--- ray/src/hd/sm_qtree.c 1999/06/10 15:22:23 3.13 +++ ray/src/hd/sm_qtree.c 2003/06/20 00:25:49 3.16 @@ -1,9 +1,6 @@ -/* Copyright (c) 1998 Silicon Graphics, Inc. */ - #ifndef lint -static char SCCSid[] = "$SunId$ SGI"; +static const char RCSid[] = "$Id: sm_qtree.c,v 3.16 2003/06/20 00:25:49 greg Exp $"; #endif - /* * sm_qtree.c: adapted from octree.c from radiance code */ @@ -16,27 +13,23 @@ static char SCCSid[] = "$SunId$ SGI"; #include "standard.h" #include "sm_flag.h" #include "sm_geom.h" +#include "object.h" #include "sm_qtree.h" -QUADTREE *quad_block[QT_MAX_BLK]; /* our quadtree */ +QUADTREE *quad_block[QT_MAX_BLK]; /* our quadtree */ static QUADTREE quad_free_list = EMPTY; /* freed octree nodes */ -static QUADTREE treetop = 0; /* next free node */ -int4 *quad_flag= NULL; +static QUADTREE treetop = 0; /* next free node */ +int32 *quad_flag= NULL; /* quadtree flags */ -#ifdef TEST_DRIVER -extern FVECT Pick_v0[500],Pick_v1[500],Pick_v2[500]; -extern int Pick_cnt,Pick_tri,Pick_samp; -extern FVECT Pick_point[500]; -extern int Pick_q[500]; -#endif - qtremovelast(qt,id) QUADTREE qt; -int id; +OBJECT id; { +#ifdef DEBUG if(qtqueryset(qt)[(*(qtqueryset(qt)))] != id) error(CONSISTENCY,"not removed\n"); +#endif ((*(qtqueryset(qt)))--); } QUADTREE @@ -59,7 +52,7 @@ qtAlloc() /* allocate a quadtree */ error(SYSTEM,"qtAlloc(): Unable to allocate memory\n"); /* Realloc the per/node flags */ - quad_flag = (int4 *)realloc((char *)quad_flag, + quad_flag = (int32 *)realloc((void *)quad_flag, (QT_BLOCK(freet)+1)*((QT_BLOCK_SIZE+7)>>3)); if (quad_flag == NULL) error(SYSTEM,"qtAlloc(): Unable to allocate memory\n"); @@ -106,16 +99,173 @@ qtDone() /* free EVERYTHING */ { if (quad_block[i] == NULL) break; - free((char *)quad_block[i]); + free((void *)quad_block[i]); quad_block[i] = NULL; } /* Free the flags */ - if (i) free((char *)quad_flag); + if (i) free((void *)quad_flag); quad_flag = NULL; quad_free_list = EMPTY; treetop = 0; } +/* + * bary_parent(coord,i) : Set coord to be value of pt at one level up in + * quadtree, given it was the ith child + * BCOORD coord[3]; :barycentric coordinates of point, also will hold + * result as side effect + * int i; :designates which child coord was + */ +bary_parent(coord,i) +BCOORD coord[3]; +int i; +{ + switch(i) { + case 0: + /* update bary for child */ + coord[0] = (coord[0] >> 1) + MAXBCOORD4; + coord[1] >>= 1; + coord[2] >>= 1; + break; + case 1: + coord[0] >>= 1; + coord[1] = (coord[1] >> 1) + MAXBCOORD4; + coord[2] >>= 1; + break; + + case 2: + coord[0] >>= 1; + coord[1] >>= 1; + coord[2] = (coord[2] >> 1) + MAXBCOORD4; + break; + + case 3: + coord[0] = MAXBCOORD4 - (coord[0] >> 1); + coord[1] = MAXBCOORD4 - (coord[1] >> 1); + coord[2] = MAXBCOORD4 - (coord[2] >> 1); + break; +#ifdef DEBUG + default: + eputs("bary_parent():Invalid child\n"); + break; +#endif + } +} + +/* + * bary_from_child(coord,child,next): Given that coord was the (child) child + * of the quadtree node, calculate what the (next) child + * is at the same level. + * BCOORD coord[3]; :At current level (child)th child of node,will also hold + * result as side effect + * int child,next; :Which child coord was (child), and which one + * is now desired(next) + */ +bary_from_child(coord,child,next) +BCOORD coord[3]; +int child,next; +{ +#ifdef DEBUG + if(child <0 || child > 3) + { + eputs("bary_from_child():Invalid child\n"); + return; + } + if(next <0 || next > 3) + { + eputs("bary_from_child():Invalid next\n"); + return; + } +#endif + if(next == child) + return; + + switch(child){ + case 0: + coord[0] = 0; + coord[1] = MAXBCOORD2 - coord[1]; + coord[2] = MAXBCOORD2 - coord[2]; + break; + case 1: + coord[0] = MAXBCOORD2 - coord[0]; + coord[1] = 0; + coord[2] = MAXBCOORD2 - coord[2]; + break; + case 2: + coord[0] = MAXBCOORD2 - coord[0]; + coord[1] = MAXBCOORD2 - coord[1]; + coord[2] = 0; + break; + case 3: + switch(next){ + case 0: + coord[0] = 0; + coord[1] = MAXBCOORD2 - coord[1]; + coord[2] = MAXBCOORD2 - coord[2]; + break; + case 1: + coord[0] = MAXBCOORD2 - coord[0]; + coord[1] = 0; + coord[2] = MAXBCOORD2 - coord[2]; + break; + case 2: + coord[0] = MAXBCOORD2 - coord[0]; + coord[1] = MAXBCOORD2 - coord[1]; + coord[2] = 0; + break; + } + break; + } +} + +/* + * int + * bary_child(coord): Return which child coord is of node at current level + * As side effect recalculate coord at next level + * BCOORD coord[3]; :At current level coordinates of point, will also set + * to coords at next level as side effect + */ +int +bary_child(coord) +BCOORD coord[3]; +{ + int i; + + if(coord[0] > MAXBCOORD4) + { + /* update bary for child */ + coord[0] = (coord[0]<< 1) - MAXBCOORD2; + coord[1] <<= 1; + coord[2] <<= 1; + return(0); + } + else + if(coord[1] > MAXBCOORD4) + { + coord[0] <<= 1; + coord[1] = (coord[1] << 1) - MAXBCOORD2; + coord[2] <<= 1; + return(1); + } + else + if(coord[2] > MAXBCOORD4) + { + coord[0] <<= 1; + coord[1] <<= 1; + coord[2] = (coord[2] << 1) - MAXBCOORD2; + return(2); + } + else + { + coord[0] = MAXBCOORD2 - (coord[0] << 1); + coord[1] = MAXBCOORD2 - (coord[1] << 1); + coord[2] = MAXBCOORD2 - (coord[2] << 1); + return(3); + } +} + + + QUADTREE qtLocate(qt,bcoord) QUADTREE qt; @@ -254,13 +404,6 @@ qtTrace_ray(qt,b,db0,db1,db2,nextptr,sign,sfactor,func } } - - - - - - - #define TEST_INT(tl,th,d,q0,q1,h,l) \ tl=d>q0;th=d
