--- ray/src/hd/sm_qtree.c 1999/01/05 16:52:39 3.10 +++ ray/src/hd/sm_qtree.c 1999/06/10 15:22:23 3.13 @@ -30,8 +30,15 @@ extern FVECT Pick_point[500]; extern int Pick_q[500]; #endif -int Incnt=0; +qtremovelast(qt,id) +QUADTREE qt; +int id; +{ + if(qtqueryset(qt)[(*(qtqueryset(qt)))] != id) + error(CONSISTENCY,"not removed\n"); + ((*(qtqueryset(qt)))--); +} QUADTREE qtAlloc() /* allocate a quadtree */ { @@ -281,18 +288,24 @@ int n; /* First check if can trivial accept: if vertex in cell */ if(s0 & s1 & s2) + { goto Lfunc_call; - + } /* Assumption: Could not trivial reject*/ /* IF any coords lie on edge- must be in if couldnt reject */ a = q1[0];b= q0[1]; c= q0[2]; if(t0[0]== a || t0[1] == b || t0[2] == c) + { goto Lfunc_call; + } if(t1[0]== a || t1[1] == b || t1[2] == c) + { goto Lfunc_call; + } if(t2[0]== a || t2[1] == b || t2[2] == c) + { goto Lfunc_call; - + } /* Test for edge crossings */ /* Test t0t1,t1t2,t2t0 against a */ /* Calculate edge crossings */ @@ -411,26 +424,33 @@ int n; char testl,testh,test_t0t1,test_t1t2,test_t2t0; unsigned int ls0,ls1,ls2; + /* May have gotten passed trivial reject if one/two vertices are ON */ a = q1[0];b= q0[1]; c= q0[2]; SIDES_LESS(t0,t1,t2,ls0,ls1,ls2,a,b,c); /* First check if can trivial accept: if vertex in cell */ if(ls0 & ls1 & ls2) + { goto Lfunc_call; - + } if(ls0==0 || ls1 == 0 || ls2 ==0) return(qt); /* Assumption: Could not trivial reject*/ /* IF any coords lie on edge- must be in if couldnt reject */ if(t0[0]== a || t0[1] == b || t0[2] == c) + { goto Lfunc_call; + } if(t1[0]== a || t1[1] == b || t1[2] == c) + { goto Lfunc_call; + } if(t2[0]== a || t2[1] == b || t2[2] == c) + { goto Lfunc_call; - + } /* Test for edge crossings */ /* Test t0t1 against a,b,c */ /* First test if t0t1 can be trivially rejected */ @@ -454,7 +474,7 @@ int n; db = t1[1] + dt21[1]*((double)(a - t1[0]))/dt21[0]; TEST_INT(testl,testh,db,q1[1],b,bl,bh) } - test_t2t0 = !(((ls0 & 5)==0) || ((ls1 & 5)==0)|| ((ls2 & 5)==0) || + test_t2t0 = !(((ls0 & 5)==0) || ((ls1 & 5)==0)|| ((ls2 & 5)==0) || ((sq0 & 5)==0) ||((sq1 & 5)==0)|| ((sq2 & 5)==0)); if(test_t2t0 && (e0 & 4)) { @@ -519,7 +539,6 @@ int n; return(qt); Lfunc_call: - qt = f.func(f.argptr,root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02,scale, s0,s1,s2,sq0,sq1,sq2,1,f,n); return(qt); @@ -650,6 +669,7 @@ BCOORD dt10[3],dt21[3],dt02[3]; BCOORD scale; unsigned int s0,s1,s2,sq0,sq1,sq2; FUNC f; +int n; { BCOORD a,b,c; BCOORD va[3],vb[3],vc[3]; @@ -740,11 +760,11 @@ FUNC f; /*************************************************************************/ /* Visit code for applying functions: NOTE THIS IS THE SAME AS INSERT CODE: except sets flags: wanted insert to be as efficient as possible: so - broke into two sets of routines + broke into two sets of routines. Also traverses only to n levels. */ qtVisit_tri(root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02,scale, - s0,s1,s2,sq0,sq1,sq2,f) + s0,s1,s2,sq0,sq1,sq2,f,n) int root; QUADTREE qt; BCOORD q0[3],q1[3],q2[3]; @@ -753,11 +773,14 @@ BCOORD dt10[3],dt21[3],dt02[3]; BCOORD scale; unsigned int s0,s1,s2,sq0,sq1,sq2; FUNC f; +int n; { BCOORD a,b,c; BCOORD va[3],vb[3],vc[3]; unsigned int sa,sb,sc; + if(n == 0) + return; /* If a tree: trivial reject and recurse on potential children */ if(QT_IS_TREE(qt)) { @@ -780,7 +803,7 @@ FUNC f; vb[2] = c; vb[0] = vc[0] = a; qtVisit_tri(root,QT_NTH_CHILD(qt,0),q0,vc, - vb,t0,t1,t2,dt10,dt21,dt02, scale>>1,sa,s1,s2,sq0,sb,sc,f); + vb,t0,t1,t2,dt10,dt21,dt02, scale>>1,sa,s1,s2,sq0,sb,sc,f,n-1); return; } if(sb==7) @@ -791,7 +814,7 @@ FUNC f; va[2] = c; vc[0] = a; qtVisit_tri(root,QT_NTH_CHILD(qt,1),vc,q1,va, - t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,sb,s2,sa,sq1,sc,f); + t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,sb,s2,sa,sq1,sc,f,n-1); return; } if(sc==7) @@ -802,7 +825,7 @@ FUNC f; va[2] = vb[2] = c; vb[0] = a; qtVisit_tri(root,QT_NTH_CHILD(qt,2),vb,va, - q2,t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,s1,sc,sa,sb,sq2,f); + q2,t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,s1,sc,sa,sb,sq2,f,n-1); return; } @@ -816,32 +839,32 @@ FUNC f; if(sa==0 && sb==0 && sc==0) { qtVisit_tri_rev(root,QT_NTH_CHILD(qt,3),va,vb, - vc,t0,t1,t2,dt10,dt21,dt02, scale>>1,sa,sb,sc,s0,s1,s2,f); + vc,t0,t1,t2,dt10,dt21,dt02, scale>>1,sa,sb,sc,s0,s1,s2,f,n-1); return; } if(sa) qtVisit_tri(root,QT_NTH_CHILD(qt,0),q0,vc,vb,t0, - t1,t2,dt10,dt21,dt02,scale>>1,sa,s1,s2,sq0,sb,sc,f); + t1,t2,dt10,dt21,dt02,scale>>1,sa,s1,s2,sq0,sb,sc,f,n-1); if(sb) qtVisit_tri(root,QT_NTH_CHILD(qt,1),vc,q1,va,t0, - t1,t2,dt10,dt21,dt02,scale>>1,s0,sb,s2,sa,sq1,sc,f); + t1,t2,dt10,dt21,dt02,scale>>1,s0,sb,s2,sa,sq1,sc,f,n-1); if(sc) qtVisit_tri(root,QT_NTH_CHILD(qt,2),vb,va,q2,t0, - t1,t2,dt10,dt21,dt02,scale>>1,s0,s1,sc,sa,sb,sq2,f); + t1,t2,dt10,dt21,dt02,scale>>1,s0,s1,sc,sa,sb,sq2,f,n-1); qtVisit_tri_rev(root,QT_NTH_CHILD(qt,3),va,vb,vc,t0, - t1,t2,dt10,dt21,dt02,scale>>1,sa,sb,sc,s0,s1,s2,f); + t1,t2,dt10,dt21,dt02,scale>>1,sa,sb,sc,s0,s1,s2,f,n-1); } /* Leaf node: Do definitive test */ else qtLeaf_visit_tri(root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02, - scale,s0,s1,s2,sq0,sq1,sq2,f); + scale,s0,s1,s2,sq0,sq1,sq2,f,n); } qtVisit_tri_rev(root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02,scale, - s0,s1,s2,sq0,sq1,sq2,f) + s0,s1,s2,sq0,sq1,sq2,f,n) int root; QUADTREE qt; BCOORD q0[3],q1[3],q2[3]; @@ -850,11 +873,14 @@ BCOORD dt10[3],dt21[3],dt02[3]; BCOORD scale; unsigned int s0,s1,s2,sq0,sq1,sq2; FUNC f; +int n; { BCOORD a,b,c; BCOORD va[3],vb[3],vc[3]; unsigned int sa,sb,sc; + if(n==0) + return; /* If a tree: trivial reject and recurse on potential children */ if(QT_IS_TREE(qt)) { @@ -876,7 +902,7 @@ FUNC f; vb[2] = c; vb[0] = vc[0] = a; qtVisit_tri_rev(root,QT_NTH_CHILD(qt,0),q0,vc, - vb,t0,t1,t2,dt10,dt21,dt02, scale>>1,sa,s1,s2,sq0,sb,sc,f); + vb,t0,t1,t2,dt10,dt21,dt02, scale>>1,sa,s1,s2,sq0,sb,sc,f,n-1); return; } if(sb==0) @@ -887,7 +913,7 @@ FUNC f; va[2] = c; vc[0] = a; qtVisit_tri_rev(root,QT_NTH_CHILD(qt,1),vc,q1,va, - t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,sb,s2,sa,sq1,sc,f); + t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,sb,s2,sa,sq1,sc,f,n-1); return; } if(sc==0) @@ -898,7 +924,7 @@ FUNC f; va[2] = vb[2] = c; vb[0] = a; qtVisit_tri_rev(root,QT_NTH_CHILD(qt,2),vb,va, - q2,t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,s1,sc,sa,sb,sq2,f); + q2,t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,s1,sc,sa,sb,sq2,f,n-1); return; } va[0] = q1[0]; @@ -911,33 +937,33 @@ FUNC f; if(sa==7 && sb==7 && sc==7) { qtVisit_tri(root,QT_NTH_CHILD(qt,3),va,vb, - vc,t0,t1,t2,dt10,dt21,dt02, scale>>1,sa,sb,sc,s0,s1,s2,f); + vc,t0,t1,t2,dt10,dt21,dt02, scale>>1,sa,sb,sc,s0,s1,s2,f,n-1); return; } if(sa!=7) qtVisit_tri_rev(root,QT_NTH_CHILD(qt,0),q0,vc,vb, - t0,t1,t2,dt10,dt21,dt02,scale>>1,sa,s1,s2,sq0,sb,sc,f); + t0,t1,t2,dt10,dt21,dt02,scale>>1,sa,s1,s2,sq0,sb,sc,f,n-1); if(sb!=7) qtVisit_tri_rev(root,QT_NTH_CHILD(qt,1),vc,q1,va, - t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,sb,s2,sa,sq1,sc,f); + t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,sb,s2,sa,sq1,sc,f,n-1); if(sc!=7) qtVisit_tri_rev(root,QT_NTH_CHILD(qt,2),vb,va,q2, - t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,s1,sc,sa,sb,sq2,f); + t0,t1,t2,dt10,dt21,dt02,scale>>1,s0,s1,sc,sa,sb,sq2,f,n-1); qtVisit_tri(root,QT_NTH_CHILD(qt,3),va,vb,vc,t0,t1, - t2,dt10,dt21,dt02,scale>>1,sa,sb,sc,s0,s1,s2,f); + t2,dt10,dt21,dt02,scale>>1,sa,sb,sc,s0,s1,s2,f,n-1); return; } /* Leaf node: Do definitive test */ else qtLeaf_visit_tri_rev(root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02, - scale,s0,s1,s2,sq0,sq1,sq2,f); + scale,s0,s1,s2,sq0,sq1,sq2,f,n); } qtLeaf_visit_tri(root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02, - scale, s0,s1,s2,sq0,sq1,sq2,f) + scale, s0,s1,s2,sq0,sq1,sq2,f,n) int root; QUADTREE qt; BCOORD q0[3],q1[3],q2[3]; @@ -945,13 +971,14 @@ BCOORD t0[3],t1[3],t2[3]; BCOORD dt10[3],dt21[3],dt02[3]; unsigned int scale,s0,s1,s2,sq0,sq1,sq2; FUNC f; +int n; { double db; unsigned int e0,e1,e2; char al,ah,bl,bh,cl,ch,testl,testh; char test_t0t1,test_t1t2,test_t2t0; BCOORD a,b,c; - + /* First check if can trivial accept: if vertex in cell */ if(s0 & s1 & s2) goto Lfunc_call; @@ -1055,9 +1082,11 @@ FUNC f; return; Lfunc_call: - f.func(f.argptr,root,qt); + + f.func(f.argptr,root,qt,n); if(!QT_IS_EMPTY(qt)) QT_LEAF_SET_FLAG(qt); + } @@ -1065,7 +1094,7 @@ Lfunc_call: /* Leaf node: Do definitive test */ QUADTREE qtLeaf_visit_tri_rev(root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02, - scale, s0,s1,s2,sq0,sq1,sq2,f) + scale, s0,s1,s2,sq0,sq1,sq2,f,n) int root; QUADTREE qt; BCOORD q0[3],q1[3],q2[3]; @@ -1073,6 +1102,7 @@ BCOORD t0[3],t1[3],t2[3]; BCOORD dt10[3],dt21[3],dt02[3]; unsigned int scale,s0,s1,s2,sq0,sq1,sq2; FUNC f; +int n; { double db; unsigned int e0,e1,e2; @@ -1191,10 +1221,198 @@ FUNC f; return; Lfunc_call: - f.func(f.argptr,root,qt); + f.func(f.argptr,root,qt,n); if(!QT_IS_EMPTY(qt)) QT_LEAF_SET_FLAG(qt); } + + +QUADTREE +qtInsert_point(root,qt,parent,q0,q1,q2,bc,scale,f,n,doneptr) +int root; +QUADTREE qt,parent; +BCOORD q0[3],q1[3],q2[3],bc[3],scale; +FUNC f; +int n,*doneptr; +{ + BCOORD a,b,c; + BCOORD va[3],vb[3],vc[3]; + + if(QT_IS_TREE(qt)) + { + a = q1[0] + scale; + b = q0[1] + scale; + c = q0[2] + scale; + if(bc[0] > a) + { + vc[0] = a; vc[1] = b; vc[2] = q0[2]; + vb[0] = a; vb[1] = q0[1]; vb[2] = c; + QT_NTH_CHILD(qt,0) = qtInsert_point(root,QT_NTH_CHILD(qt,0), + qt,q0,vc,vb,bc,scale>>1,f,n+1,doneptr); + if(!*doneptr) + { + f.func_after(f.argptr,QT_NTH_CHILD(qt,1),f,doneptr); + if(!*doneptr) + f.func_after(f.argptr,QT_NTH_CHILD(qt,2),f,doneptr); + if(!*doneptr) + f.func_after(f.argptr,QT_NTH_CHILD(qt,3),f,doneptr); + } + return(qt); + } + if(bc[1] > b) + { + vc[0] = a; vc[1] = b; vc[2] = q0[2]; + va[0] = q1[0]; va[1] = b; va[2] = c; + QT_NTH_CHILD(qt,1) =qtInsert_point(root,QT_NTH_CHILD(qt,1), + qt,vc,q1,va,bc,scale >>1,f,n+1,doneptr); + if(!*doneptr) + { + f.func_after(f.argptr,QT_NTH_CHILD(qt,0),f,doneptr); + if(!*doneptr) + f.func_after(f.argptr,QT_NTH_CHILD(qt,2),f,doneptr); + if(!*doneptr) + f.func_after(f.argptr,QT_NTH_CHILD(qt,3),f,doneptr); + } + return(qt); + } + if(bc[2] > c) + { + va[0] = q1[0]; va[1] = b; va[2] = c; + vb[0] = a; vb[1] = q0[1]; vb[2] = c; + QT_NTH_CHILD(qt,2) = qtInsert_point(root,QT_NTH_CHILD(qt,2), + qt,vb,va,q2,bc,scale>>1,f,n+1,doneptr); + if(!*doneptr) + { + f.func_after(f.argptr,QT_NTH_CHILD(qt,0),f,doneptr); + if(!*doneptr) + f.func_after(f.argptr,QT_NTH_CHILD(qt,1),f,doneptr); + if(!*doneptr) + f.func_after(f.argptr,QT_NTH_CHILD(qt,3),f,doneptr); + } + return(qt); + } + else + { + va[0] = q1[0]; va[1] = b; va[2] = c; + vb[0] = a; vb[1] = q0[1]; vb[2] = c; + vc[0] = a; vc[1] = b; vc[2] = q0[2]; + QT_NTH_CHILD(qt,3) = qtInsert_point_rev(root,QT_NTH_CHILD(qt,3), + qt,va,vb,vc,bc,scale>>1,f,n+1,doneptr); + if(!*doneptr) + { + f.func_after(f.argptr,QT_NTH_CHILD(qt,0),f,doneptr); + if(!*doneptr) + f.func_after(f.argptr,QT_NTH_CHILD(qt,1),f,doneptr); + if(!*doneptr) + f.func_after(f.argptr,QT_NTH_CHILD(qt,2),f,doneptr); + } + return(qt); + } + } + else + { + qt = f.func(f.argptr,root,qt,parent,q0,q1,q2,bc,scale,0,f,n,doneptr); + return(qt); + } +} + + +QUADTREE +qtInsert_point_rev(root,qt,parent,q0,q1,q2,bc,scale,f,n,doneptr) +int root; +QUADTREE qt,parent; +BCOORD q0[3],q1[3],q2[3],bc[3]; +BCOORD scale; +FUNC f; +int n,*doneptr; +{ + BCOORD a,b,c; + BCOORD va[3],vb[3],vc[3]; + + if(QT_IS_TREE(qt)) + { + a = q1[0] - scale; + b = q0[1] - scale; + c = q0[2] - scale; + if(bc[0] < a) + { + vc[0] = a; vc[1] = b; vc[2] = q0[2]; + vb[0] = a; vb[1] = q0[1]; vb[2] = c; + QT_NTH_CHILD(qt,0) = qtInsert_point_rev(root,QT_NTH_CHILD(qt,0), + qt,q0,vc,vb,bc,scale>>1,f,n+1,doneptr); + if(!*doneptr) + { + f.func_after(f.argptr,QT_NTH_CHILD(qt,1),f,doneptr); + if(!*doneptr) + f.func_after(f.argptr,QT_NTH_CHILD(qt,2),f,doneptr); + if(!*doneptr) + f.func_after(f.argptr,QT_NTH_CHILD(qt,3),f,doneptr); + } + return(qt); + } + if(bc[1] < b) + { + vc[0] = a; vc[1] = b; vc[2] = q0[2]; + va[0] = q1[0]; va[1] = b; va[2] = c; + QT_NTH_CHILD(qt,1) = qtInsert_point_rev(root,QT_NTH_CHILD(qt,1), + qt,vc,q1,va,bc,scale>>1,f,n+1,doneptr); + if(!*doneptr) + { + f.func_after(f.argptr,QT_NTH_CHILD(qt,0),f,doneptr); + if(!*doneptr) + f.func_after(f.argptr,QT_NTH_CHILD(qt,2),f,doneptr); + if(!*doneptr) + f.func_after(f.argptr,QT_NTH_CHILD(qt,3),f,doneptr); + } + return(qt); + } + if(bc[2] < c) + { + va[0] = q1[0]; va[1] = b; va[2] = c; + vb[0] = a; vb[1] = q0[1]; vb[2] = c; + QT_NTH_CHILD(qt,2) = qtInsert_point_rev(root,QT_NTH_CHILD(qt,2), + qt,vb,va,q2,bc,scale>>1,f,n+1,doneptr); + if(!*doneptr) + { + f.func_after(f.argptr,QT_NTH_CHILD(qt,0),f,doneptr); + if(!*doneptr) + f.func_after(f.argptr,QT_NTH_CHILD(qt,1),f,doneptr); + if(!*doneptr) + f.func_after(f.argptr,QT_NTH_CHILD(qt,3),f,doneptr); + } + return(qt); + } + else + { + va[0] = q1[0]; va[1] = b; va[2] = c; + vb[0] = a; vb[1] = q0[1]; vb[2] = c; + vc[0] = a; vc[1] = b; vc[2] = q0[2]; + QT_NTH_CHILD(qt,3) = qtInsert_point(root,QT_NTH_CHILD(qt,3), + qt,va,vb,vc,bc,scale>>1,f,n+1,doneptr); + if(!*doneptr) + { + f.func_after(f.argptr,QT_NTH_CHILD(qt,0),f,doneptr); + if(!*doneptr) + f.func_after(f.argptr,QT_NTH_CHILD(qt,1),f,doneptr); + if(!*doneptr) + f.func_after(f.argptr,QT_NTH_CHILD(qt,2),f,doneptr); + } + return(qt); + } + } + else + { + qt = f.func(f.argptr,root,qt,parent,q0,q1,q2,bc,scale,1,f,n,doneptr); + return(qt); + } +} + + + + + + +
