1 |
/* Copyright (c) 1998 Silicon Graphics, Inc. */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ SGI"; |
5 |
#endif |
6 |
7 |
8 |
* sm_ogl.c |
9 |
10 |
#include "standard.h" |
11 |
12 |
#include <GL/gl.h> |
13 |
14 |
#ifdef TEST_DRIVER |
15 |
#include <gl/device.h> |
16 |
#include <GL/glu.h> |
17 |
#include <glut.h> |
18 |
#endif |
19 |
#include "sm_flag.h" |
20 |
#include "sm_list.h" |
21 |
#include "sm_geom.h" |
22 |
#include "sm_qtree.h" |
23 |
#include "sm_stree.h" |
24 |
#include "sm.h" |
25 |
26 |
27 |
#include "sm_draw.h" |
28 |
/*static char smClean_notify = TRUE; |
29 |
MAKE STATIC LATER: ui.c using for now; |
30 |
31 |
32 |
#else |
33 |
static int smClean_notify = TRUE; |
34 |
#endif |
35 |
36 |
typedef struct { |
37 |
float dist; /* average distance */ |
38 |
BYTE rgb[3]; /* average color */ |
39 |
} QTRAVG; /* average quadtree value */ |
40 |
41 |
typedef struct { |
42 |
QUADTREE qt; /* quadtree node (key & hash value) */ |
43 |
QTRAVG av; /* node average */ |
44 |
} QT_LUENT; /* lookup table entry */ |
45 |
46 |
static QT_LUENT *qt_htbl = NULL; /* quadtree cache */ |
47 |
static int qt_hsiz = 0; /* quadtree cache size */ |
48 |
49 |
50 |
51 |
* smClean() : display has been wiped clean |
52 |
53 |
* Called after display has been effectively cleared, meaning that all |
54 |
* geometry must be resent down the pipeline in the next call to smUpdate(). |
55 |
56 |
smClean() |
57 |
58 |
59 |
60 |
61 |
int |
62 |
qtCache_init(nel) /* initialize for at least nel elements */ |
63 |
int nel; |
64 |
65 |
static int hsiztab[] = { |
66 |
8191, 16381, 32749, 65521, 131071, 262139, 524287, 1048573, 0 |
67 |
68 |
register int i; |
69 |
70 |
if (nel <= 0) { /* call to free table */ |
71 |
if (qt_hsiz) { |
72 |
free((char *)qt_htbl); |
73 |
qt_htbl = NULL; |
74 |
qt_hsiz = 0; |
75 |
76 |
return(0); |
77 |
78 |
nel += nel>>1; /* 66% occupancy */ |
79 |
for (i = 0; hsiztab[i]; i++) |
80 |
if (hsiztab[i] > nel) |
81 |
break; |
82 |
if (!(qt_hsiz = hsiztab[i])) |
83 |
qt_hsiz = nel*2 + 1; /* not always prime */ |
84 |
qt_htbl = (QT_LUENT *)calloc(qt_hsiz, sizeof(QT_LUENT)); |
85 |
if (qt_htbl == NULL) |
86 |
qt_hsiz = 0; |
87 |
for (i = qt_hsiz; i--; ) |
88 |
qt_htbl[i].qt = EMPTY; |
89 |
return(qt_hsiz); |
90 |
91 |
92 |
QT_LUENT * |
93 |
qtCache_find(qt) /* find a quadtree table entry */ |
94 |
QUADTREE qt; |
95 |
96 |
int i, n; |
97 |
register int ndx; |
98 |
register QT_LUENT *le; |
99 |
100 |
if (qt_hsiz == 0 && !qtCache_init(1)) |
101 |
return(NULL); |
102 |
tryagain: /* hash table lookup */ |
103 |
ndx = (unsigned long)qt % qt_hsiz; |
104 |
for (i = 0, n = 1; i < qt_hsiz; i++, n += 2) { |
105 |
le = &qt_htbl[ndx]; |
106 |
if (QT_IS_EMPTY(le->qt) || le->qt == qt) |
107 |
return(le); |
108 |
if ((ndx += n) >= qt_hsiz) /* this happens rarely */ |
109 |
ndx = ndx % qt_hsiz; |
110 |
111 |
/* table is full, reallocate */ |
112 |
le = qt_htbl; |
113 |
ndx = qt_hsiz; |
114 |
if (!qtCache_init(ndx+1)) { /* no more memory! */ |
115 |
qt_htbl = le; |
116 |
qt_hsiz = ndx; |
117 |
return(NULL); |
118 |
119 |
/* copy old table to new and free */ |
120 |
while (ndx--) |
121 |
if (!QT_IS_EMPTY(le[ndx].qt)) |
122 |
copystruct(qtCache_find(le[ndx].qt), &le[ndx]); |
123 |
free((char *)le); |
124 |
goto tryagain; /* should happen only once! */ |
125 |
126 |
127 |
stCount_level_leaves(lcnt, qt) /* count quadtree leaf nodes at each level */ |
128 |
int lcnt[]; |
129 |
register QUADTREE qt; |
130 |
131 |
if (QT_IS_EMPTY(qt)) |
132 |
return; |
133 |
if (QT_IS_TREE(qt)) { |
134 |
if (!QT_IS_FLAG(qt)) /* not in our frustum */ |
135 |
return; |
136 |
stCount_level_leaves(lcnt+1, QT_NTH_CHILD(qt,0)); |
137 |
stCount_level_leaves(lcnt+1, QT_NTH_CHILD(qt,1)); |
138 |
stCount_level_leaves(lcnt+1, QT_NTH_CHILD(qt,2)); |
139 |
stCount_level_leaves(lcnt+1, QT_NTH_CHILD(qt,3)); |
140 |
141 |
else |
142 |
if(QT_LEAF_IS_FLAG(qt)) |
143 |
lcnt[0]++; |
144 |
145 |
146 |
147 |
QTRAVG * |
148 |
qtRender_level(qt,v0,v1,v2,sm,lvl) |
149 |
QUADTREE qt; |
150 |
FVECT v0,v1,v2; |
151 |
SM *sm; |
152 |
int lvl; |
153 |
154 |
FVECT a,b,c; |
155 |
156 |
QTRAVG *rc[4]; |
157 |
TRI *tri; |
158 |
159 |
if (QT_IS_EMPTY(qt)) /* empty leaf node */ |
160 |
return(NULL); |
161 |
if (QT_IS_TREE(qt) && !QT_IS_FLAG(qt)) /* not in our frustum */ |
162 |
return(NULL); |
163 |
if(QT_IS_LEAF(qt) && !QT_LEAF_IS_FLAG(qt)) /* not in our frustum */ |
164 |
return(NULL); |
165 |
/* else look up node */ |
166 |
if ((le = qtCache_find(qt)) == NULL) |
167 |
error(SYSTEM, "out of memory in qtRender_level"); |
168 |
if (QT_IS_TREE(qt) && (QT_IS_EMPTY(le->qt) || lvl > 0)) |
169 |
{ /* compute children */ |
170 |
qtSubdivide_tri(v0,v1,v2,a,b,c); |
171 |
rc[0] = qtRender_level(QT_NTH_CHILD(qt,0),v0,c,b,sm,lvl-1); |
172 |
rc[1] = qtRender_level(QT_NTH_CHILD(qt,1),c,v1,a,sm,lvl-1); |
173 |
rc[2] = qtRender_level(QT_NTH_CHILD(qt,2),b,a,v2,sm,lvl-1); |
174 |
rc[3] = qtRender_level(QT_NTH_CHILD(qt,3),a,b,c,sm,lvl-1); |
175 |
176 |
if (QT_IS_EMPTY(le->qt)) |
177 |
{ /* let's make some data! */ |
178 |
int rgbs[3]; |
179 |
double distsum; |
180 |
register int i, n; |
181 |
/* average our triangle vertices */ |
182 |
rgbs[0] = rgbs[1] = rgbs[2] = 0; |
183 |
distsum = 0.; n = 0; |
184 |
if(QT_IS_TREE(qt)) |
185 |
{ /* from subtree */ |
186 |
for (i = 4; i--; ) |
187 |
if (rc[i] != NULL) |
188 |
189 |
rgbs[0] += rc[i]->rgb[0]; rgbs[1] += rc[i]->rgb[1]; |
190 |
rgbs[2] += rc[i]->rgb[2]; distsum += rc[i]->dist; n++; |
191 |
192 |
193 |
else |
194 |
{ /* from triangle set */ |
195 |
OBJECT *os; |
196 |
int s0, s1, s2; |
197 |
198 |
os = qtqueryset(qt); |
199 |
for (i = os[0]; i; i--) |
200 |
201 |
if(SM_IS_NTH_T_BASE(sm,os[i])) |
202 |
continue; |
203 |
tri = SM_NTH_TRI(sm,os[i]); |
204 |
if(!T_IS_VALID(tri)) |
205 |
continue; |
206 |
n++; |
207 |
s0 = T_NTH_V(tri,0); |
208 |
s1 = T_NTH_V(tri,1); |
209 |
s2 = T_NTH_V(tri,2); |
210 |
VCOPY(a,SM_NTH_WV(sm,s0)); |
211 |
VCOPY(b,SM_NTH_WV(sm,s1)); |
212 |
VCOPY(c,SM_NTH_WV(sm,s2)); |
213 |
distsum += SM_BG_SAMPLE(sm,s0) ? dev_zmax |
214 |
: sqrt(dist2(a,SM_VIEW_CENTER(sm))); |
215 |
distsum += SM_BG_SAMPLE(sm,s1) ? dev_zmax |
216 |
: sqrt(dist2(b,SM_VIEW_CENTER(sm))); |
217 |
distsum += SM_BG_SAMPLE(sm,s2) ? dev_zmax |
218 |
: sqrt(dist2(c,SM_VIEW_CENTER(sm))); |
219 |
rgbs[0] += SM_NTH_RGB(sm,s0)[0] + SM_NTH_RGB(sm,s1)[0] |
220 |
+ SM_NTH_RGB(sm,s2)[0]; |
221 |
rgbs[1] += SM_NTH_RGB(sm,s0)[1] + SM_NTH_RGB(sm,s1)[1] |
222 |
+ SM_NTH_RGB(sm,s2)[1]; |
223 |
rgbs[2] += SM_NTH_RGB(sm,s0)[2] + SM_NTH_RGB(sm,s1)[2] |
224 |
+ SM_NTH_RGB(sm,s2)[2]; |
225 |
226 |
n *= 3; |
227 |
228 |
if (!n) |
229 |
return(NULL); |
230 |
le->qt = qt; |
231 |
le->av.rgb[0] = rgbs[0]/n; le->av.rgb[1] = rgbs[1]/n; |
232 |
le->av.rgb[2] = rgbs[2]/n; le->av.dist = distsum/(double)n; |
233 |
234 |
if (lvl == 0 || (lvl > 0 && QT_IS_LEAF(qt))) |
235 |
{ /* render this node */ |
236 |
/* compute pseudo vertices */ |
237 |
VCOPY(a,v0); VCOPY(b,v1); VCOPY(c,v2); |
238 |
normalize(a); normalize(b); normalize(c); |
239 |
VSUM(a,SM_VIEW_CENTER(sm),a,le->av.dist); |
240 |
VSUM(b,SM_VIEW_CENTER(sm),b,le->av.dist); |
241 |
VSUM(c,SM_VIEW_CENTER(sm),c,le->av.dist); |
242 |
/* draw triangle */ |
243 |
glColor3ub(le->av.rgb[0],le->av.rgb[1],le->av.rgb[2]); |
244 |
glVertex3d(a[0],a[1],a[2]); |
245 |
glVertex3d(b[0],b[1],b[2]); |
246 |
glVertex3d(c[0],c[1],c[2]); |
247 |
248 |
249 |
return(&le->av); |
250 |
251 |
252 |
253 |
smRender_stree_level(sm,lvl) |
254 |
SM *sm; |
255 |
int lvl; |
256 |
257 |
QUADTREE qt; |
258 |
int i; |
259 |
FVECT t0,t1,t2; |
260 |
STREE *st; |
261 |
262 |
263 |
if (lvl < 0) |
264 |
return; |
265 |
st = SM_LOCATOR(sm); |
266 |
glPushAttrib(GL_LIGHTING_BIT); |
267 |
glShadeModel(GL_FLAT); |
268 |
glBegin(GL_TRIANGLES); |
269 |
for(i=0; i < ST_NUM_ROOT_NODES; i++) |
270 |
271 |
qt = ST_ROOT_QT(st,i); |
272 |
qtRender_level(qt,ST_NTH_V(st,i,0),ST_NTH_V(st,i,1),ST_NTH_V(st,i,2), |
273 |
sm,lvl); |
274 |
275 |
glEnd(); |
276 |
glPopAttrib(); |
277 |
278 |
279 |
280 |
smRender_stree(sm, qual) /* render some quadtree triangles */ |
281 |
SM *sm; |
282 |
int qual; |
283 |
284 |
int i, ntarget; |
285 |
int lvlcnt[QT_MAX_LEVELS]; |
286 |
STREE *st; |
287 |
288 |
if (qual <= 0) |
289 |
return; |
290 |
/* compute rendering target */ |
291 |
ntarget = 0; |
292 |
SM_FOR_ALL_ACTIVE_TRIS(sm,i) |
293 |
ntarget++; |
294 |
ntarget = ntarget*qual/100; |
295 |
if (!ntarget) |
296 |
return; |
297 |
for (i = QT_MAX_LEVELS; i--; ) |
298 |
lvlcnt[i] = 0; |
299 |
300 |
301 |
for(i=0; i < ST_NUM_ROOT_NODES;i++) |
302 |
stCount_level_leaves(lvlcnt, ST_ROOT_QT(st,i)); |
303 |
304 |
for (ntarget -= lvlcnt[i=0]; i < QT_MAX_LEVELS-1; ntarget -= lvlcnt[++i]) |
305 |
if (ntarget < lvlcnt[i+1]) |
306 |
break; |
307 |
/* compute and render target level */ |
308 |
smRender_stree_level(sm,i); |
309 |
310 |
311 |
312 |
313 |
#define render_tri(v0,v1,v2,rgb0,rgb1,rgb2) \ |
314 |
{glColor3ub(rgb0[0],rgb0[1],rgb0[2]); glVertex3fv(v0); \ |
315 |
glColor3ub(rgb1[0],rgb1[1],rgb1[2]); glVertex3fv(v1); \ |
316 |
glColor3ub(rgb2[0],rgb2[1],rgb2[2]); glVertex3fv(v2);} \ |
317 |
318 |
render_mixed_tri(v0,v1,v2,rgb0,rgb1,rgb2,bg0,bg1,bg2,vp,vc) |
319 |
float v0[3],v1[3],v2[3]; |
320 |
BYTE rgb0[3],rgb1[3],rgb2[3]; |
321 |
int bg0,bg1,bg2; |
322 |
FVECT vp,vc; |
323 |
324 |
double p[3],d; |
325 |
int j,ids[3],cnt; |
326 |
int rgb[3]; |
327 |
328 |
/* NOTE:Triangles are defined clockwise:historical relative to spherical |
329 |
tris: could change |
330 |
331 |
cnt = 0; |
332 |
d = 0.0; |
333 |
rgb[0] = rgb[1] = rgb[2] = 0; |
334 |
335 |
if(bg0 && bg1 && bg2) |
336 |
return; |
337 |
338 |
if(!bg0) |
339 |
340 |
rgb[0] += rgb0[0]; |
341 |
rgb[1] += rgb0[1]; |
342 |
rgb[2] += rgb0[2]; |
343 |
cnt++; |
344 |
d += DIST(vp,v0); |
345 |
346 |
if(!bg1) |
347 |
348 |
rgb[0] += rgb1[0]; |
349 |
rgb[1] += rgb1[1]; |
350 |
rgb[2] += rgb1[2]; |
351 |
cnt++; |
352 |
d += DIST(vp,v1); |
353 |
354 |
if(!bg2) |
355 |
356 |
rgb[0] += rgb2[0]; |
357 |
rgb[1] += rgb2[1]; |
358 |
rgb[2] += rgb2[2]; |
359 |
cnt++; |
360 |
d += DIST(vp,v2); |
361 |
362 |
if(cnt > 1) |
363 |
364 |
rgb[0]/=cnt; rgb[1]/=cnt; rgb[2]/=cnt; |
365 |
d /= (double)cnt; |
366 |
367 |
if(bg0) |
368 |
369 |
glColor3ub(rgb[0],rgb[1],rgb[2]); |
370 |
VSUB(p,v0,vc); |
371 |
p[0] *= d; |
372 |
p[1] *= d; |
373 |
p[2] *= d; |
374 |
VADD(p,p,vc); |
375 |
glVertex3dv(p); |
376 |
377 |
else |
378 |
379 |
glColor3ub(rgb0[0],rgb0[1],rgb0[2]); |
380 |
glVertex3fv(v0); |
381 |
382 |
if(bg1) |
383 |
384 |
385 |
VSUB(p,v1,vc); |
386 |
p[0] *= d; |
387 |
p[1] *= d; |
388 |
p[2] *= d; |
389 |
VADD(p,p,vc); |
390 |
glVertex3dv(p); |
391 |
392 |
else |
393 |
394 |
glColor3ub(rgb1[0],rgb1[1],rgb1[2]); |
395 |
glVertex3fv(v1); |
396 |
397 |
if(bg2) |
398 |
399 |
400 |
VSUB(p,v2,vc); |
401 |
p[0] *= d; |
402 |
p[1] *= d; |
403 |
p[2] *= d; |
404 |
VADD(p,p,vc); |
405 |
glVertex3dv(p); |
406 |
407 |
else |
408 |
409 |
glColor3ub(rgb2[0],rgb2[1],rgb2[2]); |
410 |
glVertex3fv(v2); |
411 |
412 |
413 |
414 |
415 |
render_bg_tri(v0,v1,v2,rgb0,rgb1,rgb2,vp,vc,d) |
416 |
417 |
418 |
FVECT vp,vc; |
419 |
double d; |
420 |
421 |
double p[3]; |
422 |
423 |
424 |
VSUB(p,v0,vc); |
425 |
if(dev_zmin >= 0.99) |
426 |
427 |
p[0] *= d; |
428 |
p[1] *= d; |
429 |
p[2] *= d; |
430 |
431 |
VADD(p,p,vp); |
432 |
glVertex3dv(p); |
433 |
434 |
435 |
VSUB(p,v1,vc); |
436 |
437 |
438 |
p[0] *= d; |
439 |
p[1] *= d; |
440 |
p[2] *= d; |
441 |
442 |
VADD(p,p,vp); |
443 |
glVertex3dv(p); |
444 |
445 |
446 |
447 |
VSUB(p,v2,vc); |
448 |
449 |
450 |
p[0] *= d; |
451 |
p[1] *= d; |
452 |
p[2] *= d; |
453 |
454 |
VADD(p,p,vp); |
455 |
glVertex3dv(p); |
456 |
457 |
458 |
459 |
smRender_mesh(sm,vp,clr) |
460 |
SM *sm; |
461 |
FVECT vp; |
462 |
int clr; |
463 |
464 |
int i,bg0,bg1,bg2; |
465 |
double d; |
466 |
int v0_id,v1_id,v2_id; |
467 |
TRI *tri; |
468 |
float (*wp)[3]; |
469 |
BYTE (*rgb)[3]; |
470 |
471 |
wp = SM_WP(sm); |
472 |
rgb =SM_RGB(sm); |
473 |
d = (dev_zmin+dev_zmax)/2.0; |
474 |
glPushAttrib(GL_DEPTH_BUFFER_BIT); |
475 |
476 |
/* First draw background polygons */ |
477 |
glDisable(GL_DEPTH_TEST); |
478 |
479 |
/* Maintain a list? */ |
480 |
SM_FOR_ALL_ACTIVE_BG_TRIS(sm,i) |
481 |
482 |
if (clr) |
483 |
SM_CLR_NTH_T_NEW(sm,i); |
484 |
tri = SM_NTH_TRI(sm,i); |
485 |
v0_id = T_NTH_V(tri,0); |
486 |
v1_id = T_NTH_V(tri,1); |
487 |
v2_id = T_NTH_V(tri,2); |
488 |
render_bg_tri(wp[v0_id],wp[v1_id],wp[v2_id],rgb[v0_id],rgb[v1_id], |
489 |
rgb[v2_id],vp,SM_VIEW_CENTER(sm),d); |
490 |
491 |
glEnd(); |
492 |
glEnable(GL_DEPTH_TEST); |
493 |
494 |
SM_FOR_ALL_ACTIVE_FG_TRIS(sm,i) |
495 |
496 |
if (clr) |
497 |
498 |
499 |
500 |
501 |
502 |
bg0 = SM_DIR_ID(sm,v0_id) || SM_BASE_ID(sm,v0_id); |
503 |
bg1 = SM_DIR_ID(sm,v1_id) || SM_BASE_ID(sm,v1_id); |
504 |
bg2 = SM_DIR_ID(sm,v2_id) || SM_BASE_ID(sm,v2_id); |
505 |
if(!(bg0 || bg1 || bg2)) |
506 |
render_tri(wp[v0_id],wp[v1_id],wp[v2_id],rgb[v0_id],rgb[v1_id], |
507 |
rgb[v2_id]) |
508 |
else |
509 |
render_mixed_tri(wp[v0_id],wp[v1_id],wp[v2_id],rgb[v0_id],rgb[v1_id], |
510 |
rgb[v2_id],bg0,bg1,bg2,vp,SM_VIEW_CENTER(sm)); |
511 |
512 |
glEnd(); |
513 |
514 |
glPopAttrib(); |
515 |
516 |
517 |
int |
518 |
compare_tri_depths(T_DEPTH *td1,T_DEPTH *td2) |
519 |
520 |
double d; |
521 |
522 |
if(td1->tri==-1) |
523 |
524 |
if(td2->tri==-1) |
525 |
return(0); |
526 |
else |
527 |
return(-1); |
528 |
529 |
if(td2->tri==-1) |
530 |
return(1); |
531 |
532 |
d = td2->depth-td1->depth; |
533 |
534 |
if(d > 0.0) |
535 |
return(1); |
536 |
if(d < 0.0) |
537 |
return(-1); |
538 |
539 |
return(0); |
540 |
541 |
542 |
int |
543 |
compare_tri_depths_old(T_DEPTH *td1,T_DEPTH *td2) |
544 |
545 |
double d; |
546 |
547 |
548 |
549 |
if(d > 0.0) |
550 |
return(1); |
551 |
if(d < 0.0) |
552 |
return(-1); |
553 |
554 |
return(0); |
555 |
556 |
557 |
LIST |
558 |
*smDepth_sort_tris(sm,vp,td) |
559 |
SM *sm; |
560 |
FVECT vp; |
561 |
T_DEPTH *td; |
562 |
563 |
int i,j,t_id,v; |
564 |
TRI *tri; |
565 |
double d,min_d; |
566 |
LIST *tlist=NULL; |
567 |
FVECT diff; |
568 |
569 |
i = 0; |
570 |
SM_FOR_ALL_NEW_TRIS(sm,t_id) |
571 |
572 |
if(SM_BG_TRI(sm,t_id)) |
573 |
574 |
tlist = push_data(tlist,t_id); |
575 |
continue; |
576 |
577 |
tri = SM_NTH_TRI(sm,t_id); |
578 |
td[i].tri = t_id; |
579 |
min_d = -1; |
580 |
for(j=0;j < 3;j++) |
581 |
582 |
v = T_NTH_V(tri,j); |
583 |
if(!SM_BG_SAMPLE(sm,v)) |
584 |
585 |
VSUB(diff,SM_NTH_WV(sm,v),vp); |
586 |
d = DOT(diff,diff); |
587 |
if(min_d == -1 || d < min_d) |
588 |
min_d = d; |
589 |
590 |
591 |
td[i].depth = min_d; |
592 |
i++; |
593 |
594 |
td[i].tri = -1; |
595 |
if(i) |
596 |
qsort((void *)td,i,sizeof(T_DEPTH),compare_tri_depths); |
597 |
return(tlist); |
598 |
599 |
600 |
601 |
602 |
LIST |
603 |
*smOrder_new_tris(sm,vp,td,sort) |
604 |
SM *sm; |
605 |
FVECT vp; |
606 |
T_DEPTH *td; |
607 |
int sort; |
608 |
609 |
int i,j,t_id,v; |
610 |
TRI *tri; |
611 |
double d,min_d; |
612 |
LIST *tlist=NULL; |
613 |
FVECT diff; |
614 |
615 |
i = 0; |
616 |
for(i=0; i < smNew_tri_cnt;i++) |
617 |
618 |
t_id = smNew_tris[i].tri; |
619 |
620 |
621 |
622 |
623 |
smNew_tris[i].tri = -1; |
624 |
continue; |
625 |
626 |
627 |
628 |
629 |
630 |
continue; |
631 |
632 |
if(!sort) |
633 |
continue; |
634 |
min_d = -1; |
635 |
636 |
637 |
638 |
639 |
640 |
641 |
642 |
643 |
min_d = d; |
644 |
645 |
646 |
647 |
648 |
if(!sort) |
649 |
return(tlist); |
650 |
qsort((void *)td,smNew_tri_cnt,sizeof(T_DEPTH),compare_tri_depths); |
651 |
return(tlist); |
652 |
653 |
654 |
655 |
smUpdate_Rendered_mesh(sm,vp,clr) |
656 |
SM *sm; |
657 |
FVECT vp; |
658 |
int clr; |
659 |
660 |
static T_DEPTH *td= NULL; |
661 |
static int tsize = 0; |
662 |
int i,v0_id,v1_id,v2_id,bg0,bg1,bg2; |
663 |
GLint depth_test; |
664 |
double d; |
665 |
LIST *bglist; |
666 |
TRI *tri; |
667 |
float (*wp)[3]; |
668 |
BYTE (*rgb)[3]; |
669 |
670 |
/* For all of the NEW triangles (since last update): assume |
671 |
ACTIVE. Go through and sort on depth value (from vp). Turn |
672 |
Depth Buffer test off and render back-front |
673 |
674 |
/* NOTE: could malloc each time or hard code */ |
675 |
#if 0 |
676 |
if(smNew_tri_cnt > tsize) |
677 |
678 |
if(td) |
679 |
free((char *)td); |
680 |
td = (T_DEPTH *)malloc(smNew_tri_cnt*sizeof(T_DEPTH)); |
681 |
tsize = smNew_tri_cnt; |
682 |
683 |
if(!td) |
684 |
685 |
error(SYSTEM,"smUpdate_Rendered_mesh:Cannot allocate memory\n"); |
686 |
687 |
bglist = smDepth_sort_tris(sm,vp,td); |
688 |
#else |
689 |
td = smNew_tris; |
690 |
if(!EQUAL_VEC3(SM_VIEW_CENTER(sm),vp)) |
691 |
bglist = smOrder_new_tris(sm,vp,td,1); |
692 |
else |
693 |
bglist = smOrder_new_tris(sm,vp,td,0); |
694 |
#endif |
695 |
wp = SM_WP(sm); |
696 |
rgb =SM_RGB(sm); |
697 |
/* Turn Depth Test off -- using Painter's algorithm */ |
698 |
699 |
glDepthFunc(GL_ALWAYS); |
700 |
701 |
/* Now render back-to front */ |
702 |
/* First render bg triangles */ |
703 |
704 |
while(bglist) |
705 |
706 |
i = pop_list(&bglist); |
707 |
if (clr) |
708 |
709 |
710 |
711 |
712 |
713 |
714 |
715 |
716 |
glEnd(); |
717 |
718 |
719 |
720 |
i=0; |
721 |
while(i != smNew_tri_cnt) |
722 |
723 |
if(td[i].tri == -1) |
724 |
725 |
i++; |
726 |
continue; |
727 |
728 |
if (clr) |
729 |
SM_CLR_NTH_T_NEW(sm,td[i].tri); |
730 |
tri = SM_NTH_TRI(sm,td[i].tri); |
731 |
732 |
733 |
734 |
735 |
736 |
737 |
738 |
739 |
rgb[v2_id]) |
740 |
else |
741 |
742 |
743 |
i++; |
744 |
745 |
glEnd(); |
746 |
747 |
/* Restore Depth Test */ |
748 |
glPopAttrib(); |
749 |
750 |
751 |
752 |
* smUpdate(view, qua) : update OpenGL output geometry for view vp |
753 |
* VIEW *view; : desired view |
754 |
* int qual; : quality level (percentage on linear time scale) |
755 |
756 |
* Draw new geometric representation using OpenGL calls. Assume that the |
757 |
* view has already been set up and the correct frame buffer has been |
758 |
* selected for drawing. The quality level is on a linear scale, where 100% |
759 |
* is full (final) quality. It is not necessary to redraw geometry that has |
760 |
* been output since the last call to smClean(). (The last view drawn will |
761 |
* be view==&odev.v each time.) |
762 |
763 |
smUpdate(view,qual) |
764 |
VIEW *view; |
765 |
int qual; |
766 |
767 |
double d; |
768 |
int last_update; |
769 |
int t; |
770 |
771 |
/* If view has moved beyond epsilon from canonical: must rebuild - |
772 |
epsilon is calculated as running avg of distance of sample points |
773 |
from canonical view: m = 1/(AVG(1/r)): some fraction of this |
774 |
775 |
776 |
if(!smMesh) |
777 |
return; |
778 |
779 |
d = DIST(view->vp,SM_VIEW_CENTER(smMesh)); |
780 |
if(qual >= 100 && d > SM_ALLOWED_VIEW_CHANGE(smMesh)) |
781 |
782 |
/* Re-build the mesh */ |
783 |
784 |
odev.v = *view; |
785 |
#endif |
786 |
mark_tris_in_frustum(view); |
787 |
smRebuild_mesh(smMesh,view); |
788 |
789 |
790 |
/* This is our final update iff qual==100 and view==&odev.v */ |
791 |
last_update = qual>=100 && view==&(odev.v); |
792 |
/* Check if we should draw ALL triangles in current frustum */ |
793 |
if(smClean_notify || smNew_tri_cnt > SM_SAMPLE_TRIS(smMesh)*SM_INC_PERCENT) |
794 |
795 |
796 |
glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT); |
797 |
#else |
798 |
if ( SM_TONE_MAP(smMesh) < SM_NUM_SAMP(smMesh)) |
799 |
800 |
tmClearHisto(); |
801 |
tmAddHisto(SM_BRT(smMesh),SM_NUM_SAMP(smMesh),1); |
802 |
tmComputeMapping(0.,0.,0.); |
803 |
tmMapPixels(SM_RGB(smMesh),SM_BRT(smMesh),SM_CHR(smMesh), |
804 |
SM_NUM_SAMP(smMesh)); |
805 |
806 |
#endif |
807 |
808 |
if (qual <= 75) |
809 |
smRender_stree(smMesh,qual); |
810 |
else |
811 |
smRender_mesh(smMesh,view->vp,last_update); |
812 |
813 |
glFlush(); |
814 |
glutSwapBuffers(); |
815 |
#endif |
816 |
817 |
/* Do an incremental update instead */ |
818 |
else |
819 |
820 |
if(!smNew_tri_cnt) |
821 |
return; |
822 |
823 |
glDrawBuffer(GL_FRONT); |
824 |
#else |
825 |
t = SM_TONE_MAP(smMesh); |
826 |
if(t == 0) |
827 |
828 |
tmClearHisto(); |
829 |
830 |
if(tmComputeMapping(0.,0.,0.) != TM_E_OK) |
831 |
return; |
832 |
833 |
tmMapPixels(SM_NTH_RGB(smMesh,t),&SM_NTH_BRT(smMesh,t), |
834 |
SM_NTH_CHR(smMesh,t), SM_NUM_SAMP(smMesh)-t); |
835 |
836 |
#endif |
837 |
smUpdate_Rendered_mesh(smMesh,view->vp,last_update); |
838 |
839 |
840 |
glDrawBuffer(GL_BACK); |
841 |
#endif |
842 |
843 |
844 |
SM_TONE_MAP(smMesh) = SM_NUM_SAMP(smMesh); |
845 |
846 |
if (last_update) |
847 |
848 |
smClean_notify = FALSE; |
849 |
smNew_tri_cnt = 0; |
850 |
#if 0 |
851 |
smClear_flags(smMesh,T_NEW_FLAG); |
852 |
#endif |
853 |
qtCache_init(0); |
854 |
855 |
856 |
