root/radiance/ray/src/hd/sm_qtree.c
Revision: 3.3
Committed: Tue Aug 25 11:03:27 1998 UTC (26 years, 8 months ago) by gwlarson
Changes since 3.2: +280 -91 lines
fixed problem with picking (ray tracking) of tetrahedron
1 /* Copyright (c) 1998 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * sm_qtree.c: adapted from octree.c from radiance code
9 */
10 /*
11 * octree.c - routines dealing with octrees and cubes.
12 *
13 * 7/28/85
14 */
15
16 #include "standard.h"
17
18 #include "sm_geom.h"
19 #include "sm_qtree.h"
20 #include "object.h"
21
22 QUADTREE *quad_block[QT_MAX_BLK]; /* our quadtree */
23 static QUADTREE quad_free_list = EMPTY; /* freed octree nodes */
24 static QUADTREE treetop = 0; /* next free node */
25 int4 *quad_flag;
26
27 QUADTREE
28 qtAlloc() /* allocate a quadtree */
29 {
30 register QUADTREE freet;
31
32 if ((freet = quad_free_list) != EMPTY)
33 {
34 quad_free_list = QT_NTH_CHILD(freet, 0);
35 return(freet);
36 }
37 freet = treetop;
38 if (QT_BLOCK_INDEX(freet) == 0)
39 {
40 if (QT_BLOCK(freet) >= QT_MAX_BLK)
41 return(EMPTY);
42 if ((quad_block[QT_BLOCK(freet)] = (QUADTREE *)malloc(
43 QT_BLOCK_SIZE*4*sizeof(QUADTREE))) == NULL)
44 return(EMPTY);
45 quad_flag = (int4 *)realloc((char *)quad_flag,
46 (QT_BLOCK(freet)+1)*QT_BLOCK_SIZE/(8*sizeof(int4)));
47 if (quad_flag == NULL)
48 return(EMPTY);
49 }
50 treetop += 4;
51 return(freet);
52 }
53
54
55 qtClearAllFlags() /* clear all quadtree branch flags */
56 {
57 if (!treetop) return;
58 bzero((char *)quad_flag,
59 (QT_BLOCK(treetop-1)+1)*QT_BLOCK_SIZE/(8*sizeof(int4)));
60 }
61
62
63 qtFree(qt) /* free a quadtree */
64 register QUADTREE qt;
65 {
66 register int i;
67
68 if (!QT_IS_TREE(qt))
69 {
70 qtfreeleaf(qt);
71 return;
72 }
73 for (i = 0; i < 4; i++)
74 qtFree(QT_NTH_CHILD(qt, i));
75 QT_NTH_CHILD(qt, 0) = quad_free_list;
76 quad_free_list = qt;
77 }
78
79
80 qtDone() /* free EVERYTHING */
81 {
82 register int i;
83
84 for (i = 0; i < QT_MAX_BLK; i++)
85 {
86 if (quad_block[i] == NULL)
87 break;
88 free((char *)quad_block[i]);
89 quad_block[i] = NULL;
90 }
91 if (i) free((char *)quad_flag);
92 quad_flag = NULL;
93 quad_free_list = EMPTY;
94 treetop = 0;
95 }
96
97
98 QUADTREE
99 qtCompress(qt) /* recursively combine nodes */
100 register QUADTREE qt;
101 {
102 register int i;
103 register QUADTREE qres;
104
105 if (!QT_IS_TREE(qt)) /* not a tree */
106 return(qt);
107 qres = QT_NTH_CHILD(qt,0) = qtCompress(QT_NTH_CHILD(qt,0));
108 for (i = 1; i < 4; i++)
109 if((QT_NTH_CHILD(qt,i) = qtCompress(QT_NTH_CHILD(qt,i))) != qres)
110 qres = qt;
111 if(!QT_IS_TREE(qres))
112 { /* all were identical leaves */
113 QT_NTH_CHILD(qt,0) = quad_free_list;
114 quad_free_list = qt;
115 }
116 return(qres);
117 }
118
119
120 QUADTREE
121 *qtLocate_leaf(qtptr,bcoord,t0,t1,t2)
122 QUADTREE *qtptr;
123 double bcoord[3];
124 FVECT t0,t1,t2;
125 {
126 int i;
127 QUADTREE *child;
128 FVECT a,b,c;
129
130 if(QT_IS_TREE(*qtptr))
131 {
132 i = bary2d_child(bcoord);
133 child = QT_NTH_CHILD_PTR(*qtptr,i);
134 if(t0)
135 {
136 qtSubdivide_tri(t0,t1,t2,a,b,c);
137 qtNth_child_tri(t0,t1,t2,a,b,c,i,t0,t1,t2);
138 }
139 return(qtLocate_leaf(child,bcoord,t0,t1,t2));
140 }
141 else
142 return(qtptr);
143 }
144
145
146
147 int
148 qtLeaf_add_tri_from_pt(qtptr,bcoord,id,v0,v1,v2,n)
149 QUADTREE *qtptr;
150 double bcoord[3];
151 int id;
152 FVECT v0,v1,v2;
153 int n;
154 {
155 int i;
156 QUADTREE *child;
157 OBJECT os[MAXSET+1],*optr;
158 int found;
159 FVECT r0,r1,r2;
160
161 if(QT_IS_TREE(*qtptr))
162 {
163 QT_SET_FLAG(*qtptr);
164 i = bary2d_child(bcoord);
165 child = QT_NTH_CHILD_PTR(*qtptr,i);
166 return(qtLeaf_add_tri_from_pt(child,bcoord,id,v0,v1,v2,++n));
167 }
168 else
169 {
170 /* If this leave node emptry- create a new set */
171 if(QT_IS_EMPTY(*qtptr))
172 *qtptr = qtaddelem(*qtptr,id);
173 else
174 {
175 qtgetset(os,*qtptr);
176 /* If the set is too large: subdivide */
177 if(QT_SET_CNT(os) < QT_SET_THRESHOLD)
178 *qtptr = qtaddelem(*qtptr,id);
179 else
180 {
181 if (n < QT_MAX_LEVELS)
182 {
183 /* If set size exceeds threshold: subdivide cell and
184 reinsert set tris into cell
185 */
186 n++;
187 qtfreeleaf(*qtptr);
188 qtSubdivide(qtptr);
189 QT_SET_FLAG(*qtptr);
190 found = qtLeaf_add_tri_from_pt(qtptr,bcoord,id,v0,v1,v2,n);
191 #if 0
192 if(!found)
193 {
194 #ifdef TEST_DRIVER
195 HANDLE_ERROR("qtAdd_tri():Found in parent but not children\n");
196 #else
197 eputs("qtAdd_tri():Found in parent but not children\n");
198 #endif
199 }
200 #endif
201 for(optr = &(os[1]),i = QT_SET_CNT(os); i > 0; i--)
202 {
203 id = QT_SET_NEXT_ELEM(optr);
204 qtTri_verts_from_id(id,r0,r1,r2);
205 found= qtLeaf_add_tri_from_pt(qtptr,bcoord,id,v0,v1,v2,++n);
206 #ifdef DEBUG
207 if(!found)
208 eputs("qtAdd_tri():Reinsert-in parent but not children\n");
209 #endif
210 }
211 }
212 else
213 if(QT_SET_CNT(os) < QT_MAX_SET)
214 {
215 *qtptr = qtaddelem(*qtptr,id);
216 }
217 else
218 {
219 #ifdef DEBUG
220 eputs("qtAdd_tri():two many levels\n");
221 #endif
222 return(FALSE);
223 }
224 }
225 }
226 }
227 return(TRUE);
228 }
229
230
231 int
232 qtAdd_tri_from_point(qtptr,v0,v1,v2,pt,id)
233 QUADTREE *qtptr;
234 FVECT v0,v1,v2;
235 FVECT pt;
236 int id;
237 {
238 char d,w;
239 int i,x,y;
240 QUADTREE *child;
241 QUADTREE qt;
242 FVECT i_pt,n,a,b,c,r0,r1,r2;
243 double pd,bcoord[3];
244 OBJECT os[MAXSET+1],*optr;
245 int found;
246
247 /* Determine if point lies within pyramid (and therefore
248 inside a spherical quadtree cell):GT_INTERIOR, on one of the
249 pyramid sides (and on cell edge):GT_EDGE(1,2 or 3),
250 or on pyramid vertex (and on cell vertex):GT_VERTEX(1,2, or 3).
251 For each triangle edge: compare the
252 point against the plane formed by the edge and the view center
253 */
254 d = test_single_point_against_spherical_tri(v0,v1,v2,pt,&w);
255
256 /* Not in this triangle */
257 if(!d)
258 return(FALSE);
259
260 /* Will return lowest level triangle containing point: It the
261 point is on an edge or vertex: will return first associated
262 triangle encountered in the child traversal- the others can
263 be derived using triangle adjacency information
264 */
265 if(QT_IS_TREE(*qtptr))
266 {
267 QT_SET_FLAG(*qtptr);
268 /* Find the intersection point */
269 tri_plane_equation(v0,v1,v2,n,&pd,FALSE);
270 intersect_vector_plane(pt,n,pd,NULL,i_pt);
271
272 i = max_index(n);
273 x = (i+1)%3;
274 y = (i+2)%3;
275 /* Calculate barycentric coordinates of i_pt */
276 bary2d(v0[x],v0[y],v1[x],v1[y],v2[x],v2[y],i_pt[x],i_pt[y],bcoord);
277
278 i = bary2d_child(bcoord);
279 child = QT_NTH_CHILD_PTR(*qtptr,i);
280 /* NOTE: Optimize: only subdivide for specified child */
281 qtSubdivide_tri(v0,v1,v2,a,b,c);
282 qtNth_child_tri(v0,v1,v2,a,b,c,i,v0,v1,v2);
283 return(qtLeaf_add_tri_from_pt(child,bcoord,id,v0,v1,v2,1));
284 }
285 else
286 {
287 /* If this leave node emptry- create a new set */
288 if(QT_IS_EMPTY(*qtptr))
289 *qtptr = qtaddelem(*qtptr,id);
290 else
291 {
292 qtgetset(os,*qtptr);
293 /* If the set is too large: subdivide */
294 if(QT_SET_CNT(os) < QT_SET_THRESHOLD)
295 *qtptr = qtaddelem(*qtptr,id);
296 else
297 {
298 /* If set size exceeds threshold: subdivide cell and
299 reinsert set tris into cell
300 */
301 qtfreeleaf(*qtptr);
302 qtSubdivide(qtptr);
303 found = qtLeaf_add_tri_from_pt(qtptr,bcoord,id,v0,v1,v2,1);
304 #if 0
305 if(!found)
306 {
307 #ifdef TEST_DRIVER
308 HANDLE_ERROR("qtAdd_tri():Found in parent but not children\n");
309 #else
310 eputs("qtAdd_tri():Found in parent but not children\n");
311 #endif
312 }
313 #endif
314 for(optr = &(os[1]),i = QT_SET_CNT(os); i > 0; i--)
315 {
316 id = QT_SET_NEXT_ELEM(optr);
317 qtTri_verts_from_id(id,r0,r1,r2);
318 found=qtAdd_tri(qtptr,id,r0,r1,r2,v0,v1,v2,1);
319 #ifdef DEBUG
320 if(!found)
321 eputs("qtAdd_tri():Reinsert-in parent but not children\n");
322 #endif
323 }
324 }
325 }
326 }
327 return(TRUE);
328 }
329
330
331 QUADTREE
332 *qtRoot_point_locate(qtptr,v0,v1,v2,pt,t0,t1,t2)
333 QUADTREE *qtptr;
334 FVECT v0,v1,v2;
335 FVECT pt;
336 FVECT t0,t1,t2;
337 {
338 char d,w;
339 int i,x,y;
340 QUADTREE *child;
341 QUADTREE qt;
342 FVECT n,i_pt,a,b,c;
343 double pd,bcoord[3];
344
345 /* Determine if point lies within pyramid (and therefore
346 inside a spherical quadtree cell):GT_INTERIOR, on one of the
347 pyramid sides (and on cell edge):GT_EDGE(1,2 or 3),
348 or on pyramid vertex (and on cell vertex):GT_VERTEX(1,2, or 3).
349 For each triangle edge: compare the
350 point against the plane formed by the edge and the view center
351 */
352 d = test_single_point_against_spherical_tri(v0,v1,v2,pt,&w);
353
354 /* Not in this triangle */
355 if(!d)
356 {
357 return(NULL);
358 }
359
360 /* Will return lowest level triangle containing point: It the
361 point is on an edge or vertex: will return first associated
362 triangle encountered in the child traversal- the others can
363 be derived using triangle adjacency information
364 */
365 if(QT_IS_TREE(*qtptr))
366 {
367 /* Find the intersection point */
368 tri_plane_equation(v0,v1,v2,n,&pd,FALSE);
369 intersect_vector_plane(pt,n,pd,NULL,i_pt);
370
371 i = max_index(n);
372 x = (i+1)%3;
373 y = (i+2)%3;
374 /* Calculate barycentric coordinates of i_pt */
375 bary2d(v0[x],v0[y],v1[x],v1[y],v2[x],v2[y],i_pt[x],i_pt[y],bcoord);
376
377 i = bary2d_child(bcoord);
378 child = QT_NTH_CHILD_PTR(*qtptr,i);
379 if(t0)
380 {
381 qtSubdivide_tri(v0,v1,v2,a,b,c);
382 qtNth_child_tri(v0,v1,v2,a,b,c,i,t0,t1,t2);
383 }
384 return(qtLocate_leaf(child,bcoord,t0,t1,t2));
385 }
386 else
387 return(qtptr);
388 }
389
390 int
391 qtPoint_in_tri(qtptr,v0,v1,v2,pt,type,which)
392 QUADTREE *qtptr;
393 FVECT v0,v1,v2;
394 FVECT pt;
395 char *type,*which;
396 {
397 OBJECT os[MAXSET+1],*optr;
398 char d,w;
399 int i,id;
400 FVECT p0,p1,p2;
401
402 qtptr = qtRoot_point_locate(qtptr,v0,v1,v2,pt,NULL,NULL,NULL);
403
404 if(!qtptr || QT_IS_EMPTY(*qtptr))
405 return(EMPTY);
406
407 /* Get the set */
408 qtgetset(os,*qtptr);
409 for (i = QT_SET_CNT(os),optr = QT_SET_PTR(os); i > 0; i--)
410 {
411 /* Find the triangle that pt falls in (NOTE:FOR now return first 1) */
412 id = QT_SET_NEXT_ELEM(optr);
413 qtTri_verts_from_id(id,p0,p1,p2);
414 d = test_single_point_against_spherical_tri(p0,p1,p2,pt,&w);
415 if(d)
416 {
417 if(type)
418 *type = d;
419 if(which)
420 *which = w;
421 return(id);
422 }
423 }
424 return(EMPTY);
425 }
426
427 QUADTREE
428 qtSubdivide(qtptr)
429 QUADTREE *qtptr;
430 {
431 QUADTREE node;
432 node = qtAlloc();
433 QT_CLEAR_CHILDREN(node);
434 *qtptr = node;
435 return(node);
436 }
437
438
439 QUADTREE
440 qtSubdivide_nth_child(qt,n)
441 QUADTREE qt;
442 int n;
443 {
444 QUADTREE node;
445
446 node = qtSubdivide(&(QT_NTH_CHILD(qt,n)));
447
448 return(node);
449 }
450
451 /* for triangle v0-v1-v2- returns a,b,c: children are:
452
453 v2 0: v0,a,c
454 /\ 1: a,v1,b
455 /2 \ 2: c,b,v2
456 c/____\b 3: b,c,a
457 /\ /\
458 /0 \3 /1 \
459 v0____\/____\v1
460 a
461 */
462
463 qtSubdivide_tri(v0,v1,v2,a,b,c)
464 FVECT v0,v1,v2;
465 FVECT a,b,c;
466 {
467 EDGE_MIDPOINT_VEC3(a,v0,v1);
468 EDGE_MIDPOINT_VEC3(b,v1,v2);
469 EDGE_MIDPOINT_VEC3(c,v2,v0);
470 }
471
472 qtNth_child_tri(v0,v1,v2,a,b,c,i,r0,r1,r2)
473 FVECT v0,v1,v2;
474 FVECT a,b,c;
475 int i;
476 FVECT r0,r1,r2;
477 {
478 switch(i){
479 case 0:
480 VCOPY(r0,v0); VCOPY(r1,a); VCOPY(r2,c);
481 break;
482 case 1:
483 VCOPY(r0,a); VCOPY(r1,v1); VCOPY(r2,b);
484 break;
485 case 2:
486 VCOPY(r0,c); VCOPY(r1,b); VCOPY(r2,v2);
487 break;
488 case 3:
489 VCOPY(r0,b); VCOPY(r1,c); VCOPY(r2,a);
490 break;
491 }
492 }
493
494 /* Add triangle "id" to all leaf level cells that are children of
495 quadtree pointed to by "qtptr" with cell vertices "t1,t2,t3"
496 that it overlaps (vertex and edge adjacencies do not count
497 as overlapping). If the addition of the triangle causes the cell to go over
498 threshold- the cell is split- and the triangle must be recursively inserted
499 into the new child cells: it is assumed that "v1,v2,v3" are normalized
500 */
501
502 int
503 qtRoot_add_tri(qtptr,id,t0,t1,t2,v0,v1,v2,n)
504 QUADTREE *qtptr;
505 int id;
506 FVECT t0,t1,t2;
507 FVECT v0,v1,v2;
508 int n;
509 {
510 char test;
511 int found;
512
513 test = spherical_tri_intersect(t0,t1,t2,v0,v1,v2);
514 if(!test)
515 return(FALSE);
516
517 found = qtAdd_tri(qtptr,id,t0,t1,t2,v0,v1,v2,n);
518 return(found);
519 }
520
521 int
522 qtRoot_add_tri_from_point(qtptr,id,t0,t1,t2,v0,v1,v2,n)
523 QUADTREE *qtptr;
524 int id;
525 FVECT t0,t1,t2;
526 FVECT v0,v1,v2;
527 int n;
528 {
529 char test;
530 int found;
531
532 test = spherical_tri_intersect(t0,t1,t2,v0,v1,v2);
533 if(!test)
534 return(FALSE);
535
536 found = qtAdd_tri_from_point(qtptr,id,t0,t1,t2,v0,v1,v2,n);
537 return(found);
538 }
539
540 int
541 qtAdd_tri(qtptr,id,t0,t1,t2,v0,v1,v2,n)
542 QUADTREE *qtptr;
543 int id;
544 FVECT t0,t1,t2;
545 FVECT v0,v1,v2;
546 int n;
547 {
548
549 char test;
550 int i,index;
551 FVECT a,b,c;
552 OBJECT os[MAXSET+1],*optr;
553 QUADTREE qt;
554 int found;
555 FVECT r0,r1,r2;
556
557 found = 0;
558 /* if this is tree: recurse */
559 if(QT_IS_TREE(*qtptr))
560 {
561 n++;
562 qtSubdivide_tri(v0,v1,v2,a,b,c);
563 test = spherical_tri_intersect(t0,t1,t2,v0,a,c);
564 if(test)
565 found |= qtAdd_tri(QT_NTH_CHILD_PTR(*qtptr,0),id,t0,t1,t2,v0,a,c,n);
566 test = spherical_tri_intersect(t0,t1,t2,a,v1,b);
567 if(test)
568 found |= qtAdd_tri(QT_NTH_CHILD_PTR(*qtptr,1),id,t0,t1,t2,a,v1,b,n);
569 test = spherical_tri_intersect(t0,t1,t2,c,b,v2);
570 if(test)
571 found |= qtAdd_tri(QT_NTH_CHILD_PTR(*qtptr,2),id,t0,t1,t2,c,b,v2,n);
572 test = spherical_tri_intersect(t0,t1,t2,b,c,a);
573 if(test)
574 found |= qtAdd_tri(QT_NTH_CHILD_PTR(*qtptr,3),id,t0,t1,t2,b,c,a,n);
575
576 #if 0
577 if(!found)
578 {
579 #ifdef TEST_DRIVER
580 HANDLE_ERROR("qtAdd_tri():Found in parent but not children\n");
581 #else
582 eputs("qtAdd_tri():Found in parent but not children\n");
583 #endif
584 }
585 #endif
586 }
587 else
588 {
589 /* If this leave node emptry- create a new set */
590 if(QT_IS_EMPTY(*qtptr))
591 *qtptr = qtaddelem(*qtptr,id);
592 else
593 {
594 qtgetset(os,*qtptr);
595 /* If the set is too large: subdivide */
596 if(QT_SET_CNT(os) < QT_SET_THRESHOLD)
597 *qtptr = qtaddelem(*qtptr,id);
598 else
599 {
600 if (n < QT_MAX_LEVELS)
601 {
602 /* If set size exceeds threshold: subdivide cell and
603 reinsert set tris into cell
604 */
605 n++;
606 qtfreeleaf(*qtptr);
607 qtSubdivide(qtptr);
608 found = qtAdd_tri(qtptr,id,t0,t1,t2,v0,v1,v2,n);
609 #if 0
610 if(!found)
611 {
612 #ifdef TEST_DRIVER
613 HANDLE_ERROR("qtAdd_tri():Found in parent but not children\n");
614 #else
615 eputs("qtAdd_tri():Found in parent but not children\n");
616 #endif
617 }
618 #endif
619 for(optr = &(os[1]),i = QT_SET_CNT(os); i > 0; i--)
620 {
621 id = QT_SET_NEXT_ELEM(optr);
622 qtTri_verts_from_id(id,r0,r1,r2);
623 found=qtAdd_tri(qtptr,id,r0,r1,r2,v0,v1,v2,n);
624 #ifdef DEBUG
625 if(!found)
626 eputs("qtAdd_tri():Reinsert-in parent but not children\n");
627 #endif
628 }
629 }
630 else
631 if(QT_SET_CNT(os) < QT_MAX_SET)
632 {
633 *qtptr = qtaddelem(*qtptr,id);
634 #if 0
635 {
636 int k;
637 qtgetset(os,*qtptr);
638 printf("\n%d:\n",os[0]);
639 for(k=1; k <= os[0];k++)
640 printf("%d ",os[k]);
641 printf("\n");
642 }
643 #endif
644 /*
645 insertelem(os,id);
646 *qtptr = fullnode(os);
647 */
648 }
649 else
650 {
651 #ifdef DEBUG
652 eputs("qtAdd_tri():two many levels\n");
653 #endif
654 return(FALSE);
655 }
656 }
657 }
658 }
659 return(TRUE);
660 }
661
662
663 int
664 qtApply_to_tri_cells(qtptr,t0,t1,t2,v0,v1,v2,func,arg)
665 QUADTREE *qtptr;
666 FVECT t0,t1,t2;
667 FVECT v0,v1,v2;
668 int (*func)();
669 char *arg;
670 {
671 char test;
672 FVECT a,b,c;
673
674 /* test if triangle (t0,t1,t2) overlaps cell triangle (v0,v1,v2) */
675 test = spherical_tri_intersect(t0,t1,t2,v0,v1,v2);
676
677 /* If triangles do not overlap: done */
678 if(!test)
679 return(FALSE);
680
681 /* if this is tree: recurse */
682 if(QT_IS_TREE(*qtptr))
683 {
684 qtSubdivide_tri(v0,v1,v2,a,b,c);
685 qtApply_to_tri_cells(QT_NTH_CHILD_PTR(*qtptr,0),t0,t1,t2,v0,a,c,func,arg);
686 qtApply_to_tri_cells(QT_NTH_CHILD_PTR(*qtptr,1),t0,t1,t2,a,v1,b,func,arg);
687 qtApply_to_tri_cells(QT_NTH_CHILD_PTR(*qtptr,2),t0,t1,t2,c,b,v2,func,arg);
688 qtApply_to_tri_cells(QT_NTH_CHILD_PTR(*qtptr,3),t0,t1,t2,b,c,a,func,arg);
689 }
690 else
691 return(func(qtptr,arg));
692 }
693
694
695 int
696 qtRemove_tri(qtptr,id,t0,t1,t2,v0,v1,v2)
697 QUADTREE *qtptr;
698 int id;
699 FVECT t0,t1,t2;
700 FVECT v0,v1,v2;
701 {
702
703 char test;
704 int i;
705 FVECT a,b,c;
706 OBJECT os[MAXSET+1];
707
708 /* test if triangle (t0,t1,t2) overlaps cell triangle (v0,v1,v2) */
709 test = spherical_tri_intersect(t0,t1,t2,v0,v1,v2);
710
711 /* If triangles do not overlap: done */
712 if(!test)
713 return(FALSE);
714
715 /* if this is tree: recurse */
716 if(QT_IS_TREE(*qtptr))
717 {
718 qtSubdivide_tri(v0,v1,v2,a,b,c);
719 qtRemove_tri(QT_NTH_CHILD_PTR(*qtptr,0),id,t0,t1,t2,v0,a,c);
720 qtRemove_tri(QT_NTH_CHILD_PTR(*qtptr,1),id,t0,t1,t2,a,v1,b);
721 qtRemove_tri(QT_NTH_CHILD_PTR(*qtptr,2),id,t0,t1,t2,c,b,v2);
722 qtRemove_tri(QT_NTH_CHILD_PTR(*qtptr,3),id,t0,t1,t2,b,c,a);
723 }
724 else
725 {
726 if(QT_IS_EMPTY(*qtptr))
727 {
728 #ifdef DEBUG
729 eputs("qtRemove_tri(): triangle not found\n");
730 #endif
731 }
732 /* remove id from set */
733 else
734 {
735 qtgetset(os,*qtptr);
736 if(!inset(os,id))
737 {
738 #ifdef DEBUG
739 eputs("qtRemove_tri(): tri not in set\n");
740 #endif
741 }
742 else
743 {
744 *qtptr = qtdelelem(*qtptr,id);
745 }
746 }
747 }
748 return(TRUE);
749 }
750
751
752
753
754
755
756
757
758
759
760
761
