1 |
/* Copyright (c) 1998 Silicon Graphics, Inc. */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ SGI"; |
5 |
#endif |
6 |
7 |
8 |
* sm_ogl.c |
9 |
10 |
#include "standard.h" |
11 |
12 |
#include <GL/gl.h> |
13 |
14 |
#ifdef TEST_DRIVER |
15 |
#include <gl/device.h> |
16 |
#include <GL/glu.h> |
17 |
#include <glut.h> |
18 |
#endif |
19 |
#include "sm_list.h" |
20 |
#include "sm_geom.h" |
21 |
#include "sm.h" |
22 |
23 |
24 |
#include "sm_draw.h" |
25 |
/*static char smClean_notify = TRUE; |
26 |
MAKE STATIC LATER: ui.c using for now; |
27 |
28 |
29 |
#else |
30 |
static int smClean_notify = TRUE; |
31 |
#endif |
32 |
33 |
typedef struct { |
34 |
float dist; /* average distance */ |
35 |
BYTE rgb[3]; /* average color */ |
36 |
} QTRAVG; /* average quadtree value */ |
37 |
38 |
typedef struct { |
39 |
QUADTREE qt; /* quadtree node (key & hash value) */ |
40 |
QTRAVG av; /* node average */ |
41 |
} QT_LUENT; /* lookup table entry */ |
42 |
43 |
static QT_LUENT *qt_htbl = NULL; /* quadtree cache */ |
44 |
static int qt_hsiz = 0; /* quadtree cache size */ |
45 |
46 |
47 |
int |
48 |
mark_active_tris(qtptr,arg) |
49 |
QUADTREE *qtptr; |
50 |
int *arg; |
51 |
52 |
QUADTREE qt = *qtptr; |
53 |
OBJECT *os,*optr; |
54 |
register int i,t_id; |
55 |
56 |
if (!QT_IS_LEAF(qt)) |
57 |
return(TRUE); |
58 |
/* For each triangle in the set, set the which flag*/ |
59 |
os = qtqueryset(qt); |
60 |
61 |
for (i = QT_SET_CNT(os), optr = QT_SET_PTR(os); i > 0; i--) |
62 |
63 |
t_id = QT_SET_NEXT_ELEM(optr); |
64 |
/* Set the render flag */ |
65 |
if(SM_IS_NTH_T_BASE(smMesh,t_id)) |
66 |
continue; |
67 |
SM_SET_NTH_T_ACTIVE(smMesh,t_id); |
68 |
/* FOR NOW:Also set the LRU clock bit: MAY WANT TO CHANGE: */ |
69 |
SM_SET_NTH_T_LRU(smMesh,t_id); |
70 |
71 |
return(TRUE); |
72 |
73 |
74 |
mark_tris_in_frustum(view) |
75 |
VIEW *view; |
76 |
77 |
FVECT nr[4],far[4]; |
78 |
79 |
/* Mark triangles in approx. view frustum as being active:set |
80 |
LRU counter: for use in discarding samples when out |
81 |
of space |
82 |
Radiance often has no far clipping plane: but driver will set |
83 |
dev_zmin,dev_zmax to satisfy OGL |
84 |
85 |
86 |
/* First clear all the quadtree node and triangle active flags */ |
87 |
qtClearAllFlags(); |
88 |
smClear_flags(smMesh,T_ACTIVE_FLAG); |
89 |
90 |
/* calculate the world space coordinates of the view frustum */ |
91 |
calculate_view_frustum(view->vp,view->hvec,view->vvec,view->horiz, |
92 |
view->vert, dev_zmin,dev_zmax,nr,far); |
93 |
94 |
/* Project the view frustum onto the spherical quadtree */ |
95 |
/* For every cell intersected by the projection of the faces |
96 |
of the frustum: mark all triangles in the cell as ACTIVE- |
97 |
Also set the triangles LRU clock counter |
98 |
99 |
/* Near face triangles */ |
100 |
smLocator_apply_func(smMesh,nr[0],nr[2],nr[3],mark_active_tris,NULL); |
101 |
smLocator_apply_func(smMesh,nr[2],nr[0],nr[1],mark_active_tris,NULL); |
102 |
/* Right face triangles */ |
103 |
smLocator_apply_func(smMesh,nr[0],far[3],far[0],mark_active_tris,NULL); |
104 |
smLocator_apply_func(smMesh,far[3],nr[0],nr[3],mark_active_tris,NULL); |
105 |
/* Left face triangles */ |
106 |
smLocator_apply_func(smMesh,nr[1],far[2],nr[2],mark_active_tris,NULL); |
107 |
smLocator_apply_func(smMesh,far[2],nr[1],far[1],mark_active_tris,NULL); |
108 |
/* Top face triangles */ |
109 |
smLocator_apply_func(smMesh,nr[0],far[0],nr[1],mark_active_tris,NULL); |
110 |
smLocator_apply_func(smMesh,nr[1],far[0],far[1],mark_active_tris,NULL); |
111 |
/* Bottom face triangles */ |
112 |
smLocator_apply_func(smMesh,nr[3],nr[2],far[3],mark_active_tris,NULL); |
113 |
smLocator_apply_func(smMesh,nr[2],far[2],far[3],mark_active_tris,NULL); |
114 |
/* Far face triangles */ |
115 |
smLocator_apply_func(smMesh,far[0],far[2],far[1],mark_active_tris,NULL); |
116 |
smLocator_apply_func(smMesh,far[2],far[0],far[3],mark_active_tris,NULL); |
117 |
118 |
119 |
VCOPY(FrustumFar[0],far[0]); |
120 |
VCOPY(FrustumFar[1],far[1]); |
121 |
VCOPY(FrustumFar[2],far[2]); |
122 |
VCOPY(FrustumFar[3],far[3]); |
123 |
VCOPY(FrustumNear[0],nr[0]); |
124 |
VCOPY(FrustumNear[1],nr[1]); |
125 |
VCOPY(FrustumNear[2],nr[2]); |
126 |
VCOPY(FrustumNear[3],nr[3]); |
127 |
#endif |
128 |
129 |
130 |
131 |
* smClean() : display has been wiped clean |
132 |
133 |
* Called after display has been effectively cleared, meaning that all |
134 |
* geometry must be resent down the pipeline in the next call to smUpdate(). |
135 |
136 |
smClean() |
137 |
138 |
139 |
140 |
141 |
int |
142 |
qtCache_init(nel) /* initialize for at least nel elements */ |
143 |
int nel; |
144 |
145 |
static int hsiztab[] = { |
146 |
8191, 16381, 32749, 65521, 131071, 262139, 524287, 1048573, 0 |
147 |
148 |
register int i; |
149 |
150 |
if (nel <= 0) { /* call to free table */ |
151 |
if (qt_hsiz) { |
152 |
free((char *)qt_htbl); |
153 |
qt_htbl = NULL; |
154 |
qt_hsiz = 0; |
155 |
156 |
return(0); |
157 |
158 |
nel += nel>>1; /* 66% occupancy */ |
159 |
for (i = 0; hsiztab[i]; i++) |
160 |
if (hsiztab[i] > nel) |
161 |
break; |
162 |
if (!(qt_hsiz = hsiztab[i])) |
163 |
qt_hsiz = nel*2 + 1; /* not always prime */ |
164 |
qt_htbl = (QT_LUENT *)calloc(qt_hsiz, sizeof(QT_LUENT)); |
165 |
if (qt_htbl == NULL) |
166 |
qt_hsiz = 0; |
167 |
for (i = qt_hsiz; i--; ) |
168 |
qt_htbl[i].qt = EMPTY; |
169 |
return(qt_hsiz); |
170 |
171 |
172 |
QT_LUENT * |
173 |
qtCache_find(qt) /* find a quadtree table entry */ |
174 |
QUADTREE qt; |
175 |
176 |
int i, n; |
177 |
register int ndx; |
178 |
register QT_LUENT *le; |
179 |
180 |
if (qt_hsiz == 0 && !qtCache_init(1)) |
181 |
return(NULL); |
182 |
tryagain: /* hash table lookup */ |
183 |
ndx = (unsigned long)qt % qt_hsiz; |
184 |
for (i = 0, n = 1; i < qt_hsiz; i++, n += 2) { |
185 |
le = &qt_htbl[ndx]; |
186 |
if (QT_IS_EMPTY(le->qt) || le->qt == qt) |
187 |
return(le); |
188 |
if ((ndx += n) >= qt_hsiz) /* this happens rarely */ |
189 |
ndx = ndx % qt_hsiz; |
190 |
191 |
/* table is full, reallocate */ |
192 |
le = qt_htbl; |
193 |
ndx = qt_hsiz; |
194 |
if (!qtCache_init(ndx+1)) { /* no more memory! */ |
195 |
qt_htbl = le; |
196 |
qt_hsiz = ndx; |
197 |
return(NULL); |
198 |
199 |
/* copy old table to new and free */ |
200 |
while (ndx--) |
201 |
if (!QT_IS_EMPTY(le[ndx].qt)) |
202 |
copystruct(qtCache_find(le[ndx].qt), &le[ndx]); |
203 |
free((char *)le); |
204 |
goto tryagain; /* should happen only once! */ |
205 |
206 |
207 |
stCount_level_leaves(lcnt, qt) /* count quadtree leaf nodes at each level */ |
208 |
int lcnt[]; |
209 |
register QUADTREE qt; |
210 |
211 |
if (QT_IS_EMPTY(qt)) |
212 |
return; |
213 |
if (QT_IS_TREE(qt)) { |
214 |
if (!QT_IS_FLAG(qt)) /* not in our frustum */ |
215 |
return; |
216 |
stCount_level_leaves(lcnt+1, QT_NTH_CHILD(qt,0)); |
217 |
stCount_level_leaves(lcnt+1, QT_NTH_CHILD(qt,1)); |
218 |
stCount_level_leaves(lcnt+1, QT_NTH_CHILD(qt,2)); |
219 |
stCount_level_leaves(lcnt+1, QT_NTH_CHILD(qt,3)); |
220 |
221 |
else |
222 |
lcnt[0]++; |
223 |
224 |
225 |
226 |
QTRAVG * |
227 |
qtRender_level(qt,v0,v1,v2,sm,lvl) |
228 |
QUADTREE qt; |
229 |
FVECT v0,v1,v2; |
230 |
SM *sm; |
231 |
int lvl; |
232 |
233 |
FVECT a,b,c; |
234 |
235 |
QTRAVG *rc[4]; |
236 |
237 |
if (QT_IS_EMPTY(qt)) /* empty leaf node */ |
238 |
return(NULL); |
239 |
if (QT_IS_TREE(qt) && !QT_IS_FLAG(qt)) /* not in our frustum */ |
240 |
return(NULL); |
241 |
/* else look up node */ |
242 |
if ((le = qtCache_find(qt)) == NULL) |
243 |
error(SYSTEM, "out of memory in qtRender_level"); |
244 |
if (QT_IS_TREE(qt) && (QT_IS_EMPTY(le->qt) || lvl > 0)) |
245 |
{ /* compute children */ |
246 |
qtSubdivide_tri(v0,v1,v2,a,b,c); |
247 |
rc[0] = qtRender_level(QT_NTH_CHILD(qt,0),v0,a,c,sm,lvl-1); |
248 |
rc[1] = qtRender_level(QT_NTH_CHILD(qt,1),a,v1,b,sm,lvl-1); |
249 |
rc[2] = qtRender_level(QT_NTH_CHILD(qt,2),c,b,v2,sm,lvl-1); |
250 |
rc[3] = qtRender_level(QT_NTH_CHILD(qt,3),b,c,a,sm,lvl-1); |
251 |
252 |
if (QT_IS_EMPTY(le->qt)) |
253 |
{ /* let's make some data! */ |
254 |
int rgbs[3]; |
255 |
double distsum; |
256 |
register int i, n; |
257 |
/* average our triangle vertices */ |
258 |
rgbs[0] = rgbs[1] = rgbs[2] = 0; |
259 |
distsum = 0.; n = 0; |
260 |
if(QT_IS_TREE(qt)) |
261 |
{ /* from subtree */ |
262 |
for (i = 4; i--; ) |
263 |
if (rc[i] != NULL) |
264 |
265 |
rgbs[0] += rc[i]->rgb[0]; rgbs[1] += rc[i]->rgb[1]; |
266 |
rgbs[2] += rc[i]->rgb[2]; distsum += rc[i]->dist; n++; |
267 |
268 |
269 |
else |
270 |
{ /* from triangle set */ |
271 |
OBJECT *os; |
272 |
int s0, s1, s2; |
273 |
274 |
275 |
for (n = os[0]; n; n--) |
276 |
277 |
qtTri_from_id(os[n],a,b,c,NULL,NULL,NULL,&s0,&s1,&s2); |
278 |
distsum += SM_BG_SAMPLE(sm,s0) ? dev_zmax |
279 |
: sqrt(dist2(a,SM_VIEW_CENTER(sm))); |
280 |
distsum += SM_BG_SAMPLE(sm,s1) ? dev_zmax |
281 |
: sqrt(dist2(b,SM_VIEW_CENTER(sm))); |
282 |
distsum += SM_BG_SAMPLE(sm,s2) ? dev_zmax |
283 |
: sqrt(dist2(c,SM_VIEW_CENTER(sm))); |
284 |
rgbs[0] += SM_NTH_RGB(sm,s0)[0] + SM_NTH_RGB(sm,s1)[0] |
285 |
+ SM_NTH_RGB(sm,s2)[0]; |
286 |
rgbs[1] += SM_NTH_RGB(sm,s0)[1] + SM_NTH_RGB(sm,s1)[1] |
287 |
+ SM_NTH_RGB(sm,s2)[1]; |
288 |
rgbs[2] += SM_NTH_RGB(sm,s0)[2] + SM_NTH_RGB(sm,s1)[2] |
289 |
+ SM_NTH_RGB(sm,s2)[2]; |
290 |
291 |
n = 3*os[0]; |
292 |
293 |
if (!n) |
294 |
return(NULL); |
295 |
le->qt = qt; |
296 |
le->av.rgb[0] = rgbs[0]/n; le->av.rgb[1] = rgbs[1]/n; |
297 |
le->av.rgb[2] = rgbs[2]/n; le->av.dist = distsum/(double)n; |
298 |
299 |
if (lvl == 0 || (lvl > 0 && QT_IS_LEAF(qt))) |
300 |
{ /* render this node */ |
301 |
/* compute pseudo vertices */ |
302 |
VCOPY(a,v0); VCOPY(b,v1); VCOPY(c,v2); |
303 |
normalize(a); normalize(b); normalize(c); |
304 |
VSUM(a,SM_VIEW_CENTER(sm),a,le->av.dist); |
305 |
VSUM(b,SM_VIEW_CENTER(sm),b,le->av.dist); |
306 |
VSUM(c,SM_VIEW_CENTER(sm),c,le->av.dist); |
307 |
/* draw triangle */ |
308 |
glColor3ub(le->av.rgb[0],le->av.rgb[1],le->av.rgb[2]); |
309 |
/* NOTE: Triangle vertex order may change */ |
310 |
glVertex3d(c[0],c[1],c[2]); |
311 |
glVertex3d(b[0],b[1],b[2]); |
312 |
glVertex3d(a[0],a[1],a[2]); |
313 |
314 |
return(&le->av); |
315 |
316 |
317 |
318 |
smRender_stree_level(sm,lvl) |
319 |
SM *sm; |
320 |
int lvl; |
321 |
322 |
QUADTREE root; |
323 |
int i; |
324 |
FVECT t0,t1,t2; |
325 |
326 |
if (lvl < 1) |
327 |
return; |
328 |
glPushAttrib(GL_LIGHTING_BIT); |
329 |
glShadeModel(GL_FLAT); |
330 |
glBegin(GL_TRIANGLES); |
331 |
for(i=0; i < 4; i++) |
332 |
333 |
root = ST_NTH_ROOT(SM_LOCATOR(sm),i); |
334 |
stNth_base_verts(SM_LOCATOR(sm),i,t0,t1,t2); |
335 |
qtRender_level(root,t0,t1,t2,sm,lvl-1); |
336 |
337 |
glEnd(); |
338 |
glPopAttrib(); |
339 |
340 |
341 |
342 |
smRender_stree(sm, qual) /* render some quadtree triangles */ |
343 |
SM *sm; |
344 |
int qual; |
345 |
346 |
int i, ntarget; |
347 |
int lvlcnt[QT_MAX_LEVELS]; |
348 |
349 |
if (qual <= 0) |
350 |
return; |
351 |
/* compute rendering target */ |
352 |
ntarget = 0; |
353 |
SM_FOR_ALL_ACTIVE_TRIS(sm,i) |
354 |
ntarget++; |
355 |
ntarget = ntarget*qual/100; |
356 |
if (!ntarget) |
357 |
return; |
358 |
for (i = QT_MAX_LEVELS; i--; ) |
359 |
lvlcnt[i] = 0; |
360 |
stCount_level_leaves(lvlcnt, SM_LOCATOR(sm)->root); |
361 |
for (ntarget -= lvlcnt[i=0]; i < QT_MAX_LEVELS-1; ntarget -= lvlcnt[++i]) |
362 |
if (ntarget < lvlcnt[i+1]) |
363 |
break; |
364 |
/* compute and render target level */ |
365 |
smRender_stree_level(sm,i); |
366 |
367 |
368 |
369 |
smRender_tri(sm,i,vp,clr) |
370 |
SM *sm; |
371 |
int i; |
372 |
FVECT vp; |
373 |
int clr; |
374 |
375 |
TRI *tri; |
376 |
double ptr[3]; |
377 |
int j; |
378 |
379 |
tri = SM_NTH_TRI(sm,i); |
380 |
if (clr) SM_CLEAR_NTH_T_NEW(sm,i); |
381 |
382 |
/* NOTE:Triangles are defined clockwise:historical relative to spherical |
383 |
tris: could change |
384 |
385 |
for(j=2; j>= 0; j--) |
386 |
387 |
#ifdef DEBUG |
388 |
if(SM_BG_SAMPLE(sm,T_NTH_V(tri,j))) |
389 |
eputs("SmRenderTri(): shouldnt have bg samples\n"); |
390 |
#endif |
391 |
glColor3ub(SM_NTH_RGB(sm,T_NTH_V(tri,j))[0], |
392 |
SM_NTH_RGB(sm,T_NTH_V(tri,j))[1], |
393 |
SM_NTH_RGB(sm,T_NTH_V(tri,j))[2]); |
394 |
VCOPY(ptr,SM_T_NTH_WV(sm,tri,j)); |
395 |
glVertex3d(ptr[0],ptr[1],ptr[2]); |
396 |
397 |
398 |
399 |
smRender_mixed_tri(sm,i,vp,clr) |
400 |
SM *sm; |
401 |
int i; |
402 |
FVECT vp; |
403 |
int clr; |
404 |
405 |
TRI *tri; |
406 |
double p[3],d; |
407 |
int j,ids[3],cnt; |
408 |
int rgb[3]; |
409 |
410 |
411 |
412 |
413 |
414 |
415 |
416 |
cnt = 0; |
417 |
d = 0.0; |
418 |
rgb[0] = rgb[1] = rgb[2] = 0; |
419 |
for(j=0;j < 3;j++) |
420 |
421 |
ids[j] = T_NTH_V(tri,j); |
422 |
if(!SM_BG_SAMPLE(sm,ids[j])) |
423 |
424 |
rgb[0] += SM_NTH_RGB(sm,ids[j])[0]; |
425 |
rgb[1] += SM_NTH_RGB(sm,ids[j])[1]; |
426 |
rgb[2] += SM_NTH_RGB(sm,ids[j])[2]; |
427 |
cnt++; |
428 |
d += DIST(vp,SM_NTH_WV(sm,ids[j])); |
429 |
430 |
431 |
if(cnt > 1) |
432 |
433 |
rgb[0]/=cnt; rgb[1]/=cnt; rgb[2]/=cnt; |
434 |
d /= (double)cnt; |
435 |
436 |
437 |
438 |
if(SM_BG_SAMPLE(sm,ids[j])) |
439 |
440 |
glColor3ub(rgb[0],rgb[1],rgb[2]); |
441 |
VSUB(p,SM_NTH_WV(sm,ids[j]),SM_VIEW_CENTER(sm)); |
442 |
p[0] *= d; |
443 |
p[1] *= d; |
444 |
p[2] *= d; |
445 |
VADD(p,p,SM_VIEW_CENTER(sm)); |
446 |
447 |
else |
448 |
449 |
glColor3ub(SM_NTH_RGB(sm,ids[j])[0],SM_NTH_RGB(sm,ids[j])[1], |
450 |
SM_NTH_RGB(sm,ids[j])[2]); |
451 |
VCOPY(p,SM_NTH_WV(sm,ids[j])); |
452 |
453 |
glVertex3d(p[0],p[1],p[2]); |
454 |
455 |
456 |
457 |
smRender_bg_tri(sm,i,vp,d,clr) |
458 |
SM *sm; |
459 |
int i; |
460 |
FVECT vp; |
461 |
double d; |
462 |
int clr; |
463 |
464 |
double p[3]; |
465 |
int j,id; |
466 |
TRI *tri; |
467 |
468 |
469 |
470 |
471 |
472 |
473 |
474 |
475 |
476 |
id = T_NTH_V(tri,j); |
477 |
glColor3ub(SM_NTH_RGB(sm,id)[0],SM_NTH_RGB(sm,id)[1], |
478 |
SM_NTH_RGB(sm,id)[2]); |
479 |
VSUB(p,SM_NTH_WV(sm,id),SM_VIEW_CENTER(sm)); |
480 |
if(dev_zmin >= 0.99) |
481 |
482 |
p[0] *= d; |
483 |
p[1] *= d; |
484 |
p[2] *= d; |
485 |
486 |
VADD(p,p,vp); |
487 |
488 |
489 |
490 |
491 |
smRender_mesh(sm,vp,clr) |
492 |
SM *sm; |
493 |
FVECT vp; |
494 |
int clr; |
495 |
496 |
int i; |
497 |
TRI *tri; |
498 |
double ptr[3],d; |
499 |
int j; |
500 |
501 |
d = (dev_zmin+dev_zmax)/2.0; |
502 |
glPushAttrib(GL_DEPTH_BUFFER_BIT); |
503 |
504 |
/* First draw background polygons */ |
505 |
506 |
glDisable(GL_DEPTH_TEST); |
507 |
508 |
SM_FOR_ALL_ACTIVE_BG_TRIS(sm,i) |
509 |
smRender_bg_tri(sm,i,vp,d,clr); |
510 |
glEnd(); |
511 |
512 |
glEnable(GL_DEPTH_TEST); |
513 |
514 |
SM_FOR_ALL_ACTIVE_FG_TRIS(sm,i) |
515 |
516 |
if(!SM_MIXED_TRI(sm,i)) |
517 |
smRender_tri(sm,i,vp,clr); |
518 |
else |
519 |
smRender_mixed_tri(sm,i,vp,clr); |
520 |
521 |
glEnd(); |
522 |
523 |
glPopAttrib(); |
524 |
525 |
526 |
smRender_tri_edges(sm,i) |
527 |
SM *sm; |
528 |
int i; |
529 |
530 |
TRI *tri; |
531 |
int j; |
532 |
double ptr[3]; |
533 |
534 |
535 |
536 |
537 |
/* Triangles are defined clockwise:historical relative to spherical |
538 |
539 |
540 |
for(j=2; j >=0; j--) |
541 |
542 |
VCOPY(ptr,SM_NTH_WV(sm,T_NTH_V(tri,j))); |
543 |
544 |
VCOPY(ptr,SM_NTH_WV(sm,T_NTH_V(tri,(j+1)%3))); |
545 |
546 |
547 |
548 |
549 |
int |
550 |
compare_tri_depths(T_DEPTH *td1,T_DEPTH *td2) |
551 |
552 |
double d; |
553 |
554 |
d = td2->depth-td1->depth; |
555 |
556 |
if(d > 0.0) |
557 |
return(1); |
558 |
if(d < 0.0) |
559 |
return(-1); |
560 |
561 |
return(0); |
562 |
563 |
564 |
LIST |
565 |
*smDepth_sort_tris(sm,vp,td) |
566 |
SM *sm; |
567 |
FVECT vp; |
568 |
T_DEPTH *td; |
569 |
570 |
int i,j,t_id,v; |
571 |
TRI *tri; |
572 |
double d,min_d; |
573 |
LIST *tlist=NULL; |
574 |
575 |
i = 0; |
576 |
SM_FOR_ALL_NEW_TRIS(sm,t_id) |
577 |
578 |
if(SM_BG_TRI(sm,t_id)) |
579 |
580 |
tlist = push_data(tlist,t_id); |
581 |
continue; |
582 |
583 |
tri = SM_NTH_TRI(sm,t_id); |
584 |
td[i].tri = t_id; |
585 |
min_d = -1; |
586 |
587 |
588 |
v = T_NTH_V(tri,j); |
589 |
if(!SM_BG_SAMPLE(sm,v)) |
590 |
591 |
d = DIST(vp,SM_NTH_WV(sm,v)); |
592 |
if(min_d == -1 || d < min_d) |
593 |
min_d = d; |
594 |
595 |
596 |
td[i].depth = min_d; |
597 |
i++; |
598 |
599 |
td[i].tri = -1; |
600 |
if(i) |
601 |
qsort((void *)td,i,sizeof(T_DEPTH),compare_tri_depths); |
602 |
return(tlist); |
603 |
604 |
605 |
606 |
smUpdate_Rendered_mesh(sm,vp,clr) |
607 |
SM *sm; |
608 |
FVECT vp; |
609 |
int clr; |
610 |
611 |
static T_DEPTH *td= NULL; |
612 |
static int tsize = 0; |
613 |
int i; |
614 |
GLint depth_test; |
615 |
double d; |
616 |
LIST *bglist; |
617 |
/* For all of the NEW triangles (since last update): assume |
618 |
ACTIVE. Go through and sort on depth value (from vp). Turn |
619 |
Depth Buffer test off and render back-front |
620 |
621 |
/* NOTE: could malloc each time or hard code */ |
622 |
if(smNew_tri_cnt > tsize) |
623 |
624 |
if(td) |
625 |
free((char *)td); |
626 |
td = (T_DEPTH *)malloc(smNew_tri_cnt*sizeof(T_DEPTH)); |
627 |
tsize = smNew_tri_cnt; |
628 |
629 |
if(!td) |
630 |
631 |
error(SYSTEM,"smUpdate_Rendered_mesh:Cannot allocate memory\n"); |
632 |
633 |
bglist = smDepth_sort_tris(sm,vp,td); |
634 |
635 |
/* Turn Depth Test off -- using Painter's algorithm */ |
636 |
637 |
638 |
639 |
/* Now render back-to front */ |
640 |
/* First render bg triangles */ |
641 |
642 |
while(bglist) |
643 |
smRender_bg_tri(sm,pop_list(&bglist),vp,d,clr); |
644 |
glEnd(); |
645 |
646 |
647 |
648 |
i=0; |
649 |
while(td[i].tri != -1) |
650 |
if(!SM_MIXED_TRI(sm,td[i].tri)) |
651 |
smRender_tri(sm,td[i++].tri,vp,clr); |
652 |
else |
653 |
smRender_mixed_tri(sm,td[i++].tri,vp,clr); |
654 |
glEnd(); |
655 |
656 |
/* Restore Depth Test */ |
657 |
glPopAttrib(); |
658 |
659 |
660 |
661 |
* smUpdate(view, qua) : update OpenGL output geometry for view vp |
662 |
* VIEW *view; : desired view |
663 |
* int qual; : quality level (percentage on linear time scale) |
664 |
665 |
* Draw new geometric representation using OpenGL calls. Assume that the |
666 |
* view has already been set up and the correct frame buffer has been |
667 |
* selected for drawing. The quality level is on a linear scale, where 100% |
668 |
* is full (final) quality. It is not necessary to redraw geometry that has |
669 |
* been output since the last call to smClean(). (The last view drawn will |
670 |
* be view==&odev.v each time.) |
671 |
672 |
smUpdate(view,qual) |
673 |
VIEW *view; |
674 |
int qual; |
675 |
676 |
double d; |
677 |
int last_update; |
678 |
int t; |
679 |
680 |
/* If view has moved beyond epsilon from canonical: must rebuild - |
681 |
epsilon is calculated as running avg of distance of sample points |
682 |
from canonical view: m = 1/(AVG(1/r)): some fraction of this |
683 |
684 |
d = DIST(view->vp,SM_VIEW_CENTER(smMesh)); |
685 |
if(qual >= 100 && d > SM_ALLOWED_VIEW_CHANGE(smMesh)) |
686 |
687 |
/* Re-build the mesh */ |
688 |
689 |
odev.v = *view; |
690 |
#endif |
691 |
smRebuild_mesh(smMesh,view->vp); |
692 |
693 |
/* This is our final update iff qual==100 and view==&odev.v */ |
694 |
last_update = qual>=100 && view==&(odev.v); |
695 |
/* Check if we should draw ALL triangles in current frustum */ |
696 |
if(smClean_notify || smNew_tri_cnt > SM_NUM_TRIS(smMesh)*SM_INC_PERCENT) |
697 |
698 |
699 |
glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT); |
700 |
#else |
701 |
if (SM_TONE_MAP(smMesh) < SM_NUM_SAMP(smMesh)) |
702 |
703 |
tmClearHisto(); |
704 |
tmAddHisto(SM_BRT(smMesh),SM_NUM_SAMP(smMesh),1); |
705 |
if(tmComputeMapping(0.,0.,0.) != TM_E_OK || |
706 |
tmMapPixels(SM_RGB(smMesh),SM_BRT(smMesh),SM_CHR(smMesh), |
707 |
SM_NUM_SAMP(smMesh)) != TM_E_OK) |
708 |
return; |
709 |
710 |
#endif |
711 |
mark_tris_in_frustum(view); |
712 |
if (qual <= 75) |
713 |
smRender_stree(smMesh,qual); |
714 |
else |
715 |
smRender_mesh(smMesh,view->vp,last_update); |
716 |
717 |
glFlush(); |
718 |
glutSwapBuffers(); |
719 |
#endif |
720 |
721 |
/* Do an incremental update instead */ |
722 |
else |
723 |
724 |
if(!smNew_tri_cnt) |
725 |
return; |
726 |
727 |
glDrawBuffer(GL_FRONT); |
728 |
#else |
729 |
t = SM_TONE_MAP(smMesh); |
730 |
if(t == 0) |
731 |
732 |
tmClearHisto(); |
733 |
734 |
if(tmComputeMapping(0.,0.,0.) != TM_E_OK) |
735 |
return; |
736 |
737 |
if(tmMapPixels(SM_NTH_RGB(smMesh,t),&SM_NTH_BRT(smMesh,t), |
738 |
SM_NTH_CHR(smMesh,t), SM_NUM_SAMP(smMesh)-t) != TM_E_OK) |
739 |
return; |
740 |
#endif |
741 |
smUpdate_Rendered_mesh(smMesh,view->vp,last_update); |
742 |
743 |
744 |
glDrawBuffer(GL_BACK); |
745 |
#endif |
746 |
747 |
SM_TONE_MAP(smMesh) = SM_NUM_SAMP(smMesh); |
748 |
if (last_update) |
749 |
750 |
smClean_notify = FALSE; |
751 |
smNew_tri_cnt = 0; |
752 |
qtCache_init(0); |
753 |
754 |
755 |
