21,dt02,scale>>1,sa,s1,s2,sq0,sb,sc,f); + t0,t1,t2,dt10,dt21,dt02,scale>>1,sa,s1,s2,sq0,sb,sc,f,n-1); if(sb!=7) qtVisit_tri_rev(root,QT_NTH_CHILD(qt,1),vc,q1,va, - t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,sb,s2,sa,sq1,sc,f); + t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,sb,s2,sa,sq1,sc,f,n-1); if(sc!=7) qtVisit_tri_rev(root,QT_NTH_CHILD(qt,2),vb,va,q2, - t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,s1,sc,sa,sb,sq2,f); + t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,s1,sc,sa,sb,sq2,f,n-1); qtVisit_tri(root,QT_NTH_CHILD(qt,3),va,vb,vc,t0,t1, - t2,dt10,dt21,dt02,scale>>1,sa,sb,sc,s0,s1,s2,f); + t2,dt10,dt21,dt02,scale>>1,sa,sb,sc,s0,s1,s2,f,n-1); return; } /* Leaf node: Do definitive test */ else qtLeaf_visit_tri_rev(root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02, - scale,s0,s1,s2,sq0,sq1,sq2,f); + scale,s0,s1,s2,sq0,sq1,sq2,f,n); } qtLeaf_visit_tri(root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02, - scale, s0,s1,s2,sq0,sq1,sq2,f) + scale, s0,s1,s2,sq0,sq1,sq2,f,n) int root; QUADTREE qt; BCOORD q0[3],q1[3],q2[3]; @@ -945,13 +1117,14 @@ BCOORD t0[3],t1[3],t2[3]; BCOORD dt10[3],dt21[3],dt02[3]; unsigned int scale,s0,s1,s2,sq0,sq1,sq2; FUNC f; +int n; { double db; unsigned int e0,e1,e2; char al,ah,bl,bh,cl,ch,testl,testh; char test_t0t1,test_t1t2,test_t2t0; BCOORD a,b,c; - + /* First check if can trivial accept: if vertex in cell */ if(s0 & s1 & s2) goto Lfunc_call; @@ -1055,9 +1228,11 @@ FUNC f; return; Lfunc_call: - f.func(f.argptr,root,qt); + + f.func(f.argptr,root,qt,n); if(!QT_IS_EMPTY(qt)) QT_LEAF_SET_FLAG(qt); + } @@ -1065,7 +1240,7 @@ Lfunc_call: /* Leaf node: Do definitive test */ QUADTREE qtLeaf_visit_tri_rev(root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02, - scale, s0,s1,s2,sq0,sq1,sq2,f) + scale, s0,s1,s2,sq0,sq1,sq2,f,n) int root; QUADTREE qt; BCOORD q0[3],q1[3],q2[3]; @@ -1073,6 +1248,7 @@ BCOORD t0[3],t1[3],t2[3]; BCOORD dt10[3],dt21[3],dt02[3]; unsigned int scale,s0,s1,s2,sq0,sq1,sq2; FUNC f; +int n; { double db; unsigned int e0,e1,e2; @@ -1191,10 +1367,199 @@ FUNC f; return; Lfunc_call: - f.func(f.argptr,root,qt); + f.func(f.argptr,root,qt,n); if(!QT_IS_EMPTY(qt)) QT_LEAF_SET_FLAG(qt); } + + +QUADTREE +qtInsert_point(root,qt,parent,q0,q1,q2,bc,scale,f,n,doneptr) +int root; +QUADTREE qt,parent; +BCOORD q0[3],q1[3],q2[3],bc[3],scale; +FUNC f; +int n,*doneptr; +{ + BCOORD a,b,c; + BCOORD va[3],vb[3],vc[3]; + + if(QT_IS_TREE(qt)) + { + a = q1[0] + scale; + b = q0[1] + scale; + c = q0[2] + scale; + if(bc[0] > a) + { + vc[0] = a; vc[1] = b; vc[2] = q0[2]; + vb[0] = a; vb[1] = q0[1]; vb[2] = c; + QT_NTH_CHILD(qt,0) = qtInsert_point(root,QT_NTH_CHILD(qt,0), + qt,q0,vc,vb,bc,scale>>1,f,n+1,doneptr); + if(!*doneptr) + { + f.func_after(f.argptr,QT_NTH_CHILD(qt,1),f,doneptr); + if(!*doneptr) + f.func_after(f.argptr,QT_NTH_CHILD(qt,2),f,doneptr); + if(!*doneptr) + f.func_after(f.argptr,QT_NTH_CHILD(qt,3),f,doneptr); + } + return(qt); + } + if(bc[1] > b) + { + vc[0] = a; vc[1] = b; vc[2] = q0[2]; + va[0] = q1[0]; va[1] = b; va[2] = c; + QT_NTH_CHILD(qt,1) =qtInsert_point(root,QT_NTH_CHILD(qt,1), + qt,vc,q1,va,bc,scale >>1,f,n+1,doneptr); + if(!*doneptr) + { + f.func_after(f.argptr,QT_NTH_CHILD(qt,0),f,doneptr); + if(!*doneptr) + f.func_after(f.argptr,QT_NTH_CHILD(qt,2),f,doneptr); + if(!*doneptr) + f.func_after(f.argptr,QT_NTH_CHILD(qt,3),f,doneptr); + } + return(qt); + } + if(bc[2] > c) + { + va[0] = q1[0]; va[1] = b; va[2] = c; + vb[0] = a; vb[1] = q0[1]; vb[2] = c; + QT_NTH_CHILD(qt,2) = qtInsert_point(root,QT_NTH_CHILD(qt,2), + qt,vb,va,q2,bc,scale>>1,f,n+1,doneptr); + if(!*doneptr) + { + f.func_after(f.argptr,QT_NTH_CHILD(qt,0),f,doneptr); + if(!*doneptr) + f.func_after(f.argptr,QT_NTH_CHILD(qt,1),f,doneptr); + if(!*doneptr) + f.func_after(f.argptr,QT_NTH_CHILD(qt,3),f,doneptr); + } + return(qt); + } + else + { + va[0] = q1[0]; va[1] = b; va[2] = c; + vb[0] = a; vb[1] = q0[1]; vb[2] = c; + vc[0] = a; vc[1] = b; vc[2] = q0[2]; + QT_NTH_CHILD(qt,3) = qtInsert_point_rev(root,QT_NTH_CHILD(qt,3), + qt,va,vb,vc,bc,scale>>1,f,n+1,doneptr); + if(!*doneptr) + { + f.func_after(f.argptr,QT_NTH_CHILD(qt,0),f,doneptr); + if(!*doneptr) + f.func_after(f.argptr,QT_NTH_CHILD(qt,1),f,doneptr); + if(!*doneptr) + f.func_after(f.argptr,QT_NTH_CHILD(qt,2),f,doneptr); + } + return(qt); + } + } + else + { + qt = f.func(f.argptr,root,qt,parent,q0,q1,q2,bc,scale,0,f,n,doneptr); + return(qt); + } +} + + +QUADTREE +qtInsert_point_rev(root,qt,parent,q0,q1,q2,bc,scale,f,n,doneptr) +int root; +QUADTREE qt,parent; +BCOORD q0[3],q1[3],q2[3],bc[3]; +BCOORD scale; +FUNC f; +int n,*doneptr; +{ + BCOORD a,b,c; + BCOORD va[3],vb[3],vc[3]; + + if(QT_IS_TREE(qt)) + { + a = q1[0] - scale; + b = q0[1] - scale; + c = q0[2] - scale; + if(bc[0] < a) + { + vc[0] = a; vc[1] = b; vc[2] = q0[2]; + vb[0] = a; vb[1] = q0[1]; vb[2] = c; + QT_NTH_CHILD(qt,0) = qtInsert_point_rev(root,QT_NTH_CHILD(qt,0), + qt,q0,vc,vb,bc,scale>>1,f,n+1,doneptr); + if(!*doneptr) + { + f.func_after(f.argptr,QT_NTH_CHILD(qt,1),f,doneptr); + if(!*doneptr) + f.func_after(f.argptr,QT_NTH_CHILD(qt,2),f,doneptr); + if(!*doneptr) + f.func_after(f.argptr,QT_NTH_CHILD(qt,3),f,doneptr); + } + return(qt); + } + if(bc[1] < b) + { + vc[0] = a; vc[1] = b; vc[2] = q0[2]; + va[0] = q1[0]; va[1] = b; va[2] = c; + QT_NTH_CHILD(qt,1) = qtInsert_point_rev(root,QT_NTH_CHILD(qt,1), + qt,vc,q1,va,bc,scale>>1,f,n+1,doneptr); + if(!*doneptr) + { + f.func_after(f.argptr,QT_NTH_CHILD(qt,0),f,doneptr); + if(!*doneptr) + f.func_after(f.argptr,QT_NTH_CHILD(qt,2),f,doneptr); + if(!*doneptr) + f.func_after(f.argptr,QT_NTH_CHILD(qt,3),f,doneptr); + } + return(qt); + } + if(bc[2] < c) + { + va[0] = q1[0]; va[1] = b; va[2] = c; + vb[0] = a; vb[1] = q0[1]; vb[2] = c; + QT_NTH_CHILD(qt,2) = qtInsert_point_rev(root,QT_NTH_CHILD(qt,2), + qt,vb,va,q2,bc,scale>>1,f,n+1,doneptr); + if(!*doneptr) + { + f.func_after(f.argptr,QT_NTH_CHILD(qt,0),f,doneptr); + if(!*doneptr) + f.func_after(f.argptr,QT_NTH_CHILD(qt,1),f,doneptr); + if(!*doneptr) + f.func_after(f.argptr,QT_NTH_CHILD(qt,3),f,doneptr); + } + return(qt); + } + else + { + va[0] = q1[0]; va[1] = b; va[2] = c; + vb[0] = a; vb[1] = q0[1]; vb[2] = c; + vc[0] = a; vc[1] = b; vc[2] = q0[2]; + QT_NTH_CHILD(qt,3) = qtInsert_point(root,QT_NTH_CHILD(qt,3), + qt,va,vb,vc,bc,scale>>1,f,n+1,doneptr); + if(!*doneptr) + { + f.func_after(f.argptr,QT_NTH_CHILD(qt,0),f,doneptr); + if(!*doneptr) + f.func_after(f.argptr,QT_NTH_CHILD(qt,1),f,doneptr); + if(!*doneptr) + f.func_after(f.argptr,QT_NTH_CHILD(qt,2),f,doneptr); + } + return(qt); + } + } + else + { + qt = f.func(f.argptr,root,qt,parent,q0,q1,q2,bc,scale,1,f,n,doneptr); + return(qt); + } +} + + + + + + + +
